587,421 active members*
3,018 visitors online*
Results 1 to 10 of 10
    Jun 2011
    54
    engrave on glass
    i tried to engrave photo on glass ,but the quality is not good
    if i take the same on wood ,its way better.
    someone knows how to improve quality ?
    Feb 2005
    124
    Double check focus height, and try to change the velocity. Covering the glass with wet paper could also be a solution.
    Dec 2008
    1258
    You need to use a low resolution (dpi) for glass to look good, the image is created by micro fractures so if you don't have sufficient spacing between points it will look blurred.
    A damp paper towel on the surface can help too as it reduces the fracture size which allows a higher resolution image.
    The type of glass is also a factor, cheap glass seems to work better. Avoid any crystal or thermal glass as it will shatter.
    Zax.
    Jun 2011
    54
    thanks ,i will try the damp/wet paper tomorrow
    what dpi you suggest ?
    Sep 2010
    Smile
    Quote Originally Posted by curious View Post
    When we test the materials, we often set the DPI of the image 600-1200
    Hope it will be help.
    Salley
    [email protected]
    Liaocheng Xinxing Electronic Co., Ltd.
    :ideaiode End Pump Laser Module Works so Well On Glass Surface
    Oct 2010
    If you're engraving something other than a photograph, go with sand etching, for less than $100 you can go to harbor freight and get a air eraser, some aluminum oxide media, and a pressure regulator. The sand etching will look much nicer than laser. You can use sign vinyl as your masking.
    Jul 2008
    5
    Quote Originally Posted by bpoulin View Post
    How do you cut the sign vinyl? Do you use a knife cutter, or can this stuff be lasered too?
    I'm a little wary on account of the fumes hazard for the optics. PVC is a no-no, how about thin vinyl sheet?
    Oct 2010
    I use a knife cutter, I run a sign biz but I just use a cheap $200 chinese vinyl cutter for these jobs. If you do some research there are polyester based vinyls out there instead of PVC based. The polyester ones are laser safe. I couldn't tell you which ones those are, but I'm sure if you ask around someone will know.
    Oct 2010
    You probably won't like the look of lasered vinyl either I forgot to mention it melts the vinyl pretty bad. You'd be better off looking for a cheap vinyl cutter, I've seen some 24" ones on ebay for less than $200.
  1. Using metal CNC mill to engrave glass?
    By zaebis in forum Engraving Machines
    Last Post: 12-01-2010, 10:27 PM
  2. using the indexer to engrave glass
    By woodman08 in forum LOGILASE Laser
    Last Post: 03-08-2010, 01:23 AM
  3. cut and engrave at which speed?
    By zaheer0047 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-08-2009, 06:59 AM
  4. how to engrave
    By cob in forum Mastercam
    Last Post: 10-17-2008, 08:51 PM
  5. Mounting rails on glass - how flat is glass?
    By Swiss in forum Linear and Rotary Motion
    Last Post: 07-25-2008, 08:10 AM
