603,940 active members*
2,166 visitors online*
Results 1 to 5 of 5
    Feb 2008
    52
    EMC2 arc settings, such a thing?
    Hi and thanks for looking.
    I'm running a Sherline lathe and mill through EMC2 on Ubuntu and everything has been going well for the three weeks that I have ventured into this.
    I'm having trouble with a profile exported from DolphinCam. I'm trying simply put a diameter on the end of 12mm acrylic stock. The animation in DC appears to be correct for the tool path but once opened in EMC2 Turn, a line in the code cuts my radius into a cone.
    The job is done in two parts within the same .nc file. The rough pass completes correctly (nice radius). The finish pass moves the tool to Z0 and moves it to an end X,Y with Radius = 4.
    My lathe doesn't process the radius and moves the tool in a straight line cutting the stock to a cone.
    The line in the g-code is:
    N1135G01Z0.0
    N1145G02X3.8Z-4.0R4.0 <-- This one
    N1155G01Z-19.2
    Q: Is there a setting in EMC2 that defines arcs?
    If not, do you have any ideas as to why this is happening.
    Thanks a lot!
    Goose
    Jul 2003
    1766
    we might need to see more - are you setting the plane to (g18)
    sam
    Feb 2008
    52
    Hi Samco...
    Thanks for the reply.
    Interestingly the plane setting was G17 not G18. I changed it and it produced an arc but the wrong way around.
    Pic 1: G17 or G19
    Pic 2: G18
    At least with G18 it's an arc, now all I need is it to be the right way around and I'll be happy.
    Thanks!
    Attached Thumbnails Attached Thumbnails Russell-20130222-00027.jpg   Russell-20130222-00028.jpg
    Feb 2007
    711
    Sorry if I am way off here, but change the G2 for a G3? (counterclockwise)
    Feb 2008
    52
    Hi Alan...
    In fact you are spot-on, however the frustration of it all is that every other arc in the .nc file is G2 and is processed properly except the finishing pass which I need to change to G3 for it to work
    Also no matter what I do, I cannot get that radius on the end of my stock. Both the rough and finish passes miss the end of the stock by around .9mm so I'm left with a flat end. That's a problem with me and the software and not for this thread but I thank you for your input.
    I give up on cnc lathe software!
    Goose
  1. Help identify stepper board and get proper EMC2 settings
    By m_elias in forum CNC Machine Related Electronics
    Last Post: 03-30-2012, 04:08 PM
  2. Mechatronics 4 axis settings for emc2
    By kweierbach in forum LinuxCNC (formerly EMC2)
    Last Post: 06-24-2009, 06:43 PM
  3. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  4. HOME LIMIT SETTINGS IN EMC2
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 02-14-2008, 12:50 AM
  5. Bit odd thing to look for... :)
    By jinu117 in forum Phase Converters
    Last Post: 12-13-2007, 10:48 PM
