603,942 active members*
3,812 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 4 of 220 234561454104
Results 61 to 80 of 5052
Hybrid View
walter Epoxy-Granite machine bases... 01-09-2007, 12:48 AM
Mcgyver its been discussed many times... 01-09-2007, 01:04 AM
walter Yeah, I've seen the... 01-09-2007, 04:24 AM
lgalla try Google search."epoxy... 01-09-2007, 04:29 PM
Episs I just noticed this material... 01-10-2007, 02:24 PM
roach ill tell you optical... 02-12-2008, 10:58 PM
romihs Hi Roach, Welcome to the... 02-13-2008, 12:18 AM
lgalla Episs Companys... 01-11-2007, 02:24 AM
walter Yes please continue- that's a... 01-11-2007, 08:25 AM
snookered1ca EG Machine base 10-27-2008, 04:23 AM
romihs Hello Bruce, Yes, the... 10-27-2008, 02:11 PM
walter Hmm... How about using some... 02-02-2007, 08:53 AM
garfieldsimons I got a a 2 x 4 block of... 07-28-2009, 03:35 PM
ckelloug Hi there veteq Roy, The... 07-29-2009, 06:26 AM
whitis Guess again. Sand can be... 10-03-2009, 06:06 AM
garfieldsimons used granite surface plates 11-30-2009, 05:18 PM
lgalla Walter thanks for showing... 01-12-2007, 05:17 AM
lgalla Hear I go again replying to... 01-12-2007, 05:28 AM
mdaweb HomeMade Moglice 08-29-2011, 02:16 PM
johnohara I think mdaweb was trying to... 08-29-2011, 04:40 PM
mdaweb Colloidal silica = magnesium... 08-29-2011, 05:32 PM
Episs I received email form Accures... 01-12-2007, 10:11 AM
RotarySMP My local library has a german... 01-12-2007, 10:21 AM
Episs How about other materials for... 01-12-2007, 02:08 PM
victorf Consider a slab of granite.... 04-16-2007, 07:26 PM
walter Thanks. This sounds great,... 04-17-2007, 02:15 AM
HBFixedGear artifical concrete machine... 04-23-2007, 09:16 PM
garfieldsimons Granite ssurface plate 04-26-2007, 03:59 PM
VoxLimbo Disposal Issues? 04-26-2007, 04:13 PM
uhrgerat Polymer concrete 05-07-2007, 02:03 PM
Joe Crumley Polymere Concrete 05-28-2007, 04:52 PM
icando48 polimer concrete 06-04-2007, 06:32 PM
ckelloug RotarySMP, Your... 06-04-2007, 07:00 PM
ckelloug Eson, That is an excellent... 06-04-2007, 07:07 PM
chineguy mixed filler 08-07-2007, 06:59 AM
robpiaz surface plates 12-10-2007, 06:30 PM
Peldor I also found a self leveling... 06-16-2008, 09:03 PM
morphious69 there are just to many posts... 08-22-2008, 01:32 AM
Calthorp epoxy 09-15-2008, 11:37 AM
probinson Sure, You can use any filler... 09-15-2008, 12:04 PM
dimitar visit: ... 03-02-2009, 11:56 AM
compositepro i didnt read the entire... 03-02-2009, 05:45 PM
ncmeinc Try Philadelphia Resins I ... 07-06-2009, 11:29 AM
Epikur serious supplier of a base in... 07-13-2009, 03:26 PM
jonixllc Epoxy Granite 09-21-2009, 12:37 PM
galaxyman7 Is there any kind of... 09-23-2009, 04:30 PM
HBFixedGear Filling a machine base 10-15-2009, 03:33 PM
JeffMN You might want to look at... 03-04-2011, 08:05 PM
Kevin_Johnson Toiling with toilet paper in... 04-13-2011, 12:31 PM
bozidar22 Does any one know if epoxy... 04-17-2011, 02:24 AM
pminmo What about polymers is so... 01-12-2007, 06:47 PM
Geof I read a couple of technical... 01-12-2007, 06:54 PM
greybeard While I'm still building m/c... 01-12-2007, 08:54 PM
schrupphobel72 Found Polymer Products The... 01-13-2007, 01:50 AM
lgalla Glad to see other member are... 01-13-2007, 06:34 AM
walter Larry, we may be onto... 01-13-2007, 12:36 PM
greybeard For the "larger" size tables,... 01-13-2007, 01:24 PM
dansutula Folks, The former Light... 01-13-2007, 03:08 PM
Mcgyver I had never thought of an... 01-13-2007, 05:00 PM
Geof This page has the numbers... 01-13-2007, 05:27 PM
turmite http://www.machinedesign.com/C... 01-13-2007, 05:29 PM
lgalla non toxic 01-13-2007, 05:46 PM
Geof I found this page which gives... 01-13-2007, 05:49 PM
walter Good point. Then again,... 01-13-2007, 06:16 PM
Mcgyver thats part of it - different... 01-13-2007, 11:32 PM
lgalla Mcgyver and Geof I have to... 01-13-2007, 06:01 PM
Geof I would hate to think what... 01-13-2007, 06:08 PM
greybeard Mike - could you revise the... 01-13-2007, 06:20 PM
schrupphobel72 Found more Polymer Concrete 01-13-2007, 09:06 PM
greybeard schrupphobel72 - Your last... 01-13-2007, 09:39 PM
lgalla Bad News 01-13-2007, 09:55 PM
turmite http://www.machinedesign.com/A... 01-14-2007, 01:46 AM
turmite http://www.machinedesign.com/C... 01-14-2007, 01:52 AM
Geof That is the link that claims... 01-14-2007, 01:56 AM
JWOOD At my last job we did some... 01-14-2007, 02:51 AM
lgalla lower cost 01-14-2007, 03:26 AM
greybeard Larry - Why not use a layer... 01-13-2007, 11:08 PM
greybeard Build a torsion box out of... 01-13-2007, 11:10 PM
schrupphobel72 attached the pic's from the... 01-13-2007, 11:23 PM
walter Ah yes, the good old... 01-14-2007, 03:57 AM
lgalla good source 01-14-2007, 04:38 AM
the4thseal After reading all of this... 01-14-2007, 05:01 AM
RotarySMP Larry, you are still talking... 01-14-2007, 09:22 AM
RotarySMP Hi Larry, I also don't... 01-14-2007, 10:05 PM
Geof I think one of the islands in... 01-14-2007, 10:26 PM
greybeard Are there no mathematicians... 01-14-2007, 10:27 PM
lgalla Hey Mark,try... 01-15-2007, 02:58 AM
Mcgyver this is mostly true. ... 01-15-2007, 03:16 AM
RotarySMP Sorry Walter, They haven't... 01-15-2007, 08:54 AM
lgalla mark You forgot to... 01-15-2007, 05:12 PM
Episs I can tell that i found ather... 01-15-2007, 09:25 PM
Aramon Maybe its good to use an... 01-15-2007, 08:51 PM
Aramon Why not use a pre-mixed epoxy... 01-15-2007, 09:42 PM
lgalla Episs the POLYLITE is... 01-15-2007, 10:24 PM
greybeard Whatever size you choose for... 01-15-2007, 10:26 PM
nMotion I hope you guys keep working... 01-19-2007, 06:44 AM
atenman1 Hi Matt How is that... 01-29-2007, 02:59 PM
atenman1 Hi Matt Can you let us see... 02-11-2007, 01:42 PM
Eson Does anyone have any idea... 02-14-2007, 12:16 PM
lgalla Hey Guys Has... 01-19-2007, 05:00 AM
atenman1 Hi Matt WOW!!! What is the... 01-19-2007, 07:48 AM
greybeard Matt - I presume that anchor... 01-19-2007, 09:42 AM
RotarySMP Larry, according to Nucky and... 01-19-2007, 12:39 PM
Mcgyver things puzzling me that I'd... 01-19-2007, 03:03 PM
lgalla Mcgyver I have to agree,... 01-19-2007, 04:37 PM
Mcgyver Larry, Yes I'd envisioned... 01-19-2007, 05:47 PM
the4thseal I am thinking about doing... 01-19-2007, 06:20 PM
Geof To some extent you are... 01-19-2007, 06:57 PM
walter That actually was the... 01-21-2007, 06:29 AM
lgalla Also try Google... 01-19-2007, 05:13 PM
BobWarfield Great thread. I have been... 01-19-2007, 07:59 PM
SACEM Filling a milling machine... 07-09-2007, 09:54 PM
Xerxes A very interesting thread! I... 01-19-2007, 08:28 PM
RICHARD ZASTROW Just saw a show on TV where... 01-19-2007, 09:18 PM
Geof Almost everything. I... 01-19-2007, 09:42 PM
RICHARD ZASTROW Both glass & granite are... 01-19-2007, 09:49 PM
Chris-Jennings I have been following this... 01-19-2007, 10:18 PM
Chris-Jennings http://books.google.co.uk/book... 01-19-2007, 10:19 PM
Chris-Jennings This is the sort of thing I... 01-20-2007, 01:20 AM
lgalla I gave a link earlyer to an... 01-20-2007, 02:57 AM
lgalla I did some fieldwork... 01-20-2007, 06:35 AM
greybeard Chris - having ploughed... 01-20-2007, 10:22 AM
Mcgyver all sand is not created... 01-20-2007, 07:18 PM
nMotion Lots of good info in this... 01-21-2007, 01:17 AM
atenman1 :wave: Hi Matt Time up!... 02-04-2007, 08:46 AM
vger Tensioning E/G 02-04-2007, 03:08 PM
lgalla Thanks Matt for the good... 01-21-2007, 04:33 AM
walter Larry, good to have you on... 01-21-2007, 05:11 AM
lgalla I am in a post mood.I always... 01-21-2007, 06:31 AM
walter Is that a birch plywood? ... 01-21-2007, 06:54 AM
lgalla Geof. you are absolutly... 01-21-2007, 07:14 AM
Geof You do not need to go to the... 01-21-2007, 03:55 PM
RotarySMP I went to the library... 01-21-2007, 03:36 PM
RotarySMP Geof, Polymer concrete offers... 01-21-2007, 04:20 PM
Geof This is copied from the... 01-21-2007, 04:43 PM
lgalla Found new source for... 01-21-2007, 07:10 PM
walter Cutting heavy steel tubing,... 01-21-2007, 07:11 PM
greybeard I think it's imperative to... 01-21-2007, 07:22 PM
Geof Yes it does and in addition... 01-21-2007, 07:34 PM
RotarySMP Geof, it is shame the thread... 01-21-2007, 08:03 PM
digits If the concrete doesn't get... 01-22-2007, 04:13 PM
Geof For what it is worth I think... 01-22-2007, 04:33 PM
greybeard Geoff, didn't my posting #93... 01-22-2007, 09:18 PM
Geof Then I was still thinking... 01-22-2007, 09:34 PM
atenman1 Good thread, read... 01-23-2007, 01:18 AM
Oldmanandhistoy Hi all, Just a quick... 01-22-2007, 09:05 PM
walter 8020 frame in zero-shrink... 01-22-2007, 09:55 PM
digits Thanks, but someone has to... 01-23-2007, 02:02 AM
atenman1 I got it!!! So sorry for... 01-23-2007, 01:34 AM
lgalla I know I have been posting... 01-23-2007, 03:03 AM
Geof Igalla; I took digits'... 01-23-2007, 04:28 AM
walter Larry, how about making a... 01-23-2007, 04:34 AM
lgalla Geof Thanks for the... 01-23-2007, 04:57 AM
walter With 8020 aluminum "core" we... 01-23-2007, 06:40 AM
greybeard I wonder if there are... 01-23-2007, 12:39 PM
digits I can't see why you'd need... 01-23-2007, 01:53 PM
lgalla I would hazard a... 01-23-2007, 05:08 PM
walter Melamine mold sounds good and... 01-23-2007, 05:25 PM
digits Hi Walter, if you use the... 01-23-2007, 05:41 PM
wizard I just got involved in this... 01-29-2007, 08:22 PM
Geof Yes, correct with Portland... 01-29-2007, 08:29 PM
digits Yes, sorry, I had imagined... 01-23-2007, 05:52 PM
lgalla Digits Jacking up the... 01-24-2007, 03:14 AM
JerryFlyGuy I'd have to say this sounds... 01-24-2007, 05:20 AM
digits Yes, the rail alignment does... 01-24-2007, 12:17 PM
Mcgyver there's a few posts here that... 01-24-2007, 02:09 PM
JerryFlyGuy Thanks for clarifyign Larry,... 01-24-2007, 02:29 PM
walter No, not water based concrete.... 01-24-2007, 03:31 AM
lgalla There is so many posts and... 01-24-2007, 04:00 AM
lgalla Jer thanks for the input and... 01-24-2007, 06:30 AM
atenman1 Hi Larry For your 3200lb... 01-24-2007, 07:32 AM
Aramon Epucret 01-24-2007, 03:25 PM
Mbk Do you know some cost about... 05-03-2009, 11:32 PM
lgalla HeY Atenman1 40gals $2200 ... 01-24-2007, 05:48 PM
walter Greybeard, Yeah, pouring... 01-24-2007, 09:40 PM
lgalla My 4200lb.paperweight is... 01-25-2007, 04:21 AM
lgalla I would like to welcome some... 01-25-2007, 05:19 AM
Geof Things are progressing too... 01-25-2007, 05:48 AM
walter Mcgyver, check out message... 01-25-2007, 06:17 AM
Mcgyver ....and?.... Of course you... 01-25-2007, 03:26 PM
walter Larry, I hope I got the link... 01-25-2007, 06:30 AM
Aramon http://www.epucret.de/maschine... 01-25-2007, 07:58 AM
walter Mcgyver, I am very... 01-25-2007, 07:16 PM
Mcgyver Walter, don't be... 01-25-2007, 09:55 PM
stlc1 we manufacture lead screws &... 01-25-2007, 10:34 PM
lgalla Removing entrapped air with a... 01-27-2007, 02:40 AM
atenman1 Hi Larry Thanks for your... 01-27-2007, 03:10 AM
walter Thanks Larry. Good info, as... 01-27-2007, 03:25 AM
atenman1 Hi Larry please elaborate... 01-27-2007, 04:56 AM
lgalla Calvin good find,Gast pumps... 01-27-2007, 05:27 AM
Geof Regarding vacuum degassing. ... 01-27-2007, 05:53 AM
lgalla Walter sorry I was... 01-27-2007, 06:20 AM
walter Again, good info. I was... 01-27-2007, 06:59 AM
ger21 You can make a cheap venturi... 01-27-2007, 02:22 PM
lgalla Geof I cannot find the oil... 01-28-2007, 05:48 AM
Geof igalla here is a picture. You... 01-29-2007, 01:43 AM
walter Here are few more machine... 01-29-2007, 07:20 AM
myinisjap have done epoxy casting 01-29-2007, 09:27 AM
vger Drilling 01-29-2007, 01:40 PM
atenman1 Hi Walter Are those granite... 01-29-2007, 09:31 AM
walter Seems like a granite to me.... 01-29-2007, 05:21 PM
Geof I think you exagerrate a... 01-29-2007, 06:09 PM
lgalla I had sujested previously... 01-29-2007, 05:30 PM
RotarySMP Doesn't sandblasting sand... 01-29-2007, 05:52 PM
myinisjap not that i know of the reason... 01-29-2007, 11:42 PM
brunog Hello all, I've discovered... 01-30-2007, 01:31 AM
walter As you guys saw, there is... 01-29-2007, 09:02 PM
JerryFlyGuy Walter, I've had some... 01-29-2007, 09:57 PM
walter Jerry, you're the... 01-30-2007, 04:52 AM
lgalla Hi new posters, Glad to... 01-30-2007, 03:38 AM
vger Shrinkage and thermals 01-30-2007, 03:56 AM
lgalla Epoxy's are generally... 01-30-2007, 04:31 AM
CNCAddict Hmm, I think the main... 01-30-2007, 04:54 AM
walter Atenman1 & Bruno, Thanks for... 01-31-2007, 07:13 AM
vger Materials 01-31-2007, 01:49 PM
lgalla I am a computer/dummy. I... 01-30-2007, 06:15 AM
walter Ok, I've been working on my... 01-30-2007, 07:48 AM
atenman1 Hi Larry and Walter would it... 01-30-2007, 10:24 AM
atenman1 Hi Larry hope this going to... 01-30-2007, 02:44 PM
brunog Larry/Walter, This site... 01-30-2007, 05:41 PM
walter picture #1 shows E/G... 01-30-2007, 06:03 PM
the4thseal What about using the sand... 01-30-2007, 10:08 PM
JerryFlyGuy Better known as Garnet, the... 01-30-2007, 10:12 PM
Geof Judging from a thread I read... 01-30-2007, 10:32 PM
JerryFlyGuy Larry asked me to post this... 01-31-2007, 02:45 AM
lgalla In reply to Atenman1, My... 01-31-2007, 03:00 AM
CNCAddict Larry, wouldn't laminating... 01-31-2007, 04:09 AM
lgalla Fellow CNC addict.Was the... 01-31-2007, 04:40 AM
brunog Larry, Just finished looking... 01-31-2007, 05:21 AM
brunog Vger, I believe they insert... 01-31-2007, 04:44 PM
oldpoopie Couldnt you use a syrifoam of... 01-31-2007, 05:23 PM
lgalla Hi Brunog, The slides are... 01-31-2007, 05:29 PM
vger Drilling granite 02-01-2007, 12:12 AM
brunog Larry, if you position... 01-31-2007, 07:43 PM
JerryFlyGuy Or, just D&T into the beam,... 01-31-2007, 09:07 PM
lgalla Where is Mark aka... 02-01-2007, 04:03 AM
brunog Larry, have you considered... 02-02-2007, 03:34 AM
lgalla Bruno thanks for the... 02-02-2007, 05:31 AM
brunog Larry, I totally aggree with... 02-02-2007, 04:25 PM
atenman1 Hi Larry Thank you for... 02-02-2007, 04:33 PM
lgalla Is this off topic?Real black... 02-02-2007, 06:07 PM
greybeard Larry - is this thought train... 02-02-2007, 07:20 PM
lgalla Calvin good research.I like... 02-03-2007, 04:52 AM
lgalla I did it again.:withstupi I... 02-03-2007, 05:55 AM
JerryFlyGuy Hey Larry, totally off topic... 02-03-2007, 05:28 PM
vger Real Granite 02-03-2007, 05:53 PM
greybeard Foamed granite ? (chair)... 02-03-2007, 07:30 PM
lgalla Steve Vger glad to see there... 02-04-2007, 05:07 AM
vger Larry, On the honeycomb... 02-04-2007, 03:26 PM
the4thseal Does anyone think that post... 02-04-2007, 06:26 AM
Geof I think this might be a... 02-04-2007, 06:43 AM
lgalla Steve good ideas.I am guilty... 02-04-2007, 05:05 PM
the4thseal Thanks, i had thought that... 02-04-2007, 07:55 PM
skippy To my way of thinking, trying... 02-04-2007, 09:23 PM
mhasting2004 Hi all Not sure if this... 03-16-2007, 06:11 AM
walter Mark, thanks for sharing.... 03-16-2007, 08:17 AM
martinw Dear Mark, That post was... 03-16-2007, 04:35 PM
brunog :cool: Walter, Check the E/C... 02-05-2007, 02:28 AM
walter Nice find Bruno. Here are the... 02-05-2007, 03:10 AM
lgalla Walter thanks fore the... 02-05-2007, 06:30 AM
Geof A "real" man asks for dunkel.... 02-05-2007, 06:47 AM
lgalla What is DUNKEL? 02-05-2007, 07:31 AM
Geof Larry you have a typo in a... 02-05-2007, 05:05 PM
lgalla Geof Just reviewed the... 02-05-2007, 07:53 AM
the4thseal As for tamping ...What about... 02-05-2007, 04:54 PM
RICHARD ZASTROW Even us Germans have open??... 02-05-2007, 06:24 PM
walter Larry, is that blue... 02-06-2007, 03:24 AM
lgalla No the blue is E/G I mis... 02-06-2007, 04:11 AM
walter Blue center all E/G, topped... 02-06-2007, 04:21 AM
JerryFlyGuy Another company who... 02-06-2007, 08:35 PM
lgalla gOOD LINK 02-07-2007, 05:29 AM
vger Moglice 02-07-2007, 01:46 PM
JerryFlyGuy Moglice claims they can use... 02-07-2007, 03:31 PM
brunog Hey Guys, You can find more... 02-09-2007, 08:37 PM
brunog Sorry the web site is... 02-10-2007, 01:37 AM
brunog John and Jerry are right,... 02-14-2007, 07:14 PM
WilliamD I'm going to try and settle... 02-14-2007, 10:15 PM
brunog William, The epoxy:aggregate... 02-14-2007, 11:45 PM
walter Great idea William, thanks... 02-15-2007, 12:53 AM
ger21 I think you want the thin... 02-15-2007, 02:55 AM
Eson I think using polymer as a... 02-15-2007, 03:23 AM
brunog Gerry, Because granite is... 02-15-2007, 04:07 AM
lgalla Guys Sorry for the... 02-15-2007, 06:28 AM
atenman1 Hi Larrylet see those "Why I... 02-16-2007, 03:55 PM
brunog Calvin, I checked the spec... 02-16-2007, 05:27 PM
JerryFlyGuy Or, they finished it off w/... 02-16-2007, 05:36 PM
walter Jerry, how about a picture? :) 02-16-2007, 05:45 PM
JerryFlyGuy Sure, when its done :D. ... 02-16-2007, 07:07 PM
walter Uhm.. I've been thinking... 02-18-2007, 06:15 AM
vger Machine pictures 02-18-2007, 03:57 PM
ger21 You could probably get some... 02-18-2007, 05:19 PM
vger The Thinker 02-18-2007, 04:08 PM
ger21 Provided you can rotate it... 02-18-2007, 05:22 PM
BobWarfield I see a couple of problems... 02-18-2007, 06:37 PM
walter Thanks for the input Bob.... 02-19-2007, 12:59 AM
WilliamD OK, I have ordered the Epoxy,... 02-19-2007, 10:24 PM
martinw Dear William, Speaking of... 02-28-2007, 02:22 AM
walter Are you going to do it in... 02-19-2007, 10:43 PM
WilliamD I will definetly try layers,... 02-20-2007, 01:18 AM
lgalla glass 02-20-2007, 02:46 AM
Eson You must have mold wax or... 02-20-2007, 03:25 AM
WilliamD Yes, I was definetly going to... 02-20-2007, 03:55 AM
lgalla William glad to see someone... 02-20-2007, 04:15 AM
vacpress i know a professional... 02-20-2007, 04:35 AM
vacpress after reading a bit of the... 02-20-2007, 04:48 AM
the4thseal what kind of temperatures are... 02-20-2007, 06:35 AM
WilliamD I found some Maguire's stuff... 02-20-2007, 06:59 AM
Eson The temperature is diffrent... 02-20-2007, 04:36 PM
WilliamD It might just come down to... 02-20-2007, 05:53 PM
lgalla William epoxy exotherm can... 02-21-2007, 12:51 AM
ger21 For reference, a few weeks... 02-21-2007, 01:02 AM
lgalla Exactally Ger The... 02-21-2007, 01:42 AM
WilliamD I was at Home Depot, and the... 02-23-2007, 04:52 AM
lgalla William Marble is... 02-23-2007, 05:25 AM
brunog William, Also look at pool... 02-23-2007, 04:53 PM
Eson How hard is it to dry sand?... 02-23-2007, 07:25 PM
WilliamD I was thinking of just drying... 02-23-2007, 09:34 PM
brunog Eson, it's not just drying... 02-24-2007, 03:28 AM
romihs SikaDur-42 02-27-2007, 02:25 PM
brunog Sposl, welcome to the forum.... 02-27-2007, 05:23 PM
romihs Bruno, Thanks. Thanks for... 02-28-2007, 12:31 AM
lgalla Hey Martin E/G should fully... 02-28-2007, 03:28 AM
romihs Teflon as a mold lining 02-28-2007, 12:36 PM
lerman Why not just line the form... 02-28-2007, 11:00 PM
martinw Dear Larry, Thank-you for... 03-01-2007, 02:34 AM
skippy when I look at the size of... 03-01-2007, 12:41 AM
lgalla Hey Martin Try... 03-01-2007, 03:45 AM
romihs Martin, I am by far not an... 03-01-2007, 10:27 AM
martinw Dear Larry, Sorry, I... 03-01-2007, 04:29 PM
Geof This link gives thermal... 03-01-2007, 05:00 PM
Big S From my use of composites,... 03-01-2007, 10:38 AM
walter Is this the resin used in... 03-01-2007, 11:29 AM
Eson Even if the resin is... 03-01-2007, 03:56 PM
Big S I don't think it will be, it... 03-01-2007, 08:39 PM
walter Larry, isn't the 'polymer... 03-02-2007, 01:04 AM
romihs Shannon, I have looked... 03-01-2007, 06:35 PM
lgalla Here is a link that gives... 03-01-2007, 08:48 PM
martinw Dear Larry, Thanks. There... 03-01-2007, 10:02 PM
Geof Maybe not; it depends how you... 03-01-2007, 11:29 PM
martinw Dear Geof, That's a fair... 03-02-2007, 12:08 AM
walter Martin, Here's the big... 03-02-2007, 01:15 AM
lgalla Ger I don't know but maybe... 03-02-2007, 12:11 AM
lgalla Posting time is here.My... 03-02-2007, 12:23 AM
the4thseal would using a heating blanket... 03-02-2007, 12:37 AM
lgalla Walter I have always... 03-02-2007, 01:37 AM
lgalla Walter you posted while I was... 03-02-2007, 01:46 AM
lgalla Martin maybe this will help... 03-02-2007, 02:03 AM
walter I agree about Prozac stress... 03-02-2007, 02:10 AM
ger21 I was thinking more in terms... 03-02-2007, 02:55 AM
Geof martinw; Do a Google search... 03-02-2007, 04:27 AM
martinw Dear Geof, I took your... 03-02-2007, 04:52 AM
Geof I was drawing an analogy... 03-02-2007, 05:45 AM
lgalla Wikipedia Fatigue is... 03-02-2007, 05:05 AM
Big S I would think that if your... 03-02-2007, 05:17 AM
brunog Sandy, I totally agree with... 03-02-2007, 05:57 AM
martinw Dear Shannon, I take the... 03-02-2007, 03:57 PM
lgalla Martin Your... 03-03-2007, 01:40 AM
martinw Dear Larry, At the risk of... 03-03-2007, 02:36 AM
lgalla Sorry Martin math was not a... 03-03-2007, 03:19 AM
martinw Dear Larry, Absolutely no... 03-03-2007, 04:06 AM
walter Good to have you on board,... 03-03-2007, 03:27 AM
lgalla Martin sorry again I missed... 03-03-2007, 04:37 AM
martinw Dear Larry, Gin and red... 03-03-2007, 05:04 AM
lgalla 7% solution 03-04-2007, 04:14 AM
brunog Larry, Your calculation in... 03-04-2007, 03:33 PM
martinw Dear Larry, I completely... 03-04-2007, 05:22 PM
lgalla To get that 157lbs/cuft it... 03-04-2007, 06:25 PM
walter ok, time for another review:... 03-06-2007, 06:13 AM
martinw Dear Larry, This is almost... 03-08-2007, 09:46 PM
lgalla Walter thanks for the... 03-06-2007, 06:47 AM
lerman You didn't tell us how much... 03-07-2007, 08:47 PM
martinw Dear Ken, As I read it,... 03-07-2007, 09:27 PM
brunog Ken, Assuming that you have... 03-08-2007, 12:31 AM
jsage Walter, Great summary. ... 03-07-2007, 09:37 PM
Zumba Does anyone here know how... 03-08-2007, 01:08 AM
martinw Dear all, It seems to me... 03-08-2007, 01:27 AM
martinw Dear Zumba, If you choose... 03-08-2007, 06:39 PM
martinw Oh dear, that is completely... 03-08-2007, 07:22 PM
brunog Zumba, Please refer to... 03-08-2007, 01:41 AM
Zumba I'm interested more in a... 03-08-2007, 03:47 AM
307startup Hmmm. I was thinking about... 03-08-2007, 01:43 AM
Zumba Too much $$. I think the... 03-08-2007, 03:57 AM
lgalla Zumba, I agree... 03-08-2007, 05:36 AM
svenakela At least Madvac and me are... 03-08-2007, 04:02 PM
Zumba Thanks, Martin for the... 03-09-2007, 04:27 AM
lgalla Hey Martin At 95%fill I... 03-09-2007, 08:23 AM
martinw Dear Larry, My guess is... 03-09-2007, 04:59 PM
Geof I think the concern about E/G... 03-09-2007, 05:19 PM
Zumba In regards to the stiffness,... 03-09-2007, 11:02 AM
brunog Larry, Martin, Geof, IMHO, i... 03-09-2007, 06:03 PM
walter Machine frame in the form of... 03-10-2007, 01:24 AM
martinw A "complete load of balls"... 03-10-2007, 03:04 AM
brunog Martin, the idea on... 03-10-2007, 08:09 PM
martinw Bruno, You may well be... 03-10-2007, 09:14 PM
lgalla stiffness 03-09-2007, 07:05 PM
walter Larry, can I ask you a... 03-11-2007, 09:55 PM
Zumba Make it taller to combat... 03-11-2007, 10:39 PM
walter Steel tubing..? ... 03-11-2007, 11:02 PM
ger21 Why do you need a 16'... 03-12-2007, 01:17 PM
martinw Please read post#380 not... 03-10-2007, 04:32 AM
brunog Martin, The 63% should be... 03-10-2007, 10:15 PM
martinw Bruno, Again, you could be... 03-11-2007, 02:32 AM
Geof But what about C/G. If it... 03-11-2007, 02:42 AM
martinw Dear Geof, I couldn't... 03-11-2007, 02:46 AM
jsage I knew there had to be a... 03-11-2007, 02:54 AM
lgalla Anyone done costing?From all... 03-11-2007, 05:36 AM
ger21 Here's an article about... 03-11-2007, 11:17 PM
brunog Ger, This is the perfect... 03-12-2007, 04:57 PM
martinw Bruno, I'm pretty sure... 03-12-2007, 06:10 PM
jsage Guegon brothers make West... 03-12-2007, 06:24 PM
ger21 The article was in a magazine... 03-12-2007, 06:44 PM
Geof Almost certainly a gain in... 03-12-2007, 08:05 PM
lgalla Walter Here is a good... 03-11-2007, 11:33 PM
walter How about encapsulating the... 03-12-2007, 05:06 AM
jsage It's sounds to me there are... 03-12-2007, 05:59 AM
martinw Dear Walter, With hollow... 03-12-2007, 03:23 PM
Zumba Yes and yes. It will be... 03-12-2007, 10:20 AM
walter Thanks, I find these posts... 03-12-2007, 04:07 PM
ger21 Whenever possible, it's a... 03-12-2007, 04:11 PM
lgalla Hey guys good answers.What I... 03-12-2007, 05:32 PM
jsage Brunog, I was thinking... 03-12-2007, 06:04 PM
Zumba Depends on the size of the... 03-12-2007, 08:45 PM
Zumba The rebar on the beam is in... 03-13-2007, 01:26 AM
Geof That is always how rebar... 03-13-2007, 01:46 AM
jsage Zumba, Not sure if you... 03-13-2007, 01:54 AM
Zumba Yea, but I avoid calculus... 03-13-2007, 03:59 AM
jsage Zumba, I needed a tutor I... 03-13-2007, 04:05 AM
ger21 I wouldn't think a 2x12 could... 03-13-2007, 02:02 AM
Zumba 19 feet, just like in the... 03-13-2007, 03:58 AM
martinw Dear Zumba, All you have... 03-13-2007, 02:11 AM
lgalla I would think the 2X12's are... 03-13-2007, 02:19 AM
ger21 But wouldn't the rebar... 03-13-2007, 02:26 AM
lgalla Agreed Gerry, re-bar may be... 03-13-2007, 02:45 AM
jsage Well folks I enjoy everyone's... 03-13-2007, 03:44 AM
martinw Dear jsage, Thanks for the... 03-13-2007, 04:05 AM
lgalla Zunba hope you don't mind me... 03-13-2007, 04:32 AM
Zumba That is interesting. In that... 03-13-2007, 01:32 PM
lgalla This is not related to the... 03-13-2007, 04:57 AM
jsage Larry, As a financial,... 03-13-2007, 08:18 AM
vger I once heard it said that the... 03-13-2007, 02:38 PM
Zumba jsage, I think the steel tube... 03-13-2007, 01:38 PM
lgalla Jsage here is the link. As a... 03-13-2007, 05:41 PM
jsage Thanks Igalla, Zumba,... 03-13-2007, 08:22 PM
jsage Igalla, I can give you a... 03-13-2007, 09:28 PM
lgalla Hey Mike I think filling a... 03-13-2007, 11:23 PM
martinw Dear Larry, One effect of... 03-14-2007, 12:01 AM
Zumba Martin, good point on the... 03-14-2007, 12:28 AM
martinw Dear Zumba, I think there... 03-14-2007, 12:40 AM
walter My machine will probably have... 03-14-2007, 01:43 AM
brunog I believe rigid foam panels... 03-14-2007, 01:12 AM
martinw Dear Bruno, Excellent... 03-14-2007, 01:32 AM
lgalla Zumba the 16lb denisity foam... 03-14-2007, 01:34 AM
martinw Dear Larry, Speaking of... 03-14-2007, 01:57 AM
brunog Larry, Drink the beer and/or... 03-14-2007, 02:18 AM
lgalla Boy I am slow at posting,3... 03-14-2007, 01:50 AM
martinw Dear all, I think there... 03-14-2007, 11:19 PM
brunog Larry, what about foaming... 03-14-2007, 02:08 AM
brunog Larrry, I am as slow as you... 03-14-2007, 02:12 AM
lgalla Bruno beleive it or not I... 03-14-2007, 03:01 AM
martinw Be warned Larry, My pencil... 03-14-2007, 03:29 AM
jsage canned laughter. :) You... 03-14-2007, 03:43 AM
walter You're after them as well? I... 03-14-2007, 04:44 AM
brunog Larry, I know you need to... 03-14-2007, 03:24 AM
lgalla Bruno I have considered the... 03-14-2007, 03:53 AM
brunog How do you intend to secure... 03-14-2007, 06:32 AM
Zumba You can secure the spoilboard... 03-14-2007, 01:53 PM
lgalla Jsage we are not really... 03-14-2007, 04:18 AM
jsage LOL, Cheers Larry, and... 03-14-2007, 04:25 AM
lgalla Walter actually ther has been... 03-14-2007, 04:56 AM
walter Good info. Thank you. 03-14-2007, 05:10 AM
martinw Testing, testing Has the... 03-14-2007, 10:51 PM
martinw Oh dear, oh dear. The zone... 03-15-2007, 11:01 PM
greybeard Yes, for the last twenty... 03-14-2007, 11:04 PM
martinw Dear John, Twenty minutes!... 03-14-2007, 11:25 PM
jsage martinw, Will definitely... 03-14-2007, 11:44 PM
greybeard Martin - your mention of... 03-14-2007, 11:47 PM
Geof Maybe a low density... 03-14-2007, 11:54 PM
lgalla Hi Martin I was out... 03-15-2007, 12:13 AM
martinw Larry, You cannot escape... 03-15-2007, 12:51 AM
lgalla Hey Bruno& Zumba back to the... 03-15-2007, 01:00 AM
ger21 Not necessarily. If you are... 03-15-2007, 01:09 AM
brunog Larry, I have a fridge... 03-15-2007, 09:31 PM
lgalla Right on Gerry,could naw said... 03-15-2007, 01:21 AM
Geof 15 to 20 Kilowatts; and... 03-15-2007, 02:42 AM
ger21 Not as much as our 50HP... 03-15-2007, 01:33 AM
lgalla Martin ,The Zone server... 03-15-2007, 02:29 AM
martinw Dear Larry, I would direct... 03-15-2007, 03:13 AM
lgalla Martin Qu'est-ce qui... 03-15-2007, 04:08 AM
jsage Oh No, Larry is a french... 03-15-2007, 11:55 AM
jsage I feel like that commercials... 03-15-2007, 08:24 PM
martinw Dear Larry, Foreign... 03-16-2007, 12:34 AM
brunog Martin, I like the idea of... 03-15-2007, 09:43 PM
brunog Jsage, Kevlar is an... 03-15-2007, 09:48 PM
lgalla Hay Martin These people run... 03-16-2007, 04:12 AM
jsage Igalla, If it is pvc I... 03-16-2007, 04:37 AM
walter Larry, you can use the... 03-16-2007, 06:24 AM
lgalla Seven of nine resistance is... 03-16-2007, 04:51 AM
lgalla Mopping complete,just have to... 03-16-2007, 05:33 AM
lgalla Martin, News of "new posts"... 03-16-2007, 05:52 AM
jsage Igalla, I figured... 03-16-2007, 06:21 AM
lgalla All alone in the Zone.... 03-16-2007, 06:15 AM
lgalla Larry, you can use the... 03-16-2007, 07:16 AM
svenakela Please address the forum... 03-16-2007, 08:04 AM
jsage I did think it was some... 03-16-2007, 07:26 PM
mhasting2004 Hi Again I never actually... 03-16-2007, 10:27 PM
martinw Dear Mark, Thank-you... 03-17-2007, 01:25 AM
Zumba Thanks for the info, Mark. ... 03-16-2007, 10:23 AM
Zumba Ah, very smart. Makes me... 03-16-2007, 10:39 PM
Zumba Martin, makes sense to me. ... 03-17-2007, 02:51 AM
walter Ok that does sound cool. How... 03-17-2007, 03:43 AM
martinw Dear Walter, I do not do... 03-17-2007, 04:19 AM
Geof I won't shrink, you actually... 03-17-2007, 04:22 AM
walter That black carbon thing... 03-17-2007, 04:34 AM
ger21 Add graphite powder to your ... 03-17-2007, 03:44 AM
Geof I think if you look into a... 03-17-2007, 03:52 AM
ger21 I better stop getting info... 03-17-2007, 03:56 AM
Geof Graphite powder is used in... 03-17-2007, 04:03 AM
jsage Graphite powder can be... 03-17-2007, 04:08 AM
Zumba I definitely do aesthetics. ... 03-17-2007, 05:18 AM
ger21 But you'll still know it's... 03-17-2007, 05:22 AM
jsage I'll take a wild guess and... 03-17-2007, 05:29 AM
Geof The black was probably not... 03-17-2007, 05:35 AM
jsage So how much does the basic... 03-17-2007, 06:13 AM
lgalla I buy carbon... 03-17-2007, 06:35 AM
martinw Dear Larry, I may be quite... 03-17-2007, 03:05 PM
Zumba Jsage, I'm estimating... 03-17-2007, 08:17 AM
jsage Zumba, Thanks, that is... 03-17-2007, 06:09 PM
ger21 We made some cantilevered... 03-17-2007, 03:14 PM
ger21 There was mention of vacuum... 03-17-2007, 03:20 PM
martinw Dear Gerry, I have a small... 03-17-2007, 05:34 PM
ger21 Martin, I've been using a... 03-17-2007, 05:53 PM
martinw Oops! Sorry Gerry. Best... 03-17-2007, 06:26 PM
jsage I was experimenting with key... 03-18-2007, 04:48 AM
lgalla Martin the epoxy gelcoat... 03-18-2007, 06:29 AM
jsage Igalla, I don't know what... 03-18-2007, 08:40 AM
Geof I think isocyanate is the... 03-18-2007, 03:02 PM
ger21 A year or 2 ago I did a lot... 03-18-2007, 03:01 PM
walter For those just joining us,... 03-18-2007, 04:36 PM
lgalla Mike two componet urethanes... 03-18-2007, 04:37 PM
jsage Larry, Works for me. I... 03-19-2007, 02:42 AM
jsage Geof, That's it. The non... 03-19-2007, 03:17 AM
Geof You have it sort of reversed... 03-19-2007, 03:51 AM
jsage Geof, Yes that sounds... 03-19-2007, 03:53 AM
lgalla Hi Mike I cannot find the... 03-19-2007, 04:52 AM
jsage Larry, This is the one.... 03-19-2007, 05:20 AM
lgalla Mike that PDF refers to... 03-19-2007, 05:43 AM
jsage ; ) I never found it... 03-19-2007, 05:52 AM
walter You can buy 3M Zeeospheres... 03-19-2007, 06:18 AM
BobWarfield Wow, 46 pages and counting? ... 03-19-2007, 11:27 PM
walter WilliamD already started some... 03-19-2007, 11:48 PM
martinw Dear Walter, Aesthetics... 03-20-2007, 12:57 AM
Zumba Hey Walter, did you end up... 03-20-2007, 12:47 AM
walter Agreed Martin. Good looks... 03-20-2007, 01:26 AM
Armstrong I have not tried it, but I... 03-20-2007, 03:38 AM
lgalla Walter the carbon black is... 03-20-2007, 04:46 AM
BobWarfield FYI, I did a design sketch... 03-20-2007, 05:02 AM
davo727 Hi, I am filling the base of... 03-20-2007, 09:55 AM
davo727 The frame insert is made from... 03-20-2007, 10:10 AM
walter Whoa, no kidding... I almost... 04-02-2007, 10:08 PM
Zumba What would be a suitable... 03-20-2007, 05:02 AM
walter Great job Davo. 03-20-2007, 04:30 PM
