603,864 active members*
3,462 visitors online*
    Jul 2003
    126
    Encoder wiring hookup help
    Working on wiring everything up. Came to a dilema.
    My enconder on the servo has these outputs.
    1- Ground
    2- Ch1
    3- ChA
    4- Vcc
    5- ChB
    The rutex drive has these inputs.
    1-+5V
    2- A Non Inverse
    3- A Inv.
    4- B Non Inverse
    5- B Inv.
    6- Shield
    9- 0V/Ground
    The ground and Vcc ones are easy to match.
    Not sure where CH1 from encoder needs to go into Rutex if anyplace
    And do I hook up to Non Inverse (my guess) or Inverse side?
    Jeff
    Oct 2003
    399
    The Ch1 I guess should be ChI for Index pulse. Don't think you need to hook that one up.
    From the Rutex R990H manual: "The single ended TTL encoder should be connected to one input only and a pull down resistor (470 - 1000 ohms) should be connected to other input."
    So you can connect your encoder outputs to either the inverting or non inverting inputs on your Rutex card. Connect 470-1000 ohm resistors between the unused inputs and ground.
    Arvid
  1. encoder issues
    By rutexus in forum Servo Drives
    Last Post: 05-22-2006, 12:49 AM
  2. Encoder output into 2 different inputs?
    By murphy625 in forum Servo Motors / Drives
    Last Post: 03-23-2005, 04:36 PM
  3. Encoder Hookup
    By murphy625 in forum CamSoft Products
    Last Post: 03-01-2005, 10:46 PM
  4. Need encoder recommendation
    By Swede in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2004, 02:01 AM
  5. Encoder wiring
    By balsaman in forum Gecko Drives
    Last Post: 12-30-2003, 06:01 PM
