603,370 active members*
3,698 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > ER-16 Collet stuck in ER-16 Tool Holder
    Sep 2008
    199
    Ok, So I'm hoping to remedy this before my boss comes back and gives me a bunch of crap about how much everything costs. I think I put a slightly too large drill bit in an ER-16 Collet. I believe the Largest you can do is .393 in ER-16 and I put in a Bit just under that, .391 I believe. Regardless of this I did some machining with this bit and I went to take it out. I unscrewed the cap and tried to pull the bit out but it wouldn't budge. I continued to unscrew to the point that the Cap and the collet disconnected. (Not Supposed to happen) Now I have the Cap off the Tool holder but the collet is still stuck in the tool holder with the Drill Bit. Is there any trick to remedy this? Old Fashioned Elbow Grease makes me think I'll damage the Collet or the Threads on the Tool Holder.
    Please have a solution!!!
    Sep 2008
    199
    I got it out! UNfortunately I had to ruin the drill bit but it was only HSS. I screwed the cap back on and clamped down on the Drill Bit in a Vise. One good swing with a dead blow and it slid right off.
    Mar 2003
    4826
    If you screwed the collet nut back on over the collet with a large tool installed, you have probably ruined the nut. It will not extract properly henceforth.
    First you get good, then you get fast. Then grouchiness sets in.
  1. Cat 40 collet tool holder question
    By dlenardu in forum MetalWork Discussion
    Last Post: 03-20-2008, 08:26 PM
  2. Can I use a collet holder with a lathe?
    By acerocket in forum CNC Tooling
    Last Post: 10-27-2007, 09:07 PM
  3. MT2 er32 Collet Holder
    By dfurlano in forum Benchtop Machines
    Last Post: 08-21-2007, 09:50 PM
  4. R8 Collet Holder Tool Setter
    By Chrisjh in forum Syil Products
    Last Post: 08-07-2007, 02:44 AM
  5. 7x10 headstock collet holder?
    By Tim Wiltse in forum Mini Lathe
    Last Post: 04-24-2007, 01:43 AM
