Density kg/mc 2283.0 5x5x1 cm EN 14617-1
Water Absorption % 0.03 5x5x1 cm EN 14617-1
Bending Strength Mpa 48 6x5x1 cm EN 14617-2
Flexural Strength N 3371 6x5x1 cm EN 14617-2
Compression Strength N/mmq 159 7x7x1 cm EN 14617-15
Deep Abrasive
Strength
mm 26.6 15x15x1 cm EN 14617-4
Surface Hardness MOHS 6 20x20x1 cm UNI EN 101
Linear Thermal
Expansion Coefficiency
10-6 °C-1 27.4 2.5x0.5x0.5 cm EN 14617-11
Dimensional Stability mm 0 30x30x1 cm EN 14617-12
Resistence to
Slipperiness
SRV Asciutta 68 20x20x1 cm
EN 14231
SRV Bagnata 16 20x20x1 cm
Impact Strength Joule 1.9 20x20x1 cm EN 14617-9
Fire Resistence Class 1
Frost Resistence KMf25 1.1 6x5x1 cm EN 14617-5
Chemical Resistence Class C4 7x7x1 cm EN 14617-10
Thermal Shock
Resistence
Damage Suffered None 2cm UNI EN 104
Colour Resistence
to Light
Notable Varation of colour Slight DIN 510994
Slipperiness
Rubber on Dry Surface
Rubber on Wet Surface
Leather on Dry Surface
(Honed Surface)
μ
μμ
0.88
0.41
0.45
30x30x2 cm B C R
Emission of lead (Pb) and
cadmium (Cd)
OKITE® Test Results
Pb C d
http://www.okite.com/pdf/OKITE_Tech_Manual.pdf
