587,467 active members*
2,952 visitors online*
Results 1 to 9 of 9
    Feb 2010
    Engraving and uneven surfaces
    I have gone from a manual engraving machine to a DIY CNC (Zen Toolworks) thinking the advantages would be huge, however, I'm beginning to wonder!! It seems that the CNC machine has to be so precise for engraving it is almost impossible
    I am slowly putting it all together, got the Dremel mounted now but having issues with the writing skipping some areas and some areas quite deep. All in all quite terrible!
    Has anyone experienced this or got any tips? I am guessing it is due to the table being uneven? Please help, I'll listen to anything you have to say!
    Many thanks.
    Aug 2008
    409
    You need to surface the table to make it parallel to your router.
    I dont know what your bed is made from but if it can be machined you should run a large straight bit or endmill over the bed surface and even it up.
    Feb 2010
    OK, many thanks, simple as that? Phew, I was wondering if I had made a big mistake.
    I have a piece of wood for the base, will get on with that over the weekend. Is there a program to do this, or just manually?
    Rgds.
    Aug 2008
    409
    Quote Originally Posted by phatjap View Post
    Rgds.
    Well, as long as your machine rails are not also warped. I dont know the details of your machine, but surfacing the table should help out a lot.
    You will have to make up a program yourself, I did mine in Vcarve and it took no time at all.
    You have to specify your table size, and how much material to take off. I suppose you could do it manually as long as you have your limits set.
    Dec 2007
    379
    As others have said you need to surface the your table or work base. If you are still having problems then perhaps your work piece is not planed/face jointed properly. If that is the case you can surface your work piece with your machine and everything should be fine. Yeah, for accurate and highly detailed engravings, greater care must be taken to insure that your work piece is flat and squared up properly.
    Aug 2009
    392
    On a side note, Dremels aren't exactly the most accurate choice for spindles, and generally have quite a bit of runout. Just something to consider.
    Jun 2006
    106
    another important thing I have seen is that you need a spindle that has give in it so when you are working on a piece that is not entirely flat the spindle will lift up over that and still leave a fairly even engraving. some I have talked to say they get around this by putting something that will squish down but give enough resistance for the depth of cut they want from their engraver.
    Oct 2006
    975
    Hello,
    Another thing to consider is some form of spring loaded engraving tool holder to allow the tool to follow the surface of the part. There are some available to purchase but with a little effort you can fabricate one that will work very well.
    Just another suggestion to help with the problem you have mentioned here.
    Regards,
    Regards,
    Wes
    Feb 2010
    Hi and thanks for your input.
    I'm currently doing a design for a spring loaded tool holder which is a mix of some designs I've seen on here but specifically for a small machine. 2 linc don't go down to 3 or 4 mmm sizes. I'm talking to a work shop at the moment to get a prototype made.
    Lets see what happens.
    Cheers.
  1. Uneven finish
    By orbyog in forum Mach Software (ArtSoft software)
    Last Post: 02-05-2010, 08:42 PM
  2. Engraving Non Uniform Surfaces
    By Bob La Londe in forum DIY CNC Router Table Machines
    Last Post: 07-28-2009, 04:36 PM
  3. Surfaces
    By Allen123 in forum BobCad-Cam
    Last Post: 03-05-2009, 10:18 PM
  4. Help with Surfaces
    By mcyr in forum Autodesk
    Last Post: 12-29-2007, 04:33 PM
  5. Engraving irregular surfaces
    By Stepper Monkey in forum Engraving Machines
    Last Post: 03-29-2007, 08:19 PM
