I am looking to replace a dynapar encoder E1501000203 but can't find that # on dynapars site. does anyone know what I can use in it's place
Jim
Jim
Send an email to Dynopar support and ask for the resolution and type of the encoder, the physical aspects you can measure.
Al.
Albert E.
Al
Thanks for the response, I had actually done that prior to asking on the forum. I have not gotten a reply yet. I read their model # description but it seems to not work for my model. Hopefully they will get back to me soon.
The E15 style does not show up in the cat. http://dynapar.com/uploadedFiles/_Si...010Catalog.pdf
Is it like the E14 series? If so Koyo sell a practically identical one, it appears yours is a 1000p/rev, you just need to check if it is differential or single ended, (6 signal leads or 3)
Al.
Albert E.
Al thanks for the reponse,
It has 3 leads, What does that mean differential or single ended.
??? A simple 2ch quadrature encoder is 4 leads minimum, if differential, 6 leads min, more if the encoder has a 1/rev marker pulse.
Unless you mean 3 leads PLUS 2 for power?
Al.
Albert E.