jsage Walter, Thanks for... 03-21-2007, 12:07 AM
brunog Jsage, you must fillet the... 03-22-2007, 12:55 AM
martinw Dear all, OK, I don't do... 03-22-2007, 01:47 AM
davo727 Well I have my R45, 7045 type... 03-22-2007, 04:20 AM
lgalla I have seen some posts... 03-21-2007, 01:36 AM
jsage Igalla, Here's what I'm... 03-21-2007, 03:18 AM
lgalla Mike very ambitious project... 03-21-2007, 04:03 AM
jsage Igalla, I just wanted to... 03-21-2007, 04:06 AM
lgalla Mike you got my attention on... 03-21-2007, 04:26 AM
jsage :cheers: :cheers: Here's... 03-21-2007, 04:33 AM
walter Sounds like a lot of work..... 03-21-2007, 05:11 AM
jsage Curiousity Speaking, Put... 03-21-2007, 05:22 AM
lgalla Mike you posted and edited... 03-21-2007, 04:41 AM
jsage Larry, well i felt like i... 03-21-2007, 04:56 AM
lgalla Mike I am of the group of... 03-21-2007, 05:08 AM
lgalla Since posting in this thread... 03-21-2007, 05:28 AM
walter Yep.... Hanging around those... 03-21-2007, 06:16 AM
brunog I was at a home building show... 03-22-2007, 01:01 AM
lgalla Mike at that accuracy,1/16... 03-21-2007, 05:42 AM
lgalla Ger21&Geof I see you guys... 03-21-2007, 05:56 AM
walter Speaking of countertops..... 03-21-2007, 06:44 AM
jsage Good article, I new they... 03-21-2007, 12:11 PM
lgalla Walter Good you posted the... 03-22-2007, 04:15 AM
romihs Larry, I have found a good... 03-22-2007, 11:20 AM
acitelin Re: Epoxy-Granite machine... 03-16-2017, 09:20 PM
walter I will be buying from them: ... 03-22-2007, 01:55 PM
lgalla Walter The $100 to... 03-22-2007, 05:29 PM
romihs If quartz is stronger, as has... 03-22-2007, 05:42 PM
walter Really? I am surprised... ... 03-22-2007, 08:17 PM
brunog if you are looking for good... 03-22-2007, 06:13 PM
walter This is also very... 03-22-2007, 08:26 PM
brunog Larry, your next door... 03-23-2007, 12:10 AM
davo727 Well, Cosmetically its not... 03-23-2007, 03:43 AM
davo727 Oh one more thing- When the... 03-23-2007, 03:54 AM
ger21 14.7psi 03-23-2007, 12:22 AM
jsage Ok Ger21, You got me, I'm... 03-23-2007, 12:29 AM
martinw Dear jsage, Gerry is spot... 03-23-2007, 12:31 AM
jsage I know he is. I just have 17... 03-23-2007, 12:37 AM
walter Nice work Davo! I think we... 03-23-2007, 04:13 AM
davo727 Thanks Walter. Yeah and... 03-23-2007, 04:20 AM
jsage I don't know if anyone... 03-23-2007, 04:55 AM
lgalla ("Removing entrapped air with... 03-23-2007, 05:18 AM
brunog Larry, You are right there... 03-23-2007, 02:51 PM
romihs Igalla, Are you sure of... 03-24-2007, 12:27 AM
jsage Ah but Sandi, Explain... 03-24-2007, 03:00 AM
romihs Interesting... One learns all... 03-24-2007, 11:10 PM
lgalla Atenman1 I think you posted a... 03-23-2007, 06:21 AM
atenman1 Hi Larry Is this the one ... 03-23-2007, 06:43 AM
lgalla Atenman1 I saw a show on... 03-23-2007, 07:13 AM
the4thseal If they agree i will be buy... 03-23-2007, 07:20 AM
lgalla You must agree US Composites... 03-23-2007, 07:48 AM
lgalla Jsage or mike I realize you... 03-23-2007, 08:02 AM
lgalla WOW I gotta catch a plane to... 03-23-2007, 08:25 AM
greybeard Morning Gentlemen. My... 03-23-2007, 08:51 AM
brunog John, Personally I will be... 03-23-2007, 03:01 PM
greybeard Hi Bruno. I agree that you... 03-23-2007, 08:35 PM
jsage Larry, Have a good trip.... 03-23-2007, 10:19 PM
Zumba Would playsand + epoxy work... 03-24-2007, 11:22 PM
walter Larry, hope you have a good... 03-25-2007, 01:55 AM
davo727 Hey Zumba, The batches I... 03-25-2007, 02:27 AM
Zumba Good info, Davo. I tried... 03-25-2007, 04:19 AM
Zumba Here's a piece of E/S (epoxy... 03-25-2007, 04:39 AM
walter Zumba, that looks pretty... 03-25-2007, 06:10 AM
jsage sposi, Just kidding... 03-25-2007, 06:39 AM
walter I'm trying to chase... 03-25-2007, 08:15 AM
Zumba Good info there, Walter. ... 03-25-2007, 08:45 AM
jsage Tetris, Never really... 03-25-2007, 08:58 AM
Geof I think it is possible you... 03-26-2007, 03:31 AM
jsage Geof, Thanks. I was just... 03-26-2007, 04:00 AM
Geof All low frequency, some... 03-26-2007, 04:16 AM
ger21 I still wouldn't want to be... 03-25-2007, 03:39 PM
Zumba Hmmm... the more I think... 03-25-2007, 08:57 AM
Zumba I was thinking that the... 03-25-2007, 10:59 AM
martinw Dear Zumba, I've been... 03-25-2007, 04:31 PM
RogerH We have a couple of machines... 03-25-2007, 03:41 PM
jsage Zumba, Very nice. I... 03-25-2007, 03:58 PM
walter The beauty is definitely... 03-25-2007, 05:15 PM
martinw Dear Walter, Alas, there... 03-25-2007, 05:27 PM
walter From ITW: About Zanite®... 03-25-2007, 05:37 PM
jsage Zumba, Again great work,... 03-25-2007, 08:14 PM
djshop I am just jumping into this... 03-25-2007, 09:43 PM
walter Dave, good to have you on... 03-25-2007, 11:00 PM
djshop german design 03-26-2007, 03:08 AM
Zumba Testing day! I had four... 03-25-2007, 10:05 PM
merl Hey guys, I can wiegh in here... 03-26-2007, 02:12 AM
djshop I also have a CMS. Mine has a... 03-26-2007, 02:59 AM
lgalla Wow I am away a day and... 03-26-2007, 04:58 AM
jsage Geof, Thanks, it occurs... 03-26-2007, 05:32 AM
walter Well, I dug up another... 03-26-2007, 06:44 AM
jsage Walter, I just did a... 03-26-2007, 06:53 AM
walter I just realized it's totally... 03-26-2007, 07:11 AM
jsage Agreed. We probably... 03-26-2007, 07:36 AM
merl Hey djshop, I hear ya on the... 03-26-2007, 07:15 AM
merl Geof , I just read your post... 03-26-2007, 07:30 AM
ahlbebuck Hi all This is my first... 03-26-2007, 02:56 PM
jsage Ahlebuck, I agree. I... 03-26-2007, 08:13 PM
djshop That is also my intent. My... 03-26-2007, 08:53 PM
Zumba Time.... somewhere in the... 03-26-2007, 09:00 PM
jsage If you really want to go all... 03-26-2007, 10:18 PM
ahlbebuck Zumba Somewhere between... 03-26-2007, 10:26 PM
jsage Albebuck, Thanks for the... 03-26-2007, 11:10 PM
ger21 From what I've read here in... 03-26-2007, 11:14 PM
ahlbebuck Ger21 You're right -... 03-26-2007, 11:31 PM
ger21 That's what they all... 03-26-2007, 11:43 PM
walter You lost me right there. 03-27-2007, 12:08 AM
ahlbebuck Gerry Do I sense a "been... 03-27-2007, 12:00 AM
ahlbebuck Walter Concrete finds its... 03-27-2007, 12:26 AM
walter Ahlbebuck, I must say I... 03-27-2007, 01:50 AM
jsage Walter, I'm sure... 03-27-2007, 04:42 AM
walter I was just getting to that... 03-27-2007, 06:01 AM
lgalla Concrete has a very low... 03-27-2007, 04:33 AM
walter Well, I gave up on concrete... 03-27-2007, 05:31 AM
lgalla Walter, Good job at the... 03-27-2007, 05:35 AM
lgalla Walter As usual you... 03-27-2007, 05:50 AM
ahlbebuck Walter To avoid the voids... 03-27-2007, 06:05 AM
lgalla Neil thanks for joining the... 03-27-2007, 06:24 AM
ahlbebuck Larry I would seal the... 03-27-2007, 07:04 AM
jsage Hilarious. I usually pick up... 03-27-2007, 07:23 AM
ahlbebuck JSAGE Aggregate sizing is... 03-27-2007, 08:06 AM
jsage Wow thanks albebuck. You... 03-27-2007, 08:43 AM
Zumba In my application, the mix... 03-27-2007, 08:50 AM
Zumba Oh and here's another... 03-27-2007, 09:01 AM
ger21 Cap one end and use vacuum? 03-27-2007, 12:29 PM
Zumba Will the bubbles from 5 feet... 03-27-2007, 09:55 PM
ahlbebuck JSAGE With all the modern... 03-27-2007, 09:39 AM
walter What about sand with 99.5%... 03-27-2007, 03:00 PM
ahlbebuck Walter Quartz is perfect -... 03-27-2007, 03:29 PM
ger21 Pour in a foot at a time,... 03-28-2007, 12:31 AM
lgalla Zumba reply to"Whaddaythink"I... 03-28-2007, 06:20 AM
lgalla Neil good to have a concrete... 03-28-2007, 06:55 AM
lgalla Wow 1 day without a post.I... 03-30-2007, 02:31 AM
walter So today I decided to hit the... 03-30-2007, 03:33 AM
lgalla Walter welcome to sand buyers... 03-30-2007, 04:03 AM
walter Larry, I got the stuff down.... 03-30-2007, 04:28 AM
Geof The mind boggles at what... 03-30-2007, 04:32 AM
yugami Where did you find a... 04-01-2007, 04:40 AM
walter You need to visit your local... 04-01-2007, 06:08 AM
yugami Thanks, I had just run into... 04-01-2007, 06:14 AM
walter http://img249.imageshack.us/im... 03-30-2007, 04:44 AM
lgalla Geof good point.This stuff is... 03-30-2007, 04:52 AM
Geof Is it an explosion hazard... 03-30-2007, 04:55 AM
lgalla Geof,an un-researched reply... 03-30-2007, 05:07 AM
Geof I went Googling. Pure... 03-30-2007, 05:14 AM
walter Good info. Thank you. 03-30-2007, 05:17 AM
lgalla Everything is dangerous in... 03-30-2007, 05:38 AM
Eson I wonder if epoxy resin... 03-30-2007, 11:00 PM
ericdwilso I went to my local landscape... 04-01-2007, 05:03 AM
Mike Mattera I used to work for Hermle... 04-01-2007, 03:29 PM
lgalla Eric pea gravel is smooth and... 04-02-2007, 04:08 AM
romihs Some testing... 04-02-2007, 01:10 PM
brunog Sandi, Nice Work!! Are... 04-02-2007, 05:02 PM
romihs Thanks for the complements... 04-02-2007, 09:54 PM
walter Good stuff Sandi! Thanks for... 04-02-2007, 04:29 PM
pupa Hi Very interesting Thread.... 04-02-2007, 11:20 PM
lgalla Hi Sandy,good work.I assume... 04-03-2007, 02:57 AM
romihs Hi Larry, Actually, I am... 04-03-2007, 09:00 AM
pupa Actually the butkicker... 04-03-2007, 09:57 AM
brunog Sandi, I have checked your... 04-03-2007, 02:58 AM
romihs Hi Bruno, Thanks for the... 04-03-2007, 09:20 AM
lgalla Vibrating the test mixes the... 04-03-2007, 04:15 PM
pupa I suggest vibrating the... 04-03-2007, 04:59 PM
walter Guys, what about press... 04-03-2007, 05:20 PM
romihs Walter, I have thought of... 04-03-2007, 06:25 PM
martinw Dear Walter, IMVVVHO, I... 04-03-2007, 06:39 PM
romihs Larry, I agree, the dry... 04-03-2007, 05:11 PM
wjfiles I use epoxy's for... 04-04-2007, 12:09 AM
walter Thanks Martin, I enjoyed that... 04-04-2007, 02:29 AM
pupa Strength read the document... 04-04-2007, 05:38 PM
walter Thanks, I appreciate the... 04-04-2007, 06:54 PM
Eson I belive that less epoxy... 04-04-2007, 07:25 PM
pupa Pleasure is mine, here is... 04-04-2007, 07:25 PM
lgalla Sandi your Quartz Cookies... 04-04-2007, 03:48 AM
romihs Larry, Thanks for the... 04-04-2007, 09:57 AM
lgalla (flame2) Heat.Flame is for... 04-04-2007, 04:23 AM
walter Larry, post #631 04-04-2007, 04:44 AM
walter I think the concrete info is... 04-04-2007, 04:57 AM
lgalla Thanks Walt. A quick pass... 04-04-2007, 05:06 AM
lgalla Walter I like the concrete... 04-04-2007, 05:31 AM
Zumba Hey dudes, I did a cure... 04-04-2007, 02:36 PM
romihs Zumba, Probably due to a... 04-04-2007, 04:05 PM
pupa Sandi just read through the... 04-04-2007, 05:52 PM
Zumba By the way... are you guys... 04-04-2007, 02:51 PM
LeeWay Why not just attach something... 04-04-2007, 02:56 PM
Zumba That would work depending on... 04-04-2007, 03:03 PM
LeeWay I don't know. I have a Ridgid... 04-04-2007, 03:24 PM
pupa 200-305 Hz seems to be the... 04-04-2007, 05:25 PM
ericdwilso You can get pneumatic... 04-05-2007, 12:32 AM
Zumba Using an eccetric disc on a... 04-04-2007, 02:58 PM
brunog Zumba, I believe you are... 04-04-2007, 03:50 PM
lgalla We should clear up the... 04-04-2007, 05:37 PM
pupa Thats is for some units. In... 04-04-2007, 05:42 PM
pupa Here is another article of a... 04-04-2007, 05:45 PM
lgalla Some very thin epoxies... 04-04-2007, 06:11 PM
Zumba Walter, I think you're spot... 04-04-2007, 09:57 PM
LeeWay Part of the strength you get... 04-04-2007, 10:34 PM
walter Check out the rebar "cage" in... 04-04-2007, 11:48 PM
Zumba As to the the thermal issue,... 04-04-2007, 10:05 PM
lgalla Which is better?A5to10% epoxy... 04-05-2007, 03:54 AM
LeeWay Rebar would still add... 04-05-2007, 04:27 AM
Stepper Monkey In using epoxies for... 04-05-2007, 07:09 AM
martinw Dear Stepper Monkey, ... 04-05-2007, 02:56 PM
brunog Martin, slow curing epoxy... 04-05-2007, 03:47 PM
Stepper Monkey It doesn't pool, it is... 04-05-2007, 05:06 PM
martinw Dear Stepper Monkey, ... 04-05-2007, 05:45 PM
lgalla No doubt rebar will add... 04-05-2007, 04:36 AM
lgalla Walter always gives strength... 04-05-2007, 05:57 AM
lgalla Hi Stepper. Do... 04-05-2007, 05:33 PM
lgalla Hay Martin. ... 04-05-2007, 05:59 PM
fyffe555 Martin, don't worry , you're... 04-05-2007, 06:15 PM
martinw Dear fyffe555, Thanks for... 04-05-2007, 06:25 PM
ger21 How do you keep the bag from... 04-05-2007, 06:32 PM
lgalla Andrew thanks for the... 04-05-2007, 06:35 PM
lgalla Gerry How do you keep the... 04-05-2007, 06:42 PM
martinw Dear Larry, But if the mix... 04-05-2007, 06:51 PM
brunog This link might help us... 04-05-2007, 08:29 PM
Stepper Monkey I dont have any clue about... 04-05-2007, 10:27 PM
martinw Dear fyffe555 and Stepper... 04-05-2007, 10:54 PM
lgalla I don't see useing Vacuum bag... 04-06-2007, 03:31 AM
lgalla In a previous life I... 04-06-2007, 04:51 AM
Zumba Now that this thread has... 04-06-2007, 03:14 PM
BobWarfield Geez guys, as Zumba says,... 04-06-2007, 04:15 PM
walter From one of the links on page... 04-07-2007, 05:29 PM
davo727 Pic of practical application... 04-07-2007, 07:13 PM
speed33317 Results of my experiment 04-07-2007, 07:17 PM
martinw Dear Walter, Any chance of... 04-07-2007, 11:03 PM
lgalla Good posts Bob&Zumba. Bob... 04-06-2007, 06:09 PM
brunog Larry, I still believe that... 04-06-2007, 08:41 PM
speed33317 Hi, Jumping in on this... 04-06-2007, 11:49 PM
walter Bruno, The mix was... 04-10-2007, 04:50 AM
lgalla Zumba,Bob,Bruno I agree this... 04-07-2007, 05:57 AM
brunog Larry, Don't feel bad about... 04-07-2007, 02:57 PM
Zumba I actually have no problem... 04-07-2007, 10:53 AM
LeeWay I have seen this type used on... 04-07-2007, 11:48 AM
brunog Zumba, Vertical vibration is... 04-07-2007, 03:04 PM
martinw Dear Zumba, I mentioned RC... 04-07-2007, 10:28 PM
lgalla Hi,my name is Galellio.I know... 04-08-2007, 03:45 AM
Geof Epoxy poured out and allowed... 04-08-2007, 03:56 AM
martinw Geof, The problem is that... 04-08-2007, 05:38 AM
lgalla Right on Galo. Epoxy surface... 04-08-2007, 03:57 AM
Zumba The main problem I had when... 04-08-2007, 04:54 AM
lgalla your castings should be done... 04-08-2007, 05:31 AM
Zumba "Alas, we live in an... 04-08-2007, 05:45 AM
lgalla Math is a bad subject for... 04-08-2007, 06:03 AM
walter Spacecraft docking and... 04-08-2007, 06:16 AM
lgalla Walter WOW who could argue... 04-08-2007, 06:20 AM
lgalla walter I'm so excited, And... 04-08-2007, 06:33 AM
Geof In the context of flat... 04-08-2007, 03:17 PM
walter ... We’re here to... 04-08-2007, 07:18 AM
lgalla Martin is .003 over 16ft good... 04-08-2007, 07:21 AM
lgalla Walter nice E/G planter.Gives... 04-08-2007, 07:47 AM
walter Ok, I’m locking myself in the... 04-09-2007, 01:17 AM
gt3073b A twist on vacuum bagging... 04-09-2007, 01:53 AM
ger21 Earlier thoughts on this... 04-09-2007, 02:18 AM
lgalla The vacuum infusion process... 04-09-2007, 04:09 AM
walter Larry, how about this: 5... 04-09-2007, 04:15 AM
walter Or this: HANDHELD CONCRETE... 04-09-2007, 04:18 AM
brunog Nice item Walter, The good... 04-10-2007, 12:52 AM
lgalla Walter I like the concrete... 04-09-2007, 04:37 AM
walter I'm still in the lab,... 04-09-2007, 06:05 AM
lgalla Walter lookin good. I... 04-09-2007, 06:31 AM
lgalla Walter don't remember if... 04-09-2007, 06:59 AM
brunog Walter, Nice work, I am... 04-09-2007, 05:25 PM
lgalla Here is something I found... 04-10-2007, 04:12 AM
walter Wow, pretty incredible! ... 04-10-2007, 04:57 AM
Geof Spinning... 04-10-2007, 05:07 AM
Switcher Walter, Nice work! Did... 04-10-2007, 05:27 AM
lgalla Walter calm down,looks like... 04-10-2007, 04:56 AM
lgalla Walter WOW are those pictures... 04-10-2007, 05:20 AM
walter Heh! Larry.. I'd love to see... 04-10-2007, 05:42 AM
lgalla Geof "Not at all related to... 04-10-2007, 05:53 AM
lgalla Walter,Walter,Walter,Good to... 04-10-2007, 06:13 AM
walter You know.. I think I really... 04-10-2007, 07:14 AM
Zumba Hey Walter, is your 1/8" ESP... 04-10-2007, 01:43 PM
walter Thanks! It's pure 1/8"... 04-10-2007, 03:08 PM
brunog Walter, Beautiful work!... 04-10-2007, 03:48 PM
walter New pics. The top is gone... 04-10-2007, 03:55 PM
walter Thanks Bruno! I appreciate... 04-10-2007, 03:58 PM
romihs Walter, Really good job... 04-10-2007, 05:09 PM
fyffe555 Just a thought but has any of... 04-10-2007, 05:48 PM
lgalla Walter Good stuff. Trying to... 04-10-2007, 06:14 PM
lgalla Fyffe555 Check... 04-10-2007, 06:33 PM
walter Thanks Sandi. I hope you guys... 04-10-2007, 08:29 PM
speed33317 Pics of my polymer castings. 04-10-2007, 09:36 PM
romihs Speed, Thanks for the... 04-11-2007, 08:52 AM
Switcher Have you guys done any... 04-10-2007, 10:20 PM
speed33317 My black sample weighs more... 04-10-2007, 10:34 PM
max_imum2000 can u also test its thermal... 04-10-2007, 10:57 PM
romihs The testing continues... 04-11-2007, 08:33 AM
walter Guys, Very nice samples.... 04-11-2007, 08:50 AM
brunog Nice work Sandi, What... 04-11-2007, 04:08 PM
romihs Third Round Results 04-11-2007, 11:12 PM
romihs Max, Most epoxies are... 04-11-2007, 08:43 AM
Mcgyver Sandi, thanks for the work... 04-11-2007, 01:10 PM
speed33317 Before I do my destructive... 04-12-2007, 03:05 AM
lgalla More reading Question :... 04-12-2007, 04:29 AM
lgalla Sandi "I noticed that the... 04-12-2007, 04:53 AM
romihs Larry, Good point! Hmmm...... 04-12-2007, 07:34 AM
lgalla Walter,Sandi,Speed,are locked... 04-13-2007, 06:04 AM
romihs Larry, Yes, it kind of got... 04-13-2007, 08:57 AM
brunog Larry, the pdf is very... 04-13-2007, 02:48 PM
WilliamD What wax are you guys using... 04-13-2007, 04:41 PM
romihs William, Until now I have... 04-13-2007, 09:43 PM
WilliamD Thanks for the info! I will... 04-13-2007, 10:01 PM
speed33317 Ok its been a week since I... 04-14-2007, 12:22 AM
martinw 1/4 inch in 20 feet 04-15-2007, 05:21 PM
walter Martin, good to see you... 04-15-2007, 10:11 PM
speed33317 Not So Scientific Testing... 04-15-2007, 10:49 PM
max_imum2000 i have read this thread from... 04-15-2007, 11:19 PM
walter "Houston, we have a... 04-15-2007, 10:39 PM
Geof Did it come back or stay bent? 04-15-2007, 11:54 PM
walter It did not. 1. The... 04-16-2007, 12:36 AM
brunog Walter, Is it really a... 04-16-2007, 12:43 AM
martinw Dear Bruno, You are bang... 04-16-2007, 01:11 AM
Geof Walter keep the fragments,... 04-16-2007, 01:16 AM
brunog Walter, If the product is... 04-16-2007, 12:50 AM
walter Good ideas. Thank you! 04-16-2007, 01:22 AM
speed33317 Here is another thought. ... 04-16-2007, 02:47 AM
eloid have a quick question, sorry... 04-23-2007, 02:43 AM
ckelloug Eloid, I'm the thread's... 04-23-2007, 03:00 AM
ckelloug We Need Carbon Black and Some... 04-23-2007, 05:22 AM
eloid [QUOTE=ckelloug;288983]Eloid,... 04-26-2007, 10:46 PM
lgalla Yes the thread is to big or... 04-23-2007, 03:06 AM
lgalla Progress! We need to compair... 04-16-2007, 04:04 AM
walter Max, I appreciate the... 04-16-2007, 04:28 AM
speed33317 My light sand is Pavestone... 04-16-2007, 04:49 AM
lgalla Walter is your blue sample... 04-16-2007, 05:05 AM
lgalla Speed33317 SLOWDOWN grab a... 04-16-2007, 05:21 AM
walter Zeeospheres only, Larry. ... 04-16-2007, 05:25 AM
lgalla Walter,you know the benifets... 04-16-2007, 05:50 AM
greybeard If you have a uniform filler... 04-16-2007, 09:19 AM
Geof Not by Pye, authored by J. E.... 04-16-2007, 08:34 PM
greybeard Geoff you beat me to it.... 04-16-2007, 08:44 PM
Geof Slightly younger grey cells... 04-16-2007, 08:53 PM
hansa WTF are you guys making??? :O... 04-16-2007, 04:16 PM
lgalla WTF are you guys making??? :O... 04-16-2007, 06:33 PM
walter Larry's right. Here are the... 04-16-2007, 06:46 PM
greybeard Geoff - if it's in front of... 04-16-2007, 09:15 PM
ger21 A few years ago, while on... 04-16-2007, 09:52 PM
Geof You mean page 165 in the... 04-16-2007, 10:21 PM
greybeard I had at the back of my mind... 04-16-2007, 10:29 PM
Geof Okay I read in a bit more... 04-16-2007, 10:47 PM
lgalla RELATIONSHIPS OF CONCRETE... 04-17-2007, 12:04 AM
brunog Larry, Read the report on my... 04-17-2007, 12:35 AM
martinw Dear Larry, Given my... 04-17-2007, 12:55 AM
brunog Check this one out... 04-17-2007, 12:27 AM
lgalla Martin the point is on my... 04-17-2007, 01:20 AM
martinw Dude, Best wishes Martin 04-17-2007, 01:31 AM
lgalla Martin forgot to ask you.Did... 04-17-2007, 01:40 AM
martinw Dear Larry, Will do, but... 04-17-2007, 02:02 AM
lgalla Victrof epoxy/granite has... 04-17-2007, 02:24 AM
ckelloug Newbie on The Thread with... 04-17-2007, 03:25 AM
LeeWay This thread has been... 04-17-2007, 11:50 AM
romihs LeeWay, I ordered my Epoxy... 04-17-2007, 04:57 PM
walter Awesome post Cameron! We... 04-17-2007, 03:51 PM
LeeWay Thanks a bunch, Walter. Here... 04-17-2007, 04:47 PM
lgalla Welcome Cameron and thank you... 04-17-2007, 04:53 PM
ckelloug The thread about Harlow and... 04-17-2007, 06:52 PM
lgalla Lee make sure you get the 635... 04-17-2007, 05:10 PM
walter Ok, here's something new. The... 04-17-2007, 06:16 PM
lgalla Walter have you tried heating... 04-17-2007, 07:22 PM
ckelloug Pardon me for stupid questions 04-17-2007, 07:44 PM
walter I'd say 4ft for unsupported... 04-17-2007, 09:14 PM
romihs Hi all, I agree with Larry... 04-17-2007, 10:27 PM
LeeWay I agree in theory with what... 04-17-2007, 11:15 PM
romihs Lee, I understand what... 04-18-2007, 12:08 AM
ckelloug Material amount in Beam makes... 04-18-2007, 01:15 AM
brunog Sandi, There a many ways of... 04-18-2007, 01:14 AM
romihs Hi Bruno, Yes, you have a... 04-18-2007, 09:05 AM
romihs My build plans 04-18-2007, 09:37 AM
LeeWay My first intended use is... 04-18-2007, 01:46 PM
lgalla Bruno good post my agree... 04-18-2007, 04:40 AM
lgalla Guys some of the engineering... 04-18-2007, 05:04 AM
lgalla Since I made the suggestion... 04-18-2007, 06:03 AM
brunog Larry, I saw all 3 pdf's: ... 04-18-2007, 04:28 PM
brunog My project is fixed gantry... 04-18-2007, 04:43 PM
brunog Bob, C'est quoi ça FEA??? ... 04-18-2007, 04:45 PM
turmite finite element analysis ... 04-18-2007, 05:47 PM
lgalla Good to hear what you guys... 04-18-2007, 05:48 PM
fyffe555 Hey Larry - we did this ages... 04-19-2007, 03:54 PM
Geof But if you are building a... 04-19-2007, 04:16 PM
fyffe555 Now there's a good idea.... ... 04-19-2007, 09:07 PM
lgalla Thanks Andrew. The question... 04-19-2007, 05:14 PM
fyffe555 Twisting forces are somewhat... 04-19-2007, 09:05 PM
martinw Dear Andrew, I hope I... 04-19-2007, 11:50 PM
fyffe555 Mostly correct - but the E/G... 04-20-2007, 02:12 AM
martinw [QUOTE=fyffe555;287890]Mostly... 04-20-2007, 02:27 AM
lgalla :confused: :confused:... 04-19-2007, 11:36 PM
lgalla I think I got it. You would... 04-20-2007, 02:53 AM
ckelloug Found this on "Dynamic... 04-20-2007, 03:25 AM
lgalla Finally nice epoxy curing... 04-23-2007, 02:18 AM
lgalla Thank you for contacting us... 04-23-2007, 03:33 AM
brunog Cameroun, do you have any... 04-23-2007, 03:34 PM
brunog Cameroun, Is there a... 04-23-2007, 04:44 PM
lgalla Walter ,quote"I used the... 04-23-2007, 04:59 PM
ckelloug Brunog Here is a web site... 04-23-2007, 06:39 PM
ckelloug Igalla, Whacking it with a... 04-23-2007, 06:45 PM
lgalla WilliamD on the sister thread... 04-23-2007, 06:03 PM
lgalla WilliamD is bashing E/G with... 04-24-2007, 03:08 AM
romihs Hello all, The 8% mix was... 04-24-2007, 08:32 AM
ckelloug Cabot Carbon Black 04-24-2007, 03:04 PM
lgalla Cameron thanks for your... 04-24-2007, 05:48 PM
ckelloug I am beginning to think that... 04-24-2007, 06:20 PM
romihs Larry, The epoxy I use (I... 04-24-2007, 11:27 PM
brunog adjustable vibrating motor... 04-24-2007, 08:12 PM
brunog adjustable vibrating motor... 04-24-2007, 08:23 PM
lerman I would be concerned about... 04-24-2007, 09:02 PM
jkeyser14 Has anyone considered using... 04-24-2007, 09:09 PM
Geof This was suggested back in... 04-25-2007, 04:05 AM
jkeyser14 Ah, yeah, I missed it. It... 04-25-2007, 04:30 AM
ckelloug Compressive Testing Costs:... 04-25-2007, 05:54 PM
greybeard Bathroom scales ? John 04-25-2007, 09:58 PM
martinw Dear Cameron, For a supply... 04-25-2007, 11:40 PM
Geof This assumes you have a... 04-26-2007, 12:45 AM
walter Looking good Bruno! That... 04-24-2007, 10:27 PM
ckelloug Reply to Walter and an idea... 04-25-2007, 12:28 AM
martinw Dear Cameron, 1) Rebars... 04-25-2007, 04:41 AM
ckelloug On point 1 In strength terms... 04-25-2007, 05:38 AM
lgalla Sandi,WOW I have never heard... 04-25-2007, 03:51 AM
walter Broke the hammer crackin'... 04-25-2007, 07:06 AM
walter Did I say walnuts?! I... 04-25-2007, 07:21 AM
lgalla John,allrocks are not created... 04-25-2007, 04:44 AM
lgalla Cameron here is something to... 04-25-2007, 05:23 AM
lgalla Cameron I can't speak for the... 04-25-2007, 05:57 AM
ckelloug Layman's Explanation of... 04-25-2007, 06:57 AM
lgalla Cameron quote: "P.S. I... 04-26-2007, 05:32 AM
VoxLimbo What sources. 04-26-2007, 02:50 PM
ckelloug Small Particles and... 04-26-2007, 06:54 PM
walter Thanks Cameron, much... 04-26-2007, 07:47 PM
ckelloug Shopmaninc/US Composites Epoxy 04-26-2007, 10:33 PM
walter In another words, a home... 04-27-2007, 01:23 AM
ckelloug Beamer Applet 04-27-2007, 05:23 AM
lgalla Here is a few pics Atenman1... 04-26-2007, 05:30 PM
walter Now that's a speaker system! 04-26-2007, 06:10 PM
lgalla Quote: This raises the... 04-27-2007, 05:15 AM
brunog Sell the house! 04-27-2007, 05:34 AM
lgalla Wow Cameron you sure have a... 04-27-2007, 06:15 AM
lgalla This is a private message for... 04-27-2007, 07:09 AM
ckelloug US Composites Epoxy 04-27-2007, 08:25 PM
lgalla Hay Cameron I posted this pdf... 04-28-2007, 05:10 AM
walter Taking Larry's advice on... 04-28-2007, 03:06 PM
ckelloug Quick reply to larry and... 04-28-2007, 03:55 PM
walter Ok, done testing. ... 04-28-2007, 03:55 PM
lgalla Cameron the fibers were 6mm.... 04-28-2007, 06:31 PM
ckelloug Larry, The fibers were 6mm... 04-28-2007, 07:10 PM
walter Moving on to the next... 04-28-2007, 08:19 PM
lgalla Walter, you are beaming?? 04-29-2007, 03:29 AM
walter Hey where did you get that... 04-29-2007, 03:52 AM
lgalla Cameron I am not a... 04-29-2007, 04:14 AM
ckelloug Cobalt(III) AcetylAcetonate 04-29-2007, 04:46 AM
lgalla FED/EX will take Hazmat... 04-29-2007, 05:13 AM
ckelloug Checking the MSDS on anything... 04-29-2007, 05:32 AM
ckelloug Rule of mixtures 04-29-2007, 06:48 AM
walter See, that's why I threw out... 04-29-2007, 11:44 PM
lgalla I am on a Hazmat roll.... 04-29-2007, 06:17 AM
lgalla MSDS roll, While on the MSDS... 04-29-2007, 06:46 AM
lgalla NO more MSDS searching for... 04-29-2007, 07:16 AM
lgalla Cameron, has it been... 04-30-2007, 06:06 AM
ckelloug Larry, The rule of... 04-30-2007, 07:06 AM
walter Heh, good stuff! But.. I... 04-30-2007, 03:59 PM
ckelloug Walter, What the math can... 04-30-2007, 04:30 PM
brunog Cameroun, Larger size... 04-30-2007, 09:15 PM
brunog Cameroun, Please download... 04-30-2007, 09:44 PM
ckelloug brunog, Is there anything... 04-30-2007, 09:49 PM
ckelloug Comapring Articles and... 05-01-2007, 03:42 AM
brunog Cameron, You'll probably... 05-01-2007, 12:50 AM
lgalla Silane coupling agents are... 05-01-2007, 04:52 AM
lgalla Exodic additives enhance... 05-01-2007, 05:31 AM
brunog I just finished reading on... 05-01-2007, 03:14 PM
walter I could use a bonding agent..... 05-01-2007, 08:05 PM
brunog Here is more info on Silane... 05-01-2007, 03:42 PM
brunog And the MSDS sheets for... 05-01-2007, 04:10 PM
lgalla Here is a comparison of some... 05-01-2007, 06:39 PM
ckelloug Curing Misinformation I spread 05-01-2007, 09:06 PM
walter I've got 2 samples with 60%... 05-01-2007, 09:48 PM
ckelloug What kind of testing... 05-01-2007, 11:38 PM
walter What others suggested:... 05-02-2007, 12:05 AM
Zumba Walter, any details on the... 05-02-2007, 01:58 AM
brunog Guys, I found all my... 05-02-2007, 02:01 AM
ckelloug Bruno, Please make sure to... 05-02-2007, 03:41 AM
brunog Cameron, I still need to... 05-02-2007, 03:55 AM
ckelloug Zumba, Can you elaborate... 05-02-2007, 03:58 AM
lgalla Bruno US Composites is still... 05-02-2007, 04:12 AM
Zumba Cameron, A belleville... 05-02-2007, 04:23 AM
walter Thanks Zumba, that is pretty... 05-02-2007, 05:11 AM
BobWarfield Try McMaster-Carr. They're... 05-02-2007, 03:17 PM
ckelloug Old Business and Welcome... 05-02-2007, 06:38 PM
lgalla Bruno a Canadian epoxy... 05-02-2007, 05:13 AM
lgalla Turbulant mixers. Turbulant... 05-02-2007, 05:57 AM
brunog Larry, Couldn't turbulent... 05-02-2007, 03:17 PM
lgalla Sorry Bruno, I... 05-02-2007, 01:34 PM
brunog Thanks for the info Larry. ... 05-02-2007, 02:23 PM
DAK3333 Hello, All I have finally... 05-02-2007, 04:41 PM
walter Thank you for joining the... 05-02-2007, 06:37 PM
thkoutsidthebox I just finished the first 40... 05-04-2007, 02:32 PM
lgalla Yes Bruno turbulent mixers... 05-02-2007, 04:45 PM
DAK3333 Qustion about Vibration... 05-02-2007, 05:07 PM
lgalla I really don't know,but to... 05-02-2007, 05:14 PM
brunog Making a single pure quartz... 05-02-2007, 05:19 PM
davo727 Hey, when yall gonna build... 05-02-2007, 06:35 PM
BobWarfield Now that's funny after over... 05-03-2007, 04:27 AM
walter Good to see you Davo! ... 05-02-2007, 07:05 PM
davo727 Hi Walter, It should be back... 05-02-2007, 08:58 PM
walter Thanks for the pictures Davo... 05-02-2007, 10:31 PM
davo727 My R45 mill is getting me... 05-03-2007, 02:34 AM
ckelloug Measuring material properties... 05-03-2007, 02:57 AM
DAK3333 CKelloug and all, 1. Load... 05-03-2007, 03:20 PM
brunog Bob, I personally don't want... 05-03-2007, 03:25 PM
BobWarfield Bruno, I'll trouble you no... 05-03-2007, 04:03 PM
walter I love when Bob gets steamed... 05-03-2007, 04:59 PM
davo727 Hi, Ckelloug - Very good... 05-03-2007, 05:11 PM
davo727 A question: Do you all think... 05-03-2007, 05:44 PM
ckelloug Don't get discouraged 05-03-2007, 08:15 PM
mholden I am sorry if this has been... 05-03-2007, 10:40 PM
walter Hello and welcome to the... 05-04-2007, 01:01 AM
hotponyshoes I do a lot of work with... 05-04-2007, 08:26 AM
ckelloug Welcome hotponyshoes and... 05-04-2007, 09:22 AM
Stepper Monkey Hey all, I just got a big... 05-04-2007, 11:55 AM
DAK3333 It is time to pass out credit 05-04-2007, 04:39 PM
ckelloug Thanks dak3333 and histrogram... 05-04-2007, 05:55 PM
walter Now that's what I call hard... 05-04-2007, 06:31 PM
ckelloug Designing a Machine with E/G... 05-05-2007, 01:11 AM
walter http://img132.imageshack.us/im... 05-05-2007, 03:40 AM
brunog Eat system epoxy 9482 05-05-2007, 04:30 AM
ckelloug I don't think they're... 05-05-2007, 05:18 AM
ckelloug An answer you didn't ask for... 05-05-2007, 06:23 AM
brunog Cameron, great post! ... 05-05-2007, 04:40 AM
walter Sorry for the delay. I... 05-05-2007, 11:25 PM
martinw Dear Walter, This is a... 05-05-2007, 11:57 PM
Geof You are wearing a face shield... 05-06-2007, 12:05 AM
ckelloug Saving Walter's Life 05-06-2007, 12:24 AM
harryn LOL - approaching vice limit,... 05-06-2007, 01:12 AM
walter Thanks guys, comments and... 05-06-2007, 01:23 AM
walter ` I should probably add that... 05-06-2007, 01:54 AM
martinw Dear Walter, Those samples... 05-06-2007, 03:01 AM
SORCHEROR you guys are forgeting one... 05-06-2007, 03:10 AM
SORCHEROR one more thing,most your mixs... 05-06-2007, 03:11 AM
SORCHEROR if your going for less epoxy... 05-06-2007, 03:17 AM
walter Thanks Martin, that is a good... 05-06-2007, 04:56 AM
ckelloug Howdy there Sorcheror . ... 05-06-2007, 05:36 AM
martinw Dear Cameron, That article... 05-06-2007, 06:14 PM
martinw [QUOTE=martinw;294322]That... 05-06-2007, 07:19 PM
walter Here are the numbers. -... 05-06-2007, 05:31 PM
walter http://img115.imageshack.us/im... 05-06-2007, 08:38 PM
walter Quoting the famous actor: ... 05-06-2007, 09:00 PM
martinw Dear Walter, His samples... 05-06-2007, 10:04 PM
greybeard It's the possibility of... 05-06-2007, 09:45 PM
walter I know what you mean... ... 05-06-2007, 10:01 PM
ckelloug Paper from Reichhold Apps... 05-07-2007, 02:08 PM
walter Thanks Martin! btw, what a... 05-06-2007, 10:15 PM
martinw Dear Walter, Let me... 05-06-2007, 10:23 PM
walter Heh..:D 05-06-2007, 10:29 PM
martinw .....and the people about to... 05-06-2007, 10:39 PM
walter commercial manufacturers of... 05-07-2007, 12:41 AM
ckelloug Trouble mixing epoxy? 05-07-2007, 04:33 AM
walter Crap, I've been washing that... 05-07-2007, 04:52 AM
djshop thinner 05-07-2007, 02:52 PM
martinw epoxy clean-up 05-07-2007, 05:13 PM
lgalla Walter con grats.No time to... 05-07-2007, 06:39 AM
brunog Nice works Walter, I was... 05-07-2007, 11:56 AM
