603,378 active members*
3,016 visitors online*
Results 1 to 4 of 4
    ENI-1024 Encoder
    Hi all,
    Has anyone any experience with CNCDrive's magnetic encoder ENI-1024? I am unsure of the correct pin numbers on the crimp on connectors, and the documentation unfortunately doesn't show this well at all. Picture below is from the ENI-1024 documentation.
    http://www.cnczone.com/forums/attach...d=347822&stc=1
    This is my take on the pin outs below:
    http://www.cnczone.com/forums/attach...d=347820&stc=1
    Can anyone confirm if this is correct?
    My motor housings are made, the magnets are fitted to shafts, I just need to crimp on my CAT5 cable.
    May 2005
    1397
    Re: ENI-1024 Encoder
    Wouldn't contacting them be the way to go?
    I do a little bit better job of documenting the pinout on my encoder:
    techref.massmind.org/techref/io/sensor/pos/enc/ENC1.htm
    but if anyone is confused, they can always email me and I answer the question... why wouldn't this manufacturer?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Dec 2003
    24260
    What you could do to obtain the pin out is to check the reverse side of the board that shows the connections and ground plane and +ve etc, and from there maybe it is possible to obtain the pin out sequence for the rest.
    Al.
    Albert E.
    Figured it out by following the pins back to IC supply and ground. Actually it was quite self explanitory.
    Pins are as follows for anyone else doing this:
    http://www.cnczone.com/forums/attach...d=348194&stc=1
    Thanks for the help.
    Jim
  1. EX 1024 error in MV 40/40 MF-M6 mori seiki
    By raokmk2003 in forum Mori Seiki Mills
    Last Post: 07-25-2021, 08:51 AM
  2. SPindle locks when in low gear on Jet old 1024
    By SwampDonkey in forum Uncategorised MetalWorking Machines
    Last Post: 01-22-2016, 03:20 PM
  3. 1024 New Lathe set, take a look
    By PoppaBear10 in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-16-2011, 09:10 PM
  4. 1024 CPR Encoder G320
    By Raba in forum Gecko Drives
    Last Post: 11-25-2010, 04:40 AM
  5. I want a minor change to my 1024.set file
    By jestism in forum Tormach Personal CNC Mill
    Last Post: 01-17-2010, 06:58 PM
