Engineer's Surface Plate - float glass?
Hi
I think I have used the right term.
I have purchased an engineer's precision square and want to ensure that the plate that I stand the item I am measuring is flat.
I checked with my local Engineer's tools supplier and the standard plate is made from granite or cast iron and is ground flat to a high level of precision. Unfortunately they are also very expensive and start at $300 +.
I was thinking that float glass my be a cost effective solution but I do not know how flat is flat when it comes to it.
Can any engineer tell me if a piece of 10mm thick float glass at 500mm by 500mm will give me a cheap practical alternative.
I am just starting out in model engineering and I want to improve my quality as much as possible but also don't want to bankrupt myself in the process.
Andy
Drat, imperfection has finally stopped working!!
