I installed EMC2 (2.2.2.1) then updated via the update manager. When I run a latency-test with the network card disabled it is under 15,000 BUT if I enable the nic it jumps to 30K-51K and jumps around in the mid 20k, if I disable the nic and restart the test it is less than 15k.
I have moved the nic to a different slot, I have not tried a new nic, curently the only 1 I have (an IBM10/100 card using an AMD chipset edvice manager lists as a PCnet32 LANCE.
I know I can disable the nic when using emc so that isn't a problem. Has anyone seen this before?
IF I could get my Netgear wg311v2 working under Ubuntu it might not be an issue... well it won't be an issue since I don't have a hard wired network connection at my router right now.....
