603,900 active members*
2,909 visitors online*
    May 2003
    109
    Encoder - Decoder
    I have a few stepper motors that have encoders one one side of them, Does anyone have a schmatic or know where to get a 3 chanel encoder interface board for around 100$
    Do most Encoder interfaces use serial, parrelle or ISA/PCI??
    Most 3 channel encoders are quadrature output (2 channels) and an index channel.
    The quadrature output (channel A and channel B) have the following output (CCW):
    A 0011001100..
    B 0110011001..
    The CW output is the reverse:
    A 0011001100..
    B 1001100110..
    These outputs are usually decoded by a quadrature decoder to give a "step" and "direction" output (or CLK and U/D signal for counters).
    The index channel gives a single output pulse once a revolution and is generally used to give an accurate "home" position.
    Mariss
    Jul 2003
    246
    Hello bcromwell
    You may build simple 8 bit up/down counter using standart
    CMOS IC and you can read the counter outputs from the PC
    paralel port.(You must write simple software)
    CHA feeds the UP/Down input, CHB feeds the clock input.
    This method use the shaft encoder in x1 mode.
  1. encoder issues
    By rutexus in forum Servo Drives
    Last Post: 05-22-2006, 12:49 AM
  2. What's your max distance to encoder?
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 05-12-2005, 04:57 PM
  3. Encoder output into 2 different inputs?
    By murphy625 in forum Servo Motors / Drives
    Last Post: 03-23-2005, 04:36 PM
  4. Need encoder recommendation
    By Swede in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2004, 02:01 AM
  5. Encoder wiring
    By balsaman in forum Gecko Drives
    Last Post: 12-30-2003, 06:01 PM