ckelloug Answers for greybeard and... 05-07-2007, 01:54 PM
walter Bruno, I will definitely... 05-07-2007, 02:28 PM
brunog Walter, Take a look a your... 05-07-2007, 11:27 PM
brunog Cameron, That PDF file from... 05-07-2007, 11:32 PM
ckelloug Bruno, How does the... 05-07-2007, 11:39 PM
speed33317 Vibrators :-) 05-08-2007, 01:54 AM
ckelloug Walter's Test Results finally... 05-08-2007, 02:32 AM
brunog Cameron, Here are the... 05-08-2007, 03:28 AM
brunog Sorry Cameron, Here is a... 05-08-2007, 03:38 AM
walter I'm not sure how many turns,... 05-08-2007, 03:54 AM
lgalla Upon reviewing past... 05-08-2007, 04:50 AM
ckelloug Acknowledging calculating... 05-08-2007, 12:55 PM
walter Thanks for doing the... 05-08-2007, 01:27 PM
fyffe555 haven't been following the... 05-08-2007, 04:02 PM
ckelloug Fyffe555, Thank you... 05-08-2007, 08:34 PM
walter Awesome post Andrew. ... 05-09-2007, 01:00 AM
ckelloug Walter, Can you post what... 05-09-2007, 03:15 AM
lgalla Un qualified observations: I... 05-09-2007, 05:24 AM
walter Dear Cameron, Some tips on... 05-09-2007, 05:37 AM
walter Lol.. Larry. Your new avatar... 05-09-2007, 05:54 AM
lgalla Walter,actually the picture... 05-09-2007, 06:27 AM
walter I dug out your old... 05-09-2007, 06:57 AM
ImanCarrot My machine has a granite... 05-09-2007, 09:13 AM
ckelloug New Aggregate Theory 05-09-2007, 12:43 PM
walter Ok, I found it... I found... 05-09-2007, 02:56 PM
martinw Dear Cameron, It was... 05-09-2007, 06:56 PM
harryn Fibers in the mixture 05-09-2007, 09:51 PM
walter Cameron, Thank you for all... 05-09-2007, 04:32 PM
ckelloug Buying sand analyzed to be... 05-09-2007, 06:13 PM
ckelloug Searching for materials. 05-09-2007, 06:17 PM
walter I think we're EXTREMELY CLOSE... 05-11-2007, 10:42 PM
brunog walter, feel free to post... 05-09-2007, 05:42 PM
walter Hi, This is the rough... 06-03-2007, 12:25 AM
ckelloug Wow, walter, This looks... 06-03-2007, 02:28 AM
Udayan Patel Hi !! Folks, I have just... 05-10-2007, 07:54 AM
greybeard Let me be the first to... 05-10-2007, 10:16 AM
ImanCarrot Welcome Udayan! This is... 05-10-2007, 04:31 PM
Udayan Patel Yes, I reckon this is by far... 05-11-2007, 04:26 AM
walter That gives me an idea... ... 05-11-2007, 05:04 AM
uhrgerat Hi John, I was wondering... 05-10-2007, 07:00 PM
greybeard Hi Jim. If my reading of the... 05-10-2007, 09:56 PM
walter Iman, great to have you on... 05-10-2007, 06:52 PM
greybeard Walter, I'm gettimg a bit... 05-10-2007, 10:07 PM
ckelloug Two things in our favor on... 05-10-2007, 11:39 PM
greybeard Thanks c for the posting.... 05-11-2007, 09:13 AM
ckelloug John, I think Larry... 05-11-2007, 01:09 PM
fyffe555 Pragmatic; (ADJ) to deal with... 05-14-2007, 03:12 PM
AkvaCNC E/G Core 05-11-2007, 04:08 PM
harryn Mixing 05-11-2007, 04:41 PM
walter Looks like HSM guys are on... 05-10-2007, 09:42 PM
lgalla Jim&john:Furfurol Flavour... 05-11-2007, 04:05 AM
lgalla this just hit me.(chair) I... 05-11-2007, 04:58 AM
walter re: Motor sizing 05-11-2007, 05:55 AM
walter Hello AkvaCNC, That is... 05-11-2007, 04:42 PM
uhrgerat Polymer Concrete 05-11-2007, 08:05 PM
BigAl1 Hi All, Been very interested... 05-11-2007, 08:36 PM
uhrgerat Polymer Concrete 05-11-2007, 09:07 PM
ckelloug Huntsman formulation for... 05-11-2007, 09:32 PM
walter These additives are a good... 05-11-2007, 10:02 PM
brunog Cameron, Aggregate mixture... 05-13-2007, 12:46 AM
ckelloug Epoxy Granite Formula CNCZ-1 05-14-2007, 04:32 AM
qroger First post to this forum, so... 05-11-2007, 10:23 PM
walter Thanks Groger, That is a... 05-11-2007, 11:51 PM
qroger Now you have done it, you... 05-12-2007, 12:08 AM
ckelloug Welcome Groger 05-12-2007, 12:30 AM
ckelloug Groger's mixing theory 05-12-2007, 12:54 AM
qroger One last post, then it's off... 05-12-2007, 12:23 AM
lgalla Anyone having trouble... 05-12-2007, 03:37 AM
walter Both Agsco and Cary Co are... 05-12-2007, 04:14 PM
qroger I know this is awful lazy of... 05-14-2007, 02:50 AM
walter check out posts 942, 946,... 05-14-2007, 03:05 AM
walter Carbon Black 05-14-2007, 05:29 AM
lgalla Glad to see the papers on... 05-14-2007, 05:30 AM
walter I fine-tuned the ratios and... 05-14-2007, 06:25 AM
ckelloug Carbon Black and other finely... 05-14-2007, 02:43 PM
fyffe555 While I'm sure your efforts... 05-14-2007, 03:25 PM
fyffe555 Spherical Aggregate? 05-14-2007, 04:16 PM
ckelloug Andrew, It is well known... 05-14-2007, 04:43 PM
fyffe555 Entirely reasonable, unless... 05-14-2007, 05:48 PM
walter Thanks Cameron, I appreciate... 05-14-2007, 05:14 PM
harryn Hi Walter - I think you are... 05-14-2007, 05:52 PM
qroger Thanks Walter!, I'm not an... 05-14-2007, 03:43 PM
qroger CKelloug, The E/G may work... 05-15-2007, 03:13 AM
harryn Sorry to take this thread OT... 05-15-2007, 05:02 AM
romihs Don't give up! 05-15-2007, 10:04 AM
LeeWay Nice work, Guys. Haven't been... 05-15-2007, 12:51 PM
walter accures castings, now that is... 05-15-2007, 04:34 AM
qroger Harryn, It is off topic, but... 05-15-2007, 02:28 PM
harryn Hi - I have not used this... 05-15-2007, 05:59 PM
walter I wasted your time, actually.... 05-16-2007, 02:12 AM
davo727 Hey Walter, do you want me to... 05-16-2007, 12:36 PM
walter Not a bad idea. We could... 05-17-2007, 05:47 AM
brunog Cameron, Does shore hardness... 05-16-2007, 03:21 PM
ckelloug Bruno, My understanding is... 05-16-2007, 03:36 PM
brunog Cameron, I am just wondering... 05-16-2007, 05:35 PM
DAK3333 Carbon black is used mostly... 05-17-2007, 05:31 PM
ckelloug Go DAK3333!!!!!! 05-17-2007, 07:03 PM
martinw Dear Cameron, Moment of... 05-18-2007, 01:23 AM
ckelloug Martin, You are absolutely... 05-18-2007, 02:17 AM
walter I tested the 14.5% sample... 05-19-2007, 04:51 AM
ckelloug Good Work, Walter 05-19-2007, 05:36 AM
walter Cameron, you are a... 05-19-2007, 06:09 AM
ckelloug So, Whatcha got? Itty... 05-19-2007, 03:42 PM
walter 0.06-0.13mm 0.25-0.50mm... 05-19-2007, 04:25 PM
ckelloug That Quartz looks great! ... 05-19-2007, 05:44 PM
brunog Nice aggregate Walter, ... 05-21-2007, 06:37 PM
qroger CKelloug I think that vacuum... 05-21-2007, 04:44 PM
brunog An old refrigerator... 05-21-2007, 06:40 PM
ckelloug Vacuum and pressure 05-22-2007, 02:05 AM
Servo Wizard Hi All, I have built... 05-22-2007, 02:30 AM
ckelloug Hydrocal B11 05-22-2007, 04:30 AM
Geof Couple of comments: If the... 05-22-2007, 04:40 AM
ckelloug Geof, Good comment... 05-22-2007, 05:59 AM
Servo Wizard ckelloug, I see that... 05-22-2007, 11:46 PM
the4thseal I am making some samples of... 05-25-2007, 03:18 AM
walter Absolutely. Davo already... 05-25-2007, 06:19 PM
the4thseal Could you post a dimension so... 05-25-2007, 06:23 PM
walter My testing rig is very crude,... 05-25-2007, 06:51 PM
ckelloug Walter's Standard Samples 05-25-2007, 08:37 PM
walter Still haven't done the jig... 05-25-2007, 10:07 PM
walter My recommendation would be... 05-28-2007, 11:16 PM
Zumba I've been out of the loop for... 05-25-2007, 06:40 PM
walter AkvaCNC says this core was... 05-26-2007, 12:22 AM
brunog Walter, Nice samples!!! ... 05-26-2007, 02:45 AM
ckelloug Vacuum Pumps 05-26-2007, 03:33 AM
lgalla Sorry for being absent,but I... 05-26-2007, 04:17 AM
ckelloug Larry, This is what I was... 05-26-2007, 05:32 AM
greybeard I've had a few years... 05-26-2007, 02:53 PM
Geof My experience parallels this.... 05-26-2007, 03:09 PM
ckelloug Minimum Useful Vacuum Level... 05-26-2007, 03:33 PM
lgalla From the APT site. 30"... 05-26-2007, 05:02 PM
walter Thanks for stopping by Larry,... 05-26-2007, 05:32 PM
brunog Are you all sure that vacuum... 05-26-2007, 09:54 PM
walter Bruno, better pics of that... 05-26-2007, 11:07 PM
ckelloug Here is an excellent paper on... 05-27-2007, 01:23 AM
walter Yes I'm still having fun and... 05-29-2007, 12:01 AM
walter Ok, we have some close ups.... 05-27-2007, 03:35 AM
ckelloug More Hot air about degassing 05-27-2007, 06:00 AM
walter Here are two saw cut samples,... 05-27-2007, 04:32 AM
walter Last post, all samples dry... 05-27-2007, 04:48 AM
lgalla Hey Walt, Going back to... 05-27-2007, 05:39 AM
fyffe555 Conversations moved back to... 05-27-2007, 03:21 PM
walter Thanks Andrew, that makes... 05-27-2007, 04:08 PM
ckelloug I think Andrew's suggestion... 05-27-2007, 06:25 PM
greybeard A thought for those intending... 05-27-2007, 07:07 PM
ckelloug Greybeard, You're exactly... 05-27-2007, 07:47 PM
walter New bits of info. Some... 05-27-2007, 08:28 PM
ckelloug The fluid they speak of in... 05-27-2007, 09:03 PM
ckelloug Fracture Toughtness of quartz 05-28-2007, 07:36 AM
brunog Cameron, Even if 15% of the... 05-27-2007, 09:12 PM
brunog Walter, After looking and... 05-27-2007, 09:45 PM
walter There is no doubt in my mind.... 05-27-2007, 10:56 PM
ckelloug Bruno, From what I was... 05-28-2007, 03:37 AM
lgalla Cameron,Bruno,I don't have a... 05-28-2007, 05:29 AM
walter These are beautiful signs Joe! 05-28-2007, 05:22 PM
millminer Polymer concrete frame? I... 05-29-2007, 01:31 AM
ckelloug Walter, If I understand... 05-29-2007, 05:15 AM
walter Well, not exactly. (This is... 05-29-2007, 07:12 AM
brunog Walter, I am actually... 05-29-2007, 02:34 PM
greybeard Gosh, with Walter thinking... 05-29-2007, 04:35 PM
lgalla Sum Summary of previous... 05-29-2007, 05:49 AM
lgalla Steel frame bolted together... 05-29-2007, 06:24 AM
Zumba http://z.about.com/d/phoenix/1... 05-31-2007, 05:29 AM
walter I think these are all good... 05-31-2007, 06:09 AM
ckelloug Hi all, I've been a bit... 05-31-2007, 02:35 PM
DAK3333 Here in the lab (back in... 05-31-2007, 03:32 PM
ckelloug DAK3333, Here's the epoxy... 05-31-2007, 03:55 PM
walter It would be nice to find out... 05-31-2007, 08:00 PM
brunog DAK, Please take a look at... 06-01-2007, 03:34 PM
Adam M. Would everyone slow or stop... 06-01-2007, 04:33 PM
ckelloug Index of ideas from the first... 06-01-2007, 05:39 PM
walter Thanks for joining the thread... 06-02-2007, 02:23 AM
martinw That is pretty heroic! Top... 06-02-2007, 11:32 PM
the4thseal Walter how do i send you the... 06-02-2007, 07:27 AM
walter Please enable your PM box. 06-02-2007, 11:10 PM
Zumba See and See. 06-02-2007, 11:32 PM
walter Thanks! All E/G pieces... 06-03-2007, 03:13 AM
the4thseal walter ....I think i have... 06-03-2007, 03:16 AM
walter You haven't. That was AOL... 06-03-2007, 03:18 AM
ckelloug walter, Your design is on... 06-03-2007, 05:14 AM
the4thseal I think i have enabled my... 06-03-2007, 05:35 PM
walter Cameron, Thank you for... 06-03-2007, 08:29 PM
walter Any idea where to get this... 06-04-2007, 03:55 AM
ckelloug Walter, The national... 06-04-2007, 04:51 AM
walter "Granitek Precision Granite... 06-04-2007, 04:41 AM
walter Thanks, good info. As for... 06-04-2007, 05:30 AM
lgalla I am dazed&confused as usual.... 06-04-2007, 06:24 AM
greybeard Just a thought about rocks in... 06-04-2007, 08:16 AM
Zumba I've done about a dozen tests... 06-04-2007, 10:32 AM
Eson I hope you guys have gloves,... 06-04-2007, 06:57 PM
RotarySMP Zumba, this is great... 06-04-2007, 06:28 PM
walter Safety 06-04-2007, 07:41 PM
RotarySMP Cameron, Thanks for the... 06-04-2007, 09:02 PM
Mazaholic Don't know if this helps but.... 06-04-2007, 11:51 PM
PlasticWorker I have read most of the posts... 06-04-2007, 11:52 PM
ckelloug Great Work New Posters! 06-05-2007, 01:59 AM
Mcgyver wow this thread has marched... 06-05-2007, 02:20 AM
ckelloug Mcgyver, I agree with you... 06-05-2007, 03:16 AM
Geof Ah but would you trust the... 06-05-2007, 04:21 AM
speed33317 Decomp Composite... 06-05-2007, 01:46 AM
lgalla I agree with Mcgyver or... 06-05-2007, 04:57 AM
lgalla Quote from Mcgyver"I do... 06-05-2007, 05:23 AM
walter So many good contributions on... 06-05-2007, 09:07 AM
lgalla Boring Epoxy 06-05-2007, 04:49 PM
greybeard Hi Eson. I have had a little... 06-05-2007, 07:58 PM
Geof Greybeard has it correct; it... 06-05-2007, 08:14 PM
greybeard Geof, I wish you had been... 06-05-2007, 08:29 PM
Mazaholic Christ...Now you guys got me... 06-06-2007, 12:55 AM
ckelloug Mazaholic, I personally... 06-06-2007, 01:34 AM
Zumba Why bother with a couple... 06-06-2007, 03:13 AM
ckelloug Zumba, I think you're... 06-06-2007, 04:46 AM
Adam M. Finally, made it through. ... 06-06-2007, 04:31 AM
Mazaholic ckelloug, Thanks for the... 06-06-2007, 05:43 AM
Adam M. I just can't seem to stay... 06-06-2007, 08:24 PM
Eson Epoxy doesnt stick to cured... 06-06-2007, 10:00 PM
ckelloug Eson, Thanks for posting... 06-06-2007, 11:44 PM
ckelloug Zumba, I don't have an... 06-07-2007, 12:06 AM
Zumba Cameron, Good info! In... 06-06-2007, 11:39 PM
Fireflowers Hi not sure if this has been... 06-06-2007, 11:48 PM
lgalla Cameron,secondary bonding is... 06-07-2007, 03:49 AM
Mazaholic I would think a paint pot... 06-07-2007, 05:20 AM
PlasticWorker Igalla 06-07-2007, 05:54 PM
ckelloug PlasticWorker, I haven't... 06-07-2007, 10:01 PM
greybeard Cameron - a couple of... 06-07-2007, 10:34 PM
walter re: Solid E/G base vs steel... 06-08-2007, 01:10 AM
Mazaholic Thanks for the feedback. The... 06-08-2007, 03:33 AM
lgalla I have asked this question... 06-08-2007, 04:39 AM
Geof If you go back many, many,... 06-08-2007, 04:50 AM
brunog Larry, Embedded 1020... 06-08-2007, 03:39 PM
Geof I am not really up on what... 06-08-2007, 03:48 PM
brunog Conceptually you must... 06-08-2007, 04:02 PM
lgalla http://www.cnczone.com/forums/... 06-08-2007, 05:02 AM
Eson Igalla: You mount the rails... 06-08-2007, 05:53 AM
greybeard Cameron - If we start with... 06-09-2007, 09:50 AM
ckelloug John, Your last paragraph... 06-10-2007, 05:09 AM
ckelloug Thoughts on the factors in... 06-11-2007, 08:30 AM
lgalla Aggregating is it not?100... 06-10-2007, 06:09 AM
greybeard Thanks Cameron for spending... 06-10-2007, 11:02 PM
rockingjess Hi there! I´m trying to... 06-10-2007, 11:51 PM
ckelloug Rockingjess, There are... 06-11-2007, 06:15 AM
lgalla Cameron,Wollastanite appears ... 06-11-2007, 04:15 AM
gerryv I've not followed the whole... 06-11-2007, 01:57 PM
ckelloug Gerryv, The ductal product... 06-11-2007, 05:02 PM
PlasticWorker Rockingjess OT reply 06-11-2007, 07:08 PM
greybeard I've just read one of their... 06-11-2007, 11:04 PM
ckelloug Greybeard, Fibers are... 06-12-2007, 12:39 AM
ckelloug Introduction to Material... 06-12-2007, 03:23 AM
walter Hi everyone, just a quick... 06-11-2007, 10:59 PM
lgalla Poor quartz 06-12-2007, 03:42 AM
ckelloug Larry, I wouldn't outlaw... 06-12-2007, 06:19 AM
greybeard Time for a party - we've just... 06-12-2007, 09:04 AM
walter Party!!! 06-12-2007, 09:24 AM
ckelloug Walter, Let's add Mixture... 06-12-2007, 03:31 PM
rancherbill I have been lurking for the... 06-12-2007, 04:17 PM
greybeard Walter - could you post a... 06-12-2007, 06:07 PM
Eson rancherbill: That wouldnt be... 06-12-2007, 06:08 PM
ckelloug Hi Bill, Your comments are... 06-12-2007, 06:47 PM
walter Guys, focus.. :) It's not the... 06-12-2007, 07:48 PM
ckelloug Walter, Do you have a... 06-12-2007, 07:58 PM
Geof I suggest putting some... 06-12-2007, 08:28 PM
ckelloug The rotating seal in Geof's... 06-12-2007, 09:03 PM
greybeard I see the deLarrard book is... 06-12-2007, 09:26 PM
ckelloug Greybeard, That testing... 06-12-2007, 10:06 PM
walter Good suggestion Geof! But... 06-12-2007, 09:13 PM
jkeyser14 speakers 06-12-2007, 10:48 PM
walter Here's something tasty :D ... 06-13-2007, 01:17 AM
ckelloug According to someone from the... 06-13-2007, 03:44 AM
Jay C My point being, that despite... 06-13-2007, 03:35 PM
ckelloug OT: Why I'm here lest anybody... 06-13-2007, 04:17 PM
walter Quote"I myself have visited... 06-13-2007, 04:42 PM
Jay C There are both kinds here.... 06-13-2007, 06:40 PM
Geof Nonsense; you generalise far... 06-13-2007, 07:43 PM
walter So, let me get this... 06-13-2007, 11:14 PM
ckelloug Greybeard, I'd think about... 06-14-2007, 12:13 AM
lgalla Oh,OH More reading,sorry,but... 06-13-2007, 05:12 AM
lgalla De-airing agents. Can't find... 06-13-2007, 05:47 AM
ckelloug Surface Energy 06-13-2007, 07:33 AM
walter Aye,Aye Sir! I will pay them... 06-13-2007, 03:56 PM
Jay C Damn, 2 for 2. I wasn't... 06-13-2007, 04:34 PM
turmite Hi guys, I've only posted... 06-13-2007, 04:45 PM
ckelloug Jay, No offense taken. ... 06-13-2007, 05:27 PM
greybeard Some time back I posted my... 06-13-2007, 08:55 PM
greybeard E/G sample testing jig No.2 06-13-2007, 09:11 PM
Geof Your 60 G may or may not be... 06-13-2007, 09:13 PM
greybeard I took the easy way out - I... 06-13-2007, 09:35 PM
greybeard I've just done some... 06-13-2007, 11:30 PM
Geof I think you are correct that... 06-13-2007, 11:49 PM
ckelloug Turmite, Resin transfer... 06-14-2007, 01:55 AM
walter That's it. I'm getting that... 06-14-2007, 02:18 AM
lgalla Walter,flies in honey?Is this... 06-14-2007, 04:41 AM
Mazaholic Here's what i've been... 06-14-2007, 05:09 AM
walter Wow Larry, that changes... 06-14-2007, 06:45 AM
ckelloug Teacher, Teacher, I think... 06-14-2007, 03:59 PM
lgalla Mazaholic from Epoxyaholic.... 06-14-2007, 05:18 AM
Mazaholic Wow! I didn't even... 06-14-2007, 05:24 AM
ckelloug de Larrard's Paper 06-14-2007, 06:11 AM
lgalla Walter,I guess you know you... 06-14-2007, 04:06 PM
Eson Vacuum for the people! ... 06-14-2007, 04:52 PM
tiwanacote . 06-14-2007, 11:47 PM
lgalla Fumed silica,Silicon... 06-15-2007, 03:33 AM
ckelloug Hi all, I just put in a... 06-15-2007, 05:10 AM
walter Someone mentioned Harbor... 06-15-2007, 06:46 AM
ckelloug Walter, If the ABS... 06-15-2007, 01:09 PM
greybeard Not specifically, but is this... 06-15-2007, 02:16 PM
rancherbill Cameron I was spraying... 06-15-2007, 04:28 PM
ckelloug Rancher Bill, Slightly OT,... 06-15-2007, 05:00 PM
lgalla Paint pot,vacuum pot... 06-15-2007, 04:51 AM
Mazaholic Tanks Larry:) I'm going... 06-15-2007, 05:39 AM
Mazaholic Cameron. That would be great... 06-15-2007, 05:47 AM
lgalla Cam I have been short{5'/7"}... 06-15-2007, 06:11 AM
fyffe555 Hi Larry, been busy... :) ... 06-15-2007, 07:00 PM
fyffe555 Toughness 06-15-2007, 07:25 PM
ckelloug Andrew, I think I... 06-15-2007, 08:05 PM
fyffe555 Thinning Epoxy 06-15-2007, 09:01 PM
lgalla Maz, good idea.I went to my... 06-15-2007, 06:18 AM
fyffe555 Cameron. So called reactive... 06-15-2007, 10:24 PM
fyffe555 Epoxy sticking to Epoxy? 06-15-2007, 11:24 PM
ckelloug I'm not afraid of the 777 but... 06-16-2007, 12:13 AM
fyffe555 Not so sure, The earlier... 06-16-2007, 01:44 AM
ckelloug I'm not sure about the... 06-16-2007, 12:03 AM
lgalla http://www.northerncoatings.co... 06-16-2007, 04:57 AM
Mazaholic Ive been looking at the... 06-16-2007, 07:06 AM
PlasticWorker ckelloug 06-16-2007, 07:20 PM
ckelloug Plastic Worker, I don't... 06-16-2007, 09:20 PM
ckelloug Mazaholic, That liquid... 06-16-2007, 09:32 PM
walter Internal Foam Cores! 06-17-2007, 12:24 AM
walter http://img145.imageshack.us/im... 06-17-2007, 04:56 AM
lgalla Walter,your latest post is... 06-17-2007, 05:09 AM
ckelloug Walter, The maximum... 06-17-2007, 03:42 PM
walter Thanks! And speaking of... 06-17-2007, 05:09 PM
ckelloug Geez Walter, This one is... 06-17-2007, 05:36 PM
walter Up to 327 lbs now. I'm... 06-18-2007, 12:52 AM
ckelloug Wow Walter, With 327... 06-18-2007, 01:32 AM
lerman Can You Measure The... 06-18-2007, 02:09 AM
brunog Cameron,Walter, This was... 06-18-2007, 03:03 PM
walter Continuing on 'Internal Foam... 06-17-2007, 07:05 PM
greybeard Congrats Walter on a picture... 06-17-2007, 08:08 PM
walter Glad to help! :) ... 06-17-2007, 09:36 PM
walter Nothing special. It's exactly... 06-18-2007, 02:19 AM
ckelloug Holy guacamole Walter! At... 06-18-2007, 03:19 AM
lgalla Foam cores could be simply... 06-18-2007, 03:27 AM
walter Thank you both. That is good... 06-18-2007, 03:33 AM
lgalla Walter,in your pictures you... 06-18-2007, 03:43 AM
ckelloug I'll think about the foam... 06-18-2007, 05:12 AM
brunog Cameron, This is a sample... 06-18-2007, 03:54 PM
ckelloug Bruno, I've looked at your... 06-19-2007, 12:25 AM
JDW I use to run a Machine /... 06-18-2007, 01:54 PM
brunog Cameron, maybe I was a... 06-19-2007, 12:57 AM
lgalla Bruno,this may be to high tec... 06-19-2007, 05:52 AM
ckelloug I shaped Gantry Beam 06-19-2007, 08:02 AM
Zumba Bruno, that's a cool looking... 06-19-2007, 11:59 PM
brunog Zumba, 1- The design purpose... 06-20-2007, 02:40 PM
Zumba In regards to foam core.... ... 06-20-2007, 12:15 AM
Zumba BTW, has anyone here seen E/G... 06-20-2007, 12:23 AM
ckelloug Hi Zumba, I'm interested... 06-20-2007, 04:11 AM
walter I've seen some different... 06-20-2007, 05:53 AM
brunog Walter, That's where Shore D... 06-20-2007, 02:44 PM
brunog East systems epoxy 9482 is... 06-20-2007, 02:51 PM
ckelloug brunog, I see you've... 06-20-2007, 04:00 PM
brunog Cameron, I am presently... 06-20-2007, 04:20 PM
ckelloug Bruno, I think you should... 06-20-2007, 04:54 PM
ckelloug Thank you to 3M for... 06-20-2007, 05:03 PM
ckelloug Got deLarrard's Book on... 06-21-2007, 11:31 PM
greybeard Quote ...The maximum... 06-22-2007, 08:08 PM
lerman Am I correct that the... 06-22-2007, 08:46 PM
greybeard Ken - I can't get my head... 06-22-2007, 09:19 PM
lerman I take the word uniformly to... 06-22-2007, 09:40 PM
walter Thanks for the great info... 06-23-2007, 12:38 AM
lgalla Walter In reply to hardcore... 06-23-2007, 04:12 AM
greybeard Re the 10% volume of each... 06-23-2007, 01:28 PM
walter Coupling Agents and Peanut... 06-24-2007, 02:16 AM
walter Here's more: The lure of... 06-24-2007, 02:57 AM
lgalla Walter, methyl hydrate is a... 06-24-2007, 04:49 AM
walter Thanks Larry. And thanks for... 06-24-2007, 05:46 AM
walter This latest mix got me pumped... 06-24-2007, 06:49 AM
greybeard Walter, sorry to ask, as I'm... 06-24-2007, 12:25 PM
walter Hi John, I own a small... 06-24-2007, 04:43 PM
greybeard Thanks Walter. I've got an... 06-24-2007, 05:14 PM
Zumba Walter, nice tests. Those... 06-25-2007, 12:07 AM
walter Zumba, My experience is... 06-25-2007, 01:38 AM
greybeard Cameron - are the de Larrard... 06-25-2007, 04:31 AM
ckelloug De Larrard's formulas are by... 06-25-2007, 04:53 AM
greybeard Thanks Cameron. I'd... 06-25-2007, 05:32 AM
Zumba Hey Walter, how deep would... 06-25-2007, 06:43 AM
walter It might work, I'm not sure... 06-25-2007, 04:53 PM
greybeard I've been looking for a... 06-25-2007, 05:47 PM
ckelloug Admixtures 06-25-2007, 09:34 PM
lgalla John,try Lawrence... 06-26-2007, 01:15 AM
lgalla John,when buying 500 micron... 06-26-2007, 01:31 AM
ckelloug Seeing the round aggregate, ... 06-26-2007, 06:50 AM
Zumba What do you guys have in mind... 06-26-2007, 07:07 AM
greybeard Larry - thanks for the... 06-26-2007, 09:58 AM
ckelloug Reichhold 37-127/ 37-606... 06-26-2007, 03:23 PM
walter I'm intrigued by this post.... 06-27-2007, 01:30 AM
walter Thank you Cameron. I... 06-27-2007, 12:40 AM
lgalla Walter,I have the same hunch... 06-27-2007, 04:45 AM
ckelloug Larry, You need the... 06-27-2007, 05:17 AM
Zumba Cameron, Excellent idea... 06-27-2007, 06:29 AM
greybeard Cameron - re you post #1624,... 06-28-2007, 09:36 AM
ckelloug John, On this side of the... 06-28-2007, 11:54 AM
walter John, I'd be happy to send... 06-28-2007, 05:39 PM
ckelloug Walter, Thanks for the... 06-28-2007, 07:11 PM
WayneHill I have been following this... 06-28-2007, 05:57 PM
greybeard Walter - this is a quick... 06-28-2007, 10:24 PM
ckelloug de Larrard Simulators: en... 06-28-2007, 11:05 PM
walter You've obviously put a lot of... 06-29-2007, 01:31 AM
ger21 14psi = ~1 ton/sq ft. If... 06-29-2007, 02:27 AM
ckelloug Try a closed mold with weight... 06-29-2007, 04:22 AM
lgalla Walter here is a copy from... 06-29-2007, 04:56 AM
lgalla Too late,too many beers,]make... 06-29-2007, 05:16 AM
Zumba Larry, I'm pretty sure... 06-29-2007, 06:57 AM
ckelloug Pump up the Volume, and Pack... 06-29-2007, 07:37 PM
walter Looks like I'm going to need... 06-29-2007, 10:44 PM
Zumba Sweet jeebus, Walter. It's... 06-29-2007, 11:47 PM
Zumba Hey Cameron, I agree that... 06-30-2007, 12:04 AM
lgalla I am sure Walter will still... 06-30-2007, 02:29 AM
walter Have a look at the pictures-I... 06-30-2007, 03:00 AM
lgalla My math is bad,Cameron if a... 06-30-2007, 03:12 AM
ckelloug Walter, Not only have you... 06-30-2007, 03:49 AM
lgalla Walter we are tandem... 06-30-2007, 03:34 AM
lgalla Cam,Grr. I'll stay tuned but... 06-30-2007, 04:57 AM
walter Cameron, Could you please... 06-30-2007, 09:00 PM
ckelloug Novec Fluorosurfactant 06-30-2007, 09:31 PM
greybeard Walter - mail en route, and... 06-30-2007, 10:08 PM
ckelloug Simulation Results. Still... 06-30-2007, 11:53 PM
walter Good info, thanks! I'm... 06-30-2007, 09:55 PM
walter Love the spin casting idea.... 07-01-2007, 02:20 AM
lgalla I don't understand vibration... 07-01-2007, 02:51 AM
ckelloug Explanations of compaction... 07-01-2007, 05:32 AM
walter It isn't new mix- it's... 07-01-2007, 06:56 AM
walter Cameron, I oppose your... 07-01-2007, 07:24 AM
ckelloug Walter, A picture is worth... 07-01-2007, 04:15 PM
greybeard Just to show my impatience,... 07-01-2007, 05:24 PM
greybeard Cameron - source of confusion... 07-01-2007, 04:05 PM
walter These numbers are easy to... 07-01-2007, 08:28 PM
lerman Someone a short ways back... 07-02-2007, 01:47 AM
ckelloug This is a good idea though... 07-02-2007, 02:12 AM
ckelloug Interesting but non-useful... 07-02-2007, 06:17 AM
lgalla John or Greybeard,I like your... 07-02-2007, 06:12 AM
walter Speaking of countertop guys.... 07-02-2007, 07:30 AM
greybeard I managed to get the test... 07-02-2007, 12:56 PM
granitedoug L S Starrett Tru-Stone... 07-02-2007, 01:06 PM
greybeard And I'm sure they would do a... 07-02-2007, 04:44 PM
ckelloug granitedoug, Thanks for... 07-02-2007, 05:01 PM
lgalla Walter you cannot substitute... 07-03-2007, 04:04 AM
ckelloug The model I got from de... 07-03-2007, 04:40 AM
greybeard On the subject of formula.... 07-04-2007, 02:40 PM
ckelloug John, This is very similar... 07-05-2007, 02:45 PM
Zumba Anyone have any idea what the... 07-05-2007, 05:24 PM
greybeard While my wife has been doing... 07-05-2007, 08:51 PM
alexccmeister Is it possible for us lot... 07-06-2007, 01:36 AM
walter Yes, that's what I'll be... 07-06-2007, 01:49 AM
lgalla Walter says"ya gotta go with... 07-06-2007, 02:15 AM
Zumba Cameron, thanks for the info... 07-06-2007, 03:16 AM
walter Hi Bruno, good to see you! :)... 07-06-2007, 04:02 AM
lgalla alien countertops 07-06-2007, 05:24 AM
walter I know. They say 93% purified... 07-06-2007, 05:53 AM
brunog Don't forget this information... 07-06-2007, 01:26 PM
brunog Cameron, Walter,John,Larry. ... 07-06-2007, 03:57 AM
lgalla Ultrasound 07-06-2007, 04:13 AM
greybeard Do they say how wide it was... 07-06-2007, 02:15 PM
Xerxes Forgive me that I have read... 07-06-2007, 03:53 PM
greybeard Welcome Xerxes, and I can... 07-06-2007, 04:15 PM
Xerxes Good! I would think that... 07-06-2007, 04:24 PM
alexccmeister Why not just get... 07-06-2007, 04:59 PM
walter Xerxes, very good points. We... 07-06-2007, 05:47 PM
ckelloug Brief notes on Epoxy and... 07-06-2007, 08:22 PM
Xerxes Has anyone tried to get a... 07-06-2007, 08:49 PM
Zumba I believe Walter received a... 07-06-2007, 09:28 PM
walter That's right. Here's the... 07-06-2007, 09:48 PM
greybeard If I'm spin casting a thick... 07-07-2007, 10:09 AM
walter I'm beginning to really like... 07-08-2007, 07:00 AM
walter Help! 07-08-2007, 11:54 PM
lgalla Walter,I have used PVA or... 07-09-2007, 02:50 AM
walter Thank you Larry, your advice... 07-09-2007, 03:24 AM
lgalla Walter,I will just babble on... 07-09-2007, 04:15 AM
lgalla Heads-up Nevada E/Gusers.The... 07-09-2007, 04:34 AM
walter No draft Larry, it has to... 07-09-2007, 04:57 AM
ckelloug Walter, It's probably... 07-09-2007, 05:10 AM
Geof I don't know if it would be... 07-09-2007, 05:17 AM
walter Those are very good advices,... 07-09-2007, 06:38 AM
greybeard I'd suggest you wax the... 07-09-2007, 07:12 AM
lgalla Methyl hydrate is a good... 07-09-2007, 03:32 PM
ckelloug The many names of Methyl... 07-09-2007, 03:40 PM
Geof Lacquer Thinner also contains... 07-09-2007, 03:52 PM
ger21 I looked at the msds for the... 07-09-2007, 10:25 PM
walter I've used lacquer thinner in... 07-09-2007, 04:40 PM
ckelloug Walter, Lacquer Thinner... 07-09-2007, 04:51 PM
lgalla Straight Methyl hydrate works... 07-10-2007, 02:49 AM
walter Great stuff, thank you all! ... 07-10-2007, 06:22 AM
Eson I think you should use steel... 07-10-2007, 06:43 AM
ckelloug No Go on BYK C-8000 07-10-2007, 06:31 PM
walter Thanks, that saves us time... 07-11-2007, 06:04 PM
walter Thanks Eson. Steel would... 07-10-2007, 05:40 PM
svenakela I was searching the Internet... 07-11-2007, 09:47 AM
walter Good stuff Sven. The O... 07-11-2007, 05:33 PM
greybeard Hi Walter. Suddenly it's... 07-11-2007, 05:53 PM
ckelloug John, The testing... 07-11-2007, 06:06 PM
ckelloug Walter, Excellent... 07-11-2007, 07:13 PM
walter Real granite test results ... 07-11-2007, 06:53 PM
Xerxes Has anyone tried using vacuum... 07-11-2007, 07:57 PM
ckelloug Xerxes, There has been a... 07-11-2007, 08:56 PM
Xerxes No need to do mixing in... 07-11-2007, 11:05 PM
walter The mix is pretty thick. ... 07-11-2007, 11:13 PM
ckelloug I'm predicting that the 8%... 07-12-2007, 03:15 AM
Xerxes I think it would be way too... 07-11-2007, 11:43 PM
lgalla Walter the commercial mixes... 07-12-2007, 03:51 AM
walter How do you know that? 07-12-2007, 04:04 AM
ckelloug Wetting agents = surfactants.... 07-12-2007, 05:32 AM
lgalla Walter this is what I read in... 07-12-2007, 04:37 AM
walter Thanks. I did the... 07-12-2007, 04:45 AM
lgalla CaesarStone® (made in Israel)... 07-12-2007, 04:49 AM
lgalla Saved My But Phew 07-12-2007, 05:17 AM
lgalla LesPaul for sissys 07-12-2007, 05:41 AM
walter Well... I'm getting... 07-12-2007, 06:01 AM
ckelloug Walter, The sample with... 07-12-2007, 07:37 AM
ckelloug John, I've thought about... 07-12-2007, 07:49 AM
greybeard Cameron - I understand the... 07-12-2007, 08:01 PM
ckelloug Wow, Lots of incredibly... 07-12-2007, 08:53 PM
walter Anything from 0.5mm to 5mm... 07-12-2007, 07:50 PM
alexccmeister Are all these mixes going to... 07-12-2007, 06:49 AM
greybeard Walter - Your figure seemed a... 07-12-2007, 07:07 AM
walter John, You're right. My... 07-12-2007, 06:55 PM
greybeard Just a bit of info I've... 07-12-2007, 07:36 PM
greybeard On the surfactant thingy - a... 07-12-2007, 10:02 PM
lgalla Cameron,I buy time on a 5X10... 07-13-2007, 02:45 AM
ckelloug Larry, Thanks. I'm still... 07-13-2007, 04:01 AM
walter Cameron, just a vial or two... 07-13-2007, 04:38 AM
greybeard Cameron - thanks for the pm.... 07-13-2007, 07:23 AM
greybeard Having just discovered a... 07-13-2007, 11:55 AM
lgalla Finally found a weight of a... 07-14-2007, 04:21 AM
brunog Larry, epoxy has approx half... 07-14-2007, 01:34 PM
the4thseal you guys are moving so fast... 07-14-2007, 08:07 AM
brunog Apparently all counter top... 07-14-2007, 01:58 PM
walter The4thseal, BYK A-525... 07-14-2007, 06:53 PM
the4thseal thanks I will get some. 07-15-2007, 01:12 AM
ckelloug Explaining the de Larrard... 07-16-2007, 06:54 AM
greybeard Many thanks Cameron, you've... 07-16-2007, 08:24 AM
greybeard This posting was one second... 07-16-2007, 09:04 AM
greybeard A typo here I think. The... 07-16-2007, 10:52 PM
ckelloug Corrected Aggregate... 07-17-2007, 03:43 AM
greybeard I'm happy with everything... 07-17-2007, 07:46 AM
DaveP Hopefully only slightly off... 07-19-2007, 04:50 PM
Zumba Real granite is probably uber... 07-19-2007, 10:44 PM
walter Got my Harbor Freight... 07-20-2007, 08:25 AM
brunog Cool vibrators Walter, As... 07-20-2007, 03:47 PM
ckelloug Vibration and Post Curing 07-20-2007, 05:49 PM
Geof I think it will depend on how... 07-20-2007, 06:37 PM
lazlo Hi Walter, Cameron, This... 07-23-2007, 08:33 PM
walter Great info. Thank you all! 07-20-2007, 11:01 PM
walter Hi Robert, we are working on... 07-23-2007, 10:36 PM
ckelloug Lazlo, I'm up to my... 07-24-2007, 04:44 AM
alexccmeister I read on this thread someone... 07-25-2007, 08:07 AM
greybeard MDF certainly delaminates... 07-25-2007, 10:43 AM
walter Good question Alex. Mold... 07-25-2007, 12:11 PM
greybeard Walter - hope I wasn't out of... 07-25-2007, 12:38 PM
alexccmeister That is the reason why I am... 07-25-2007, 01:19 PM
