603,929 active members*
3,097 visitors online*
Thread: Enclosures
Results 1 to 6 of 6
    Oct 2009
    87
    Enclosures
    Building an enclosure right this moment , started on it at 2:00 Sat. Afternoon.
    Should finish it by noon Sunday. All from home depot and ace hardware. 32 wide 30 deep 30 tall
    Total build around $130.00
    I'll post pics. Later Peace
    Mar 2005
    335
    good luck, I work on the 10 times rule with electronics and enclosures. it will take you ten times longer than you expect it to.
    Oct 2009
    87
    Almost finished it today, drank some beer and lost some motivation.
    Then the Pro Bowl came on. I could have finished it then I got stuck on how to do the front doors. Can't slide up cause the pitch of my roof , A-frame cabin.
    I will get some hinges tomorrow an make split doors opening to each side.
    Oct 2009
    87
    Enclosure would not fit the door of my hobby room , .53 too wide.
    Remove room door and went in. That was a close shave
    Remember the 6 P's
    Proper - Planning - Prevents - Piss - Poor - Performance
    Oct 2009
    87
    Built ventilation system for enclosure today. 6" flex pipe and 4"dry vent tubing with a 5" component fan 85 cfm seems to plenty of ventilation. Both pipe outside of the house , taking a cut and running wide open the enclosure only emits 18 decibels and a inside temp. Of 64 degrees . In the summer I'll hook the intake to the air conditioning vent.
    Apr 2007
    2580
    Well Uuh.....
    THIS THREAD IS WORTHLESS WITHOUT PICS!!!!!!!!!!:rainfro:
    Peace
    Pete
  1. RE: Enclosures for Gecko 540
    By fucema in forum Gecko Drives
    Last Post: 07-15-2010, 12:37 AM
  2. Bit for Cutouts in Plastic Enclosures
    By gpraceman in forum Want To Buy...Need help!
    Last Post: 06-23-2010, 04:23 PM
  3. Enclosures
    By Mcgyver in forum CNC Machine Related Electronics
    Last Post: 07-25-2006, 09:27 PM
  4. Drive enclosures
    By Redline in forum Stepper Motors / Drives
    Last Post: 07-22-2006, 10:35 AM
  5. CNC enclosures
    By owhite in forum DIY CNC Router Table Machines
    Last Post: 01-22-2004, 06:57 PM
