588,210 active members*
4,481 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Endmill to cut aluminum with high speed router?
    Jan 2010
    30
    I know I've seen it somewhere, but after 10 minutes of looking I admit defeat. I read on one thread or another that there are special router bits / endmills for use on high speed (wood) routers that will cut aluminum. I want to do some simple milling using my Bosch Colt and thought I'd give it these bits a try, if I could only find them!
    Thanks much -- Paul
    standard end mills work well enough with a router
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Mar 2003
    35538
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. High feed endmill
    By mackie29 in forum Hard / High Speed Machining
    Last Post: 02-28-2010, 01:52 AM
  2. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
  3. Have High Speed Modem, and Dial up Using Router
    By tobyaxis in forum Computers / Desktops / Networking
    Last Post: 07-24-2006, 03:17 AM
  4. High-Speed 3 (4?) axis cnc router
    By rherman in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 04:31 AM
  5. 3 Flute High Helix Endmill Problem
    By Joe_CNC in forum MetalWork Discussion
    Last Post: 07-20-2005, 01:07 AM
