603,942 active members*
4,374 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > End Mills and Engraving Bits For CNC Router
Results 1 to 7 of 7
    Mar 2010
    Smile End Mills and Engraving Bits For CNC Router
    Get what you want from us ! Let our mills and bits to be your working partners!
    The end mills and engraving bits produced by our factory have high efficiency in aluminum, acrylic, PVC, ABS, MDF, plastic, softwood and hardwood, marble and granite, whatever in cutting and engraving.
    Quality and service are first! Price to make you smile! We want to find you to be our customers and agents to build a stronger business!
    Please send me email: [email protected] if you are interest, thanks!
    Mar 2003
    35494
    Set up a web site with online ordering and you'll sell a lot more than by just giving an email address.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2004
    5951
    Granite?
    Really? I never knew you could cut granite with endmills; all I've seen are massive sintered-diamond tools. How are these endmills constructed, what speeds and feeds are recommended, how much do they cost, and how long will they last?
    Andrew Werby
    www.computersculpture.com
    Mar 2010
    Hello Gerry,
    Thank you for your kind & good advice!!
    Best regards,
    Cindy
    Mar 2010
    Hello Awerby,
    The end mills for marble and granite produced by our factory are made from silicon carbide and PCD, there are more than twenty sizes and shapes to these end mills. The price is: from US dollars 5 to US dollars 70 . How's its wear resistance? How's the feeds? It depends on which size and shape, which material you want, how's your CNC router .
    Thank you!
    Best regards,
    Cindy
    Apr 2004
    5951
    Are these two different types of endmill
    or a combination of those materials? I've used silicon carbide grinding wheels before, but that material wouldn't last long as an endmill; it would constantly be wearing away.
    Polycrystaline diamond (PCD) sounds like a better bet; are these tools sintered (with the diamond throughout the material) or plated (with diamond adhered to the outside of the shape)?
    So if we used a PCD endmill, say a 1cm round end type, how long a cut would it be able to make cutting 1mm deep in granite before it wore out? What would be the optimum feedrate for that? Does it need water coolant, or can it work dry?
    Andrew Werby
    Quote Originally Posted by endmills world View Post
    Hello Awerby,
    Thank you!
    Best regards,
    Cindy
    Mar 2010
    Hi Andrew,
    The endmills only made from silicon carbide tend to wear away quickly, as you experienced, so, it need to combine with other material to produce for improving its life time.
    The endmills plated with PCD, NOT sintered, sintered is very expensive for the customers! As your example, the endmill should have withstood about 3 hours before its thoughly wore out. My advice for the splindle speed go to 9000 rmp, here its formula: Chipload x ( # of cutting edges ) x rmp = feedrate. Because during the course of operation on the granite, will generate a lot of heat, so, it must be accompanied with water or coolant! I also sell CNC router specified for stone, it along with a tube to fill water.
  1. Engraving Bits
    By pike88 in forum Engraving Machines
    Last Post: 03-26-2009, 11:12 AM
  2. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  3. Engraving toolpaths for router bits
    By jemmyell in forum Engraving Machines
    Last Post: 02-04-2008, 06:11 AM
  4. Engraving Bits
    By JMFabrications in forum MetalWork Discussion
    Last Post: 03-16-2006, 02:08 AM
  5. End mills engraving bits
    By signIT in forum Material Machining Solutions
    Last Post: 09-13-2004, 04:45 AM