walter Yeah, there is no problem... 07-25-2007, 02:21 PM
alexccmeister Hi Walter, Thanks. I will... 07-25-2007, 03:19 PM
walter Yeah, very important... 07-25-2007, 10:20 PM
Geof I suggest you do not consider... 07-26-2007, 06:03 AM
ckelloug Geof, I agree completely... 07-26-2007, 07:18 AM
alexccmeister Thanks guys. My questions are... 07-26-2007, 01:49 AM
lgalla Expansion bolts,maybe... 07-26-2007, 02:06 AM
greybeard I'm assuming that "melinex"... 07-26-2007, 08:28 AM
ckelloug John, I know I still owe... 07-26-2007, 04:49 PM
greybeard Cameron - good point re thin... 07-27-2007, 11:25 AM
ckelloug John, Looking at... 07-30-2007, 07:47 PM
greybeard Hi Cameron. Thanks for the... 07-30-2007, 09:02 PM
ckelloug Tg is the glass transition... 07-30-2007, 11:55 PM
walter I did it! 07-30-2007, 11:37 PM
brunog Nice work Walter! Tell us... 07-31-2007, 02:25 AM
Bob, B. This is a bit off topic,... 07-31-2007, 01:05 AM
walter Thanks! The motors worked... 07-31-2007, 03:10 AM
ckelloug Walter, That's a rather... 07-31-2007, 04:16 AM
walter LOL, I wanted to post picture... 07-31-2007, 04:25 AM
lgalla I you cannot afford the... 07-31-2007, 04:47 AM
greybeard Thanks everyone for your kind... 07-31-2007, 11:46 AM
Bob, B. Sorry about the mix up. I... 07-31-2007, 03:07 PM
ckelloug Thread Index Updated 08-02-2007, 03:56 AM
ckelloug John, The nancor clay... 08-04-2007, 12:50 AM
BrendaEM [That was me.] Also,... 08-04-2007, 03:13 AM
BrendaEM For a low-buck mixer, you... 08-04-2007, 12:32 AM
Bob, B. ckelloug, Imagine the pain... 08-04-2007, 04:15 AM
ckelloug Bob B, I haven't thought a... 08-04-2007, 12:38 PM
walter Two granite devices posing... 08-04-2007, 06:28 PM
gerryv Walter, Frankly it is an... 08-05-2007, 12:57 AM
Xerxes Wow! That is impressive :O ... 08-05-2007, 10:03 AM
ckelloug Walter, That piece looks... 08-05-2007, 03:51 PM
martinw Dear Walter, I have been... 08-12-2007, 12:02 AM
Glacern Walter, Very impressive,... 08-05-2007, 12:33 AM
BrendaEM It would be interesting to... 08-05-2007, 01:35 AM
walter Thank you Cameron, thanks... 08-05-2007, 04:12 PM
ckelloug I believe it was lgalla aka... 08-05-2007, 05:04 PM
nine 16 A shout from the gallery:... 08-05-2007, 05:31 PM
walter Cameron, Larry is... 08-05-2007, 05:31 PM
BrendaEM If the thermal expansion... 08-05-2007, 07:17 PM
walter Here once again is the list... 08-05-2007, 07:47 PM
lgalla Great Work Walter, In a... 08-06-2007, 05:45 AM
the4thseal Walter i am on my knees.... 08-06-2007, 07:43 AM
walter Thank you! I don't think I... 08-06-2007, 11:04 PM
walter Summary: 08-07-2007, 03:33 AM
brunog Walter, You did some fine... 08-07-2007, 04:54 AM
Bob, B. Walter, If I walked into a... 08-07-2007, 05:27 AM
ironDigit creativity ,inovativity... 08-08-2007, 02:42 AM
Zumba Walter, your results are... 08-08-2007, 06:46 AM
alexccmeister I am impressed too. Can't... 08-08-2007, 07:48 AM
walter Thanks everyone, really... 08-08-2007, 02:23 PM
lgalla Thoughts to consider: A... 08-09-2007, 03:38 AM
BrendaEM The stiffness aside... ... 08-09-2007, 07:53 AM
ckelloug If I remember correctly about... 08-09-2007, 04:26 PM
BrendaEM Thanks Camron, After... 08-09-2007, 05:24 PM
AustinT I want to play! Hi I... 08-09-2007, 11:36 PM
greybeard Cameron - starting from Bob... 08-09-2007, 11:58 PM
ckelloug John, The 1975 book of... 08-10-2007, 12:56 AM
ckelloug Austin T, Have fun. ... 08-10-2007, 01:11 AM
AustinT Sounds good to me Cameron. ... 08-10-2007, 11:59 PM
ger21 Buy 5 gallons and your close.... 08-11-2007, 01:13 AM
BrendaEM Perhaps like conventional... 08-11-2007, 01:53 AM
lgalla Ways & means 08-11-2007, 02:46 AM
greybeard OK, so this is where I show... 08-11-2007, 09:50 PM
walter Thanks Martin! Good to see... 08-12-2007, 01:26 AM
ckelloug Would folks be interested in... 08-13-2007, 05:59 PM
lerman Can We Build A Machine? 08-13-2007, 09:17 PM
ckelloug Ken, ASTM D790 does... 08-13-2007, 10:37 PM
walter Cameron, Great to see you... 08-15-2007, 04:00 PM
greybeard Walter - I think your... 08-15-2007, 04:18 PM
ckelloug Walter and John, Thanks... 08-15-2007, 06:30 PM
VetteNut72 Hi everyone! My name is Craig... 08-16-2007, 11:17 PM
lgalla Craig Welcome A-poxy,Caution... 08-17-2007, 05:35 AM
walter VetteNut72, Thanks for... 08-17-2007, 06:20 AM
greybeard Hi All. When asking a UK... 08-17-2007, 08:14 AM
harryn After some initial postings... 08-17-2007, 08:24 AM
scavenger Hi All, Seems like we all... 08-17-2007, 04:42 PM
ckelloug scavenger, Most anything... 08-17-2007, 06:13 PM
lgalla A few quick questions for... 08-17-2007, 11:16 PM
walter Larry, Two concrete... 08-17-2007, 11:59 PM
ckelloug Making the Grade 08-18-2007, 07:17 PM
greybeard Hi Phil, and welcome.... 08-19-2007, 01:29 PM
walter VetteNut72, Looking good!... 08-26-2007, 12:24 AM
ckelloug VetteNut72, That stuff is... 08-26-2007, 02:00 AM
walter Cameron, Didn't we have... 08-26-2007, 05:09 AM
ckelloug Walter, Despite the fights... 08-26-2007, 05:20 PM
AustinT Hey I have some news on a... 08-27-2007, 06:16 AM
goldcoast Where to buy aggregates 08-27-2007, 09:00 AM
ckelloug AustinT, Your result is... 08-27-2007, 11:28 PM
walter Thanks for the great post-... 08-28-2007, 01:13 AM
ckelloug Ceiba-Geigy = Huntsman... 08-28-2007, 01:24 AM
walter Welcome, Goldcoast! Did... 08-28-2007, 12:43 AM
lgalla If the rocks are breaking as... 08-28-2007, 01:39 AM
walter Larry, I've been... 08-28-2007, 02:11 AM
lgalla Walter been wondering too.Is... 08-28-2007, 04:06 AM
AustinT Sorry I didnt get the video... 08-29-2007, 02:49 AM
ckelloug Testing Thoughts 08-29-2007, 03:17 AM
walter Awesome results AustinT. ... 08-29-2007, 07:52 PM
AustinT Hi Walter, I have access to a... 08-29-2007, 11:33 PM
ckelloug AustinT, What an awesome... 08-30-2007, 12:31 AM
jhudler Barium Sulfate and measuring... 08-30-2007, 03:40 AM
lgalla Donut know,anyone know the... 08-30-2007, 04:18 AM
lgalla Sorry,had to end fast because... 08-30-2007, 04:48 AM
BEARINGMAN Fan 08-30-2007, 05:04 AM
lgalla Hi I am HAL.Heuristically... 08-30-2007, 05:34 AM
lgalla Dow...n 08-30-2007, 05:38 AM
lgalla Iam down. Beatles Quote:... 08-30-2007, 06:08 AM
lgalla Learned a lot to-day, You... 08-30-2007, 06:17 AM
HelicalCut I don't see any advantages to... 08-30-2007, 01:48 PM
VetteNut72 Thanks Walter, got your... 08-30-2007, 05:43 PM
jhudler HelicalCut, There more... 08-31-2007, 12:38 AM
walter Jhudler, Optical turning... 08-30-2007, 07:07 PM
jhudler E/G RF45 Technology... 08-31-2007, 12:53 AM
walter I agree on RF45.... 08-31-2007, 02:23 AM
jhudler Walter, If you haven't yet... 09-03-2007, 03:55 PM
walter I'm very limited here;... 09-04-2007, 04:20 PM
ckelloug the4thseal, In making your... 09-04-2007, 08:43 PM
Xerxes Walter, I wouldn't worry... 08-31-2007, 09:45 PM
lgalla Epoxy nuts 09-01-2007, 03:15 AM
jhudler Epoxy Nuts 09-01-2007, 03:34 AM
ckelloug Jack, I know that you were... 09-01-2007, 03:53 AM
lgalla Just for interest,Moglice:... 09-02-2007, 04:11 AM
RICHARD ZASTROW Cameron, E/G type material... 09-02-2007, 06:26 PM
the4thseal how do those percentages work... 09-02-2007, 10:57 PM
jhudler Moglice and E/G 09-03-2007, 12:50 AM
the4thseal i understand now what you... 09-03-2007, 02:18 AM
HelicalCut JHudler I wasn't... 09-03-2007, 03:38 AM
jhudler HelicalCut, I did understand... 09-03-2007, 04:19 AM
HelicalCut Cheers, I know where you are... 09-05-2007, 04:05 AM
lgalla Jack thanks for the Philly... 09-03-2007, 06:03 AM
ckelloug I'm relatively clueless about... 09-03-2007, 03:47 PM
jhudler Just a taste of what's in the... 09-03-2007, 05:03 PM
jhudler Need something to handle... 09-03-2007, 05:37 PM
ckelloug Jack, Degassing may be... 09-03-2007, 06:17 PM
the4thseal can you buy Teflon to make... 09-03-2007, 10:04 PM
ckelloug Teflon Powder 09-03-2007, 10:10 PM
ger21 Unless you go to Ebay, where... 09-04-2007, 02:00 AM
the4thseal too bad it is soooo expensive... 09-03-2007, 10:24 PM
dfro Yes!!!! I have finally found... 09-06-2007, 01:08 AM
the4thseal never mind i have found... 09-03-2007, 10:31 PM
lgalla the4thseal,I already posted... 09-04-2007, 02:52 AM
jhudler I think we need to loose the... 09-04-2007, 04:03 AM
lgalla jhudler,the spheres specified... 09-04-2007, 04:37 AM
the4thseal sorry about that.......this... 09-04-2007, 09:09 AM
greybeard I haven't noticed any... 09-04-2007, 11:08 PM
the4thseal no problems here, the forum... 09-05-2007, 05:52 AM
ckelloug I've started seeing random... 09-05-2007, 06:55 PM
the4thseal for leveling out the eg... 09-05-2007, 08:09 PM
greybeard Hi 4thseal. I've assumed I'd... 09-05-2007, 08:31 PM
lgalla Epoxy surface plate 09-06-2007, 02:20 AM
ckelloug Thoughts on meniscuses and... 09-06-2007, 04:13 AM
martinw Dear Cameron and Larry, ... 09-06-2007, 04:07 PM
the4thseal i understand the portion... 09-06-2007, 06:34 AM
krazatchu mixing 09-06-2007, 08:12 AM
dfro cameron, I much prefer... 09-06-2007, 08:33 AM
lgalla Martin, Dam or no Dam, that... 09-07-2007, 03:57 AM
martinw Dear Larry, Errr... damned... 09-08-2007, 12:03 AM
blurrycustoms Hey all you epoxy-granite... 09-08-2007, 03:33 AM
HelicalCut "I wonder what is the tensile... 09-07-2007, 01:12 PM
Mcgyver Helical, I agree with a lot... 09-07-2007, 02:47 PM
ckelloug Hi all, HelicalCut makes... 09-07-2007, 04:07 PM
dfro Vibrating table 09-07-2007, 05:15 PM
martinw Dear Cameron. Thanks for... 09-07-2007, 08:18 PM
greybeard I'm not sure where this... 09-07-2007, 08:12 PM
lgalla Gotta agree with Greybeard,I... 09-08-2007, 04:11 AM
dfro shopmaninc.com sells liquid... 09-08-2007, 05:50 AM
HelicalCut McGyver Increasing the... 09-08-2007, 12:05 PM
greybeard Surely the contact angle... 09-08-2007, 10:29 PM
dfro E/G mill base 09-09-2007, 12:20 AM
ckelloug Dave, Your design looks... 09-09-2007, 01:42 AM
lgalla plates etc. 09-09-2007, 04:34 AM
dfro I am having a 'duh' moment. ... 09-09-2007, 05:51 AM
ckelloug The resin and hardener both... 09-10-2007, 03:23 AM
ckelloug John, I've got the data... 09-10-2007, 03:32 AM
dfro But seriously, once I have... 09-10-2007, 04:55 AM
martinw Dear Cameron, Thank you so... 09-11-2007, 12:41 AM
martinw Dear Larry, The last time... 09-10-2007, 12:43 AM
thkoutsidthebox Here ya go: ... 09-10-2007, 08:12 PM
dfro Walter, Those are really... 09-11-2007, 12:00 AM
walter That is good thinking;... 09-11-2007, 02:06 AM
jhudler Dfro, In an E/G mixture with... 09-09-2007, 06:46 AM
jhudler Cameron, On the subject... 09-09-2007, 06:57 AM
dfro Jack, In respose to your... 09-09-2007, 08:35 AM
walter That's a good looking table... 09-09-2007, 11:56 PM
walter lol! Good to see you... 09-10-2007, 01:01 AM
lgalla Dave,the carbon black is made... 09-10-2007, 02:25 AM
walter Can anyone help me decipher... 09-11-2007, 02:22 AM
jhudler Hardness Shore D1/D15 84/83 –... 09-11-2007, 04:18 AM
dfro Walter, Thank you for the... 09-11-2007, 07:06 AM
walter I've had everything in... 09-11-2007, 10:22 PM
brunog Walter, 20% by volume Epoxy... 09-14-2007, 08:40 PM
Coogrrr Questions - just a couple... 09-11-2007, 08:03 PM
ckelloug The Glass transition... 09-12-2007, 12:40 AM
ckelloug coogrrr, You could... 09-12-2007, 12:57 AM
dfro I thought I would share some... 09-12-2007, 06:24 AM
lgalla Dave,I agree on the pre... 09-11-2007, 02:36 AM
jhudler Walter, where did you... 09-11-2007, 11:00 AM
walter Thanks for your help. ... 09-11-2007, 11:56 AM
lgalla Dave I don't think you are... 09-11-2007, 04:44 PM
dfro Larry, I was talking about... 09-11-2007, 07:37 PM
Coogrrr hold down system? 09-11-2007, 08:19 PM
dfro Coog, My feeling is that... 09-11-2007, 09:01 PM
greybeard Coog - I'd be interested in... 09-11-2007, 10:11 PM
Coogrrr some kind of paste.... 09-11-2007, 11:47 PM
svenakela Darn! That was a really nice... 09-12-2007, 06:35 AM
jhudler Anyone looked at Titanium... 09-12-2007, 11:15 PM
dfro Here are my latest sketches... 09-13-2007, 03:33 AM
jhudler dfro, I really think you... 09-13-2007, 05:57 AM
jhudler dfro, My apology, I should... 09-13-2007, 04:14 PM
jhudler Walter, Do you have a... 09-13-2007, 04:18 PM
walter I'll make the samples and... 09-13-2007, 05:02 PM
dfro Jack, No worries. Thanks... 09-13-2007, 08:52 PM
jhudler Have to read up on using a... 09-13-2007, 05:55 PM
ckelloug John, It's a regular... 09-18-2007, 10:41 PM
jhudler dfro, I don't believe... 09-13-2007, 10:19 PM
yugami I don't think this is as hard... 09-14-2007, 01:32 AM
lgalla Dave I agree with Jack.Too... 09-14-2007, 02:52 AM
jhudler yugami, The casting takes... 09-14-2007, 04:29 AM
jhudler Larry, I guess we differ... 09-14-2007, 05:34 AM
jhudler Larry, Sorry, I re-read what... 09-14-2007, 03:25 PM
ckelloug Hi all, It looks like a... 09-14-2007, 04:56 PM
greybeard Ho hum.......... 09-15-2007, 05:25 PM
walter That actually is a pretty... 09-16-2007, 09:23 PM
walter I'm doing some assembly work-... 09-16-2007, 09:29 PM
ckelloug The description of the... 09-19-2007, 12:51 AM
dfro I have almost everything I... 09-19-2007, 01:25 AM
greybeard Thanks Walter, but I make no... 09-16-2007, 09:41 PM
jhudler [QUOTE=greybeard;343489]I... 09-19-2007, 08:41 PM
walter Well there you go, it's... 09-17-2007, 03:55 AM
romihs Go going Walter! 09-17-2007, 03:18 PM
jhudler Jesus! Even with gantry splay... 09-17-2007, 04:50 PM
walter Good to see you Sandi! I... 09-18-2007, 02:14 AM
romihs Recipe 09-18-2007, 10:13 AM
brunog Walter, High speed machining... 09-19-2007, 12:43 AM
jhudler I totally concur!! 09-19-2007, 02:16 AM
romihs Silica fume 09-22-2007, 12:40 AM
ckelloug Jack, Kudos on the bubble... 09-22-2007, 07:36 PM
jhudler Is that for tile, sound... 09-23-2007, 12:19 AM
jhudler "Admet eXpert 5601" that's... 09-18-2007, 11:07 PM
greybeard A quick look at the pdf I... 09-19-2007, 09:10 PM
jhudler I believe, your gut feeling... 09-20-2007, 05:57 AM
greybeard Hi Jack. If you look at the... 09-20-2007, 08:04 AM
jhudler LOL! I thought that was some... 09-21-2007, 01:32 AM
walter Bruno, Thank you for your... 09-22-2007, 09:24 AM
jhudler Walter's sample report. 09-22-2007, 02:54 PM
Guest From your numbers it looks... 09-25-2007, 02:31 AM
jhudler I think I've changed my first... 09-22-2007, 04:52 PM
Eson Hey guys, what do you think... 09-23-2007, 03:23 PM
walter Thanks Harryn! I did scratch... 09-24-2007, 08:56 PM
walter Jack, thank you for your work... 09-24-2007, 09:24 PM
jhudler Oh wow no need to apologize.... 09-24-2007, 10:13 PM
greybeard Jack, I'd be v.grateful if... 09-24-2007, 11:00 PM
walter Minimill base update 09-24-2007, 10:30 PM
the4thseal looking... 09-24-2007, 10:54 PM
greybeard Cameron - the photocopies... 09-24-2007, 11:02 PM
walter Thanks The4thseal! Eson,... 09-24-2007, 11:24 PM
lgalla Jack,at 3.5WX4.5LX2.5H in... 09-25-2007, 03:22 AM
ckelloug Jack, Not to harp but the... 09-25-2007, 06:25 PM
jhudler Larry, My only problem with... 09-25-2007, 03:33 AM
lgalla Jack,sorry may have a hard... 09-25-2007, 04:13 AM
jhudler Larry, That's what I meant,... 09-25-2007, 04:21 AM
lgalla Jack, sucks doesn't... 09-25-2007, 04:50 AM
jhudler Cameron, Harp taken... :) ... 09-25-2007, 08:47 PM
greybeard Jack - any chance of a lead... 09-25-2007, 09:05 PM
jhudler Well I generally play around... 09-26-2007, 12:55 AM
greybeard Thanks Jack. By this I guess... 09-26-2007, 08:02 AM
jhudler The Sample is in the CTE... 09-26-2007, 12:58 AM
jhudler Well it looks like the CTE is... 09-26-2007, 04:53 AM
jhudler John, You'd still have a... 09-26-2007, 12:30 PM
greybeard Sorry Jack, I should have... 09-26-2007, 02:18 PM
speed33317 World Record 10-03-2007, 01:28 AM
jhudler John, I've seen a device... 09-26-2007, 03:21 PM
greybeard Good grief, you've started me... 09-26-2007, 03:55 PM
BILLFUNK29 I have not cast a standalone... 10-01-2007, 01:57 PM
jhudler Bill, Nice to have you... 10-01-2007, 04:51 PM
walter Yes.. and that Philidelphia... 10-01-2007, 05:52 PM
jhudler Probably Chockfast Red...... 10-01-2007, 06:15 PM
walter Thanks! I visited ITW... 10-01-2007, 09:28 PM
jhudler I'm in collection mode at the... 10-03-2007, 02:44 AM
jhudler Oh and looking at different... 10-03-2007, 02:45 AM
lgalla Speed, Just building dreams... 10-03-2007, 02:55 AM
ckelloug Calm Before Storm 10-03-2007, 04:35 AM
Peldor First off, very cool thread!... 10-03-2007, 10:45 PM
ckelloug Peldor, The epoxy Walter... 10-04-2007, 03:39 AM
harryn I am not an expert on... 10-05-2007, 03:53 PM
Low-Alloy Epoxy Resin infusion 10-05-2007, 05:44 PM
walter One hot minimill base coming... 10-03-2007, 08:57 AM
Mike F I have been following this... 10-03-2007, 11:54 AM
jhudler You know it just occurred to... 10-05-2007, 06:20 AM
Peldor You know I was thinking that,... 10-05-2007, 02:18 PM
lgalla To inject resin,you must have... 10-05-2007, 04:09 PM
jhudler Larry, ok got that... another... 10-05-2007, 05:29 PM
greybeard Aren't we going round in... 10-05-2007, 05:54 PM
ckelloug Not to burst any bubbles but.... 10-06-2007, 05:47 PM
greybeard Sorry to confuse matters. I... 10-06-2007, 06:03 PM
harryn Hi Walter - Thank you for... 10-06-2007, 06:20 PM
MaX-MoD Hi everybody! I'm very... 10-06-2007, 08:09 PM
ckelloug Jack, The stuff from... 10-07-2007, 09:40 AM
greybeard Cameron - no apology... 10-07-2007, 12:42 PM
nine 16 Walter (et al), Your... 10-07-2007, 05:06 PM
daviddecker Walter, sorry it did not... 10-07-2007, 05:47 PM
jhudler This thread has gotten so... 10-05-2007, 07:57 PM
harryn If you make a (very)... 10-05-2007, 09:11 PM
ckelloug I hate to post without adding... 10-05-2007, 09:33 PM
greybeard Sorry to be serious, Jack,... 10-05-2007, 08:13 PM
greybeard Graham's law of diffusion -... 10-05-2007, 09:42 PM
lgalla Helium makes me laugh due to... 10-06-2007, 04:56 AM
Eson Wouldnt helium be easier to... 10-06-2007, 02:01 PM
jhudler Helium!!! Damn that's good... 10-06-2007, 02:57 PM
walter Test Base update 10-06-2007, 05:44 PM
yugami Walter, How did you attach... 10-07-2007, 11:47 PM
walter What I really need is a... 10-06-2007, 07:06 PM
harryn Hi Walter - Can't help you... 10-07-2007, 06:55 AM
Eson walter I see that you use... 10-07-2007, 12:42 AM
jhudler Ok someone look at this;... 10-07-2007, 03:40 AM
the4thseal i looked at this stuff but... 10-07-2007, 04:58 AM
jhudler John, You said that you were... 10-07-2007, 04:59 PM
greybeard Hi Jack. Lots of pages ago,... 10-07-2007, 06:48 PM
ckelloug Testing Machine is... 10-08-2007, 05:38 PM
walter Thanks Cameron! Much... 10-08-2007, 06:42 PM
307startup just thought you might want... 10-09-2007, 04:02 AM
walter Thanks everyone! I appreciate... 10-08-2007, 01:07 AM
yugami Walter, Thanks, somehow I... 10-08-2007, 02:31 AM
HBFixedGear If the issue is flow to the... 10-08-2007, 03:29 PM
harryn I think you might be on to... 10-08-2007, 04:34 PM
Peldor You could also do this and... 10-08-2007, 06:04 PM
greybeard Sometime ago, in a posting a... 10-08-2007, 05:35 PM
greybeard Cameron -Thanks for the... 10-08-2007, 11:09 PM
lgalla Vacuum infusion or pressure... 10-09-2007, 04:17 AM
ckelloug Jack, Where did you find... 10-13-2007, 09:08 AM
harryn Another interesting option is... 10-13-2007, 08:47 PM
ckelloug Harryn, Interesting on the... 10-14-2007, 07:39 AM
walter microcrystalline silica? 10-14-2007, 08:55 PM
walter I don't think I paid more... 10-15-2007, 09:41 PM
jhudler Ok I've ordered the... 10-13-2007, 08:25 AM
jhudler On the 37-058... It's another... 10-13-2007, 04:09 PM
greybeard Current recipe I'm trying to... 10-14-2007, 08:37 PM
jhudler 3M Zeeospheres pricing 10-15-2007, 07:42 PM
romihs Jack, WOW!! I contacted 3M... 10-15-2007, 08:28 PM
jhudler Walter, Where did you buy... 10-16-2007, 01:44 AM
lgalla Jack try... 10-16-2007, 02:36 AM
krazatchu Just saw this article... ... 10-16-2007, 03:45 AM
svenakela Anyone in the Ohio area who... 10-16-2007, 07:14 AM
jhudler Would love to know what they... 10-16-2007, 11:43 PM
ckelloug John, It was Gamsky and... 10-17-2007, 04:21 PM
307startup Speaking of reinforcements... 10-19-2007, 04:31 AM
MaX-MoD their products seems... 10-19-2007, 11:11 AM
greybeard Thanks Cameron. I'm picking... 10-19-2007, 04:59 PM
dang Hiya, This is my 1st post... 10-20-2007, 04:37 PM
ckelloug dang, Glad to have you... 10-20-2007, 05:33 PM
ckelloug dang, Walter, the... 10-21-2007, 12:19 AM
sc brian I have designed and built... 10-16-2007, 05:45 PM
jhudler You're reading my mind :) ... 10-16-2007, 11:41 PM
greybeard Cameron - somewhere buried in... 10-17-2007, 01:37 AM
the4thseal can these bearing handle the... 10-17-2007, 03:38 AM
jhudler Are you talking about the new... 10-17-2007, 03:42 AM
the4thseal don't get me wrong ......air... 10-17-2007, 06:20 AM
jhudler Well more than linear motion... 10-17-2007, 07:07 AM
the4thseal hhhmmmmm......precision... 10-17-2007, 07:18 AM
jhudler 3M Zeeospheres pricing (part... 10-17-2007, 05:06 PM
jhudler Using pool filter sand for... 10-18-2007, 03:08 AM
dang Thanks Cameron, I mean... 10-21-2007, 12:09 AM
brunog Dang, I don't see why not,... 10-21-2007, 03:56 AM
RotarySMP Dang, Those lines you ask... 10-21-2007, 08:09 AM
dang Awesome! Plastic, how easy is... 10-21-2007, 09:23 AM
millminer Glass 10-21-2007, 05:14 PM
dang Glass Aggregate 10-22-2007, 03:33 AM
lgalla Surface Plate Tech. 10-21-2007, 10:56 PM
ger21 Larry, if you look around,... 10-21-2007, 11:18 PM
harryn Hi Larry - This sounds like... 10-28-2007, 06:55 PM
RotarySMP Igalla, Why don't you just... 10-22-2007, 09:13 AM
ckelloug dang, Glass is basically... 10-22-2007, 06:05 PM
RotarySMP For the most part the... 10-22-2007, 08:03 PM
walter Great info everyone. Thanks... 10-22-2007, 08:58 PM
walter More destructive testing. ... 10-22-2007, 11:45 PM
yugami I'm guessing that thermal... 10-23-2007, 02:22 PM
svenakela Oh, I missed to comment on... 10-27-2007, 08:35 PM
walter Thanks Sven, I appreciate the... 10-28-2007, 01:37 AM
MaX-MoD to get a flas cast, just use... 10-22-2007, 08:48 PM
ger21 Walter, have you tried "wet... 10-23-2007, 12:15 AM
walter Thanks Gerry. I'll try that... 10-23-2007, 12:29 AM
ckelloug Wow Walter, You've been... 10-23-2007, 04:16 AM
lgalla Wow,Walter the video was so... 10-23-2007, 04:51 AM
lgalla Under heat lamps the steel... 10-24-2007, 02:17 AM
ckelloug Larry, I think you are... 10-24-2007, 06:39 AM
walter Thanks everyone, I appreciate... 10-24-2007, 07:44 AM
harryn Hi Walter - nice pictures. ... 10-24-2007, 07:59 PM
jhudler Vacuum tests 10-25-2007, 06:05 AM
MaX-MoD good job jhulder, finally... 10-25-2007, 09:56 AM
svenakela Physically there's no... 10-25-2007, 11:38 AM
jhudler The pump I'm using is a... 10-25-2007, 02:01 PM
jhudler I had to make some... 10-25-2007, 06:55 PM
walter Great work Jack! I'm looking... 10-25-2007, 09:23 PM
greybeard Hi all. Just a brief post to... 10-26-2007, 10:53 AM
walter Good to have you back, John! 10-26-2007, 11:16 AM
Eson Could it be possible to pour... 10-26-2007, 01:50 PM
greybeard I think an often overlooked... 10-26-2007, 06:36 PM
ckelloug Segregation is a function of... 10-26-2007, 06:57 PM
greybeard Hi Cameron. I agree that the... 10-27-2007, 11:32 AM
jhudler In my testing I do not see... 10-27-2007, 03:27 PM
jhudler John, After working with... 10-26-2007, 10:31 PM
jhudler Movies!!! 10-26-2007, 09:31 PM
lgalla Good stuff Jack!!! How your... 10-26-2007, 10:04 PM
jhudler Kids paper drinking cups are... 10-26-2007, 10:12 PM
Eson jhudler Wear gloves!... 10-27-2007, 01:13 AM
jhudler I've tried that (not on... 10-27-2007, 02:27 AM
greybeard Cameron - what are you doing... 10-27-2007, 11:35 AM
jhudler Cross Sections of items in... 10-27-2007, 05:37 PM
greybeard Hi Jack. As a matter of fact... 10-27-2007, 07:10 PM
jhudler Yes they were. Ahh I just... 10-27-2007, 07:21 PM
greybeard That's my cover blown then. 10-27-2007, 07:29 PM
jhudler Ok someone checkout my... 10-27-2007, 11:00 PM
romihs Sieves 10-27-2007, 11:48 PM
jhudler I found all I needed on eBay.... 10-28-2007, 01:18 AM
lgalla Walter& Sven I had the same... 10-28-2007, 02:24 AM
lgalla Woops!Jack,didn't know you... 10-28-2007, 02:46 AM
jhudler Larry, in the video and the 3... 10-28-2007, 03:12 AM
jhudler Oh tested mixing with the... 10-28-2007, 03:34 AM
greybeard Hi Harryn. I, too, am... 10-28-2007, 07:21 PM
jhudler Harry, Three steps are (if I... 10-28-2007, 07:44 PM
lgalla Thanks for the input guys.... 10-28-2007, 09:42 PM
greybeard Thin wall plastic pipe down... 10-28-2007, 10:00 PM
walter Jack, Thank you for that... 10-28-2007, 09:56 PM
jhudler LOL I didn't see... errr...... 10-28-2007, 10:49 PM
walter Some think it might go all... 10-28-2007, 11:14 PM
jhudler I was refering to the edges... 10-29-2007, 12:36 AM
the4thseal scale is an issue but i think... 10-28-2007, 11:53 PM
lgalla John,thank you,good idea.Any... 10-29-2007, 12:01 AM
the4thseal if the boarders are the same... 10-29-2007, 01:09 AM
jhudler Surface tension is molecular... 10-29-2007, 01:39 AM
jhudler Turns out the research was... 11-01-2007, 06:03 PM
the4thseal that is correct.... that is... 10-29-2007, 02:11 AM
jhudler ditto! 10-29-2007, 02:17 AM
ckelloug First off, thanks all for 8... 10-29-2007, 04:46 AM
the4thseal one last comment on the... 10-29-2007, 04:45 AM
walter Jack, here's something to... 10-29-2007, 11:56 PM
the4thseal yup yup yup......still... 10-30-2007, 12:38 AM
307startup walter... would you mind... 10-30-2007, 01:04 AM
walter WYLD, I believe it's this... 10-30-2007, 01:17 AM
307startup Thanks much, I do appreciate... 10-30-2007, 01:30 AM
lgalla I was testing some surround... 10-30-2007, 02:40 AM
jhudler Damn Larry! Stole my... 10-30-2007, 02:46 AM
lgalla Jack,good time to upgrade the... 10-30-2007, 03:08 AM
jhudler Mass drivers would be great... 10-30-2007, 03:31 AM
the4thseal igalla- so how are you... 10-30-2007, 03:09 AM
lgalla the4thseal.Being of age or... 10-30-2007, 03:33 AM
lgalla Jack,we had input many... 10-30-2007, 03:58 AM
RotarySMP There are surely applications... 10-30-2007, 09:00 AM
greybeard Mark - thanks for that... 10-30-2007, 09:31 AM
jhudler Try this;... 10-30-2007, 09:36 PM
greybeard Thanks Jack. John 10-30-2007, 11:24 PM
RotarySMP Nope, it is the guys... 10-30-2007, 10:41 AM
jhudler That was pretty cool, have to... 10-30-2007, 09:41 PM
greybeard Is that the small conical one... 10-30-2007, 12:46 PM
jhudler Here's what he said about it:... 10-30-2007, 06:30 PM
jhudler Lesions learned 10-30-2007, 09:32 PM
lgalla Jack,the German guys are... 10-31-2007, 08:11 AM
RotarySMP What the Austrian helicopter... 10-31-2007, 05:56 PM
jhudler Back in the late 70's I was... 10-31-2007, 10:43 PM
sp1nm0nkey Is there any index to the... 11-01-2007, 01:23 AM
ckelloug Link to the thread index 11-01-2007, 02:14 AM
lgalla Jack,Fyffe or Andrew has... 11-02-2007, 06:16 AM
ckelloug An Olive Branch for Andrew 11-02-2007, 07:27 AM
jhudler Mold for ASTM D-790 test... 11-03-2007, 12:24 AM
ckelloug I was planning on using a... 11-05-2007, 04:19 PM
jhudler That's about what I'm left... 11-05-2007, 05:02 PM
ckelloug I really doubt it would... 11-05-2007, 05:31 PM
yugami I was just running HDPE... 11-06-2007, 01:27 AM
jhudler Ok here it is fresh off the... 11-06-2007, 03:08 AM
ckelloug Jack, After review of... 11-06-2007, 03:48 AM
dang This is the second time I've... 11-08-2007, 01:15 AM
jhudler Dang, Well dang'it I didn't... 11-08-2007, 02:55 AM
ckelloug dang, I agree that vacuum... 11-08-2007, 03:13 AM
jhudler Vacuum show stopper! 11-08-2007, 03:44 AM
jkeyser14 I have a friend who pots very... 11-08-2007, 10:32 AM
greybeard It's great to have people's... 11-08-2007, 02:22 PM
jhudler Vacuum boiling epoxy 11-08-2007, 04:42 PM
jhudler Last night's test of boiling... 11-08-2007, 05:11 PM
ckelloug I think these experiments... 11-08-2007, 05:21 PM
MaX-MoD Has anybody tried using these... 11-08-2007, 10:22 PM
ckelloug Bonjour Max-Mod, Je... 11-08-2007, 10:41 PM
MaX-MoD You don't have to be ashamed... 11-09-2007, 12:21 AM
greybeard Just a last thought before I... 11-09-2007, 12:32 AM
qroger I just checked into the last... 11-09-2007, 03:24 AM
vacpress is there any agency that goes... 11-09-2007, 03:35 AM
lgalla Guys,ya ain't boiling the... 11-09-2007, 05:22 AM
jhudler Second boiling test 11-09-2007, 06:10 AM
ckelloug After a bit of googling, I... 11-09-2007, 07:57 AM
jhudler I wouldn't say out, just keep... 11-09-2007, 09:17 PM
lgalla This should be self... 11-10-2007, 02:27 AM
harryn Hi, I decided not to re-quote... 11-16-2007, 08:51 PM
jhudler Need milled carbon fiber... 11-12-2007, 06:24 AM
ckelloug I call Home Court Advantage! ... 11-12-2007, 05:06 PM
jhudler Would be nice to have a... 11-12-2007, 05:24 PM
ckelloug Jack, Can you give me some... 11-12-2007, 06:55 PM
jhudler There's apparently two types... 11-12-2007, 07:31 PM
ckelloug Boring equations for short... 11-12-2007, 07:56 PM
the4thseal how do cure the epoxy at... 11-13-2007, 03:25 AM
jhudler I've not been using a heated... 11-13-2007, 05:27 AM
jhudler Search eBay for "temperature... 11-13-2007, 03:42 AM
Jay C PID controller for... 11-13-2007, 04:22 AM
the4thseal i hook up heating elements to... 11-13-2007, 05:23 AM
svenakela Even though you have an epoxy... 11-13-2007, 08:11 AM
ckelloug Svenakela has way more... 11-13-2007, 04:05 PM
jstransky Is anybody able to help me to... 11-15-2007, 07:50 PM
ckelloug jstransky, Welcome. ... 11-15-2007, 08:26 PM
thomasz Hello! I think you're... 11-16-2007, 09:25 AM
jhudler Walter 11-18-2007, 02:04 AM
jhudler Status 11-18-2007, 02:56 AM
walter Hi Jack, Not much to... 11-18-2007, 07:16 AM
Steven.ji Helllo, everyone who will... 11-19-2007, 03:37 PM
ckelloug Stevenji, The article you... 11-19-2007, 05:02 PM
jhudler DGEBPA -vs- DGEBPF 11-22-2007, 04:40 AM
walter Very interesting Jack, thanks... 11-22-2007, 05:49 AM
MaX-MoD Hi, I've got some French... 11-23-2007, 09:53 PM
walter Max, It appears that the... 11-23-2007, 10:51 PM
greybeard The "diorite" component in... 11-23-2007, 11:26 PM
jhudler Wow those are huge chunks of... 11-23-2007, 11:44 PM
MaX-MoD they are using 0 to 4mm... 11-24-2007, 01:18 AM
walter Jack, they appear to be using... 11-24-2007, 01:23 AM
MaX-MoD well thank you all the great... 11-24-2007, 01:32 AM
MaX-MoD Germans seem to be far more... 11-24-2007, 01:55 AM
ckelloug MaxMod, Thanks for the... 11-24-2007, 03:18 AM
lgalla Cameron,I agree with all your... 11-24-2007, 04:42 AM
greybeard Then you could circulate... 11-24-2007, 09:37 AM
Viperia This is a damn long thread... 11-26-2007, 09:43 PM
ckelloug Viperia Epoxy Granite is... 11-26-2007, 10:33 PM
ckelloug Hey sposl, we haven't heard... 11-26-2007, 10:34 PM
Viperia Hello, Thanks for this... 11-26-2007, 11:31 PM
romihs Hey! :-) 11-27-2007, 08:53 AM
Mcgyver then you didn't to the part... 11-28-2007, 02:36 AM
walter Sandi, Congratulations on... 11-27-2007, 09:04 AM
jhudler Stiff? See walters posts... 11-28-2007, 03:10 AM
walter Larry Help! I need some... 11-28-2007, 03:38 AM
jhudler Curious... are you casting on... 11-28-2007, 03:58 AM
Mcgyver Jack build away - really, i... 11-28-2007, 04:28 AM
walter Mcgyver, could you analyze... 11-28-2007, 04:43 AM
jhudler Sorry missed this bit...... 11-28-2007, 05:02 AM
walter Jack, I made my own... 11-28-2007, 04:28 AM
ckelloug Mcgyver, You have made a... 11-28-2007, 04:55 AM
walter Cheap beer saved the day!... 11-28-2007, 05:24 AM
eloid Re: Epoxy-Granite machine... 08-14-2015, 05:01 AM
eloid Re: Epoxy-Granite machine... 08-14-2015, 11:13 AM
jhudler Mcgyver, I (or anyone else... 11-28-2007, 04:43 AM
lgalla smoki'n 11-28-2007, 04:51 AM
jhudler Use cheap beer! :) 11-28-2007, 04:52 AM
Mcgyver Walter, those are good... 11-28-2007, 03:28 PM
ckelloug Mcgyver, In the context of... 11-28-2007, 05:15 PM
walter Mikron HSM600, Monoblock... 11-28-2007, 09:59 PM
MaX-MoD from the french document I've... 11-28-2007, 10:42 PM
jhudler Wow when you guys were... 11-29-2007, 01:19 AM
greybeard Walter, I wonder if the... 11-28-2007, 11:02 PM
lgalla Jack& Walter,If meniscus is... 11-28-2007, 11:30 PM
jhudler Oh your using TT epoxy. Hmmm... 11-29-2007, 01:24 AM
jhudler LOL Maybe it was repulsed by... 11-29-2007, 01:35 AM
walter No time to answer. Larry... 11-29-2007, 01:37 AM
lgalla Walter spread it around with... 11-29-2007, 02:17 AM
lgalla Directions Lar 11-29-2007, 02:25 AM
walter Torch and heat lol! that... 11-29-2007, 02:35 AM
