Originally Posted by
machinehop5
...600 baud is to high try 300 after looking around the net I found this thread below:
The cable should be a regular serial cable.
Settings in the controller: For transfer both ways 300 baud, for transfer out of the controller higher rates can be used. DO NOT use higher rates than 300 baud for transfer to the controller, for me everything looked OK but blocks were lost and no warning given.
Settings on the computer, BOTH in the device manager and terminal program. 300baud, 7 data bits, even parity, 1 stop bit, RTS/CTS flow control. Turn off FIFO buffers or set to a small size.
Transfer from the controller should now work with no problems. To transfer a file to the controller you might first need to transfer a file out of the controller, this is to set the flow control lines in the correct state. When using PComm the small CTS indicator should be red, otherwise transfer to the controller does not work.
The exact format of the file is also important for the transfer to work, first line should be of the format "%0001 CRLF". This means % program number space carriage return linefeed, the space is important!
The other lines have the format "N0005 G01 X10.000CRLF", i.e block number space space instruction carriage return linefeed. Two spaces after block number and no space after the instruction(s), do not forget the decimal point. Last in the file it must be "M30CRLF"
With a file in the right format and the CTS indicator lit (if using PComm) press "INT 1 ENTER O 1 ENTER INP" on the controller (1 means any free program number here). The screen should display the amount of free memmory and the display should say somethingIforgot but lo at the end anyway.
Now send the file from the computer.
/Staffan
