587,478 active members*
3,082 visitors online*
    Dec 2005
    7
    EMC Light addition
    I have a EMC without a light, there is a light switch on the controller, i would like to add a light myself, is there a wiring diagram anywhere that could guide me to wiring this thing up?
    Aug 2003
    812
    I'd just get one from enco, waterproof machine strp light and run the on / off cable and switch into the control pendent. You should find a 110V transformer in the control cab you can tap. If you don't feel comfortable doing this I'd get a pro to do it for you.
    Jul 2004
    374
    The machine is already wired for a light. There is a lead [that will be connected to nothing] in the overhead cable trough that is wired to the switch on the control panel. Just use a multimeter to verify that you have the proper lead.
    I was lucky and was able to use one of the existing [plugged] holes in the trough for my light, so I didn't have to do any drilling or cutting to install a light.