jhudler Larry, I know they say it's... 11-29-2007, 03:20 AM
walter Ok, I've got it under... 11-29-2007, 04:27 AM
lgalla Viscosity 11-29-2007, 05:53 AM
harryn Hi Larry The targeted... 11-29-2007, 10:47 PM
harryn LOL - I forgot to tell the... 11-30-2007, 02:41 AM
jhudler Max-Mod... your avatar on... 11-29-2007, 07:45 AM
jhudler Larry, Walter, I'm wondering... 11-29-2007, 04:00 PM
greybeard OK Jack, your mention of... 11-29-2007, 05:30 PM
the4thseal ok what does "SWMBO" mean? s... 11-29-2007, 06:24 PM
Mcgyver SWMBO = She who must be... 11-29-2007, 06:43 PM
the4thseal it appears i need to make a... 11-29-2007, 08:26 PM
lgalla Harryn,good you talked to the... 11-29-2007, 11:42 PM
greybeard .......and for dogs chasing... 11-30-2007, 12:00 AM
jhudler Question, is this attempt at... 11-30-2007, 01:09 AM
lgalla My shortest post ever,Yes for... 11-30-2007, 01:32 AM
harryn For my goals: - I would like... 11-30-2007, 02:32 AM
lgalla In the jist of trying to keep... 11-30-2007, 03:10 AM
ckelloug Howdy all, My new building... 11-30-2007, 06:31 PM
jhudler He was looking for a flat and... 11-30-2007, 08:58 PM
harryn Hi, I missed that the torsion... 12-01-2007, 08:04 AM
jhudler Just remember that floor when... 12-01-2007, 05:00 PM
ckelloug Harryn, Thanks for the... 12-01-2007, 05:57 PM
walter Yes, definitely. You can use... 12-02-2007, 07:06 PM
jhudler How about building a flat... 11-30-2007, 03:11 AM
walter DIY Epoxy-Granite surface... 11-30-2007, 07:58 PM
lgalla Walter sure is exciting.If I... 12-01-2007, 03:51 AM
jhudler Sporty! Damn he forgot the... 12-01-2007, 04:11 AM
walter lol Jack How about that... 12-01-2007, 07:08 AM
jhudler :) 12-01-2007, 07:24 AM
jhudler The other day I was finger... 12-01-2007, 07:32 AM
jhudler Interesting observation 12-01-2007, 05:56 AM
walter By volume? 12-01-2007, 06:07 AM
jhudler yes, by volume 12-01-2007, 06:09 AM
jhudler Current formula 12-01-2007, 06:33 AM
jhudler Speaking of "Sporty"... ... 12-01-2007, 04:48 PM
wizard Not experience per say but... 12-27-2007, 12:16 PM
lgalla Harryn,I would not bother... 12-01-2007, 04:52 PM
lgalla Jack,The German guys were... 12-01-2007, 05:21 PM
jhudler The Zeeospheres are a... 12-01-2007, 06:24 PM
harryn Cameron - Yes, PM on its way.... 12-01-2007, 10:56 PM
jhudler I think Gupta's claim that an... 12-02-2007, 05:12 PM
ckelloug Packing Theory vs. Specific... 12-02-2007, 06:02 PM
jhudler I"m using vibration and... 12-02-2007, 06:53 PM
walter Everything goes through the... 12-02-2007, 07:28 PM
jhudler Walter, Thanks, I see the... 12-02-2007, 07:46 PM
greybeard I've just done a quick... 12-02-2007, 08:45 PM
jhudler Yes 12-02-2007, 09:21 PM
jhudler Thick epoxy 12-02-2007, 09:25 PM
Steven.ji For the ploymer concrete,... 12-09-2007, 01:59 PM
walter Epoxy-granite is more of a... 12-10-2007, 08:14 AM
jhudler I am not sure what you are... 12-10-2007, 03:57 AM
ckelloug Stephen.ji, We're... 12-10-2007, 05:56 AM
jhudler I'd make some nasty joke... 12-10-2007, 06:13 AM
lgalla Lucky 12-10-2007, 06:57 AM
jhudler No just your average melamine... 12-10-2007, 07:24 AM
jhudler Walter, How did you hold all... 12-10-2007, 06:36 PM
jhudler 2500 12-10-2007, 06:37 PM
greybeard OK - the party's at your... 12-10-2007, 07:05 PM
jhudler Ok as long you bring the... 12-10-2007, 07:27 PM
walter I glued them in place with... 12-10-2007, 06:58 PM
greybeard ...and Walter brings the... 12-10-2007, 09:04 PM
walter You got it!! Thanks... 12-10-2007, 10:32 PM
lgalla Moglice/Granitan. Found... 12-10-2007, 09:59 PM
jhudler I've been wait'n to try that... 12-10-2007, 10:35 PM
jhudler http://www.schneeberger.com/me... 12-10-2007, 10:55 PM
greybeard er, remember my thoughts on... 12-10-2007, 11:03 PM
lgalla Some new Zanite guidlines:... 12-10-2007, 11:18 PM
jhudler WHOA! "ZANITE composite has a... 12-11-2007, 12:35 AM
tmarks11 anybody happen to mention yet... 12-11-2007, 12:43 AM
walter That sounds more like Datron... 12-11-2007, 01:10 AM
jhudler Nice video! Stiffness... 12-11-2007, 03:15 AM
fdew Just a quick hello right now.... 12-14-2007, 03:33 AM
ckelloug fdew, Welcome to the Epoxy... 12-14-2007, 04:29 PM
wizard We have to thank your friend!... 12-27-2007, 10:36 AM
jhudler Frank, First welcome to the... 12-15-2007, 05:24 AM
fdew Your machines look good on... 12-16-2007, 05:50 PM
jhudler Frank, that's a lot to... 12-18-2007, 05:01 AM
ckelloug Please Don't Post Proprietary... 12-18-2007, 06:37 AM
harryn Thanks for stopping by... 12-18-2007, 06:49 PM
jhudler Mixers 12-18-2007, 06:57 PM
harryn Uhm - I think it is actually... 12-19-2007, 02:33 AM
jhudler E/G has a long open time and... 12-19-2007, 04:34 AM
ckelloug The polyethylene drum has the... 12-20-2007, 06:12 PM
walter Here's a translated version... 12-23-2007, 08:54 PM
greybeard Cameron - I've just tripped... 12-23-2007, 11:43 PM
jhudler Greybeard, you ever see this... 12-29-2007, 05:33 PM
walter Ok this one took a bit but I... 12-24-2007, 09:51 AM
jumper Epoxy grout has been used for... 12-24-2007, 04:18 PM
jhudler Anyone know what's the... 12-24-2007, 04:18 PM
greybeard I've posted this as an... 12-24-2007, 04:53 PM
jhudler Release agent 12-29-2007, 12:11 AM
lgalla Jack,sure looks like PVA.For... 12-29-2007, 01:20 AM
jhudler Larry, One picture from... 12-29-2007, 03:49 AM
greybeard Hi Jack. No, I've not come... 12-29-2007, 05:52 PM
jhudler John, BTW your aggregate... 12-29-2007, 06:14 PM
greybeard The latter. I decided that... 12-29-2007, 06:38 PM
walter Weekend reading: Self... 12-30-2007, 08:22 PM
harryn Gee, I wonder how similar... 12-31-2007, 09:05 AM
walter Walter bags a big one. 12-30-2007, 08:41 PM
Zumba Those crazy Germans sure like... 12-31-2007, 12:38 PM
ckelloug Wow Walter and John, These... 12-31-2007, 05:34 PM
greybeard Well, I've finally started. ... 01-01-2008, 07:39 PM
jhudler Nice find Walter! Wow... 12-30-2007, 10:35 PM
greybeard Nice ones Walter. I'm... 12-30-2007, 11:09 PM
walter John, Nice to see your... 12-31-2007, 06:45 AM
greybeard Fascinating reading Harry. I... 12-31-2007, 11:13 AM
lgalla hi Guys, I stated from the... 01-02-2008, 05:00 AM
speed33317 Germans 01-02-2008, 05:13 AM
peach mcclure what is an 80/20 frame? 01-02-2008, 08:59 AM
RotarySMP The German guys really don't... 01-02-2008, 11:09 AM
thomasz Hello all an a good new year!... 01-02-2008, 06:50 PM
the4thseal Those Italian Elte HF... 01-02-2008, 07:03 PM
walter Thanks for the info Thomas.... 01-02-2008, 07:58 PM
speed33317 This thread 01-03-2008, 02:53 AM
ckelloug Status 01-03-2008, 03:37 AM
Jay C Ah, now this is something I... 01-03-2008, 05:29 AM
RotarySMP Servus Thomas, Danke fürs... 01-03-2008, 05:53 PM
thomasz Hello Mark! Danke - immer... 01-03-2008, 06:19 PM
the4thseal is there a us distributor for... 01-03-2008, 07:31 PM
thomasz Hello the4thseal! I don't... 01-03-2008, 10:09 PM
brunog Cameron, Isn't it surprising... 01-04-2008, 01:36 AM
ckelloug Bruno, The difference... 01-04-2008, 01:55 AM
speed33317 This thread 01-04-2008, 03:30 AM
jhudler Found this today;... 01-06-2008, 04:07 AM
ckelloug Jack, What seems... 01-06-2008, 05:36 AM
jhudler DOH!! Drainbramge... I... 01-06-2008, 06:22 AM
walter I guess the big question is -... 01-06-2008, 10:40 PM
brunog Gret Info Jack! Best... 01-06-2008, 05:57 PM
greybeard Getting near to mixing up... 01-06-2008, 07:48 PM
greybeard On second thoughts, I can see... 01-06-2008, 08:28 PM
ckelloug John, The simplest... 01-06-2008, 10:04 PM
greybeard Hi Cameron. To be as consise... 01-06-2008, 10:45 PM
ckelloug Walter, We're probably... 01-07-2008, 02:03 AM
harryn Cameron, since real life... 01-07-2008, 03:54 AM
jhudler "short carbon fibers!" MINE!... 01-07-2008, 04:00 AM
walter LOL!! ... 01-07-2008, 04:18 AM
ckelloug Harryn, The model that... 01-07-2008, 08:11 AM
jhudler Can't get that vibrating... 01-07-2008, 04:07 AM
thomasz Morning! Here a link to a... 01-07-2008, 09:12 AM
greybeard Hi Thomas. Thank you for... 01-07-2008, 10:13 PM
walter Thomas, is Moglice a German... 01-07-2008, 05:42 PM
thomasz Hello Walter! Yes - we... 01-07-2008, 05:45 PM
walter Amazing stuff. Can you mount... 01-07-2008, 05:49 PM
jhudler Walter, If all you are... 01-08-2008, 04:02 AM
harryn Interestingly, there are some... 01-08-2008, 05:03 AM
thomasz Hello Walter! Yes, but... 01-07-2008, 07:13 PM
walter Let's say I take this master... 01-07-2008, 07:23 PM
thomasz Hello agin! Yes, thats the... 01-07-2008, 07:44 PM
walter Very good info, thank you.... 01-07-2008, 07:49 PM
walter DWH310FL 01-08-2008, 01:32 AM
walter Yeah, I've seen the... 01-08-2008, 04:30 AM
jhudler Damit! I knew you were going... 01-08-2008, 04:38 AM
walter Mine's broke. But it's been... 01-08-2008, 04:42 AM
jhudler Lapping is something a kin to... 01-09-2008, 08:05 AM
lgalla rails and rails&rails 01-08-2008, 05:32 AM
magick_man I just wanted to thank you... 01-12-2008, 06:16 AM
walter "rails!" MINE! MINE!... 01-08-2008, 05:35 AM
the4thseal i did not know that those... 01-08-2008, 07:01 AM
lgalla THK SR series are best for... 01-08-2008, 07:36 AM
the4thseal that makes sense thank you. 01-08-2008, 08:29 AM
thomasz Hello John! These... 01-08-2008, 12:08 PM
thomasz Hello again! Here some... 01-08-2008, 12:56 PM
thomasz ... and again 50135 ... 01-08-2008, 12:58 PM
walter Thanks for all the useful... 01-08-2008, 06:38 PM
greybeard I just know this post might... 01-09-2008, 12:00 AM
harryn ThomasZ - have you by chance... 01-09-2008, 01:47 AM
jhudler Ouch! Sure you can't redesign... 01-09-2008, 08:14 AM
walter I wouldn't worry about that.... 01-09-2008, 08:44 AM
USMCPOP I haven't seen most of this... 01-17-2008, 07:34 PM
harryn Hi - Thanks for joining into... 01-17-2008, 09:47 PM
walter Still no picture... :-) 01-09-2008, 08:19 AM
jstransky Quarz sand 01-10-2008, 09:16 AM
jhudler Never got around to lapping... 01-09-2008, 08:29 AM
jhudler Hey who's going to do the... 01-09-2008, 08:34 AM
vishnu Thats a good job. Like to see... 01-09-2008, 07:13 PM
walter Nope. I finished the castings... 01-09-2008, 08:41 PM
ckelloug Walter, Are you talking... 01-09-2008, 08:47 PM
Eson Found this, nothing new but... 01-10-2008, 12:11 AM
jhudler jstransky, Sand filters... 01-10-2008, 06:19 PM
jstransky Sand size ? 01-10-2008, 06:51 PM
jhudler jstransky, If that is all... 01-11-2008, 05:30 PM
jhudler Surface Puck! 01-11-2008, 06:24 PM
Eson That's sick! Unbelievable... 01-11-2008, 07:38 PM
Zumba Very nice work, Jack. No... 01-14-2008, 10:18 AM
jhudler Walter purchased his at Cary... 01-14-2008, 03:56 PM
ckelloug Jack, Your video of... 01-15-2008, 07:38 PM
jhudler About a little over an hour.... 01-16-2008, 01:09 AM
Gizmot funny that you mention that.... 01-16-2008, 05:18 PM
Eson Does anyone know any price... 01-16-2008, 09:21 PM
lerman Please let me know what you... 01-16-2008, 10:23 PM
harryn Hi Ken, I had no idea you... 01-17-2008, 05:08 PM
lgalla Ken, I would not use a plain... 01-19-2008, 01:54 AM
Dan S has anyone tried acrylic... 01-19-2008, 02:05 AM
lerman What I had in mind was first... 01-19-2008, 02:42 AM
jhudler I would read about Henry... 01-19-2008, 04:12 AM
lazlo Larry, I think you may... 01-24-2008, 04:14 AM
jhudler Well... I guess that would... 01-18-2008, 06:26 AM
ckelloug Larry, Since zeeospheres... 01-18-2008, 07:01 AM
Eson Well im not sure what i am... 01-19-2008, 04:40 AM
jhudler Are you trying to build... 01-19-2008, 05:15 AM
USMCPOP Well, I just thought I'd... 01-17-2008, 10:57 PM
ckelloug usmcpop, Take a look at... 01-17-2008, 11:56 PM
Zumba Those fillers may be... 01-18-2008, 03:25 AM
USMCPOP Cameron, I wasn't... 01-18-2008, 12:33 AM
harryn One of the reasons that so... 01-18-2008, 01:07 AM
lgalla Zumba, Confucius Say:Man... 01-18-2008, 04:14 AM
jhudler Photomicrograph of 200... 01-18-2008, 08:14 AM
jhudler Order of magnitude higher and... 01-18-2008, 08:17 AM
ckelloug I never did trust gupta and... 01-18-2008, 06:40 PM
Dan S I just finished reading this... 01-18-2008, 11:30 PM
greybeard Welcome and well done Dan. If... 01-18-2008, 11:53 PM
jhudler Acrylic Water would be in the... 01-19-2008, 02:23 AM
Dan S I stopped by hobby lobby on... 01-19-2008, 04:22 AM
jhudler That Quick Water is almost 3... 01-19-2008, 04:54 AM
Dan S I have half a gallon of... 01-19-2008, 05:37 AM
jhudler Larry, Did you find a... 01-19-2008, 02:24 AM
jhudler Kenneth, In order to lap... 01-19-2008, 03:18 AM
lgalla Ken,I understand now.A long... 01-19-2008, 03:50 AM
jhudler Dan, What does it say on the... 01-19-2008, 04:29 AM
jhudler It's a Urethane (Isocyanate),... 01-19-2008, 04:45 AM
brunog Dan, Don't worry about the... 01-19-2008, 06:10 AM
jhudler Dan, You'd want to use the #3... 01-19-2008, 11:27 AM
jhudler Wow a idea just smacked me... 01-19-2008, 05:44 PM
brunog Alternate solution 01-19-2008, 06:03 PM
MaX-MoD Hello, it's a little bit... 02-20-2008, 07:12 PM
greybeard Er,one tube, or do I misread... 01-19-2008, 07:08 PM
jhudler Bruno, That would certianly... 01-19-2008, 07:09 PM
jhudler John, See picture. The cap's... 01-19-2008, 07:23 PM
jhudler I've got to get me some... 01-19-2008, 07:30 PM
greybeard I think I misread the concept... 01-19-2008, 07:33 PM
brunog Moglice 01-19-2008, 10:21 PM
jhudler Bloody ell I need to keep... 01-19-2008, 10:39 PM
ger21 Cheap on Ebay.... 01-19-2008, 11:37 PM
karmicthreat Wow, you guys have really... 01-20-2008, 12:01 AM
lgalla Gerry's link as has teflon... 01-19-2008, 11:45 PM
lgalla '"Bruno, That would certianly... 01-20-2008, 02:33 AM
jhudler Larry, I had imagined a large... 01-20-2008, 03:24 AM
brunog Jack, I suggest adding about... 01-20-2008, 04:23 AM
jhudler Yep I think your right, that... 01-20-2008, 04:41 AM
brunog Larry, Did you receive my... 01-20-2008, 04:40 AM
brunog Jack, I believe zeeospheres... 01-20-2008, 04:44 AM
jhudler 100 Grams total: powders... 01-20-2008, 05:01 AM
lgalla Bruno& Jack. The... 01-20-2008, 05:21 AM
jhudler Larry, From what I've seen in... 01-20-2008, 05:32 AM
greybeard An experiment to justify... 01-20-2008, 01:41 PM
brunog optimal volume 01-21-2008, 02:49 PM
greybeard If you use 2.2gm/cc for the... 01-21-2008, 11:04 PM
brunog John, I redid my math on the... 01-22-2008, 01:44 AM
rad45 Hi People, I know very... 01-21-2008, 11:30 AM
greybeard Welcome rad45. It's always... 01-21-2008, 02:10 PM
ckelloug Hi rad45, You are on the... 01-21-2008, 03:39 PM
greybeard I can see where you're going,... 01-21-2008, 03:23 PM
brunog John, Holly sh...,:eek: I... 01-21-2008, 05:56 PM
greybeard "Collapsed" as in "when... 01-21-2008, 04:43 PM
greybeard It's been a funny day here. ... 01-21-2008, 04:48 PM
ckelloug John, The viscosity... 01-21-2008, 04:53 PM
greybeard Respect to Walter. I think he... 01-21-2008, 05:08 PM
greybeard Bruno, I think you've given... 01-21-2008, 07:17 PM
lgalla Cabosil is not a lightweight... 01-21-2008, 09:33 PM
brunog John, at 2.2g/cc density my... 01-21-2008, 10:14 PM
jetski Pet Rock 01-21-2008, 10:10 PM
greybeard For the purposes of clarity... 01-21-2008, 10:10 PM
jhudler Really should have a variable... 01-21-2008, 11:13 PM
greybeard For beaker, read 100ml... 01-21-2008, 11:29 PM
jhudler That Dimmer has to work with... 01-21-2008, 11:42 PM
lgalla Adding Fumed Silica to... 01-22-2008, 12:24 AM
jhudler One needs to computer the... 01-22-2008, 03:51 AM
ckelloug My original purpose in adding... 01-22-2008, 08:12 AM
greybeard For a while I thought you... 01-22-2008, 08:09 PM
ckelloug dang, In the postings by... 01-23-2008, 12:14 AM
jkeyser14 I definitely agree with their... 01-23-2008, 03:47 AM
dang I'd hate to change the... 01-22-2008, 09:40 AM
romihs FS2MG 01-22-2008, 12:59 PM
lgalla Robert, I am not very good... 01-24-2008, 04:48 AM
lazlo Hi Larry, The stock Nook... 01-24-2008, 06:03 AM
jhudler Try... 01-27-2008, 03:57 PM
ckelloug Well, I did it. I hacked... 01-29-2008, 08:12 AM
BobWarfield Gentlemen, I invested most of... 01-30-2008, 05:38 PM
ckelloug Bob, Filling the machine... 01-30-2008, 10:18 PM
jhudler In the vibration damping mass... 01-31-2008, 02:00 AM
BobWarfield No issue with the vacuum... 01-31-2008, 02:45 AM
jhudler Pool sands are typically... 01-31-2008, 03:38 AM
jhudler About the PVC. Different... 01-31-2008, 03:58 AM
BobWarfield It isn't the force involved,... 01-31-2008, 05:57 AM
jhudler I didn't include the warning... 01-31-2008, 06:17 AM
ckelloug I agree with Bob on the PVC... 01-31-2008, 08:33 AM
jhudler Thought just hit me reading... 01-31-2008, 06:14 AM
lgalla BW and Jack, I might add... 01-31-2008, 07:22 AM
jhudler PVC Pipe is designed to... 01-31-2008, 11:26 AM
greybeard Jack - re the high cost of... 01-31-2008, 12:54 PM
BobWarfield Larry, a pressure pot... 01-31-2008, 05:09 PM
ckelloug Bob's post and a PM I just... 01-31-2008, 09:40 PM
ckelloug The Compressible Packing... 02-01-2008, 12:29 AM
greybeard Cameron - is it reasonable to... 02-01-2008, 12:41 AM
ckelloug John, thanks for the... 02-01-2008, 12:52 AM
greybeard Looking ahead, the only fly... 02-01-2008, 01:02 AM
ad_bfl Thanks for the pdf Cameron, I... 02-01-2008, 01:47 AM
lerman For ordinary stuff (sand,... 02-01-2008, 01:47 AM
lerman Cameron, Thanks for... 02-01-2008, 02:13 AM
ckelloug Ken, I think I didn't... 02-01-2008, 03:36 AM
greybeard Hi Gizmot. I agree with you... 02-01-2008, 06:19 PM
Quad2T ITW Polymer Technologies... 02-02-2008, 02:36 AM
greybeard Cameron - With my last... 02-02-2008, 02:15 PM
ckelloug John, I think we still... 02-02-2008, 05:11 PM
greybeard Thanks for your thoughts,... 02-02-2008, 05:47 PM
lerman As soon as I get my program... 02-02-2008, 06:08 PM
BobWarfield The trouble with computers in... 02-02-2008, 05:51 PM
sigma relief I've been lurking for a... 02-03-2008, 06:01 AM
jhudler John, This statement was... 02-03-2008, 05:32 PM
ckelloug I'm behind right now but I'm... 02-03-2008, 05:50 PM
sigma relief My Non Linear materials... 02-05-2008, 05:16 AM
greybeard Cameron - well, I went to the... 02-03-2008, 11:35 AM
sigma relief I was doing some thinking... 02-03-2008, 06:45 PM
speed33317 How about this 02-04-2008, 01:54 AM
ad_bfl What about starting with the... 02-04-2008, 05:28 PM
ckelloug I've been running the sim... 02-04-2008, 06:00 PM
jhudler Let me preface by saying; I... 02-04-2008, 03:13 AM
KristerW You might want to check out... 02-04-2008, 11:39 AM
greybeard Welcome Krister. You'll find... 02-04-2008, 03:05 PM
ckelloug KristerW, Welcome. Thomas... 02-04-2008, 04:53 PM
jhudler Metal powders on eBay 02-05-2008, 05:24 AM
BobWarfield John, the brute force method... 02-05-2008, 05:51 AM
ckelloug sigma_relief, It sounds... 02-05-2008, 01:35 PM
greybeard Meanwhile, back at the... 02-05-2008, 04:58 PM
ckelloug greybeard, If you would... 02-05-2008, 08:03 PM
greybeard :eek:.. as I feared. ... 02-05-2008, 10:16 PM
jhudler Spot on as you lot say. The... 02-05-2008, 11:30 PM
ckelloug Reichhold actually recommends... 02-06-2008, 03:14 PM
lgalla Jack here are some spec's on... 02-06-2008, 12:01 AM
acondit Another Lurker, I have... 02-07-2008, 09:36 PM
ckelloug Welcome Alan and the other... 02-07-2008, 11:59 PM
BobWarfield I regret to inform you that... 02-08-2008, 12:24 AM
jhudler Why that's as clear as a... 02-08-2008, 12:27 AM
ckelloug Sorry to post jokes about the... 02-08-2008, 03:39 AM
acondit I have been working on a... 02-10-2008, 06:15 PM
ckelloug Alan, I have no experience... 02-11-2008, 01:22 AM
acondit Cameron, The column on a... 02-11-2008, 03:32 AM
ckelloug Alan, I saw your PM and... 02-12-2008, 12:06 AM
greybeard Cameron -if I spin test... 02-12-2008, 08:49 AM
Gizmot pretty much what I was... 02-12-2008, 02:06 PM
ad_bfl One thing not discussed in... 02-12-2008, 05:08 PM
romihs ad_bfl, A quick, and... 02-12-2008, 10:07 PM
jhudler Sound card is great for this.... 02-13-2008, 04:55 PM
greybeard Further question to the above... 02-13-2008, 09:43 AM
lgalla Alan there has been... 02-12-2008, 10:26 PM
roach been making "GRANITAN" for 24... 02-12-2008, 10:48 PM
ckelloug ad_bfl, Really accurate... 02-12-2008, 10:54 PM
ckelloug Hey roach, Welcome to the... 02-12-2008, 10:56 PM
lgalla Sandi,I don't think... 02-14-2008, 09:55 PM
sigma relief Igalla I understand the... 02-15-2008, 04:11 AM
ckelloug sigma_relief John, Don't... 02-15-2008, 05:12 AM
jhudler Ok you stole this quote from... 02-15-2008, 05:53 AM
lgalla Sandi,John, Thanks for the... 02-15-2008, 04:03 PM
jhudler Larry, Is that real concrete... 02-15-2008, 06:36 PM
lgalla Sorry Jack, that is an old... 02-15-2008, 07:19 PM
ad_bfl Hi Larry Stiff does make a... 02-15-2008, 08:04 PM
roach we're making a m/ctool at the... 02-20-2008, 08:18 PM
lerman Cameron, Am I still... 02-20-2008, 11:41 PM
lerman Cameron, Looking at my... 02-21-2008, 12:46 AM
LN-JET Hello all, lurker here. I... 02-15-2008, 09:13 PM
romihs John K, I am thinking of a... 02-15-2008, 10:51 PM
jhudler Lars, A good media blasting... 02-16-2008, 05:23 AM
brunog Larry, This might sound... 02-16-2008, 02:15 AM
lgalla Hi Brunog, Vertical is great... 02-16-2008, 03:29 AM
ger21 If you're using these tools... 02-16-2008, 07:15 AM
ckelloug Modeling Paper Update 02-16-2008, 09:36 AM
jhudler Larry, I've had in the back... 02-16-2008, 05:55 AM
sigma relief Cameron, If I am... 02-20-2008, 03:01 AM
ckelloug John K, This particular... 02-20-2008, 04:20 PM
greybeard Silly question - deleted. 02-22-2008, 04:52 PM
jhudler Good point. If I recall,... 02-25-2008, 04:34 PM
sigma relief hmm, not sure where all the... 02-26-2008, 02:28 AM
roach im a shy person till im drunk... 02-29-2008, 10:28 PM
roach oi where r u all 03-01-2008, 12:29 AM
ckelloug Hey Roach, Cool post. ... 03-01-2008, 04:03 AM
Zumba Hey folks, Been away from... 03-02-2008, 09:31 PM
Zumba While on the topic of big... 03-02-2008, 10:39 PM
romihs Zumba, Data in this PDF... 03-03-2008, 12:51 AM
Zumba Thanks Sandi. How does... 03-03-2008, 02:43 AM
lgalla Cameron, Would nesting... 03-03-2008, 05:02 AM
roach the sizes are just sieve... 03-03-2008, 09:55 PM
roach only called it "granitan"... 03-03-2008, 10:01 PM
BobWarfield FYI, I have embarked on a... 03-04-2008, 05:18 AM
lgalla Good work Bob! It is good to... 03-04-2008, 05:56 AM
BobWarfield Hi Larry. Yes, the sand was... 03-04-2008, 06:17 AM
ironDigit couldn't it be that the... 03-04-2008, 09:39 PM
BobWarfield In a word, YES! Time to... 03-04-2008, 10:11 PM
ckelloug Well, I think that Bob... 03-05-2008, 07:32 AM
BrendaEM Does anyone have a... 03-05-2008, 03:26 PM
jhudler This is one of the problems... 03-06-2008, 03:11 AM
the4thseal where are you buying the... 03-06-2008, 04:02 AM
jhudler I bought some from AGSCO, and... 03-06-2008, 06:50 AM
jhudler Let see; Velocity, Linear... 03-07-2008, 12:24 AM
BobWarfield Amazing results are possible... 03-07-2008, 04:39 AM
lgalla It would be great to get sand... 03-07-2008, 05:27 AM
jhudler I've washed and dryed all the... 03-07-2008, 07:05 AM
Eson Would Ultra sound washers... 03-07-2008, 01:38 PM
jhudler No, in fact that would be a... 03-07-2008, 02:51 PM
roach yes should be about 2500kg/m... 03-07-2008, 04:42 PM
roach you can buy kiln dried sand... 03-07-2008, 04:46 PM
jhudler So that would be Huntsman... 03-07-2008, 06:43 PM
Zumba Is this resin available in... 03-08-2008, 11:00 PM
Zumba Edit: nevermind 03-08-2008, 11:05 PM
jhudler EG/LF - Epoxy Granite / Low... 03-09-2008, 09:20 PM
brunog Nice work Jack! I suggest... 03-09-2008, 09:54 PM
jhudler I sprayed "EPOXEASE" release... 03-09-2008, 11:03 PM
romihs Jack, Amassing job you did... 03-09-2008, 11:19 PM
jhudler Thanks! The original... 03-09-2008, 11:52 PM
jhudler Just played with it now that... 03-09-2008, 11:24 PM
brunog Jack, How thick is the low... 03-10-2008, 02:01 AM
jhudler It's an 1/8 of an inch...... 03-10-2008, 02:11 AM
BrendaEM Only as thick as a mint? 03-10-2008, 04:55 PM
jhudler We we... a "wafer-thin mint"... 03-10-2008, 05:29 PM
roach coarse you have to be careful... 03-10-2008, 09:24 PM
brunog Jack, have you started... 03-15-2008, 05:56 PM
jhudler Bruno, I've only done some... 03-16-2008, 04:16 AM
lgalla Jack,never heard of reagent... 03-17-2008, 02:11 AM
jhudler The isopropyl (rubbing, IPA)... 03-17-2008, 02:57 AM
lgalla Jack,ever thought of trying... 03-17-2008, 03:23 AM
jhudler Shhhhh! that's next 03-17-2008, 02:23 PM
greybeard Acme nuts as turkey stuffing... 03-17-2008, 09:29 AM
jhudler Found Dallas,Texas supplier... 03-17-2008, 09:00 PM
roach you misunderstood me we wash... 03-18-2008, 07:27 PM
jhudler The granite we get is stored... 03-19-2008, 03:19 AM
lgalla I may be labeled Benedict... 03-18-2008, 10:02 PM
romihs Roach, Do you guys... 03-18-2008, 11:00 PM
USMCPOP Has anyone made any granite... 03-18-2008, 11:03 PM
Zumba Material costs of E/G are... 03-18-2008, 11:23 PM
jhudler :eek: I have more eloquent,... 03-19-2008, 02:02 AM
Gizmot he's a frenchman? where... 03-19-2008, 04:02 AM
lgalla Oui Je suis francais de... 03-19-2008, 04:40 AM
roach not personally our supplier... 03-19-2008, 07:22 PM
brunog Larry, I can just feel the... 03-19-2008, 11:00 PM
jhudler Acadiens! You mean some... 03-20-2008, 04:53 AM
lgalla Jack ya got-it... 03-20-2008, 05:33 AM
jhudler Guess the joke is lost in... 03-20-2008, 02:21 PM
roach some companies do use this... 03-20-2008, 09:59 PM
roach ive done it so if u need help... 03-20-2008, 10:01 PM
jhudler I can't bring myself to punch... 03-25-2008, 04:23 AM
sergizmo I'll try it with a standard... 03-25-2008, 05:05 AM
jhudler GFCI 03-25-2008, 05:24 AM
garfieldsimons Diamond hole saws 03-25-2008, 02:50 PM
roach diamond holesaws are best but... 03-28-2008, 12:51 AM
sergizmo I already have the granite... 03-28-2008, 05:17 AM
jhudler Seriously, you 're worrying a... 03-28-2008, 06:24 AM
brunog Serge, If drilling holes in... 03-30-2008, 04:57 AM
sergizmo Bruno, I think drilling... 03-30-2008, 08:59 PM
speed33317 I am going to cheat 03-31-2008, 12:34 AM
speed33317 3000 03-31-2008, 12:35 AM
dsquire Cheating!!! 03-31-2008, 12:45 AM
BrendaEM For drilling holes, if you... 03-30-2008, 10:16 AM
jhudler Thought I would followup with... 04-01-2008, 08:40 PM
romihs Ckelloug, Good things come... 04-01-2008, 08:58 PM
lgalla On the testing; Would... 04-01-2008, 09:10 PM
ckelloug Larry, Funny you should... 04-01-2008, 09:43 PM
jhudler It was 2 hours... the post... 04-02-2008, 02:29 AM
lgalla the starting pistol has... 04-02-2008, 04:49 AM
jhudler 120C/250F! Damn I'm still... 04-02-2008, 05:11 AM
ckelloug So Far So Bad. . . Well, I... 04-02-2008, 03:11 PM
jhudler Mix more than you need, then... 04-02-2008, 07:38 PM
ckelloug I'll echo greybeard that... 04-02-2008, 08:08 PM
greybeard :o Polymer chemistry, yes... 04-02-2008, 08:24 PM
sigma relief Its great to see some real... 04-03-2008, 03:35 AM
lgalla race update 04-03-2008, 06:18 AM
ckelloug Well, I've learned a bit... 04-04-2008, 05:55 AM
jhudler which begs the question;... 04-04-2008, 06:24 AM
ckelloug Jack, In answer to your... 04-04-2008, 03:44 PM
lgalla I was taught to have slightly... 04-04-2008, 04:29 PM
harryn Factorial Analysis 04-04-2008, 08:27 PM
harryn Post Cure Temperature 04-04-2008, 08:38 PM
ckelloug harryn, Good Call and nice... 04-04-2008, 08:45 PM
greybeard My first read through... 04-04-2008, 10:28 PM
ckelloug Epoxy Test Results 04-06-2008, 05:51 AM
ckelloug Zumba, Thanks for the tip.... 04-06-2008, 06:15 AM
Zumba Cameron, those are some... 04-06-2008, 05:22 AM
lgalla Apparently Northrop Grumman... 04-07-2008, 03:44 AM
ckelloug To really have fun however,... 04-07-2008, 04:28 AM
Zumba I started using epoxy when I... 04-07-2008, 05:55 AM
greybeard Cameron - Is this to suggest... 04-07-2008, 08:54 AM
brunog Epoxitech makes an epoxy... 04-07-2008, 09:24 PM
mp006ltk best formula 04-07-2008, 10:12 PM
sigma relief hmm, must not have hit post... 04-08-2008, 04:24 AM
ckelloug greybeard John, Spin... 04-08-2008, 08:49 AM
greybeard Hi John. I think this is the... 04-08-2008, 09:34 AM
sigma relief greybeard I am concerned... 04-08-2008, 11:15 PM
greybeard John - thank you for your... 04-09-2008, 09:05 AM
sigma relief I am a little worried that... 04-10-2008, 03:28 AM
lgalla Recent observations. I... 04-10-2008, 05:10 AM
harryn Design of Experiments 04-10-2008, 05:24 PM
ad_bfl That would definitely be a... 04-10-2008, 10:44 PM
ckelloug sigma John, Strength and... 04-11-2008, 04:11 AM
ckelloug This is a repost of a link... 04-11-2008, 04:23 AM
jhudler Silica will start to melt... 04-11-2008, 04:11 AM
harryn Hi - I wasn't very clear. I... 04-11-2008, 04:47 AM
rowbare Cameron, Some posts back,... 04-10-2008, 05:42 PM
roach no when it breaks it should... 04-10-2008, 07:03 PM
roach ill try a pic of the matrix... 04-10-2008, 08:56 PM
sigma relief hmm, this is twice I've... 04-11-2008, 04:40 AM
ckelloug sigma John, Sorry not to... 04-11-2008, 05:46 AM
harryn Hi Cameron - I think your... 04-15-2008, 04:25 PM
corrie Very interesting thread,crazy... 04-16-2008, 03:19 AM
greybeard Cameron - The only "modulus"... 04-11-2008, 08:17 AM
ckelloug Mastering Moduli 04-11-2008, 01:52 PM
greybeard That's good news - we're... 04-11-2008, 02:41 PM
roach to me your way too hot for... 04-11-2008, 06:45 PM
sigma relief Cameron, I have a lot of... 04-12-2008, 01:08 AM
ckelloug sigma John, I think your... 04-12-2008, 07:50 PM
jhudler 37-606 may not be ideal... 04-15-2008, 03:50 AM
ckelloug For the record, Silane is... 04-15-2008, 03:57 AM
jhudler Oh.. I forgot... define... 04-15-2008, 03:56 AM
lgalla no puns 04-15-2008, 05:25 AM
brunog Roach, Slow down, you type... 04-19-2008, 04:23 PM
lgalla dfro, could not have said it... 04-20-2008, 04:29 AM
dfro Larry, Your response is... 04-20-2008, 05:37 AM
Zumba Interesting link from Roach. ... 04-20-2008, 05:07 PM
greybeard ... and then switches to... 04-20-2008, 06:07 PM
ckelloug greybeard, Do you have any... 04-20-2008, 07:46 PM
Preston E Hello Cameron, What your... 04-21-2008, 10:26 PM
greybeard Hi Cameron. Unfortunately... 04-20-2008, 08:55 PM
roach funny? 04-21-2008, 07:36 PM
jhudler Using 37-127/37-606 the pot... 04-22-2008, 11:09 AM
Preston E Hi Jack, The typical way... 04-22-2008, 02:18 PM
ckelloug Jack, It's interesting... 04-22-2008, 02:49 PM
Preston E Cameron, Salvador Monte is a... 04-22-2008, 03:11 PM
Steven.ji In China, more and more... 04-28-2008, 01:48 PM
Zumba If box ways were a good idea... 04-30-2008, 07:41 PM
Guest Not necessarily. Box members... 05-01-2008, 02:06 AM
Zumba :confused: You've got some... 05-01-2008, 06:56 AM
greybeard I'm losing a lot of time with... 05-01-2008, 09:21 PM
greybeard Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa... 05-02-2008, 05:34 PM
Steven.ji Is it possible to bond... 05-03-2008, 01:48 PM
jhudler Yes you can. 05-03-2008, 06:23 PM
greybeard Jack, that was very succinct.... 05-03-2008, 09:35 PM
jhudler Didn't want to over... 05-04-2008, 02:11 AM
greybeard Persevering, but...... 05-03-2008, 10:38 PM
greybeard Managed to pick up a working... 05-04-2008, 12:38 PM
greybeard Great - we move forward.... 05-05-2008, 09:45 PM
romihs John, Those samples look... 05-05-2008, 10:19 PM
greybeard Hi Sandi. I've had them on... 05-06-2008, 07:08 AM
ckelloug John, Your work is... 05-06-2008, 09:59 AM
greybeard Er, yes. We gave up the... 05-06-2008, 10:39 AM
ckelloug For real fun, try putting an... 05-06-2008, 10:43 AM
romihs John, That photo is very... 05-06-2008, 11:26 AM
greybeard Sandi - if I reduced the... 05-06-2008, 11:55 AM
greybeard Cameron - the samples are now... 05-08-2008, 12:52 PM
harryn The high resolution ones are... 05-08-2008, 04:32 PM
roach steven.ji ive seen your pic... 05-09-2008, 08:11 PM
greybeard A question for the... 05-10-2008, 10:44 PM
ckelloug John, I ran the model. I... 05-11-2008, 06:20 AM
greybeard Am I right in assuming,... 05-11-2008, 07:09 AM
ckelloug I'd say yes. The reason that... 05-11-2008, 07:18 AM
greybeard So, my summing up might be... 05-11-2008, 07:43 AM
romihs Sieves 05-12-2008, 12:04 PM
greybeard Sandi - The sieves in my... 05-12-2008, 10:39 PM
greybeard Sieve making for the... 05-13-2008, 09:36 PM
probinson Particulate Sorting 05-14-2008, 03:03 AM
greybeard Hi Pete - and welcome. I like... 05-14-2008, 08:24 AM
probinson It could be even simpler that... 05-14-2008, 01:51 PM
Pakou epoxy/granite or... 05-14-2008, 10:51 AM
