603,939 active members*
2,347 visitors online*
    Nov 2004
    436
    Encoder to drive and DRO?
    Hello, all. I have been using mach for about 3 years now, driving a 3 axis servo system (homebuilt).
    I understand that there are inputs for a DRO within mach. Are these plugged in using the parallel port, or can I use another input?
    I currently use my parallel port to control my Gecko Drives, and I would like to send the encoder signals from my servos to both the Drive and back to the computer, for diagnostic stuff I want to do.
    Feb 2006
    65
    You'll have to use a second parallel port for the inputs but here is a circuit to allow feedback to the pc and to the servo drivers. I don't have a board layout but this circuit is pretty simple.
    Attached Files Attached Files
    "Good judgement comes from experience, and a lot of that comes from bad judgment." - Will Rogers
    Apr 2006
    113
    I bought this board but have not set it up yet http://www.rogersmachine.net/encoderinterface.html
    Jim
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. stepper drive encoder support
    By patrick71100 in forum Stepper Motors / Drives
    Last Post: 09-17-2006, 07:50 PM
  3. Replies: 1
    Last Post: 03-17-2006, 01:20 AM
  4. can brushless drive drive brushed motors ?
    By max_imum2000 in forum Servo Motors / Drives
    Last Post: 02-09-2006, 02:35 PM
  5. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
