588,205 active members*
3,926 visitors online*
    Mar 2008
    5
    emt super 80 barfeeder problem
    Hi!
    I have a problem with my bar feeder (emt super 80). We haven't used it since I came to this company, and I only have an instruction manual translated in very poor English. The bar feeders menu is in Dutch (!?) I know some German and I could understand the setting of parameters but l don't have any data for starting it in auto mode. And also have no clue of what l should write in the cnc program to make it work. The late has a Fanuc 20i system. Simply opening the chucks with M11 inside program wouldn't start the bar feeder. Pushing start cycle on the bar feeder while in auto mode is only possible when chucks are closed, and that has no logic, because when the bar hits the rear of the chucks the bar feeder gives me an error, and I don't think it should work in this way. So if anyone had similar problems or worked with such a bar feeder(emt super 80) and knows the way l should proceed with programing ant the bar feeder itself l would be very thankful.
    Matyi
    Mar 2011
    after you prepare the bar feeder put it in auto mode.
    the program looks like this
    T1212
    (TAMPON)
    S10M3
    M1100
    M10
    G4X0.5
    G4X0.5
    /2M98P900
    G0X5.Z5.
    Z0.3
    M46
    M47
    M11
    G4X2.
    G0X200.Z200.M05
    M01
    G0G40X200.Z200.
    Re: emt super 80 barfeeder problem
    i have a bar super 80 feeder with a Mitsubishi fx2n 48mr plc, and the plc battery has fail and lost the program, could you provide me the download to get the machince up and running, we are happy to pay for the code if it works
    Jun 2023
    Did you find the program, I faced the same problem
  1. Desperately need help with Super PID problem
    By TurnTex in forum Spindles / VFD
    Last Post: 12-30-2017, 11:01 PM
  2. Mazak barfeeder problem
    By kennyp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-12-2010, 04:43 PM
  3. Super X3 Problem
    By bullseye in forum Syil Products
    Last Post: 11-14-2007, 03:57 AM
  4. 300 barfeeder problem
    By metaltec in forum Haas Lathes
    Last Post: 11-06-2007, 10:27 PM
  5. Problem with BNC Miyano Barfeeder lathe.
    By Tonenc in forum DNC Problems and Solutions
    Last Post: 11-09-2005, 02:46 AM
