I've just done a quick calculation on the amount of epoxy required, as per Gamski/Gupta ( 31 micron thick layer on average) for two different particle sizes.
I took 100 ccs of 200 micron particles in the first case, and 2mm particles in the second.
This gives a volume of each particle as 0.004189 cu mm for the first, and 4.189 cu mm for the second.
Assuming both to have a packing value of 72%, the total number of particles is 1.72 x 10^7, and 1.72 x 10^4 respectively.
However the surface areas are 2.16 x 10^4 sq cms and 2.16 x 10^3 sq cms, so the volume required to fulfill G/G's requirements will be 67 ccs and 6.7 ccs epoxy for 100 ccs of 200 micron and 2mm particles respectively.
I think that as an approximation this bears out Jack's observation of the amount required to wet G200 at 40% by volume, which at first sight seems a lot.
Jack, is your "UHMW" material referring to ultra high molecular weight polythene ?
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
