Sometime ago, in a posting a long way back, it was accepted that the mix might contain aggregate particles up to a maximum of 20% of the mold width.
If your fairly dry mix contains gravel 1/4" in diameter, and you want to push this down a tube within a 1.25" wide mold space, what might the dimensions of the tube be, if you need it to withstand any degree of pressure ?
I would suggest that the bore of the tube would add a fairly high degree of resistance to the flow of such a mix, and shoveling it in and vibrating it might be a lot simpler.
If you were considering a much more fluid mix, with a lower particle/mold size ratio, and needed to get into blind corners, then it might offer advantages.
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
