Anyone out there able to help out with a problem on a Emco 5 Cnc Lathe.
I picked up this machine in a neglected state and after cleaning it up, it was found to have 2 x 3.15 Amp surge fuses blown.
I replaced these, and powered it up, everything was good, until i threw the white motor switch, " yes, you guessed it, they blew again " , it appears that the board supplying the feed power to all the motors has got 3 red LED's that i believe should illuminate. These are showing no activity.
Any suggestions, guys.......
