I am having problems with a home built machine that has been working great for about a year. I use Mach3 and a Gecko 540 board with a Smoothstepper. When I tried to zero the y axis, the emergency stop button on Mach3 was tripped. However, the motors are still on. To get Mach3 to turn the emergency button to green, I have to reload Mach3. When I touch any key on the keyboard, the same problem occurs.
If you have any suggestions on what could be causing this problem, I would greatly appreciate it.
Thanks for your help!
