588,075 active members*
5,074 visitors online*
Thread: Enclosure
Page 1 of 2 12
Results 1 to 20 of 21
    Mar 2012
    133
    Enclosure
ID:	237092onAttachment 237090 February 27th I got my second 1100, this is the finished enclosure, with chip conveyor
    and lots of extra goodies. Integrated swing hoist and behind spindle port block for coolant,
    mister, air blast and vacuum. Manual/Automatic door closer.
    Mar 2012
    102
    Re: Enclosure
    Wow! Nice work!
    Nov 2007
    2151
    Re: Enclosure
    Now I see the hoist! Very nice setup!
    That picture didn't come up when I first looked.
    I would like to see picture of chip conveyor. sounds like a cool mod.
    md
    Mar 2012
    133
    Re: Enclosure
    Mar 2012
    133
    Re: Enclosure
    Quote Originally Posted by mountaindew View Post
    md
    Will have more pictures later, need a guard on the drive and a cover on the coolant recovery system.
    Soon will have a youtube video of the system working.
    Nov 2013
    402
    Re: Enclosure
    CHIP CONVEYOR !!????
    How on Earth did you rig-up a chip conveyor?
    Please post lots of pictures.
    Mar 2012
    133
    Re: Enclosure
    Quote Originally Posted by RussMachine View Post
    Soon will have more pictures. I built my own heavy base that is wider than the mill and built a 28" wide 34" long conveyor between the legs of the base.
    The conveyor dumps the chips into a bin with wheels on it. There is a pan that encloses the chip conveyor to catch all the coolant and drains into
    the coolant tank, after it goes through screens and the oil pillow. Took a little figuring, but after the second try got it to be leak prof.
    I let it drain over night and run the chip conveyor the next time I fire up the mill. That keeps the coolant out of the chip bin.
    The coolant pump has a tee to a coiled garden hose and nozzle, so just hit the panel switch and wash the mill down.
    It takes about a minute to clean the mill.
    Apr 2013
    1788
    Re: Enclosure
    That looks great! I'm eagerly awaiting more photos to drool over.
    Your hoist looks suspiciously like a Horrible Fright 60346. If it is, have you figured out a way to lift slower than ~15 feet/minute? I have one and find that it is far too fast to position things precisely.
    Mar 2012
    133
    Re: Enclosure
    Quote Originally Posted by kstrauss View Post
    I doubled the cable that slows it in half. Later I am going to build a new gear reduction box to slow it even more.
    Apr 2013
    1788
    Re: Enclosure
    At least on my similar hoist the doubled cable gives ~15 fpm and a single cable gives ~30 fpm. If you modify the gearbox I'd love to see the details so that I can do the same.
    Mar 2012
    133
    Re: Enclosure
    More pulleys like a block and tackle will work too.
    Nov 2010
    291
    Re: Enclosure
    That enclosure looks very useful. I like the shelves on the sides instead of wasted space like the stock overhangs. I have a sandblaster that fits right in there so I filled it up that way. I think I will build some shelves there to store some of the smaller accessories.
    Mar 2012
    133
    Re: Enclosure
    Here is a picture of the conveyor, the coolant tank here and pump was just temporary till I got the new system and pump.
    [ATTACH=CONFIG]237270[/ATTACH Here is a picture of the side window.Click image for larger version.
Name:	side window 008.jpg
    Mar 2012
    133
    Re: Enclosure
    This picture shows the clearance for the vise handle and the slots for the chips to
    fall on the chip conveyer. TAttachment 237522he 6" vise handle can stay on as it will never hit the enclosure.
    The the coolant tank has the screens and oil soak pillow to take care of any small
    chips and oil.
    Jan 2012
    789
    Re: Enclosure
    Awesome work.
    Mar 2012
    133
    Re: Enclosure
    Quote Originally Posted by tbaker2500 View Post
    Awesome work.
    Thank you, So far this enclosure has worked out so well, I am going to scrap the enclosure I built for the first
    1100. That enclosure will be the same but geared for folks with less room. Swinging front shelves to get to the
    chip bin and coolant system. Oiler,coolant, mister, ect will all be accessed from the front. Double sliding doors.
    Also pallet jack/forklift points to just pick it up and move if needed, built in.
  17. #17
    Feb 2007
    1041
    Re: Enclosure
    Looks great !
  18. #18
    Mar 2012
    133
    Re: Enclosure
    Will have more picks soon, here is a picture of the Hoist stored. The arm that holds the hoist
    Has been load tested 500lbs. The Attachment 238418
  19. #19
    Jul 2004
    1424
    Re: Enclosure
    Awesome job. Did you draft up any plans or build it on the fly?
    Where did you source the chip conveyor belt from?
    Quote Originally Posted by Sp-4renegade View Post
    the coolant tan...I let it drain over night and run the chip conveyor the next time I fire up the mill. That keeps the coolant out of the chip bin.
    I am guessing it would make a mess if you ran the conveyor belt while flood coolant was in operation? What about if you angled the conveyor belt up instead of made it flat? All of the chip conveyors I have seen seem to be angled up at 30-45 degree angles, which allows time for the coolant to drain off before dumping.
  20. #20
    Jul 2004
    1424
    Re: Enclosure
    duplicate
Page 1 of 2 12
  1. The Enclosure
    By zerodegreec in forum Benchtop Machines
    Last Post: 04-17-2013, 01:33 AM
  2. VFD Enclosure help please
    By fireguy976 in forum MetalWork Discussion
    Last Post: 05-02-2009, 06:13 PM
  3. What to use for an enclosure?
    By Tim Wiltse in forum Xylotex
    Last Post: 10-03-2008, 08:36 AM
  4. My new enclosure
    By David Da Costa in forum Commercial CNC Wood Routers
    Last Post: 10-28-2006, 06:03 PM
  5. New All In One Enclosure
    By mlaws1172 in forum CNC Machine Related Electronics
    Last Post: 10-21-2006, 01:26 AM
