603,940 active members*
2,388 visitors online*
IndustryArena Forum: Epoxy Granite
Page 5 of 7 34567
Threads 81 to 100 of 138
Discuss Epoxy Granite constructed machines here!
  1. Sticky Thread Sticky: Index to "Epoxy-Granite machine bases" thread
    Started by walter, 06-10-2007 10:38 PM
    12-02-2011, 05:45 AM Go to last post
  1. 635 Thin Epoxy questions?
    Started by JMcDonald, 11-27-2015 11:27 AM
    base, epoxy, filled, rails, steel
    01-05-2016, 10:04 AM Go to last post
  2. Designing with EG
    Started by KKamel, 09-06-2015 02:37 PM
    11-01-2015, 07:56 AM Go to last post
  3. epoxy granite for precision machine
    Started by mshamber, 08-06-2015 06:25 AM
    08-06-2015, 06:25 AM Go to last post
  4. Post Best way to make Shell and Tube Heat Exchanger
    Started by aticoexport, 08-05-2015 09:06 AM
    exchanger, heat, heat transfer, make, shell
    08-05-2015, 09:06 AM Go to last post
  5. simple test piece
    Started by turpija, 12-07-2014 12:34 PM
    aluminum, cnc, cut, easy, epoxy, fixed, granite, mold, mould, open, part, parts, plate, problem, removal, simple, star, steel, stick, surface, tape, test, thread, top
    08-03-2015, 07:13 AM Go to last post
  6. A new epoxy granite CNC
    Started by muppy, 12-26-2012 08:55 PM
    07-02-2015, 11:46 AM Go to last post
    06-23-2015, 03:28 AM Go to last post
  7. Epoxy Granite Mill Head filling
    Started by d@niel, 06-04-2013 06:00 AM
    06-23-2015, 02:49 AM Go to last post
  8. Rustoleum Turbocrete
    Started by Inskeep, 05-12-2015 04:05 PM
    50/50, appreciated, crushed, granite, ratio
    05-20-2015, 10:08 AM Go to last post
  9. Open Source CNC Build
    Started by Motorsports-X, 05-13-2015 04:38 AM
    cnc, machinist, mazak, forum, base
    05-15-2015, 12:23 AM Go to last post
  10. Bubbles in Mixture of Epoxy Resin
    Started by Saimon, 04-24-2015 06:31 AM
    casting-mould, epoxy, epoxy bases, epoxy granite, epoxy-granite
    05-02-2015, 09:09 AM Go to last post
  11. How do you mix larger quantities of epoxy granite?
    Started by gt40, 02-24-2015 12:33 AM
    03-27-2015, 06:39 AM Go to last post
  12. Building an EG machine
    Started by snowluck, 03-21-2014 10:18 AM
    everyone, four, mos, next
    03-09-2015, 06:12 AM Go to last post
  13. Inserts cast against Surface Plate?
    Started by Zathras, 09-28-2012 12:00 PM
    02-19-2015, 08:05 AM Go to last post
    02-10-2015, 03:49 PM Go to last post
  14. Question REAL granite? Tombstone slabs?
    Started by RCaffin, 12-18-2014 10:55 AM
    01-29-2015, 04:49 PM Go to last post
  15. Uba Tuba granite as machine base?
    Started by AxelFoley, 12-22-2014 01:38 AM
    246, 387, 463, base, counter, countertop, craigslist, found, free, giving, granite, html, ing, link, machine, phoenix, rid, suitable, url, wanti, wanting, wondering, zip
    12-22-2014, 01:38 AM Go to last post
  16. Make your own Timing Pulley from epoxy
    Started by JohnMcNamara, 08-28-2011 01:24 PM
    12-07-2014, 12:56 PM Go to last post
    10-12-2014, 12:22 PM Go to last post
  17. Smile Epoxy Mortar or Grout CNC built
    Started by sahilkit, 08-21-2014 07:45 AM
    08-28-2014, 01:17 PM Go to last post
Page 5 of 7 34567
Forum Information and Options
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