greybeard Welcome Pakou. The reason... 05-14-2008, 12:25 PM
greybeard Nice one Pete. :D John 05-14-2008, 02:23 PM
roach pakou the exothermic reation... 05-14-2008, 08:34 PM
ckelloug Need favor in Lexington, VA 05-16-2008, 12:00 AM
roach is that anywhere near... 05-16-2008, 07:06 PM
ckelloug John, I got the sample set... 05-18-2008, 12:25 AM
greybeard Great. I'm going to produce a... 05-18-2008, 08:02 AM
greybeard Ooops.... 05-23-2008, 02:31 PM
greybeard Herewith todays results,... 05-24-2008, 05:18 PM
ckelloug I'm still on travel and thus... 05-24-2008, 11:11 PM
probinson John, Once you have a... 05-27-2008, 08:31 AM
greybeard Thanks Pete, I'll give that a... 05-27-2008, 09:30 AM
probinson John, I wouldn't expect... 05-27-2008, 02:16 PM
greybeard Pete, I may have given you... 05-27-2008, 08:40 PM
probinson Hey John, I hope you don’t... 05-28-2008, 03:54 PM
ckelloug Pete, Anybody who can read... 05-28-2008, 05:03 PM
greybeard Hi Pete. Very happy to have... 05-28-2008, 05:22 PM
greybeard Hi Cameron. Seems I need to... 05-28-2008, 05:23 PM
probinson Hi Cameron, Actually,... 05-28-2008, 11:10 PM
probinson I just took a look at the... 05-29-2008, 12:09 AM
ckelloug Pete, I am a research... 05-29-2008, 12:47 AM
sigma relief John Just a few ideas on... 05-29-2008, 03:24 AM
greybeard So it looks like a... 05-29-2008, 05:21 PM
greybeard I don't know how many of you... 05-29-2008, 08:42 AM
ad_bfl VERY VERY Scary, you just... 05-29-2008, 03:44 PM
sigma relief John, I don't remember... 05-30-2008, 03:43 AM
greybeard JK- funny enough I've been... 05-30-2008, 02:36 PM
probinson Hey John, Split... 05-30-2008, 06:49 PM
greybeard Hi Pete. I should have added... 05-30-2008, 07:43 PM
ckelloug Hi John, I haven't... 06-02-2008, 04:24 PM
greybeard Cameron, I've now collected... 06-03-2008, 10:32 PM
ckelloug John, I'll see if I can't... 06-05-2008, 05:54 AM
ckelloug John, The cpm simulator... 06-07-2008, 08:39 PM
greybeard The percentage column seems... 06-07-2008, 10:36 PM
ckelloug John, That came from the... 06-07-2008, 11:02 PM
greybeard Thanks Cameron. I've just... 06-07-2008, 11:24 PM
ckelloug The sample regimen for ASTM... 06-08-2008, 12:55 AM
greybeard Well, I'm back from sitting... 06-12-2008, 10:14 AM
greybeard OK folks, it's mixing time... 06-14-2008, 05:14 PM
probinson I'd say your best to mix the... 06-14-2008, 08:28 PM
ckelloug I'd agree with pete that... 06-14-2008, 09:02 PM
greybeard Thanks Pete and Cameron.... 06-14-2008, 09:07 PM
greybeard Well, that was fairly... 06-16-2008, 10:51 AM
brunog John, your sample does looks... 06-17-2008, 04:23 AM
greybeard Hi Bruno. Yes, I agree with... 06-17-2008, 12:58 PM
ckelloug John, How have you been... 06-18-2008, 09:31 AM
greybeard Hi Cameron, By weight. ... 06-18-2008, 10:06 AM
greybeard Oops.... destroyed tailstock... 06-18-2008, 12:12 PM
greybeard Cameron, I still have a small... 06-20-2008, 09:31 PM
ckelloug John, Excellent point. A... 06-21-2008, 12:53 AM
greybeard Thanks Cameron. Could you... 06-21-2008, 08:07 AM
greybeard Maths help required ! 06-21-2008, 12:19 PM
ckelloug Samples Sawed 06-22-2008, 07:19 PM
greybeard Could you use 11mm diam rod... 06-22-2008, 07:23 PM
greybeard Another engineering/maths... 06-22-2008, 07:57 PM
ckelloug John, I'm headed over to... 06-22-2008, 08:12 PM
greybeard Perhaps I should have added... 06-22-2008, 08:40 PM
probinson John, A quick calculation... 06-22-2008, 09:23 PM
probinson Actually, my last post brings... 06-22-2008, 09:36 PM
greybeard Thanks for worked example,... 06-22-2008, 09:50 PM
ckelloug Testing of John's First... 06-23-2008, 03:54 AM
probinson Sorry, I missed that detail... 06-23-2008, 11:53 AM
greybeard Hi Pete. An interesting... 06-23-2008, 01:02 PM
ckelloug There is some definite... 06-23-2008, 02:58 PM
greybeard :o Thanks Cameron. :wee: 06-23-2008, 08:52 AM
greybeard Re my post #3224, my plot... 06-23-2008, 03:33 PM
probinson Hmm... So your axis of... 06-23-2008, 05:13 PM
greybeard One of my early postings on... 06-23-2008, 05:54 PM
greybeard I may be absent for a little... 06-25-2008, 09:35 PM
ckelloug John, I posted on the... 06-25-2008, 09:44 PM
greybeard Beat me there by two orders... 06-25-2008, 09:54 PM
ckelloug Ohaus in the U.S. and Canada... 06-25-2008, 10:16 PM
ckelloug John, Back in Post 3200,... 06-27-2008, 06:40 AM
ckelloug Density of mixture vs. number... 06-28-2008, 07:18 PM
ckelloug Initial Report on Hexion... 06-29-2008, 01:09 AM
brunog Cameron, what do you mean ... 06-30-2008, 12:22 AM
ckelloug Hi Bruno, Yup rock sizes. ... 06-30-2008, 02:12 AM
greybeard Cameron - you had me very... 06-30-2008, 08:02 AM
ckelloug gbJohn, Unfortunately, my... 06-30-2008, 08:52 AM
brunog Cameron, Thanks for the... 06-30-2008, 02:08 PM
greybeard Hi Cameron. The dinner party... 06-30-2008, 03:07 PM
ckelloug Beta is the theoretical... 06-30-2008, 03:22 PM
greybeard As I suspected, this is where... 06-30-2008, 04:28 PM
ckelloug The Beta=.6 was used for all... 06-30-2008, 04:48 PM
greybeard So could I suggest that the... 06-30-2008, 04:57 PM
ckelloug Phi is the actual packing... 06-30-2008, 04:59 PM
greybeard phi it is then. :D John 06-30-2008, 05:11 PM
greybeard Cameron, how would the... 06-30-2008, 09:41 PM
ckelloug gbJohn, Here is the... 07-01-2008, 03:43 AM
greybeard Thanks for the figures,... 07-01-2008, 06:29 AM
ckelloug John, Here's the sim... 07-01-2008, 02:50 PM
greybeard Interesting. The increase in... 07-01-2008, 05:01 PM
ckelloug John, Cool on the beta... 07-01-2008, 05:32 PM
greybeard I've just measured the... 07-01-2008, 05:45 PM
greybeard Can anyone offer some help on... 07-05-2008, 02:42 PM
probinson John, I use Armsrong A-2... 07-06-2008, 03:48 PM
greybeard Thanks Pete for the timely... 07-06-2008, 04:45 PM
probinson John, If you can mix for... 07-06-2008, 09:34 PM
greybeard OK Pete, I'll give that a try... 07-06-2008, 10:10 PM
greybeard Cameron - now that I've got a... 07-07-2008, 03:30 PM
ckelloug The 3/8 is the thickness for... 07-07-2008, 03:58 PM
Low-Alloy Where'd everybody go? 08-13-2008, 02:13 AM
dsquire Hi I was just reading... 08-13-2008, 03:13 AM
qroger The forum is castigating me... 08-13-2008, 02:16 PM
greybeard Rather than outer darkness or... 08-13-2008, 02:33 PM
qroger Race cars and stuff 08-13-2008, 05:53 PM
ckelloug Sorry all, It's been a... 08-14-2008, 05:25 AM
CncLite1 Comp Vs Tension 08-16-2008, 06:39 PM
jhudler Forgive me father for I have... 08-13-2008, 04:42 PM
jhudler Oh did I mention it's been... 08-13-2008, 04:45 PM
greybeard Carbon fibre mesh under... 08-20-2008, 04:59 PM
svenakela Carbon fibre is almost non... 08-20-2008, 09:16 PM
CncLite1 Composite EG 08-20-2008, 09:54 PM
JerryFlyGuy However, that being said, you... 08-21-2008, 12:10 AM
CncLite1 Pre-Stressed seems to... 08-21-2008, 12:41 AM
svenakela My point is the same as... 08-21-2008, 08:31 AM
CncLite1 Prestressed 08-21-2008, 01:34 PM
greybeard Sounds straightforward, but... 08-20-2008, 11:17 PM
sigma relief Having worked a lot with... 08-21-2008, 01:40 AM
brunog We nned to be creative in the... 08-21-2008, 06:03 PM
sigma relief Bruno, I think your pre-fab... 08-22-2008, 03:25 AM
sigma relief Morphious Active damping... 08-22-2008, 03:46 AM
CncLite1 I agree 100% with Sigma on... 08-22-2008, 01:28 PM
ckelloug cnclite1, I've been using... 08-22-2008, 06:31 PM
CncLite1 Had a few minutes to get a... 08-23-2008, 02:59 PM
sigma relief CNCLite, I am assuming the... 08-23-2008, 08:02 PM
CncLite1 EG reinforced 08-23-2008, 08:47 PM
CncLite1 Aggregate selection 08-24-2008, 01:46 PM
ckelloug cnclite1, ad_bfl was... 08-24-2008, 09:49 PM
brunog Markus, I am sure the work... 09-07-2008, 01:15 AM
bloefeld Some general comments 09-22-2008, 06:24 PM
brunog Markus, The photos are the... 09-07-2008, 01:31 AM
ticica Larger test fixture 09-08-2008, 04:00 PM
ckelloug ticica, I am finally back... 09-08-2008, 11:16 PM
ticica What size mold should I make... 09-09-2008, 07:02 PM
ckelloug Hi Ivan, The general rule... 09-09-2008, 07:33 PM
Mel White Marcus Do you have a contact... 09-09-2008, 05:15 PM
krazatchu I found this 2 axis... 09-23-2008, 08:05 AM
ckelloug krazatchu, Thanks for... 09-24-2008, 04:29 PM
jhudler Wow the red clay on white... 09-27-2008, 07:25 PM
lerman It isn't obvious to me what... 09-27-2008, 08:04 PM
krazatchu I haven't done a patent... 09-28-2008, 02:45 AM
bloefeld Mixer gizmo 09-29-2008, 11:02 PM
krazatchu Hehe... I was wrong... It... 09-28-2008, 02:59 AM
krazatchu Speed ratio's are here... ... 09-28-2008, 03:04 AM
jhudler Mixer 09-28-2008, 03:17 AM
krazatchu Woot! Good find! 09-28-2008, 03:25 AM
lerman After reading the document,... 09-29-2008, 01:07 AM
rowbare This patent seems to be a... 09-29-2008, 03:25 AM
jhudler Having messed with vacuuming... 09-29-2008, 03:25 AM
jhudler I was thinking of a several... 09-29-2008, 05:38 AM
rowbare That is a lot of force... The... 09-29-2008, 05:43 PM
lerman Why not six buckets of equal... 09-29-2008, 08:19 PM
rowbare That might not be all that... 09-29-2008, 08:35 PM
jhudler If this were strictly a... 09-30-2008, 08:47 AM
bloefeld Orbital motion 09-30-2008, 05:45 PM
probinson A couple quick... 09-30-2008, 06:31 PM
bloefeld Vacuum 09-30-2008, 10:38 PM
ckelloug Yeah for the troll! 10-01-2008, 12:46 AM
bloefeld Ckellough 10-01-2008, 02:37 AM
jhudler Except I tried that it and... 10-01-2008, 03:35 AM
ckelloug Jack, This vacuum idea... 10-01-2008, 03:54 AM
bloefeld Not an issue 10-01-2008, 04:29 AM
jhudler Bloefeld, sorry I may not... 10-01-2008, 05:47 AM
probinson Vacuum infusion is different... 10-01-2008, 06:44 AM
probinson Oh, and by the way, those... 10-01-2008, 07:03 AM
bloefeld Infusion confusion 10-01-2008, 05:25 PM
ckelloug I have the capability to do... 10-01-2008, 05:43 PM
bloefeld Excellent resource about... 10-03-2008, 01:19 AM
Low-Alloy Bloefeld, can provide a link... 10-03-2008, 01:57 PM
bloefeld Pumping glue 10-03-2008, 05:06 PM
krazatchu http://www.princessauto.com/im... 10-03-2008, 02:27 PM
krazatchu Here in Korea, concrete is... 10-04-2008, 09:06 AM
ckelloug Initial IPDA Result... 10-06-2008, 07:45 AM
crr Lurker Present 10-10-2008, 07:13 PM
romihs Time.... 10-10-2008, 08:13 PM
ckelloug I think I understand... 10-10-2008, 08:40 PM
crr Thanks Sandi and Cameron! ... 10-10-2008, 09:31 PM
lgalla Chris be careful. Sorry I... 10-15-2008, 02:58 AM
crr Update #2 10-15-2008, 08:46 PM
Calthorp Chopped strand 10-15-2008, 09:45 PM
Low-Alloy Paint pot for pumping? 10-16-2008, 06:54 PM
probinson My thoughts on...... Using... 10-16-2008, 07:19 PM
crr Pressure for epoxy 10-16-2008, 07:43 PM
Low-Alloy Mold pressure 10-16-2008, 08:50 PM
probinson Sounds perfect a a first... 10-16-2008, 07:54 PM
probinson Actually, I really don't see... 10-16-2008, 09:12 PM
lgalla Resin transfer molding and... 10-17-2008, 02:34 AM
ckelloug Howdy all, I wanted to say... 10-17-2008, 10:02 PM
qroger I hope I am not repeating. In... 10-20-2008, 03:07 PM
jhudler Just a note: Lest we forget... 10-29-2008, 07:55 AM
ckelloug snookered1ca, What did... 10-29-2008, 05:31 PM
snookered1ca Cameron, crosslink... 10-29-2008, 05:55 PM
crr molding cavities 10-29-2008, 06:05 PM
snookered1ca I'm new to this group and... 10-29-2008, 06:07 PM
snookered1ca Background info 10-29-2008, 07:16 PM
ckelloug snookered, Check the... 10-30-2008, 08:17 AM
MrStainless Epoxy Granite - Alternatives 11-05-2008, 08:31 PM
ckelloug Welcome Mr. Stainless, ... 11-05-2008, 08:54 PM
jhudler Cameron, Have we run across... 10-30-2008, 08:34 AM
crr Hi Jack! I am planning on... 10-30-2008, 01:33 PM
ckelloug Jack, Tony thinks that the... 10-30-2008, 04:13 PM
Preston E Cameron, the Jeffamine... 11-02-2008, 01:10 AM
snookered1ca Steel shot filler 10-30-2008, 04:58 PM
lgalla I got gas 10-31-2008, 03:04 AM
Mcgyver hadn't been around this... 10-31-2008, 07:20 PM
probinson I'm sure that it is due to... 11-02-2008, 02:04 AM
bloefeld The string is correct 11-03-2008, 04:58 PM
probinson Thanks for the backup on this... 11-03-2008, 07:21 PM
ckelloug The outgassing question from... 11-03-2008, 07:55 PM
greybeard H Mr. S. I'd like to echo... 11-05-2008, 09:07 PM
ckelloug ServoWizard mentioned plaster... 11-05-2008, 09:21 PM
MrStainless Cameron, John, Thanks for... 11-06-2008, 09:45 AM
greybeard Thanks Bill. I did suspect... 11-06-2008, 01:27 PM
craigl2 A` 11-12-2008, 06:21 AM
alex_ku Hi guys! I'v found video... 11-18-2008, 01:55 PM
Zathras Aggregate good enough? 11-27-2008, 05:24 AM
Zumba Great video, Alex! 11-27-2008, 12:42 PM
ckelloug Zathras, I'll take a look... 11-28-2008, 08:02 AM
Zathras Hi Cameron, Seriously, if... 11-28-2008, 11:41 AM
Kenrick Hi guys sorry about this but... 11-28-2008, 02:40 PM
greybeard Hi Kenrick, and welcome. I... 11-28-2008, 03:18 PM
ckelloug Zathras, I will get to... 11-28-2008, 10:15 PM
ckelloug Lab tour now that the mold is... 12-11-2008, 03:15 AM
PoppaBear10 I have read the Index and... 12-20-2008, 04:47 PM
Eson Ive been thinking of using... 12-21-2008, 04:03 AM
ckelloug Hi PoppaBear10, Glad... 12-22-2008, 07:25 AM
rowbare Cameron, I am guessing... 12-22-2008, 03:10 PM
ckelloug Bob, These are by volume. ... 12-22-2008, 04:39 PM
thespindoc Thanks for all the work! 12-25-2008, 04:55 PM
thespindoc Measuring ingredients 12-25-2008, 08:54 PM
brunog Cameron, I've started... 12-28-2008, 11:24 PM
thespindoc Thanks Cameron for the very... 12-29-2008, 01:45 PM
greybeard HAPPY NEW YEAR to one and... 12-29-2008, 10:59 PM
ckelloug I ran a couple tests the... 01-03-2009, 11:06 PM
crr WOW 01-05-2009, 06:30 PM
ckelloug As long as a combination of... 01-05-2009, 06:42 PM
romihs Cameron, Regarding the... 01-06-2009, 10:34 AM
greybeard Hi Sandi. Sieving quartz... 01-06-2009, 10:53 AM
romihs Hi John, Wow... I was not... 01-06-2009, 11:47 AM
ckelloug Hi Sandi, Here's what I... 01-07-2009, 12:36 AM
altaic Hello all, I've been sort of... 01-07-2009, 02:15 PM
ckelloug Welcome Will, A lot of us... 01-07-2009, 04:50 PM
BillTodd . Fasinating. I wonder if... 01-07-2009, 05:10 PM
brunog Cameron, As stupid as it may... 01-08-2009, 02:59 AM
altaic Hi Cameron, thanks for the... 01-08-2009, 04:04 AM
ckelloug Pretty Close to... 01-08-2009, 08:38 AM
altaic Hi Bruno, did you vibrate (by... 01-08-2009, 08:19 PM
brunog Cameron, Actually the result... 01-09-2009, 02:28 AM
ckelloug Bruno, If I understand... 01-09-2009, 03:41 AM
altaic I did some testing today... ... 01-09-2009, 06:49 AM
romihs Vibrating 01-09-2009, 12:32 PM
brunog Will, Sandi is right the... 01-09-2009, 06:36 PM
altaic I had read those posts... 01-09-2009, 11:19 PM
romihs Will, I did not think that... 01-10-2009, 12:31 AM
altaic Sandi, I understand; I just... 01-10-2009, 01:24 AM
brunog Will, did the quartz... 01-10-2009, 03:22 AM
altaic Good question. I'll have to... 01-10-2009, 03:46 AM
ckelloug Better Aggregate formula 01-10-2009, 07:18 AM
BillTodd Just a thought: What about... 01-10-2009, 01:24 AM
altaic This may be a very good... 01-10-2009, 01:38 AM
altaic I've been hunting for low... 01-10-2009, 03:43 AM
altaic Cameron, thanks for the... 01-10-2009, 02:32 PM
ckelloug Will, In my scan of the... 01-10-2009, 08:56 PM
Bada Bing We had some bases made at... 01-12-2009, 03:19 PM
altaic I've made progress in the... 01-13-2009, 10:13 PM
greybeard Will, re "viscosity reducing... 01-13-2009, 10:40 PM
altaic Thanks John, I'll give them a... 01-13-2009, 11:12 PM
greybeard It has just occurred to me... 01-13-2009, 11:18 PM
altaic No, those are good ideas, but... 01-14-2009, 07:15 AM
altaic I've been thinking about... 01-14-2009, 11:59 PM
ticica Capillary effect around... 01-16-2009, 06:51 AM
altaic Hi ticica, I wouldn't know... 01-16-2009, 08:34 AM
rowbare Maybe this is the kind of... 01-16-2009, 07:51 PM
altaic Hello again all, I'm so... 01-16-2009, 08:18 AM
greybeard If it's any help, I've... 01-16-2009, 10:32 AM
ticica Once you had the holes... 01-17-2009, 01:13 AM
greybeard I was placing M4 nuts, so I... 01-17-2009, 11:34 AM
brunog Will, Ticica, The whole idea... 01-16-2009, 06:55 PM
ticica Bruno, I also wanted to... 01-16-2009, 08:17 PM
altaic Bruno, that setup in post #30... 01-16-2009, 09:41 PM
brunog [quote=altaic;552694]Bruno,... 01-16-2009, 11:31 PM
altaic I guess I'm still not clear... 01-17-2009, 02:16 AM
ticica No. By inserts, I meant... 01-17-2009, 03:41 AM
ckelloug Hi Will, You are right... 01-17-2009, 07:11 AM
brunog John, Is your spincasting... 01-16-2009, 11:36 PM
brunog Ivan, It's still possible to... 01-16-2009, 11:43 PM
sigma relief In regards to self leveling... 01-24-2009, 02:44 AM
ticica I thought it was more on the... 01-29-2009, 06:26 AM
sigma relief Ticica, you are absolutely... 02-01-2009, 10:11 PM
ticica As far as the meniscus effect... 02-02-2009, 05:09 AM
ckelloug Sigma John, I had the... 02-02-2009, 05:12 PM
lgalla the EP is flat!!! 02-03-2009, 02:59 AM
altaic Hi all, It's been awhile... 02-03-2009, 12:16 AM
sigma relief I am not trying to keep... 02-05-2009, 02:09 AM
ckelloug sigma John, You could very... 02-05-2009, 04:52 AM
lgalla Sigma John, ... 02-05-2009, 07:53 PM
altaic Hey guys, Cameron, that... 02-05-2009, 08:51 PM
the4thseal as far as the meniscus, we... 02-06-2009, 12:09 AM
altaic So, I'm starting to get... 02-14-2009, 08:30 PM
greybeard Following your musings with... 02-14-2009, 09:32 PM
probinson I have not performed any... 02-16-2009, 02:48 PM
altaic Ah, that makes sense. I while... 02-17-2009, 03:10 PM
ckelloug Ultrasound and other bonding... 02-17-2009, 04:38 PM
tootalew I started reading this post... 02-15-2009, 06:40 PM
tootalew I do want to tip my hat to... 02-15-2009, 11:32 PM
LXH That is perfect~! I use... 03-05-2009, 09:41 PM
Quad2T ITW sold polymer casting... 03-06-2009, 03:09 AM
dfro Cameron, I have all the... 03-06-2009, 08:57 AM
dfro I think I get what Cameron... 03-08-2009, 10:32 PM
ckelloug Confirming dfro's... 03-09-2009, 04:10 AM
greybeard Hi Cameron. Yes, I think I... 03-10-2009, 11:22 PM
ckelloug Eating My Own Metaphorical... 03-20-2009, 04:42 AM
messar different epoxy - any... 03-20-2009, 11:01 AM
greybeard Hi Matt. Big jump, in more... 03-20-2009, 12:46 PM
ckelloug Hi Matt, Sikafloor 261... 03-20-2009, 05:15 PM
messar Hi Cameron, Thanks for... 03-20-2009, 11:52 PM
semi-lucid Cameron A long time ago in... 03-21-2009, 02:50 AM
ckelloug Hi semi-lucid, I have... 03-21-2009, 04:28 AM
semi-lucid Cameron I didn't mean to... 03-21-2009, 10:11 PM
ckelloug semi-lucid John, Most... 03-21-2009, 11:09 PM
SolarSystemsLLC FYI - Epoxy Granite... 03-22-2009, 08:50 AM
ckelloug Well, I just got back from... 03-22-2009, 10:18 PM
the4thseal dammmmmm Germans!!!!!!!!! :)... 03-24-2009, 06:07 AM
harryn All is not lost - there are... 03-30-2009, 07:26 PM
harryn Cameron - did you get a... 03-30-2009, 07:55 PM
ckelloug Harry, I've only done 1... 03-30-2009, 08:21 PM
unclejoe first post/ concrete base 03-24-2009, 12:57 PM
brunog Sandi, Very interesting... 03-24-2009, 05:40 PM
ckelloug Drat. While the puck... 03-27-2009, 04:36 PM
MaX-MoD Hello everybody, today a... 03-28-2009, 10:56 AM
ckelloug Thanks to MaxMOD for the... 03-29-2009, 11:25 PM
Quad2T <<<An important thing I noted... 04-02-2009, 04:55 AM
greybeard Cameron - thanks for your... 03-30-2009, 08:31 PM
ckelloug John, I saw the comment on... 03-30-2009, 09:00 PM
greybeard On the subject of papers -... 03-30-2009, 09:41 PM
Nami Hey guys, Been reading... 04-01-2009, 02:56 AM
ckelloug Burt, This is exactly the... 04-01-2009, 05:13 AM
SolarSystemsLLC Burt, You think for less... 04-01-2009, 05:34 AM
Nami Solar, Way back when I... 04-01-2009, 06:29 AM
Brenck Hi everyone, First post... 04-03-2009, 07:23 AM
ckelloug Hi Brenck, Thanks for... 04-03-2009, 04:59 PM
Brenck Thanks Cameron, I mean my... 04-03-2009, 07:36 PM
ckelloug Brenck, The mineral size... 04-03-2009, 08:39 PM
Brenck Thanks for the explanations.... 04-04-2009, 02:48 AM
ckelloug Brenck, Like epoxy resin,... 04-04-2009, 05:54 PM
gerryv Tested/Locked-Down Set of... 04-06-2009, 01:53 PM
TOOL MQR Gerry, If you want a machine,... 04-06-2009, 02:19 PM
jhudler I think he's being overly... 04-16-2009, 09:51 PM
lazlo Ah, that explains a lot. ... 04-16-2009, 10:16 PM
romihs Lazlo, You are correct, I... 04-16-2009, 10:30 PM
J13 howdy, I've been lurking... 04-18-2009, 04:52 PM
ckelloug Lazlo, The original... 04-20-2009, 10:12 PM
jhudler <O:p</O:p <O:p</O:p Gordon... 04-21-2009, 04:47 AM
lazlo Yeah, but you're suggesting... 04-23-2009, 05:01 PM
ckelloug Lazlo, I think the... 04-23-2009, 05:11 PM
J13 Thanks Cameron, I've spoken... 04-20-2009, 10:47 PM
craigl2 J13, I have been... 04-21-2009, 05:10 AM
J13 The aggregates I'm looking at... 04-21-2009, 02:30 PM
greybeard Is 60micron a typo ? If not,... 04-21-2009, 05:02 PM
J13 it wasn't a typo - the way im... 04-21-2009, 07:58 PM
greybeard So, that will give you a very... 04-21-2009, 08:22 PM
J13 in that case i could add in... 04-21-2009, 08:46 PM
ckelloug Hi Craigl and J13, I... 04-21-2009, 09:44 PM
J13 I've read thru what you... 04-22-2009, 06:32 PM
ckelloug J13, I've thought about... 04-22-2009, 07:11 PM
greybeard In several places on the... 04-21-2009, 09:32 PM
the4thseal i have been working on the... 04-22-2009, 07:43 PM
J13 I'de LOVE to see some results... 04-22-2009, 08:00 PM
the4thseal that is what i have been... 04-22-2009, 08:33 PM
ckelloug Attached are plots of filler... 04-22-2009, 09:14 PM
the4thseal that is what i have been... 04-22-2009, 08:12 PM
jhudler Here's what I worked out for... 04-24-2009, 09:14 PM
J13 I guess I'll use e/g as fill,... 04-29-2009, 10:33 AM
jhudler If you're creating something... 04-29-2009, 10:52 AM
Mbk This thread captured my... 05-01-2009, 03:28 PM
jhudler Welcome the to group! You... 05-01-2009, 07:31 PM
Mbk I'm looking at ZANITE faq and... 05-02-2009, 01:13 PM
jhudler Post machining of composite... 05-02-2009, 06:48 PM
Mbk Quantities can be... 05-02-2009, 09:26 PM
greybeard Glad to hear the BL came up... 05-05-2009, 05:24 PM
Mbk Need also to understand if I... 05-06-2009, 12:36 PM
jestah infusion? 05-11-2009, 12:56 PM
ckelloug Hi Jestah and welcome. The... 05-11-2009, 02:44 PM
Brenck I was wondering in an... 05-12-2009, 04:26 AM
TRIMI YOU CAN BUY TURCITE AT Toll... 05-23-2009, 08:14 AM
diverjohn46 Epoxy Granite filler 05-25-2009, 09:57 AM
ckelloug John, Thanks for the... 06-01-2009, 03:07 PM
jonixllc Epoxy Granite 06-08-2009, 01:44 PM
the4thseal Be careful of outfits that... 06-08-2009, 09:12 PM
alex_ku and why its bad to have more... 06-09-2009, 07:46 AM
jonixllc By volume. As for Alex, if... 06-09-2009, 03:19 PM
the4thseal thanks for the by volume. 06-09-2009, 07:28 PM
alex_ku I agree with you, but also... 06-11-2009, 11:16 AM
alex_ku help needed 06-11-2009, 12:17 PM
jonixllc Contact: ... 06-11-2009, 01:04 PM
Eric R. INSERTS for Casting 07-02-2009, 01:30 PM
jonixllc Alex- Your english is OK... 06-11-2009, 01:11 PM
Oldmanandhistoy Hi jonixlic, Just want to... 06-09-2009, 08:22 PM
alex_ku Thanks jonixllc! Waiting for... 06-11-2009, 01:27 PM
lgalla Jonixllc, I thought... 06-12-2009, 04:49 AM
jonixllc Here are my thoughts on... 06-12-2009, 02:31 PM
ckelloug Jonixllc, Thank you kindly... 06-12-2009, 08:12 PM
jonixllc Rock of Ages in Graniteville,... 06-12-2009, 08:44 PM
Herbertkabi Look at pressed polymer... 06-13-2009, 04:57 PM
the4thseal you can not buy small amounts... 07-21-2009, 11:32 PM
jvalger Here is one online source for... 07-21-2009, 11:53 PM
turnpoint Hi Eric, You stated: "I am... 07-22-2009, 03:43 PM
jvalger Hi Brandon, Yeah, that is... 07-22-2009, 07:46 PM
turnpoint Hi Jeff, I'm getting out of... 07-22-2009, 08:29 PM
Eric R. Hi Brandon, Sound very... 07-22-2009, 09:45 PM
the4thseal Or, do it yourself. Simpler... 07-22-2009, 10:48 PM
veteq Comparison 07-24-2009, 08:18 PM
veteq External vibrator 07-24-2009, 10:33 PM
Eric R. Hi Roy, If you are looking... 07-27-2009, 09:15 AM
Steven.ji Dear Friend I appriciated... 08-16-2009, 02:36 PM
bookmarkmaster Epoxy-Granite machine bases... 08-23-2009, 03:42 PM
Herbertkabi Density kg/mc 2283.0 5x5x1 cm... 08-26-2009, 09:46 PM
jvalger Look at this one for an... 08-03-2009, 01:34 AM
the4thseal that makes sense.....thank you 08-03-2009, 06:38 AM
MaxxD Long time lurker 08-08-2009, 04:15 AM
lgalla Sorry for not following the... 07-26-2009, 05:27 AM
robp1104 This may be way too late in... 08-10-2009, 10:33 PM
Zathras A bit of Googling for sand &... 09-23-2009, 06:10 PM
jberg have you read this stydy? 09-25-2009, 08:13 AM
ckelloug Hi jberg, It sounds like... 09-26-2009, 08:13 AM
dflora Re poor surface finish. I... 10-06-2009, 07:38 PM
samara samara hello...i'm new here...i'm... 09-27-2009, 10:53 AM
tootalew Just a bit off topic, but it... 09-28-2009, 12:47 AM
Quad2T Nah, it's probably a granite... 09-30-2009, 08:00 PM
Brenck Man... This thread is going... 09-30-2009, 04:38 PM
tootalew My face might be new to the... 09-30-2009, 10:37 PM
ckelloug Yep, tootalew, It turned... 10-01-2009, 10:30 PM
Brenck Cameron, As soon as you... 10-03-2009, 01:33 AM
ncmeinc epoxy base for machines 10-08-2009, 12:03 PM
ckelloug Eric R, Do you have... 10-15-2009, 04:15 PM
lgalla WHITIS,sorry you had to read... 10-04-2009, 12:02 AM
ckelloug Hi Brenck, The mixture... 10-05-2009, 07:44 AM
brunog Dflora, I believe this... 10-07-2009, 01:45 AM
Brenck I dunno if someone asked... 10-07-2009, 05:05 AM
Eric R. Let's shake..... 10-08-2009, 08:38 AM
Low-Alloy I am wondering which would... 10-11-2009, 03:14 AM
Eric R. As a rule of thumb, for... 10-11-2009, 09:12 AM
Brenck I dunno but for logical... 10-11-2009, 07:46 AM
HBFixedGear Sorry I have no clue where... 10-15-2009, 03:36 PM
ckelloug Bob, If all you're trying... 10-15-2009, 03:51 PM
tootalew Here is some good reading... 10-15-2009, 05:08 PM
jberg epoxy vs vinyl etc resins 10-15-2009, 06:58 PM
Eric R. Hi Cameron, A while ago I... 10-15-2009, 07:11 PM
Brenck Cameron, Thanks for the... 10-15-2009, 07:32 PM
Brenck Eric, That American... 10-15-2009, 07:54 PM
ckelloug I did a few minutes of... 11-19-2009, 07:09 PM
Brenck I am talking to some... 10-15-2009, 10:42 PM
Eric R. Cameron, Thanks for your... 10-15-2009, 11:56 PM
greybeard Can I throw into the pot... 10-16-2009, 05:42 PM
Eric R. Hi John, I had been... 10-16-2009, 06:43 PM
Brenck I think that if you make it... 10-16-2009, 01:29 AM
Eric R. I don't think that is the... 10-16-2009, 08:20 AM
ckelloug Simulation Data Glitch 10-16-2009, 04:03 PM
greybeard Hi Eric. My little knowledge... 10-16-2009, 08:02 PM
Eric R. Hi John, I think that any... 10-16-2009, 09:02 PM
greybeard Nice one Eric. Something... 10-16-2009, 09:12 PM
Eric R. :D:violin::D Great drawing,... 10-16-2009, 10:48 PM
ckelloug John, Agreed Great... 10-17-2009, 12:16 AM
greybeard Can someone give me a formula... 10-17-2009, 04:54 PM
Brenck Eric, Does the motors have... 10-17-2009, 05:20 PM
Zathras John, Assuming simple... 10-18-2009, 06:34 AM
Eric R. Hi Brenck, There are... 10-19-2009, 05:03 PM
garagon127 Hey, greybeard, Download... 10-26-2009, 04:46 PM
garagon127 Hey, greybeard, Download... 10-26-2009, 04:48 PM
greybeard Thanks Zanthras, that's the... 10-18-2009, 10:05 AM
lgalla Sorry for not following the... 10-19-2009, 09:36 PM
ckelloug Howdy, Greybeard John's... 10-24-2009, 10:41 PM
jvalger It seems to be the consensus... 10-25-2009, 10:58 PM
Eric R. I have read this patent and I... 11-10-2009, 06:03 AM
ckelloug Hi Eric, I don't know... 11-10-2009, 06:51 PM
greybeard Hi all. I had a look at the... 11-11-2009, 09:52 PM
bsdphk I'm reading a very... 11-11-2009, 11:54 PM
greybeard Hi, and thanks for the link.... 11-12-2009, 10:11 AM
jberg Hi all, Any comments for... 11-19-2009, 05:58 PM
lgalla Vinyl ester is up scaled... 11-20-2009, 01:08 AM
draemr Packing algorithm? 11-21-2009, 01:35 AM
Nami Some pics and video of... 11-21-2009, 04:47 AM
brunoboyee how thick was your steel... 12-19-2010, 03:38 AM
jberg Hi Thanks for you reply, ... 11-22-2009, 04:51 PM
Brenck Burt, Does all the... 11-22-2009, 06:47 PM
Nami Well, all sound is vibration... 11-23-2009, 01:35 AM
lgalla V/E 11-23-2009, 01:54 AM
jberg I plan to made few proto... 11-23-2009, 12:41 PM
Brenck You surely have a lot of... 11-23-2009, 01:54 AM
Nami No, it's just a chopper... 12-03-2009, 05:53 AM
the4thseal where do you get carbon nano... 11-23-2009, 09:18 PM
jberg I have ask epoxy what include... 11-24-2009, 08:31 AM
Eng-Meethaq Hi, please I need an books... 11-29-2009, 06:50 PM
phil c It's an interesting... 12-05-2009, 12:28 AM
ckelloug Hi jberg, I'm still happy... 12-06-2009, 01:37 AM
DarkDesigns Epoxy Granite 12-24-2009, 12:30 AM
the4thseal pics? 12-24-2009, 01:02 AM
daedalus Happy new year everyone. Just... 01-01-2010, 10:35 PM
veteq Hey Daedalus, Had just a... 01-02-2010, 12:20 AM
veteq If i remember the Germans i... 01-02-2010, 01:13 AM
lgalla Walter and I started the... 01-17-2010, 10:11 PM
daedalus Hi Roy, I have been trying... 01-02-2010, 12:40 AM
veteq Hee Tom, Nice paper,... 01-02-2010, 01:04 AM
daedalus Hi Roy, If you look at the... 01-02-2010, 01:39 AM
veteq You are right Tom, sorry, my... 01-02-2010, 01:57 AM
PedroS Hi I'm from Portugal ,... 01-13-2010, 12:16 PM
Brenck Hi guys, I read the... 01-14-2010, 04:35 AM
brunog Let me put the amount of... 01-19-2010, 03:47 PM
dfro Hey guys, I am using e/g... 01-22-2010, 06:59 AM
dfro Here is a picture of my e/g... 01-23-2010, 05:24 PM
AFAIK Hello all. I have been... 02-03-2010, 01:08 AM
greybeard Hi AFAIK, and welcome. That... 02-03-2010, 10:10 AM
ckelloug AFAIK, You look very... 02-03-2010, 11:38 PM
AFAIK Hey again. Greybeard,... 02-04-2010, 02:55 PM
dfro AFAIK, Excellent drawing for... 02-04-2010, 09:49 PM
greybeard ....and dogs, children and... 02-05-2010, 08:59 AM
RotarySMP Have you modelled your gantry... 02-05-2010, 10:55 PM
oxford Precsion Epoxy Products 02-09-2010, 12:03 AM
brunog Oxford, Seems to me that... 02-09-2010, 03:06 PM
stevv05 This is my first post on this... 02-11-2010, 10:58 PM
AFAIK Hey rotary, thanks for that... 02-09-2010, 02:56 PM
RotarySMP I think you would be better... 02-10-2010, 08:11 PM
RotarySMP I think you would be better... 02-10-2010, 08:12 PM
lgalla Cameron, U are the number... 02-12-2010, 12:02 AM
RotarySMP I agree that it was great... 02-12-2010, 01:03 PM
dfro That is definitely my plan. ... 02-12-2010, 06:53 PM
oxford Mike from Precision Epoxy... 02-13-2010, 02:49 AM
johnohara Proposal For New Thread Branch 02-14-2010, 11:16 PM
stevv05 New Thread Branch 02-15-2010, 05:19 PM
RotarySMP deleted duplicate 02-12-2010, 01:04 PM
RomanLini I'm interested in the... 02-16-2010, 08:07 AM
greybeard I'm sorry, Romanlini, but... 02-16-2010, 09:12 AM
RotarySMP The recommendation of the the... 02-16-2010, 08:30 AM
brunog Low viscosity Epoxy 02-16-2010, 03:53 PM
ckelloug Bruno, The no-blush stuff... 02-16-2010, 05:09 PM
johnohara Latest E/G Sample 02-17-2010, 01:49 AM
oxford ckelloug: 02-17-2010, 02:36 AM
RomanLini I'd really like to hear a... 02-17-2010, 09:23 PM
johnohara Sample: 0.25 - 0.50mm... 02-17-2010, 10:21 PM
RotarySMP Stones of uniform size will... 02-17-2010, 10:55 PM
johnohara Sample #3 02-18-2010, 05:02 AM
lgalla John good work. What is the... 02-18-2010, 05:46 AM
lgalla John,I just read your last... 02-18-2010, 06:00 AM
johnohara lgalla, Got the impression... 02-18-2010, 04:19 PM
ckelloug If you're using a true... 02-18-2010, 04:24 PM
johnohara . 02-18-2010, 04:22 PM
johnohara ckelloug, I'm using US... 02-18-2010, 05:05 PM
lgalla "I think they're casting... 02-18-2010, 05:18 PM
johnohara Sample #4 02-18-2010, 06:09 PM
lgalla John I asked previously what... 02-20-2010, 02:21 AM
johnohara My Understanding 02-22-2010, 08:41 PM
ckelloug Hi Johnohara, You're on... 02-22-2010, 09:15 PM
johnohara . . . Nice. Is that a choir?... 02-22-2010, 09:42 PM
AFAIK Materials in the UK 05-14-2010, 12:06 AM
brunog John, Larry is right, your... 02-20-2010, 04:03 AM
lgalla Someone may ask"how do I know... 02-20-2010, 05:46 AM
Brenck Considering making a machine... 02-20-2010, 08:16 AM
johnohara Gravel Sizes 02-20-2010, 05:22 PM
johnohara Zanite Close-Up 02-20-2010, 09:14 PM
johnohara A Closer Look At Aggregate... 02-21-2010, 01:54 AM
lgalla Sorry for no replys... 02-22-2010, 01:08 AM
