588,141 active members*
5,623 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Engrave on a curved surface
Results 1 to 7 of 7
    Jan 2006
    2985
    Can Artcam pro do v carving on a curved piece? I want to engrave some chair backs and i need to figure out if artcam can do it from a dxf and then specify the radius of curvature.
    Matt
    Nov 2006
    303
    I dont think it can. V carving is a 2D toolpath. You could make the curve with a 2 rail sweep and apply the feature using the triangle form subtracted into the curve. Then machine the whole thing, or just the feature if the curve is already done, as a relief.
    Todd
    Attached Thumbnails Attached Thumbnails sample curve 700X584.jpg   sample curve 2 700X584.jpg
    Jan 2007
    634
    Artcam does indeed have engraving features, with several ways to do this sort of thing. I have used them quite a bit for v-bit carving in the past, but seldom on irregularly curved objects.
    Getting a toolpath generated to do this is easy, getting the curve you program in to exactly match the curve of your actual workpiece is nigh impossible. With a v-bit even a few thousandths change in depth will obviously change the width of the cut as well, so even very minor changes in depth are noticable.
    I don't work with routers at all, but perhaps there is some kind of feedback sensor for controlling depth stop, or even a weighted/springloaded telescoping toolholder to keep even pressure - and therefore depth of cuts - over uneven surfaces? How is this problem normally solved? I have always wondered!
    Jan 2006
    2985
    thanks guys i think i have gotten what i want with feature machining and just using a v bit, even though it isn't a v carving toolpath.
    Matt
    Jan 2007
    634
    You can also try using the "machine along vector" toolpathing tool. It is a very simple way to do the same thing. It just follows the vector lines - like a pen plotter path - all you set is the depth.
    Jul 2007
    10
    spring loaded engraving
    Quote Originally Posted by Stepper Monkey View Post
    Check this out:
    http://www.2linc.com/spring_loaded_engraving_tool.htm
    Aug 2006
    6
    "machine along vector" can not ... any new update ? to cut along vector on curve surface
  1. Rhino engrave text on curved surface
    By replicapro in forum Rhino 3D
    Last Post: 03-11-2008, 06:32 PM
  2. creating a straight c-bore on a curved surface
    By bennett71 in forum Solidworks
    Last Post: 02-14-2007, 07:58 AM
  3. JPEG/DXF file to a curved surface?
    By Dougotio in forum Rhino 3D
    Last Post: 01-26-2006, 07:27 PM
  4. text/dingbat to curved surface?
    Last Post: 01-19-2006, 01:58 AM
  5. How do I engrave numbers...
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 08:35 PM