Brenck Larry, I was planning on... 02-22-2010, 02:33 AM
lgalla John,What are you planning to... 02-21-2010, 02:07 AM
johnohara Three More Aggregate Sizes 02-22-2010, 12:00 AM
lgalla Brenck,good question.... 02-22-2010, 04:58 AM
Brenck Larry, This is basically... 02-22-2010, 05:53 AM
RotarySMP I never understood the appeal... 02-22-2010, 10:34 AM
ckelloug Hi Johnohara, The CNCZ1... 02-22-2010, 04:43 PM
johnohara Mix Questions 02-22-2010, 06:47 PM
ckelloug Hi johnohara, To keep... 02-22-2010, 07:33 PM
lgalla Brenck, Looks... 02-22-2010, 04:20 PM
Brenck The reason for using... 02-22-2010, 04:38 PM
altaic Hi Roy, I haven't seen... 02-23-2010, 11:10 PM
veteq Hey Will, Most off the... 02-24-2010, 12:50 AM
altaic Hi Roy, We're talking... 02-24-2010, 02:16 AM
veteq Hey Will, Nice to read we... 02-24-2010, 07:39 PM
RotarySMP I think there are too many... 02-24-2010, 09:33 PM
veteq Hey Mark, I`m a believer... 02-25-2010, 12:43 AM
altaic Hey Roy, Nice machine design!... 02-24-2010, 09:43 PM
johnohara E/G Observation 02-24-2010, 10:13 PM
altaic Hey John, I'm not planning to... 02-24-2010, 10:46 PM
veteq Hey Will, Like the... 02-25-2010, 01:00 AM
altaic Hey Roy, Creep is the right... 02-25-2010, 01:30 AM
lgalla Creep of epoxy seems to be a... 02-25-2010, 01:52 AM
veteq ...And hold dimensional... 02-25-2010, 06:09 AM
lgalla packing densidy 02-25-2010, 04:31 AM
altaic Okay, this is my take on... 02-25-2010, 05:17 AM
RomanLini That's pretty much summed it... 02-25-2010, 09:12 AM
jonpry Those curves are designed... 02-25-2010, 08:20 PM
oxford Precision Epoxy Products 02-25-2010, 10:31 PM
harryn Hi, Just checking in. I like... 02-26-2010, 12:18 AM
jonpry Creep 02-26-2010, 12:41 AM
lgalla Will,you have answered your... 02-25-2010, 05:58 AM
RotarySMP Roy, sorry if my post rubbed... 02-25-2010, 11:32 AM
ckelloug Will, I ran the model with... 02-25-2010, 02:47 PM
altaic Hey guys, I made a series of... 02-25-2010, 04:34 PM
altaic Hi Cameron, Thanks for the... 02-25-2010, 05:24 PM
veteq Hey Guys, Mark, i ended... 02-25-2010, 06:29 PM
ckelloug Will, You have a good... 02-25-2010, 06:30 PM
veteq Hey Cameron, Next week i... 02-25-2010, 06:50 PM
brunog Oxford, You might just be... 02-26-2010, 02:48 PM
brunog Creep 02-26-2010, 03:23 PM
johnohara Surface Coat 02-26-2010, 03:40 PM
brunog John, They do this for... 02-26-2010, 03:49 PM
lgalla John it is called a... 02-26-2010, 04:02 PM
johnohara Slurry Coat / Gel Coat 02-26-2010, 04:16 PM
ckelloug If we can coax jhudler out of... 02-26-2010, 04:24 PM
brunog John, My crazy idea was to... 02-26-2010, 04:21 PM
brunog Larry, You forgot to post... 02-26-2010, 04:25 PM
brunog John, There is extensive... 02-26-2010, 04:53 PM
ckelloug Hi Oxford, That slurry... 02-26-2010, 06:46 PM
veteq Well said Cameron, Keep up... 02-26-2010, 07:08 PM
lgalla The slurry coat system and... 02-26-2010, 07:30 PM
veteq Thats a nice machine... Been... 02-26-2010, 07:48 PM
RotarySMP Shame they painted that... 02-26-2010, 07:52 PM
veteq Thats the trick Mark, It... 02-26-2010, 07:54 PM
oxford I like Zeeosphere's simple... 02-26-2010, 09:46 PM
ckelloug Oxford, I agree that that... 02-26-2010, 09:58 PM
jonpry FEM 02-27-2010, 01:48 AM
lgalla At the beginning of the... 02-26-2010, 07:54 PM
lgalla jonpry,perhaps you could run... 02-27-2010, 02:37 AM
jonpry Larry, Perhaps you... 02-27-2010, 04:12 AM
johnohara Can't Upload Images 03-01-2010, 07:11 PM
johnohara Sample #5 03-01-2010, 07:25 PM
brunog Cameron, Would it be... 02-27-2010, 03:59 PM
brunog Sorry, double post 02-27-2010, 04:00 PM
ckelloug Hi Jonpry, Good job on the... 03-01-2010, 04:45 PM
altaic Hey Cameron, Something just... 03-03-2010, 02:51 AM
brunog QED: "quod erat... 03-04-2010, 09:45 PM
lgalla Jonpry ask Bruno or Cam,I... 03-04-2010, 10:18 PM
ckelloug Jonopry, I don't agree... 03-05-2010, 04:21 PM
jonpry We should probably just agree... 03-05-2010, 09:23 PM
Steven.ji I heard a Spanish company... 03-07-2010, 05:00 AM
brunog Steven, I believe it's... 03-09-2010, 03:15 PM
ckelloug Let me be the first to... 03-16-2010, 12:16 AM
cncagain Any questions yet for Terry? 04-19-2010, 01:35 PM
Herbertkabi I dont believe these thing... 04-19-2010, 10:33 PM
ckelloug Somebody else ought to talk... 04-19-2010, 11:02 PM
johnohara Cameron~ Roach... 04-20-2010, 12:39 AM
ckelloug I miss Roach. I learned a... 04-20-2010, 12:56 AM
johnohara Then there it shall be. Post... 04-20-2010, 01:16 AM
vishnu I think its time to freeze... 04-20-2010, 07:29 PM
veteq We need "Birth Control", (for... 04-20-2010, 07:41 PM
cncagain Freeze before finding answer? 04-27-2010, 07:34 PM
osiervt Who do I need to contact for... 07-25-2010, 05:45 AM
vishnu Guys please don't take this... 04-28-2010, 07:39 PM
veteq In the index there is a link... 04-28-2010, 08:38 PM
johnohara Thread Already Exists 04-28-2010, 08:47 PM
jhudler New Forum? 04-29-2010, 07:19 AM
brunog I like the idea of a separate... 04-29-2010, 01:48 PM
vishnu I stay by you guys. A piece... 04-29-2010, 06:38 PM
Brenck I think its a good idea to... 04-29-2010, 09:03 PM
greybeard AFAIK, sent PM John 05-14-2010, 09:04 AM
ckelloug AFAIK, Do you have... 05-17-2010, 07:54 PM
TZE Hi all! A am sorry about my... 05-17-2010, 09:20 PM
AFAIK ckelloug, I have not found... 05-17-2010, 10:27 PM
greybeard I think the way to go is to... 05-18-2010, 11:13 AM
Steven.ji Hi Friend I used to... 06-01-2010, 02:00 PM
Steven.ji Hi Friend I'm intereted... 06-01-2010, 01:55 PM
greybeard I think it makes much more... 06-09-2010, 07:32 PM
brunog I agree, the materials forum... 06-10-2010, 06:29 PM
brunog Welcome aboard Ensar, You... 07-15-2010, 01:45 PM
ckelloug Hi Ensar, That thesis is a... 07-16-2010, 07:22 PM
mchabot Hi, Here is a link on a... 07-19-2010, 10:15 AM
brunog Il y a des gens qui... 07-19-2010, 03:14 PM
RomanLini Thank you very much for... 07-25-2010, 08:40 PM
brunog Now that's the spirit... 07-25-2010, 04:09 PM
brunog Romanlini, You can actually... 07-25-2010, 11:27 PM
RomanLini Thanks you Veteg and Brunog... 07-26-2010, 07:27 PM
veteq Its a nice machine... and the... 07-26-2010, 08:34 PM
brunog Romanlini, I allways like to... 07-27-2010, 02:33 PM
nebbiasound Vibrating table 07-27-2010, 06:46 PM
rowbare RomanLini, I think that... 07-28-2010, 10:16 PM
RomanLini Bruno- I do think a "proper"... 07-29-2010, 08:01 PM
veteq Romani, of course all views... 07-29-2010, 08:35 PM
greybeard Hi all. Just a few... 08-06-2010, 08:59 AM
brunog Hey John, nice to hear from... 08-06-2010, 04:54 PM
greybeard Hi Bruno, "More thumbs than... 08-06-2010, 09:11 PM
brunog My wife and I were playing 4... 08-06-2010, 10:14 PM
ger21 I've made a cup of epoxy-sand... 08-07-2010, 02:27 AM
ckelloug Hi nebiasound, On the... 08-07-2010, 04:37 AM
the4thseal i was looking... 08-07-2010, 05:47 AM
RomanLini Correct, with very low %... 08-09-2010, 06:07 AM
brunog Gerry, The reason you did... 08-09-2010, 02:08 AM
Herbertkabi I dont understand why to go... 08-09-2010, 03:59 PM
RomanLini Hi Herbert, that was probably... 08-14-2010, 01:21 PM
ckelloug Hi Romanlini, I agree with... 08-14-2010, 05:01 PM
howard.zhu hello everyone this is... 08-20-2010, 09:01 AM
ckelloug Sample Made! 08-22-2010, 05:06 AM
greybeard Hi Cameron, and welcome to... 08-22-2010, 08:42 AM
Quad2T It's not "bad... 08-22-2010, 10:07 PM
RomanLini Yep. I've already worked with... 08-23-2010, 02:53 AM
ckelloug Hi Romanlini, My machine... 08-23-2010, 06:01 AM
RomanLini Ahah. Now I understand your... 08-24-2010, 08:16 AM
ckelloug It was a good suggestion but... 08-24-2010, 04:45 PM
RomanLini Isn't that modulus very low,... 08-28-2010, 12:21 PM
ckelloug Hi Roman, We're lacking a... 08-28-2010, 05:03 PM
veteq Hey Cameron, Nice to see... 08-28-2010, 11:21 PM
ckelloug Hi Roy, I used Mann... 08-29-2010, 02:18 AM
veteq Hey Cameron, nice to hear... 08-29-2010, 04:38 PM
Steven.ji PVA release agent is available 09-05-2010, 02:26 AM
johnohara Hi Cameron~ Congrats on... 08-30-2010, 02:38 PM
ckelloug Hi Johnohara, Air... 08-30-2010, 04:12 PM
jhudler Hi gang! Silicone?!?!?... 09-02-2010, 06:52 AM
jhudler Oh one other thing. Vibrate... 09-02-2010, 06:58 AM
veteq Hee Jhudler, Silicones... 09-02-2010, 04:29 PM
jhudler Of course Silicone is your... 09-02-2010, 10:55 PM
lgalla I refinished some pro speaker... 09-03-2010, 03:02 AM
jhudler I forgot all about the most... 09-03-2010, 05:01 AM
veteq Thanks guys, think i... 09-03-2010, 12:29 PM
ckelloug Hi Roy, There are zillions... 09-03-2010, 09:45 PM
veteq Hee Cameron, If i pour... 09-03-2010, 10:59 PM
Steven.ji it's not necessary to make a... 09-04-2010, 07:24 AM
lgalla Sanding or grinding does not... 09-04-2010, 12:13 AM
Steven.ji Hi did you recieve my... 09-04-2010, 07:28 AM
Palms Epoxy Granite base for... 09-23-2010, 03:29 PM
RomanLini Do you manufacture your own... 09-25-2010, 11:56 AM
osiervt I did a few runs this... 10-17-2010, 05:42 AM
jhudler That looks like an almost... 10-17-2010, 07:53 PM
rowbare Cameron, With regards to... 10-20-2010, 02:23 AM
jhudler I'm of the mind that epoxy is... 10-20-2010, 02:36 AM
greybeard Hi Cameron – yes still... 10-21-2010, 09:30 AM
jhudler I think compression opens up... 10-21-2010, 07:22 PM
ckelloug Hi Jack, Here's my... 10-21-2010, 07:56 PM
RomanLini I'm not sure about "too"... 10-21-2010, 07:59 PM
osiervt If we have already tried this... 10-21-2010, 10:16 PM
ckelloug Roman, I think your... 10-22-2010, 03:58 PM
RomanLini Sorry I wasn't clear with the... 10-22-2010, 08:59 PM
Kevin_Johnson Yes, exactly. But think... 01-31-2011, 10:43 AM
Kevin_Johnson In practice, you CAN reach... 01-31-2011, 10:54 AM
brunog I believe that voids left in... 10-22-2010, 02:34 AM
RotarySMP Is this discussion of... 10-22-2010, 10:26 AM
greybeard Somewhere in the archaic... 10-22-2010, 05:18 PM
greybeard If the epoxy polymerization... 10-29-2010, 06:34 PM
ckelloug Hi guys, I'm stuck on... 10-29-2010, 11:14 PM
johnohara I used US Composites 635 with... 10-29-2010, 11:31 PM
RomanLini Temperature control. I have 3... 10-30-2010, 01:51 AM
Nivea Vibrate Dry or Wet? 10-30-2010, 02:29 PM
ckelloug This sounds very much worth... 10-30-2010, 07:25 PM
greybeard If you consider just the step... 10-30-2010, 09:26 PM
RomanLini I'm not surprised! I would... 10-31-2010, 02:11 AM
RotarySMP Hi Krille356, Thanks for... 11-01-2010, 01:37 PM
Krille356 Hi I´m using a 20mm ball,... 11-02-2010, 04:52 PM
Krille356 I have updated page 7 with... 11-02-2010, 04:59 PM
greybeard Hi Krille356, and thanks for... 11-02-2010, 04:59 PM
Krille356 Yes, my figures is by weight. 11-02-2010, 05:26 PM
RotarySMP Thanks for the detailed info... 11-02-2010, 07:01 PM
Eric R. I'm back! 11-02-2010, 08:08 PM
johnohara Black Iron Oxide 11-04-2010, 07:31 PM
johnohara Correction 11-04-2010, 09:29 PM
RomanLini Interesting build thread... 11-03-2010, 02:56 AM
ckelloug Hi Krille356, I agree with... 11-03-2010, 03:35 AM
johnohara If there's too much epoxy, it... 11-03-2010, 04:32 AM
bugattibuilder Hi Eric, Where did you... 11-03-2010, 07:16 PM
RotarySMP I like your practical... 11-03-2010, 10:39 PM
Krille356 It is dry dye oxide black, in... 11-04-2010, 04:09 PM
RomanLini I apologise Krille356, my... 11-04-2010, 09:50 AM
Steven.ji Hi Krille356 AS your... 11-23-2010, 11:13 AM
Krille356 Hi Please explain what is... 11-23-2010, 05:05 PM
hkswan Possible process improvements? 11-25-2010, 05:32 PM
Krille356 1. Yes I did use a spray able... 11-26-2010, 05:00 PM
Steven.ji Hi PSD is particle size... 12-21-2010, 04:22 AM
greybeard Accepted - I don't want to... 11-26-2010, 10:08 PM
ckelloug Hi and Welcome hkswan, ... 11-26-2010, 10:36 PM
ckelloug New Recipe 12-05-2010, 02:23 AM
Nivea Can anyone help out with a... 12-12-2010, 01:13 PM
greybeard Cameron, yet another thought... 12-05-2010, 12:53 PM
Kevin_Johnson Hi John, This might have... 12-30-2010, 03:19 PM
greybeard Hi Kevin, and welcome. ... 12-30-2010, 05:03 PM
Kevin_Johnson I think dispensing systems... 12-30-2010, 05:33 PM
RomanLini That sounds like a great... 12-10-2010, 10:47 AM
Steven.ji A useful Standard 12-21-2010, 07:57 AM
ckelloug Hi johnohara, Yes, the... 12-21-2010, 04:56 PM
RomanLini I'm not convinced that... 12-22-2010, 12:41 AM
jvalger Interlocking granules... of... 12-23-2010, 12:14 AM
Kevin_Johnson It is interesting to think... 12-30-2010, 03:30 PM
Kevin_Johnson My guess would be that IF... 12-30-2010, 03:43 PM
johnohara Cameron~ Is the vibration... 12-19-2010, 09:53 PM
RomanLini Thanks for that link! That is... 12-26-2010, 03:56 PM
greybeard The topic of vacuum degassing... 12-30-2010, 05:54 PM
Kevin_Johnson I do have some experience... 12-30-2010, 06:27 PM
greybeard Ah, a man after my own heart... 12-30-2010, 07:14 PM
RomanLini I don't think you will ever... 01-02-2011, 11:02 AM
Kevin_Johnson I think it is worth looking... 01-02-2011, 06:53 PM
ckelloug Howdy all, Welcome... 01-05-2011, 06:06 AM
Kevin_Johnson Just as with aerated oil in a... 01-05-2011, 10:24 AM
Kevin_Johnson In the dental industry an... 01-05-2011, 10:30 AM
Kevin_Johnson If you look carefully at... 01-05-2011, 11:10 AM
Kevin_Johnson "There is no set whose... 01-05-2011, 12:13 PM
johnohara Is it my imagination or are... 01-05-2011, 05:52 PM
ckelloug Johnohara, Rycroft's paper... 01-05-2011, 06:09 PM
Kevin_Johnson Heck, use a magnetic ore... 01-05-2011, 06:20 PM
rusel Hi Just thought you might... 01-10-2011, 12:40 AM
ckelloug Bruno, I agree. That sums... 01-10-2011, 06:05 PM
Kevin_Johnson When I first found the thread... 01-05-2011, 06:13 PM
greybeard No, John, you're quite right.... 01-05-2011, 06:03 PM
RomanLini Thanks Cameron for taking the... 01-06-2011, 02:31 PM
greybeard Ah, "there's the rub" - would... 01-06-2011, 03:24 PM
ckelloug Hi Roman, Thanks for... 01-06-2011, 06:32 PM
Kevin_Johnson My emphasis : No, the... 01-17-2011, 12:36 PM
brunog Cameron, There is something... 01-17-2011, 09:21 PM
ckelloug Bruno, Agree that the... 01-17-2011, 09:55 PM
RomanLini I think you are correct in... 01-07-2011, 05:41 PM
greybeard I concede to your "point",... 01-07-2011, 06:02 PM
ckelloug Hi Roman and greybeard, ... 01-07-2011, 08:46 PM
brunog importance of low viscosity... 01-09-2011, 08:42 PM
bagherdn i've used epoxy but not for... 01-16-2011, 08:05 PM
Nivea Are we satisfied with the... 01-17-2011, 01:19 AM
veteq 200% the first one....!!!... 01-17-2011, 01:37 AM
Nivea That's my point, Thomas's... 01-17-2011, 01:46 AM
greybeard Hi Roy. Now I know what they... 01-17-2011, 10:28 AM
lgalla Bruno, I wonder what Larry... 01-18-2011, 01:57 AM
ckelloug Hi lgalla, Good to see you... 01-18-2011, 04:52 AM
RomanLini I think the solution to some... 01-18-2011, 08:32 AM
greybeard Cameron, you're quite right... 01-18-2011, 12:18 PM
johnohara Interesting story on SlashDot... 01-18-2011, 04:50 PM
ckelloug Roman, I agree totally... 01-18-2011, 06:20 PM
Kevin_Johnson Accepted. 01-18-2011, 05:37 PM
Fireman11 I wasn't being snide. I... 01-18-2011, 06:00 PM
Kevin_Johnson I started my business as a... 01-18-2011, 06:24 PM
greybeard Re the method of using excess... 01-19-2011, 12:27 AM
Kevin_Johnson Be cautious: a possible side... 01-19-2011, 02:30 PM
greybeard deleted due to duplicate post 01-19-2011, 12:28 AM
Nivea This small sample was a... 01-19-2011, 08:32 AM
RomanLini I apologise Cameron, on... 01-19-2011, 09:17 AM
greybeard Good points Kevin, and I... 01-19-2011, 03:14 PM
Nivea John, Great question,... 01-19-2011, 04:51 PM
greybeard Yes, I think there have... 01-19-2011, 05:40 PM
greybeard Cameron - I have been... 01-19-2011, 09:35 PM
greybeard Further to the above, I've... 01-19-2011, 10:00 PM
Nivea John, Thanks for posting... 01-22-2011, 05:39 AM
ckelloug Roman, No offense taken. ... 01-20-2011, 07:28 AM
RomanLini Keep in mind you can't just... 01-20-2011, 11:25 AM
Kevin_Johnson I have been slowly plowing... 01-20-2011, 03:45 PM
ckelloug Roman, I agree with you... 01-20-2011, 06:05 PM
RomanLini Sorry if I was no clear... 01-21-2011, 09:22 AM
greybeard Great Shae, and thanks for... 01-22-2011, 10:50 AM
greybeard Few more like that Cameron,... 01-24-2011, 04:11 PM
greybeard Just managed to get JMVisions... 01-24-2011, 07:15 PM
RomanLini Cameron, didn't you vibrate... 01-25-2011, 03:47 AM
brunog Cameron, I am really not... 01-25-2011, 04:01 PM
ckelloug Hi Roman, I did vibrate... 01-25-2011, 05:24 PM
RomanLini Very interesting, I've never... 01-26-2011, 01:46 PM
lgalla John ever thought 01-26-2011, 11:31 PM
johnohara I have thought about how to... 01-26-2011, 11:43 PM
lgalla Why is there so much concern... 01-27-2011, 04:55 AM
greybeard Hi Russell, I had looked at... 01-28-2011, 03:47 PM
johnohara Kevin~ Congratulations.... 01-29-2011, 02:10 AM
Kevin_Johnson Patient -- ? No, I am just... 01-29-2011, 10:35 AM
rusel greybeard John The heading... 01-30-2011, 11:50 PM
johnohara Looking forward to the... 01-29-2011, 07:11 PM
ckelloug Testing observations 01-29-2011, 10:40 PM
johnohara Cameron~ Husky Mortar... 01-30-2011, 12:22 AM
Kevin_Johnson A few pics. I ground a few... 01-30-2011, 08:29 AM
RomanLini Interesting results Cameron... 01-30-2011, 12:38 PM
ckelloug Hi Roman, I'm using an... 01-30-2011, 07:37 PM
brunog Roman, we discussed this a... 01-30-2011, 11:28 PM
brunog This what I have, I can mix a... 01-30-2011, 11:20 PM
RomanLini Cameron at 3g/cc for the... 01-31-2011, 09:53 AM
brunog Roman, you are right there... 01-31-2011, 03:05 PM
RomanLini Thank you very much for... 02-03-2011, 03:53 PM
ckelloug Hi Roman, The 504cm^3... 02-03-2011, 05:11 PM
Kevin_Johnson Be careful. Alumina (for... 02-05-2011, 04:28 PM
Kevin_Johnson Sans application of vacuum... 02-07-2011, 01:50 PM
ckelloug Hi Kevin, I haven't... 02-09-2011, 06:49 AM
howard.zhu Hi, everyone This is... 02-09-2011, 10:53 AM
Steven.ji Hello Everyone I want Gel... 02-11-2011, 01:52 AM
Kevin_Johnson Hi Steven, The article... 02-11-2011, 02:07 PM
Kevin_Johnson re zeeospheres 02-11-2011, 02:23 PM
ckelloug I'm now stuck at a remote... 02-13-2011, 07:30 PM
Kevin_Johnson Slide 17 -- almost guaranteed... 02-13-2011, 09:22 PM
greybeard Kevin, I'm going to have to... 02-20-2011, 12:22 AM
Kevin_Johnson rough idea 02-20-2011, 02:17 PM
greybeard Kevin, As I said, I don't... 02-21-2011, 12:00 PM
Kevin_Johnson There is a net downward... 02-21-2011, 07:17 PM
Kevin_Johnson Hi Cameron, I think the... 02-21-2011, 07:39 PM
Nivea Cameron, Do you think it's... 03-04-2011, 11:13 AM
brunog Welcome aboard ClockMakerDK,... 03-10-2011, 06:03 PM
brunog Cameron, Have you tested... 03-10-2011, 06:04 PM
ClockMakerDK CNC Epoxy Granite Router 03-10-2011, 06:18 PM
ckelloug Hi Bruno, I want to test... 03-10-2011, 07:53 PM
mitip It does work 03-14-2011, 09:39 PM
ClockMakerDK CNC Epoxy Granite Router 03-15-2011, 09:57 AM
RomanLini Very interesting build, thank... 03-26-2011, 09:48 AM
Steven.ji Hi Cameron How do you get... 04-02-2011, 01:56 PM
ckelloug Hi all, I've been very... 04-02-2011, 04:36 PM
RomanLini To Woo- polyester has a very... 04-18-2011, 03:34 PM
woo yeah, that waz my... 04-18-2011, 04:32 PM
Steven.ji Woo The price of epoxy is... 06-12-2011, 09:19 AM
RomanLini I don't know the type of... 06-12-2011, 08:33 PM
castinite Epoxy vs Polyester 06-13-2011, 02:19 PM
bugattibuilder To the Croatian guy: You are... 06-14-2011, 07:20 AM
probinson Woo - If sbr20 rails are... 04-19-2011, 05:56 PM
woo i will try some mold.i put... 04-19-2011, 10:15 PM
jestah Hi guys, I have worked a... 04-22-2011, 05:43 AM
ckelloug Hi Jestah, Sorry the last... 04-22-2011, 09:02 AM
tronger hello everybody! I have one... 04-28-2011, 11:47 AM
ckelloug Because the base of a machine... 04-28-2011, 05:14 PM
bagherdn key feature 04-29-2011, 04:45 PM
tronger Because the base of a machine... 05-01-2011, 01:56 AM
Kevin_Johnson That would be determined... 05-04-2011, 12:37 PM
Kevin_Johnson I am sure it has been... 05-04-2011, 12:50 PM
castinite Epoxy granite machine bases 05-04-2011, 01:07 PM
Kevin_Johnson http://www.cnczone.com/forums/... 05-04-2011, 03:15 PM
Herbertkabi hi, I have not read this... 05-08-2011, 06:41 PM
brunog Herbertkabi, I believe this... 05-10-2011, 01:46 AM
lgalla Here is another source for... 05-11-2011, 03:24 AM
JohnMcNamara "Mineral Casting" 05-31-2011, 03:19 PM
greybeard "A rose by any other name... 05-31-2011, 08:29 PM
castinite Mineral Castings 06-01-2011, 02:20 PM
JohnMcNamara epoxy concrete nomenclature 06-01-2011, 02:56 PM
Kevin_Johnson It is something to watch and... 07-15-2011, 08:26 AM
greybeard Kevin, I don't want to appear... 07-15-2011, 09:39 AM
Kevin_Johnson Your suggestion to be aware... 07-15-2011, 02:11 PM
Steven.ji These days, I always wonder... 06-18-2011, 03:20 PM
castinite Epoxy Granite Weathering 06-18-2011, 04:03 PM
Steven.ji Epoxy Granite Weathering 06-20-2011, 01:44 PM
castinite EP Weathering Stability 06-20-2011, 01:59 PM
JohnMcNamara Tool grinder in production 06-21-2011, 03:44 AM
ngg117254 hi John, Epoxy base as an... 06-24-2011, 08:04 AM
JohnMcNamara Have a go build something 06-24-2011, 02:43 PM
RotarySMP I agree with you John, too... 06-24-2011, 03:52 PM
ckelloug John, I am impressed with... 06-24-2011, 04:24 PM
RomanLini Beautiful work John! :) 06-25-2011, 07:57 AM
JohnMcNamara Hi Rotary SMP Hi ckelloug... 06-26-2011, 03:26 PM
ckelloug John, I salute your... 06-27-2011, 02:32 PM
castinite Actual EG Cast Bases 06-30-2011, 05:21 PM
JohnMcNamara Hi Castinette The green... 07-01-2011, 02:02 PM
castinite Grinder Base 07-01-2011, 02:25 PM
romihs Castinite, That is very... 07-01-2011, 03:08 PM
johnohara Terry~ Picture 2: "Bimbo... 07-01-2011, 04:13 PM
Steven.ji Hi Terry The steel bar in... 07-08-2011, 03:43 PM
Kevin_Johnson Steven, you might consider... 07-15-2011, 08:09 AM
RomanLini Workers with heaters and... 07-09-2011, 01:29 AM
ckelloug Hi Roman, I must admit... 07-09-2011, 01:43 AM
yancho Hello.Excuse the language but... 07-09-2011, 05:58 PM
RomanLini Cameron- Sorry I should have... 07-11-2011, 12:04 AM
yancho I watched film-Breton... 07-11-2011, 07:15 PM
greybeard Kevin, thank you for your... 07-15-2011, 02:34 PM
JohnMcNamara Whats in a name? 07-15-2011, 02:37 PM
Kevin_Johnson It's counterproductive until... 07-15-2011, 02:45 PM
yancho What is the chance to hit the... 07-17-2011, 06:33 PM
RomanLini I'm curious about that too. I... 07-18-2011, 10:52 AM
brunog The original Moglice formula... 07-19-2011, 11:52 PM
yancho Work boldly with polymer 07-17-2011, 06:35 PM
RomanLini Interesting! Well I'm... 07-20-2011, 09:28 AM
yancho Therefore, all silent and not... 07-20-2011, 12:45 PM
ihavenofish i keep loosing track of this... 08-06-2011, 05:42 PM
RomanLini This is just a guess as I... 08-07-2011, 01:44 AM
ihavenofish hmmm, you could be right... 08-07-2011, 02:37 AM
yancho I think housing is made ​​of... 08-13-2011, 05:24 PM
Steven.ji My Product for Engraving... 08-17-2011, 01:20 PM
Steven.ji My Product for Engraving... 08-17-2011, 01:24 PM
rowbare It looks good Steven. Are... 08-17-2011, 02:44 PM
Steven.ji Big Channel 08-19-2011, 09:49 AM
yancho It looks good Steven. Can you... 08-17-2011, 09:43 PM
veteq Is that full epoxy granite... 08-17-2011, 11:03 PM
Steven.ji It's full epxoy granite we... 08-19-2011, 10:28 AM
Steven.ji machine information 08-19-2011, 10:24 AM
RomanLini Nice work! Looks like you... 08-18-2011, 08:28 AM
Steven.ji I never copy anyone which... 08-19-2011, 10:30 AM
jestah Hi guys, Bit of shamless... 08-18-2011, 08:36 AM
yancho Hello jestah.Make holes in... 08-18-2011, 09:48 PM
stewi Hi jestah, your Z-motor... 08-18-2011, 10:14 PM
jestah I have added some small holes... 08-18-2011, 10:35 PM
stewi It depends on the speed you... 08-18-2011, 11:24 PM
stewi If your spindle has a... 08-19-2011, 01:01 PM
RomanLini Hi Steven.ji, sorry I was not... 08-19-2011, 12:34 PM
yancho Coefficients of Linear... 08-19-2011, 01:14 PM
Steven.ji Smallest machine base 08-19-2011, 01:58 PM
jestah Hi Yancho, Thanks for... 08-21-2011, 11:59 AM
yancho hello Steven.I wanted and... 08-19-2011, 09:31 PM
Steven.ji XYZ 400x400x150 ... 08-20-2011, 03:52 AM
Steven.ji epoxy resin 08-20-2011, 11:58 PM
yancho Thanks Steven.Yancho 08-21-2011, 11:21 AM
yancho Hello jestah.I also want to... 08-21-2011, 06:00 PM
jestah Thank you so much for you... 08-22-2011, 02:00 AM
jestah cast in inserts 08-22-2011, 02:39 AM
yancho Hello jestah.View the links... 08-22-2011, 08:05 AM
yancho What a way to upload photos? 08-24-2011, 01:49 PM
thomasz Hi - here is Thomas from... 08-24-2011, 01:59 PM
romihs Hi Thomas, That looks... 08-24-2011, 02:28 PM
thomasz Hi! Yes two parts. Real... 08-24-2011, 05:37 PM
yancho Congratulations to Thomas,... 08-24-2011, 06:25 PM
thomasz Hi! The parts are from... 08-24-2011, 08:09 PM
romihs Thomas, My apologies. ... 08-25-2011, 12:15 PM
thomasz Sandi, okay i know what... 08-25-2011, 12:24 PM
Steven.ji we buy the linear surface... 08-28-2011, 07:56 AM
veteq Think Thomas uses... 08-28-2011, 01:02 PM
Steven.ji yes, the replication gauge is... 08-28-2011, 01:50 PM
RomanLini Beautiful machine Thomas! I... 08-25-2011, 01:05 PM
thomasz Hi, we don't grind the... 08-25-2011, 01:16 PM
veteq Hey Thomas, you are the man... 08-26-2011, 11:06 PM
RomanLini Excellent info, thank you... 08-26-2011, 09:03 PM
yancho All are buried in bills and... 08-29-2011, 08:24 PM
veteq Pretty old machine...is it... 08-29-2011, 08:32 PM
yancho Hello Thomas. I looked in... 08-29-2011, 08:50 PM
yancho Is not new but is interesting... 08-29-2011, 08:54 PM
thomasz Yan, it's no problem - I look... 08-30-2011, 06:18 AM
rocketflier Searching epoxy concrete... 04-12-2012, 08:45 AM
mchabot I have already post the... 04-17-2012, 12:37 PM
yancho Hello Thomas. Thanks very... 08-30-2011, 07:15 AM
RomanLini In the "open source designs"... 08-31-2011, 12:30 PM
yancho When wood cutting forces are... 09-06-2011, 11:43 AM
Steven.ji Our Big Product 10-06-2011, 09:01 AM
rocketflier You're not using Popsicle... 10-07-2011, 06:31 AM
johnohara Steven.ji~ Why does a... 10-07-2011, 10:01 PM
RomanLini I found this somewhere else... 10-18-2011, 11:27 AM
ckelloug Hi alex_ku, My suggestion... 10-18-2011, 04:22 PM
alex_ku Hi Cameron, They have few... 10-19-2011, 08:06 AM
ihavenofish i had thought that one was... 10-18-2011, 08:06 PM
RomanLini Their specs page;... 10-19-2011, 02:08 PM
manipul You will find 18% is more... 10-19-2011, 04:50 PM
CyberGolem Awesome 10-21-2011, 02:44 PM
ckelloug Hi Alex_ku, The aggregate... 10-21-2011, 07:01 PM
rocketflier I think it was the smooth-on... 10-21-2011, 09:29 PM
alex_ku John, Cameron, thanks !!!... 10-20-2011, 08:05 AM
johnohara Alex Ku~ Keep it simple.... 10-20-2011, 04:50 PM
CyberGolem Oblivious 10-21-2011, 02:41 PM
rocketflier [edit]I see Mr Doh4Eev2tae is... 11-07-2011, 06:13 AM
compositepro can i ask if anyone has also... 11-09-2011, 12:35 AM
rocketflier There have been several... 11-09-2011, 03:51 AM
rad45 Using Carbon Fibre in E/G 11-16-2011, 09:16 AM
rad45 Hi People, Thanks for your... 11-23-2011, 10:53 AM
yancho Hello. I made only one test,... 11-23-2011, 02:43 PM
ckelloug Hi Rocketflier, For... 11-23-2011, 04:35 PM
johnohara Good 12 minute video of a... 11-23-2011, 09:40 PM
rocketflier Thanks for the feedback. The... 11-23-2011, 10:31 PM
rocketflier I feel like Dekoda Fred. ... 11-26-2011, 06:51 AM
Nami Hey Guys, Been a while... 12-03-2011, 06:29 AM
greybeard Photoelastic Stress Analysis 12-19-2011, 11:47 AM
yugami I don't know of anything as... 12-20-2011, 06:17 AM
greybeard I always think there must be... 12-20-2011, 10:39 AM
wschmiedlin Epoxy-granite 01-24-2012, 03:30 PM
castinite When Milltronics started, I... 01-24-2012, 03:48 PM
veteq Would a UHPC (ultra high... 01-24-2012, 03:54 PM
rocketflier Concrete countertops: Using... 01-25-2012, 02:03 AM
cjtoombs Volume Conservation = False 03-13-2012, 12:31 AM
lgalla one more... 01-26-2012, 03:27 AM
lgalla homag 01-26-2012, 03:59 AM
JohnMcNamara Hi All Having downloaded... 01-26-2012, 04:40 AM
Steven.ji Is there anyone with... 09-13-2012, 04:28 AM
alex_ku John, What about to cover it... 01-26-2012, 08:04 AM
JohnMcNamara Hi Alex Yes that would... 01-26-2012, 08:59 AM
alex_ku Hi All Here is my first... 01-28-2012, 01:33 PM
rybov Hi Alex, Like you I am... 01-29-2012, 10:12 PM
pecamuzicar Oh, dobar dan Mr lgalla, :-))... 03-14-2012, 04:56 PM
lgalla TAMO METEP XENO please... 03-15-2012, 02:59 AM
pecamuzicar Thanks Larry, In that my... 03-16-2012, 10:55 AM
janaf Hi, is that the spindle... 03-19-2012, 03:03 PM
alex_ku Yes, it's spindle house.... 03-20-2012, 08:33 AM
alex_ku Now I'v found one more... 01-28-2012, 02:46 PM
alex_ku Hi Jacob, Thanks for... 01-30-2012, 09:02 AM
pecamuzicar Thixotropic epoxide resin? 02-02-2012, 05:24 PM
lgalla Peter you can not use a... 03-12-2012, 10:51 PM
pecamuzicar Thanks lgalla, Yes, it... 03-14-2012, 01:48 AM
lgalla Peter CPS is viskoznost.The... 03-14-2012, 02:48 AM
RomanLini Good info thanks! And the... 05-17-2012, 10:20 PM
rocketflier tap, tap, tap,... this thing... 07-01-2012, 02:35 AM
compositepro I know this thread has been... 08-18-2012, 10:45 PM
leix_99 Why would anybody do such... 08-18-2012, 10:56 PM
compositepro No worries man :cool: 08-18-2012, 11:30 PM
greybeard Hi compositepro, ... 08-19-2012, 10:25 AM
compositepro I have always followed a rule... 08-19-2012, 03:27 PM
Steven.ji Hi friend I has been... 08-21-2012, 12:09 PM
compositepro Was just wondering why your... 08-18-2012, 11:19 PM
Steven.ji For epoxy granite, it's... 08-21-2012, 12:22 PM
leix_99 My machine was casted using... 08-21-2012, 06:36 PM
Steven.ji what machine do you cast? 08-22-2012, 01:46 AM
leix_99 Compositepro, really nasty... 08-19-2012, 01:08 PM
rowbare CompositePro, There has... 08-20-2012, 06:55 PM
jonixllc We'd have to understand how... 08-21-2012, 02:07 PM
rad45 Carbon Fibre has minuses as... 08-21-2012, 05:37 PM
Steven.ji Firstly, mix the carbon... 08-22-2012, 01:35 AM
leix_99 http://www.cnczone.com/forums/... 08-22-2012, 01:58 AM
Steven.ji Small and thin part is... 08-22-2012, 08:36 AM
shedbob Nice machine leix_99 I am... 08-22-2012, 12:42 PM
greybeard Hi one and all. This may... 10-03-2012, 08:56 PM
ger21 UV will break down most cured... 10-03-2012, 11:27 PM
brunog John, Epotek make UV curable... 10-04-2012, 12:05 AM
greybeard Hi Gerry, So far I've found... 10-04-2012, 09:04 AM
workaholic_ro Might look as a silly... 11-21-2012, 11:01 PM
greybeard If it's thin enough to difuse... 11-21-2012, 11:12 PM
workaholic_ro Chemistry has never been my... 11-22-2012, 09:06 PM
ihavenofish you can use a vacuum for 3... 11-22-2012, 09:22 PM
ihavenofish cnc mill parts are usually... 11-21-2012, 11:12 PM
workaholic_ro I need to know what's in your... 11-22-2012, 08:54 PM
greybeard Hi workaholic ro, I had... 11-22-2012, 09:38 PM
ger21 And in nearly 6 years, that... 11-22-2012, 11:16 PM
ihavenofish ... DO something... as in,... 11-22-2012, 11:25 PM
ger21 If the aggregate is tightly... 11-23-2012, 12:06 AM
pecamuzicar Hi EG guys again, Did you... 12-06-2012, 11:49 PM
probinson Making EG lathe head is no... 12-08-2012, 12:05 AM
pecamuzicar @probinson Thanks for... 12-11-2012, 03:29 PM
probinson Headstock Bearing Heat ... 12-12-2012, 03:25 AM
probinson Let me consolidate some of my... 12-13-2012, 07:16 PM
pecamuzicar @probinson Thank you for... 12-15-2012, 02:21 PM
yancho In EG can embed pipes for... 12-15-2012, 04:45 PM
rybov Polymer concrete lathe... 12-19-2012, 09:47 PM
Steven.ji All of us discuss every... 01-19-2013, 12:13 PM
JohnMcNamara Compare test beams of Steel... 01-29-2013, 06:28 AM
gozos Very interresting document!... 01-29-2013, 08:39 AM
wizard A big thank you! 01-29-2013, 11:21 AM
marsheng I was wondering on a epoxy... 04-02-2013, 10:05 AM
the4thseal I think one of the problems... 04-03-2013, 05:24 AM
marsheng Cast iron is machined dry so... 04-04-2013, 12:50 AM
ihavenofish would the graphite... 04-04-2013, 04:19 AM
greybeard One of the criteria for... 04-04-2013, 09:42 AM
Razvan Vladeanu Hi guys, I've been following... 04-27-2013, 04:32 PM
probinson Personally, I would recommend... 04-29-2013, 02:19 PM
svenakela The epoxy will not stick to... 04-27-2013, 10:46 PM
castinite Glass Mold Base 05-15-2013, 12:46 PM
Razvan Vladeanu Thanks for the replies guys.... 04-30-2013, 12:53 AM
probinson It's always tempting to push... 04-30-2013, 01:57 PM
Razvan Vladeanu No need to apologize mister... 04-30-2013, 10:43 PM
probinson It would be very interesting... 05-02-2013, 04:59 PM
Razvan Vladeanu I agree with you. For the big... 05-03-2013, 11:12 AM
the4thseal Where can one by nano tubes? 05-03-2013, 09:40 PM
johnohara Science Daily ran an... 05-03-2013, 10:17 PM
JohnMcNamara Hi All A little back of... 05-04-2013, 02:22 AM
compositepro CNT's will improve resin... 09-02-2013, 06:48 PM
William7white it is generally accepted that... 05-04-2013, 06:00 AM
psykhon What about the idea of using... 05-10-2013, 02:03 AM
svenakela I am doing that several times... 05-15-2013, 10:38 AM
probinson If you are casting a rigid... 05-15-2013, 07:37 PM
svenakela Aren't you reading my answer... 05-15-2013, 09:45 PM
probinson I am reading your post but it... 05-15-2013, 11:26 PM
Talgat Can you share with your... 05-19-2013, 08:17 PM
svenakela We use glass as the... 05-20-2013, 08:41 AM
Talgat Thanks a lot for your info.... 05-20-2013, 09:49 AM
lgalla Products | Entropy Resins... 10-19-2013, 02:04 AM
JohnMcNamara Hi Igala So has this... 10-19-2013, 08:55 AM
Stonemason101 Hi John, This is a polymer... 11-30-2013, 09:51 AM
DaBit Epoxy concrete shrinkage? 01-03-2014, 11:23 AM
gozos Very interesting experience!!... 01-03-2014, 10:22 PM
DaBit Sure. The steel strips are... 01-04-2014, 09:48 AM
bhurts Does anyone know if using... 10-19-2013, 02:47 PM
castinite Ben, You can use shootpeen... 10-21-2013, 12:16 PM
Steven.ji I use it, and get good... 11-18-2013, 01:57 PM
Stonemason101 Fillers 11-25-2013, 06:29 AM
KKamel Interesting idea to use glass... 11-26-2013, 12:35 PM
JohnMcNamara The trouble with glass is it... 11-26-2013, 01:24 PM
Stonemason101 Glass gives the most perfect... 11-27-2013, 05:31 AM
Stonemason101 Glass moulds 11-27-2013, 05:38 AM
johnohara Stonemason101~ Do you have... 11-27-2013, 06:06 AM
Stonemason101 Hi John, Don't know what... 11-30-2013, 09:30 AM
JohnMcNamara Hi DaBit Nice to see you... 01-05-2014, 01:31 AM
DaBit The shrinkage seems to be the... 01-05-2014, 10:10 AM
mactec54 DaBit To eliminate one... 01-05-2014, 03:05 PM
DaBit I used regular cold rolled... 01-05-2014, 07:55 PM
JohnMcNamara Hi DaBit Some machine... 01-06-2014, 08:54 AM
DaBit Hi John, I used that... 01-06-2014, 10:18 AM
Stonemason101 Very neat job done!! Hi... 01-06-2014, 11:59 AM
DaBit Stonemason101: thanks for the... 01-06-2014, 12:47 PM
Stonemason101 Hi D, The use of a vibe... 01-06-2014, 01:33 PM
Stonemason101 Hi again D! Forgot 2 mention... 01-06-2014, 02:17 PM
JohnMcNamara Hi DaBit Your work looks... 01-06-2014, 01:38 PM
DaBit @StoneMason101: I am looking... 01-06-2014, 02:49 PM
Stonemason101 Hi D,The vapour cure is more... 01-07-2014, 10:46 AM
DaBit Hi Kevin, I wonder how I... 01-07-2014, 11:51 AM
Stonemason101 Hi D, We use ribbon... 01-07-2014, 12:29 PM
Low-Alloy Ribbon Blender Build? 02-15-2014, 05:42 AM
DaBit Although the entire synthetic... 01-07-2014, 03:17 PM
Stonemason101 Once mixed, grab a handful... 01-07-2014, 04:41 PM
DaBit Not that much luck with those... 01-07-2014, 10:50 PM
DaBit I did not do the postcure; it... 01-09-2014, 11:46 PM
Stonemason101 EG Composite casting 01-12-2014, 06:18 PM
DaBit Looks great! Questions: -... 01-12-2014, 07:32 PM
johnohara Hi Stonemason101~ Nice... 01-12-2014, 10:05 PM
johnohara Stonemason101~ Are you... 01-15-2014, 05:27 PM
Stonemason101 Guys, My humblest apologies ... 01-16-2014, 07:00 AM
JohnMcNamara Hi All On the sag of a... 01-16-2014, 09:00 AM
ihavenofish I'm confused by this too.... 01-15-2014, 09:32 PM
johnohara ihavenofish~ 8.5% by... 01-15-2014, 10:10 PM
JohnMcNamara Hi John O'Hara I have... 01-16-2014, 06:36 AM
DaBit A dry mixture in a real... 01-18-2014, 04:49 PM
Stonemason101 Hi DaBit, That cast is... 01-19-2014, 07:54 AM
DaBit It looks great indeed. I was... 01-20-2014, 12:47 AM
Stonemason101 Hi DaBit Please post a pic... 01-20-2014, 07:33 AM
DaBit Hi Stonemason101, I will... 01-21-2014, 10:14 AM
rad45 Yes, DaBit, we have all... 01-21-2014, 12:47 PM
DaBit Oh yes, I do.... Now you... 01-21-2014, 02:19 PM
rocketflier Did you post-cure heat? 01-21-2014, 11:37 PM
DaBit Not yet.. I will leave the... 01-21-2014, 11:57 PM
DaBit If I reduce shrinkage, I... 01-24-2014, 03:38 PM
DaBit I have the flu so I didn't do... 01-25-2014, 09:20 PM
the4thseal This is fantastic. You can... 01-26-2014, 03:11 AM
Low-Alloy How to search this thread? 02-14-2014, 04:57 AM
rocketflier At the top of the messages,... 02-14-2014, 09:03 AM
Low-Alloy Thanks for the help with... 02-15-2014, 02:55 AM
nateman_doo wow... 400 pages?! ... 02-27-2014, 12:22 AM
clmenz Fantastic instruction on how... 02-14-2014, 03:53 PM
rocketflier What is it you cannot find? 02-14-2014, 04:53 PM
DaBit A little: ... 02-27-2014, 01:34 AM
bhurts Re: Epoxy-Granite machine... 04-19-2014, 09:58 PM
wizard Re: Epoxy-Granite machine... 04-20-2014, 05:04 AM
phil c Re: Epoxy-Granite machine... 04-21-2014, 07:25 PM
DaBit Re: Epoxy-Granite machine... 04-19-2014, 10:25 PM
ger21 Re: Epoxy-Granite machine... 04-20-2014, 05:28 AM
ihavenofish Re: Epoxy-Granite machine... 04-20-2014, 04:58 PM
bhurts Re: Epoxy-Granite machine... 04-20-2014, 07:51 AM
DaBit Re: Epoxy-Granite machine... 04-22-2014, 10:21 AM
rowbare Re: Epoxy-Granite machine... 04-23-2014, 08:02 PM
bhurts Re: Epoxy-Granite machine... 04-22-2014, 10:02 PM
DaBit Re: Epoxy-Granite machine... 04-23-2014, 01:36 PM
lgalla Re: Epoxy-Granite machine... 06-15-2014, 03:11 AM
DaBit Re: Epoxy-Granite machine... 04-23-2014, 08:49 PM
ihavenofish Re: Epoxy-Granite machine... 04-24-2014, 07:12 AM
aguskov Re: Epoxy-Granite machine... 06-02-2014, 05:40 PM
DaBit Re: Epoxy-Granite machine... 06-03-2014, 11:46 AM
gozos Re: Epoxy-Granite machine... 06-03-2014, 12:19 PM
DaBit Re: Epoxy-Granite machine... 06-03-2014, 01:02 PM
Aaron1975 Re: Epoxy-Granite machine... 06-18-2014, 07:12 AM
thegolfer Re: Epoxy-Granite machine... 07-15-2014, 11:12 AM
ckelloug Re: Epoxy-Granite machine... 07-15-2014, 04:53 PM
ihavenofish Re: Epoxy-Granite machine... 07-16-2014, 04:26 AM
thegolfer Re: Epoxy-Granite machine... 07-16-2014, 10:32 AM
svenakela Re: Epoxy-Granite machine... 07-20-2014, 10:12 AM
thegolfer Re: Epoxy-Granite machine... 07-16-2014, 10:47 AM
ckelloug Re: Epoxy-Granite machine... 07-15-2014, 04:50 PM
svenakela Re: Epoxy-Granite machine... 07-15-2014, 08:49 PM
ckelloug Re: Epoxy-Granite machine... 07-16-2014, 05:47 PM
CaptainVee Re: Epoxy-Granite machine... 07-16-2014, 09:18 PM
thegolfer Re: Epoxy-Granite machine... 07-17-2014, 01:37 AM
aveliz123 Re: Epoxy-Granite machine... 11-08-2014, 01:47 PM
ckelloug Re: Epoxy-Granite machine... 11-08-2014, 08:18 PM
ckelloug Re: Epoxy-Granite machine... 07-17-2014, 03:01 AM
CaptainVee Re: Epoxy-Granite machine... 07-17-2014, 07:30 AM
DaBit Re: Epoxy-Granite machine... 07-29-2014, 09:09 AM
thegolfer Re: Epoxy-Granite machine... 07-29-2014, 01:05 PM
jhudler Re: Epoxy-Granite machine... 08-04-2014, 09:18 AM
lgalla Re: Epoxy-Granite machine... 11-20-2014, 03:17 AM
JohnMcNamara Re: Epoxy-Granite machine... 08-04-2014, 01:29 PM
jhudler Re: Epoxy-Granite machine... 08-04-2014, 08:33 PM
ckelloug Re: Epoxy-Granite machine... 08-07-2014, 04:32 PM
Low-Alloy Re: Epoxy-Granite machine... 09-26-2014, 02:53 PM
Steven.ji Re: Epoxy-Granite machine... 09-26-2014, 03:22 PM
probinson Re: Epoxy-Granite machine... 09-26-2014, 03:29 PM
ckelloug Re: Epoxy-Granite machine... 09-26-2014, 05:12 PM
probinson Re: Epoxy-Granite machine... 11-20-2014, 06:12 PM
harryn Re: Epoxy-Granite machine... 12-09-2014, 12:31 PM
jhudler Re: Epoxy-Granite machine... 12-17-2014, 10:57 PM
Low-Alloy Re: Epoxy-Granite machine... 12-24-2014, 07:11 PM
rocketflier Re: Epoxy-Granite machine... 02-24-2015, 02:05 AM
jhudler Re: Epoxy-Granite machine... 12-17-2014, 11:35 PM
jhudler Re: Epoxy-Granite machine... 12-17-2014, 10:55 PM
rowbare Re: Epoxy-Granite machine... 12-21-2014, 05:15 AM
mdfuller Re: Epoxy-Granite machine... 01-31-2015, 06:32 PM
RotarySMP Re: Epoxy-Granite machine... 02-21-2015, 07:49 PM
gt40 Re: Epoxy-Granite machine... 02-26-2015, 11:21 PM
anarchos Re: Epoxy-Granite machine... 02-27-2015, 12:00 PM
probinson Re: Epoxy-Granite machine... 02-27-2015, 01:43 PM
CaptainVee Re: Epoxy-Granite machine... 02-27-2015, 04:07 PM
konobi Re: Epoxy-Granite machine... 10-09-2015, 04:42 AM
RotarySMP Re: Epoxy-Granite machine... 03-10-2015, 10:16 AM
garyfivell So it's all about the mix? 03-24-2015, 06:46 PM
dan_the_welder Re: Epoxy-Granite machine... 04-24-2015, 02:50 AM
shedbob Re: Epoxy-Granite machine... 05-03-2015, 08:48 AM
eloid I didnt have the time to read... 08-05-2015, 01:13 PM
castinite Re: Epoxy-Granite machine... 08-05-2015, 07:01 PM
probinson Re: Epoxy-Granite machine... 08-07-2015, 12:32 AM
lcvette Re: Epoxy-Granite machine... 08-31-2015, 01:18 AM
RotarySMP Re: Epoxy-Granite machine... 10-09-2015, 10:03 AM
konobi Re: Epoxy-Granite machine... 10-19-2015, 06:33 PM
konobi Re: Epoxy-Granite machine... 11-03-2015, 10:38 PM
CaptainVee Re: Epoxy-Granite machine... 11-04-2015, 07:57 AM
RotarySMP Re: Epoxy-Granite machine... 11-04-2015, 11:46 AM
konobi Re: Epoxy-Granite machine... 11-04-2015, 09:08 PM
konobi Re: Epoxy-Granite machine... 11-07-2015, 07:01 AM
CaptainVee Re: Epoxy-Granite machine... 11-07-2015, 07:20 AM
konobi Re: Epoxy-Granite machine... 01-04-2016, 07:31 PM
ckelloug Re: Epoxy-Granite machine... 01-04-2016, 09:06 PM
CaptainVee Re: Epoxy-Granite machine... 11-07-2015, 07:50 AM
konobi Re: Epoxy-Granite machine... 11-07-2015, 07:59 AM
CaptainVee Re: Epoxy-Granite machine... 11-13-2015, 04:38 PM
ckelloug Some Quick thoughts... 12-17-2015, 08:58 PM
ckelloug Re: Epoxy-Granite machine... 02-15-2016, 10:33 PM
oz1411 Re: Epoxy-Granite machine... 02-16-2016, 01:36 AM
WolfmansBrother Re: Epoxy-Granite machine... 11-19-2017, 10:33 PM
castinite Re: Epoxy-Granite machine... 11-20-2017, 12:27 AM
RotarySMP Re: Epoxy-Granite machine... 03-17-2017, 12:49 PM
vib Re: Epoxy-Granite machine... 04-13-2018, 08:47 AM
scipione205 Re: Epoxy-Granite machine... 04-13-2018, 07:08 PM
PSI Re: Epoxy-Granite machine... 04-22-2017, 06:56 PM
WolfmansBrother Re: Epoxy-Granite machine... 06-14-2017, 08:59 PM
scipione205 Re: Epoxy-Granite machine... 10-04-2017, 05:58 PM
rocketflier Re: Epoxy-Granite machine... 10-05-2017, 06:54 AM
scipione205 Re: Epoxy-Granite machine... 10-05-2017, 08:49 AM
RCaffin Re: Epoxy-Granite machine... 10-05-2017, 02:47 AM
RCaffin Re: Epoxy-Granite machine... 10-05-2017, 07:19 AM
NeoTech Re: Epoxy-Granite machine... 11-20-2017, 09:17 AM
rocketflier Re: Epoxy-Granite machine... 11-21-2017, 03:42 AM
NeoTech Re: Epoxy-Granite machine... 11-21-2017, 09:14 AM
vib Re: Epoxy-Granite machine... 05-06-2018, 03:07 PM
RCaffin Re: Epoxy-Granite machine... 11-21-2017, 09:28 AM
RotarySMP Re: Epoxy-Granite machine... 11-22-2017, 09:53 PM
rocketflier Re: Epoxy-Granite machine... 11-24-2017, 07:14 PM
RotarySMP Re: Epoxy-Granite machine... 11-24-2017, 09:21 PM
scipione205 Re: Epoxy-Granite machine... 11-25-2017, 09:48 PM
RotarySMP Re: Epoxy-Granite machine... 11-26-2017, 05:35 PM
kevincnc Re: Epoxy-Granite machine... 05-01-2018, 04:41 AM
danilom Re: Epoxy-Granite machine... 05-01-2018, 07:17 PM
kevincnc Re: Epoxy-Granite machine... 10-10-2019, 09:47 PM
footpetaljones Re: Epoxy-Granite machine... 10-11-2019, 01:40 AM
kevincnc Re: Epoxy-Granite machine... 05-03-2018, 04:57 AM
JohnMcNamara Hi All Gee its been a... 11-16-2018, 03:03 PM
RCaffin Re: Epoxy-Granite machine... 10-10-2019, 11:49 PM
peteeng Re: Epoxy-Granite machine... 10-11-2019, 05:51 AM
__Britt Re: Epoxy-Granite machine... 10-11-2019, 07:51 AM
peteeng Re: Epoxy-Granite machine... 10-11-2019, 08:17 AM
Obivan Re: Epoxy-Granite machine... 10-16-2019, 07:59 AM
peteeng Re: Epoxy-Granite machine... 10-16-2019, 09:04 AM
peteeng Re: Epoxy-Granite machine... 10-16-2019, 10:27 AM
peteeng Re: Epoxy-Granite machine... 10-17-2019, 01:36 AM
peteeng Re: Epoxy-Granite machine... 10-20-2019, 11:25 AM
klaas123 Re: Epoxy-Granite machine... 10-20-2019, 03:11 PM
peteeng Re: Epoxy-Granite machine... 10-20-2019, 10:55 PM
peteeng Re: Epoxy-Granite machine... 10-22-2019, 11:07 AM
Obivan Re: Epoxy-Granite machine... 10-23-2019, 02:58 PM
peteeng Re: Epoxy-Granite machine... 10-23-2019, 08:54 PM
lukahr Re: Epoxy-Granite machine... 10-24-2019, 09:15 PM
peteeng Re: Epoxy-Granite machine... 10-24-2019, 09:35 PM
lukahr Re: Epoxy-Granite machine... 10-25-2019, 08:07 AM
peteeng Re: Epoxy-Granite machine... 10-25-2019, 08:26 AM
lukahr Re: Epoxy-Granite machine... 10-25-2019, 10:05 AM
peteeng Re: Epoxy-Granite machine... 10-25-2019, 10:42 AM
peteeng Re: Epoxy-Granite machine... 10-25-2019, 11:35 AM
lukahr Re: Epoxy-Granite machine... 10-25-2019, 12:56 PM
lukahr Re: Epoxy-Granite machine... 10-26-2019, 04:47 PM
peteeng Re: Epoxy-Granite machine... 10-26-2019, 08:41 PM
lukahr Re: Epoxy-Granite machine... 10-27-2019, 09:20 PM
peteeng Re: Epoxy-Granite machine... 10-26-2019, 10:52 PM
Obivan Re: Epoxy-Granite machine... 10-29-2019, 06:30 AM
peteeng Re: Epoxy-Granite machine... 10-29-2019, 06:43 AM
Obivan Re: Epoxy-Granite machine... 10-29-2019, 01:22 PM
peteeng Re: Epoxy-Granite machine... 10-29-2019, 08:33 PM
peteeng Re: Epoxy-Granite machine... 10-29-2019, 08:42 PM
peteeng Re: Epoxy-Granite machine... 10-30-2019, 11:04 PM
peteeng Re: Epoxy-Granite machine... 11-01-2019, 03:48 AM
peteeng Re: Epoxy-Granite machine... 11-04-2019, 04:04 AM
mactec54 Re: Epoxy-Granite machine... 11-04-2019, 01:37 PM
peteeng Re: Epoxy-Granite machine... 11-04-2019, 08:52 PM
peteeng Re: Epoxy-Granite machine... 11-04-2019, 08:59 PM
peteeng Re: Epoxy-Granite machine... 11-08-2019, 12:37 AM
peteeng Re: Epoxy-Granite machine... 11-09-2019, 09:31 PM
mactec54 Re: Epoxy-Granite machine... 11-09-2019, 09:51 PM
peteeng Re: Epoxy-Granite machine... 11-09-2019, 10:16 PM
peteeng Re: Epoxy-Granite machine... 11-10-2019, 08:18 AM
davebaldwin Re: Epoxy-Granite machine... 06-07-2020, 02:53 PM
peteeng Re: Epoxy-Granite machine... 11-10-2019, 09:54 PM
flick Re: Epoxy-Granite machine... 12-04-2019, 05:13 AM
peteeng Re: Epoxy-Granite machine... 12-04-2019, 06:00 AM
Buoyen Very informative thread. Tons... 12-11-2019, 05:34 PM
peteeng Re: Epoxy-Granite machine... 12-11-2019, 09:34 PM
Buoyen Re: Epoxy-Granite machine... 12-12-2019, 03:19 PM
peteeng Re: Epoxy-Granite machine... 01-11-2020, 09:56 PM
Buoyen Re: Epoxy-Granite machine... 01-23-2020, 02:52 PM
Buoyen Re: Epoxy-Granite machine... 04-15-2020, 05:49 PM
peteeng Re: Epoxy-Granite machine... 04-15-2020, 09:33 PM
Buoyen Re: Epoxy-Granite machine... 04-16-2020, 09:29 AM
peteeng Re: Epoxy-Granite machine... 04-16-2020, 09:39 AM
peteeng Re: Epoxy-Granite machine... 06-07-2020, 10:00 PM
RotarySMP Re: Epoxy-Granite machine... 06-09-2020, 11:42 AM
jono5axe Re: Epoxy-Granite machine... 06-11-2020, 04:44 AM
peteeng Re: Epoxy-Granite machine... 06-09-2020, 12:13 PM
peteeng Re: Epoxy-Granite machine... 06-10-2020, 01:16 AM
RotarySMP Re: Epoxy-Granite machine... 06-10-2020, 08:47 AM
peteeng Re: Epoxy-Granite machine... 06-10-2020, 10:07 AM
RotarySMP Re: Epoxy-Granite machine... 06-10-2020, 03:32 PM
peteeng Re: Epoxy-Granite machine... 06-10-2020, 12:30 PM
peteeng Re: Epoxy-Granite machine... 06-10-2020, 10:23 PM
peteeng Re: Epoxy-Granite machine... 06-11-2020, 08:26 AM
RotarySMP Re: Epoxy-Granite machine... 06-15-2020, 06:17 AM
peteeng Re: Epoxy-Granite machine... 06-20-2020, 11:22 PM
Mikeedd Re: Epoxy-Granite machine... 12-25-2020, 07:06 AM
Mikeedd Re: Epoxy-Granite machine... 12-25-2020, 08:37 AM
Obivan Re: Epoxy-Granite machine... 02-15-2021, 12:28 PM
badhabit Re: Epoxy-Granite machine... 02-15-2021, 12:57 PM
CaptainVee Re: Epoxy-Granite machine... 02-15-2021, 01:11 PM
badhabit Re: Epoxy-Granite machine... 02-15-2021, 02:05 PM
peteeng Re: Epoxy-Granite machine... 02-15-2021, 09:01 PM
badhabit Re: Epoxy-Granite machine... 02-15-2021, 09:33 PM
peteeng Re: Epoxy-Granite machine... 02-15-2021, 09:52 PM
badhabit Re: Epoxy-Granite machine... 02-15-2021, 10:05 PM
peteeng Re: Epoxy-Granite machine... 02-15-2021, 10:26 PM
Obivan Re: Epoxy-Granite machine... 02-16-2021, 07:07 AM
pippin88 Re: Epoxy-Granite machine... 02-16-2021, 07:16 AM
peteeng Re: Epoxy-Granite machine... 02-16-2021, 08:00 AM
pippin88 Re: Epoxy-Granite machine... 02-16-2021, 08:08 AM
pippin88 Re: Epoxy-Granite machine... 02-16-2021, 08:11 AM
peteeng Re: Epoxy-Granite machine... 02-16-2021, 08:42 AM
badhabit Re: Epoxy-Granite machine... 02-16-2021, 01:29 PM
badhabit Re: Epoxy-Granite machine... 02-16-2021, 01:42 PM
peteeng Re: Epoxy-Granite machine... 02-16-2021, 09:08 PM
peteeng Re: Epoxy-Granite machine... 02-18-2021, 07:02 AM
badhabit Re: Epoxy-Granite machine... 02-18-2021, 11:24 AM
badhabit Re: Epoxy-Granite machine... 02-19-2021, 02:42 PM
pippin88 Re: Epoxy-Granite machine... 02-18-2021, 11:34 AM
badhabit Re: Epoxy-Granite machine... 02-18-2021, 11:41 AM
peteeng Re: Epoxy-Granite machine... 02-18-2021, 11:46 AM
peteeng Re: Epoxy-Granite machine... 02-19-2021, 09:23 PM
badhabit Re: Epoxy-Granite machine... 02-23-2021, 03:47 PM
peteeng Re: Epoxy-Granite machine... 02-20-2021, 12:13 AM
peteeng Re: Epoxy-Granite machine... 02-23-2021, 08:36 PM
badhabit Re: Epoxy-Granite machine... 02-24-2021, 02:42 PM
the4thseal Re: Epoxy-Granite machine... 02-25-2021, 09:51 PM
badhabit Re: Epoxy-Granite machine... 02-25-2021, 10:00 PM
excitedbox Re: Epoxy-Granite machine... 03-04-2021, 12:28 PM
peteeng Re: Epoxy-Granite machine... 03-11-2021, 09:10 PM
Mikeedd Re: Epoxy-Granite machine... 03-13-2021, 12:37 AM
badhabit Re: Epoxy-Granite machine... 03-13-2021, 08:11 AM
Mikeedd Re: Epoxy-Granite machine... 03-13-2021, 09:51 PM
badhabit Re: Epoxy-Granite machine... 03-13-2021, 10:11 PM
Mikeedd Re: Epoxy-Granite machine... 03-17-2021, 11:11 PM
Mikeedd Re: Epoxy-Granite machine... 03-17-2021, 11:40 PM
badhabit Re: Epoxy-Granite machine... 03-19-2021, 09:46 AM
suspension Re: Epoxy-Granite machine... 02-07-2024, 02:35 AM
badhabit Re: Epoxy-Granite machine... 02-07-2024, 08:39 AM
peteeng Re: Epoxy-Granite machine... 03-19-2021, 10:33 AM
badhabit Re: Epoxy-Granite machine... 03-19-2021, 11:08 AM
peteeng Re: Epoxy-Granite machine... 03-19-2021, 11:36 AM
Mikeedd Re: Epoxy-Granite machine... 03-20-2021, 12:59 AM
badhabit Re: Epoxy-Granite machine... 03-20-2021, 07:22 AM
peteeng Re: Epoxy-Granite machine... 03-20-2021, 08:56 AM
badhabit Re: Epoxy-Granite machine... 03-20-2021, 09:15 AM
peteeng Re: Epoxy-Granite machine... 03-20-2021, 09:43 AM
badhabit Re: Epoxy-Granite machine... 03-20-2021, 10:03 AM
pippin88 Re: Epoxy-Granite machine... 02-07-2024, 09:58 PM
peteeng Re: Epoxy-Granite machine... 02-08-2024, 12:42 AM
greybeard Hi Adam, and welcome to the... 06-06-2007, 06:49 PM
ckelloug Adam, Here's a long... 06-06-2007, 09:54 PM
martinw Dear Cameron, IMVVHO, CFM... 06-09-2007, 01:10 AM
ckelloug Cool Post about the granite... 07-19-2007, 06:07 PM
greybeard Could it be because they've... 07-19-2007, 06:15 PM
ckelloug Mold release and bolts 07-25-2007, 10:57 PM
martinw Expansion bolts 07-26-2007, 12:19 AM
brunog I have been working on this... 07-30-2007, 10:54 PM
    Jul 2006
    1256
    Glad to see other member are researching E/G What we need to know is the mix ratio of epoxy to filler by weight.
    Episs price looks realy good.Maybee you could E mail them again and ask how much epoxy is encluded,then we can calculate the mix ratio.You would'nt want to ship 400lbs of sand.Buy the epoxy and source the filler locally.By the way you are in Latvia.I use lots of birch ply from your country.
    Here is some info if anyone wants to calculate volume.
    1 gallon of material,1/4"thick is 6.4sqft
    1gal of epoxy=10lbs.
    1gallon of granite=24lbs
    1cuft epoxy=7.2gal
    1cuft granite=166lbs
    Mark good stuff on particle sizing.Ihave only used graded fillers in the 20 to 200micron size.The idea is to use different particle sizes to fill in the spaces between the larger sizes.To get the 15% epoxy ratio I imange you would need fine gravel and graded fines to reduce the resin demand.Another trick is to add milled glass fiber 1/32"which increases the bond strength.Over 60% fill the mix is getting beyond pouring consistancy.I might add E/G for machines is subject to vibratory compaction which is "you gotta shake the hell outa it".
    Pimo&geof
    Why epoxy over portland as a bonding agent ? It is more expensive, must be better.Just kidding.Simply put epoxy is a superior"glue"which does not shrink and is fullly cured and stable in one week.Portland can take years to settle.
    Water+steel=IO2=rust.good luck getting your portland out of your mill upright.
    Greybeard
    Great minds think alike.I am working on the same idea.For the table I will use W-13 wide flange I beams for the perimenter of the table.The beams are 4"x4".Filling the interior with 4" of E/G would be too expencive.I working on a sandwitch.Two E/G surfaces with a honeycomb core[niacore]Honeycombs used in boat engine rooms reduce sound transmission which also means they absorb vibration.Here is a link you will like.www.precisionepoxy.com.Your final unfilled epoxy pour will level to .005.now you have a perfect surface to mount the linear guides and reference to gantry squaring.
    Hey Guys found the link which answers many questions.Try Google
    machine design polymer castings.
    If you guys still have intrest,
    tomorrow I will post an epoxy 101
    Larry
    Granite chip sweeper
    May 2003
    792
    Larry, we may be onto something here
    Our home made machines are growing in size, it takes ridiculous amount of time to weld these silly structures...
    The alternative should be:
    1. pourable, non toxic
    2. low cost
    3. zero shrinkage
    4. self leveling
    5. low cost...
    The idea is to use concrete-like solution for frames, tables, etc.
    How thick can we go with this "polymer-concrete" type of products?
    Do we need reinforcements?
    I'd like to be able to "pour" my frame- let's say 2"x4" slabs of zero shrinkage concrete-type-of-stuff. I would just use regular Home Depot cement but that stuff shrinks..
    I think the self leveling feature is also important- imagine router tables with 8' - 16' of work area... Such a pain to level those linear rails!
    My solution- just pour a 4" x 4" slabs and fasten the rails.
    Yes, some of these compounds have incredible properties (vs cast iron) but we're trying to solve some very "basic" problems here.
    Jun 2005
    1436
    For the "larger" size tables, would there be a good case forbuilding it straight onto the floor ?
    You may well need a fence around it to keep the kids and the pets from investigating this noisy "animal" tearing up and down, but if you've already got a concrete floor flex in the x axis shouldn't be a problem.
    You could even park the car over it ?
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
    Jan 2004
    59
    Folks,
    The former Light Machines Corp. (Manchester, NH, USA), now owned by Intelitek, has been using Polymer Concrete for the frames of their top-line ProLight PLM and Benchman milling machines for nearly 20 years now. At one time (in the mid 1990's the bases were being made by ITW Philadelphia Castings. In fact there were pictures of the PLM molds and castings in the ITW catalog. I'm not sure if ITW is still making the bases for Intelitek, and I suspect possibly not, as I have noticed some minor changes in the newer PLM castings, and an absence of the PLM pictures on the current ITW website (although this may be for "trade-secrecy" reasons).
    At one time I had seen an intentionally fractured sample bar (2"x2"-ish tensile or flexure test?) of the "zanite" type material used in the PLM bases. As I recall, some of the quartz or granite aggregate was similar in size and shape to "fish tank gravel" like BB-size (.18-.25" / 5-6mm). Anyhow - when professionally engineered/applied, polymer concrete can be an outstanding material. And with a bit of research and experimentation, I'll bet that us DIY folks could yield very good results. Good Luck!
    Mar 2005
    1136
    Quote Originally Posted by walter View Post
    I had never thought of an epoxy granite structure as replacing a steel fabrication, its not strong enough imo, the yield stress is much lower than steel or cast iron irrc and the modulus of elasticity is about 1/6. saw it more as a way to stop a fabrication ringing like a bell. commercial practice suggests the same, where I have been able to see commercial uses for epoxy concrete, it is either filling the voids in a CI or steel structure OR use as a heavy base for machines deploying negligible forces, ie optical equipment. I would not make a metal working machine just of epoxy concrete, not unless a lot engineering calcs proved my assessment wrong. don't forget to normalize any fabrications going into a machine
    Larry you mentioned earlier 50X better than steel and 10x better than CI for epoxy/granite's vibration dampening abilities, seems high to me. I'd read CI is 1x better than steel and Epoxy granite 50% better than CI. Not that easy to find info on the subject though, after all vibration is a magnitude and a decay, its not straightforward, at least to me, what better means, but 10x seems high.
    thanks for all the good info being posted on the subject, I continue to believe it holds promise for high end diy machines
    Jul 2005
    12177
    Quote Originally Posted by Mcgyver View Post
    ...Larry you mentioned earlier 50X better than steel and 10x better than CI for epoxy/granite's vibration dampening abilities, seems high to me. I'd read CI is 1x better than steel and Epoxy granite 50% better than CI. Not that easy to find info on the subject though, after all vibration is a magnitude and a decay, its not straightforward, at least to me, what better means, but 10x seems high.
    This page has the numbers claiming better damping characteristics:
    http://www.accurescasting.com/polymer.html
    On other pages I found some rather unbelievable claims for casting accuracy such as +/-0.0005".
    But they do refer to 'machine bases and support structures' so they are not talking about using this stuff for the entire machine.
    Jun 2003
    2103
    Then I guess this machine won't work!
    Here is the story link.
    http://www.machinedesign.com/Content...MecRG02-01.jpg
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jul 2006
    1256
    non toxic
    Walter
    Epoxy is only nontoxic after full cure, one week.People tend to think it is not toxic as it has no flamable solvents.Epoxy can pass through your skin.Wear gloves and mask if sanding.
    Larry
    Jul 2005
    12177
    I found this page which gives a lot of answers that lead me to conclude this is not a technique that can be readily adapted to DIY; considering you first need to make a very precise steel mold and the material cannot be worked after casting.
    http://www.itwpolymercastings.com/faqzanite.html
    But the materials are not difficult to find:
    "Zanite® polymer composite is a blend of pure silicon dioxide ceramic (99.8%) quartz aggregate, specially formulated high strength epoxy resin and selected additives. The natural elliptical shape of quartz is ideal for casting intricate structures."
    In fewer words; sand and epoxy.
    May 2003
    792
    I had never thought of an epoxy granite structure as replacing a steel fabrication, its not strong enough imo, the yield stress is much lower than steel or cast iron irrc and the modulus of elasticity is about 1/6....
    Good point.
    Then again, folks here don't build metal working CNCs. 90% of these machines are destined for wood, mdf, foam, plastics, aluminium.
    I'm into wood machining, and really dislike the idea of steel tubing, welds, drilling. Fastening together 800 lbs of tubing would take months! I even hate the smell of it
    I just need the basic rigidity and level- I'll go with (reinforced) concrete type of material.
    Thanks for all the replys- you guys are the best!
    Mar 2005
    1136
    Good point.
    thats part of it - different paradigm - no doubt we're visualizing two very different machines! its building metal working cnc's that interest me, I have little interest in wood machines for now. my thoughts were that a heavy weldment, using structural shapes could be filled with E/G and you'd have a chance at a metal working machine, small work envelope but very heavy and rigid. still, from I've been able to learn, its advantage over steel/CI is in vibration dampening, not strength or rigidity.
    Jul 2006
    1256
    Mcgyver and Geof
    I have to agree, I cant see a hobyist building an entire machine ofE/G.For us hobbists we can use it for table tops,machine bases and weldment filling.Yes there are commercial machines totally composites, made in molds.
    I would hate to think what would happen if a forklift bumped into a 100% polymer machine
    Larry
    Jul 2005
    12177
    Quote Originally Posted by lgalla View Post
    ...I would hate to think what would happen if a forklift bumped into a 100% polymer machine Larry
    I would hate to think what would happen if a forklift bumped into any machine!!(chair)
    But I do have a question: You say; "there are commercial machines totally composites", are there really? All I have read refers to machine bases not the full machine.
    Jun 2005
    1436
    Mike - could you revise the link to that story in #23 as your link is only to the picture.Thanks
    John
    Jan 2007
    10
    Found more Polymer Concrete
    http://5128.rapidforum.com/topic=110...6&search=beton
    try this link. German cnc site. Just look at those pic's. Looks Good
    Attached Thumbnails Attached Thumbnails T6765_110773689090_Portal7.jpg   T6765_110773689090_Portal6.jpg   6765_110773689090_Form4.jpg   T6765_110773689090_Porta2.jpg
    Jun 2005
    1436
    schrupphobel72 - Your last three images are corelpaint (?) could you make them jpegs so we can enlarge them.
    Not sure about the link as I don't read German -it's a forum, I think ?
    John
  17. #17
    Jul 2006
    1256
    Bad News
    And now for the bad news, cost.
    Lets assume$50/gal for epoxy,10 cents a pound for sand.I will round off to the nearist numbers.
    To simplify things we will try 33 1/3 % epoxy/sand.
    1cu/ft epoxy=7gallons =70lbs=$350
    1cu/ft sand=166lbs=$16.60X2=$33.20
    Now we take 1 cuft epoxy and 2cuft sand and have our33%to66% ratio
    So the cost for 3cuft=$350.00+33.20=$383.20
    Cost per cuft.=$120.00
    Weight of 3cuft 402lbs
    Cost/sqft=$10.00
    Our 3cuft at $383.20 gives us 32sqft one inch thick.
    Looking back to post #10 from Episs we are close to the same price and weight
    More calculations for my 6'X12'X4" router table.Lets see 72sqft4"thick=280sq ft X$10=$2800.00 Total weight 3080lbs
    Larry
  18. #18
    Jun 2003
    2103
    Quote Originally Posted by greybeard View Post
    John
    http://www.machinedesign.com/ASP/vie...MDSite&catId=0
    Sorry about that.
    Mike
  19. #19
    Jun 2003
    2103
    I guess my first post wasn't clear enough. The only thing on the structure of this machine that is metal is the bed. Go read the info about it. It is a metal working machine made almost entirely of the PC you have been discussing here.
    If you search you will find many articles about metal working machines that have been made that hold better tolerences because they are built of PC.
    Mike
  20. #20
    Jul 2005
    12177
    That is the link that claims a casting precision which I find hard to believe. Here is a quote:
    "A mixture of reactive, high-strength resin and mineral aggregates makes as-cast machine components to 0.0005-in./ft flatness, with hole diameters to ±0.0001 in., and feature dimensions to ±0.0005 in./ft."
Page 4 of 220 234561454104
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
