603,953 active members*
2,574 visitors online*
IndustryArena Forum > CAM Software > Mastercam > ERROR Cannot find parasolid data in solidworks file?
Results 1 to 7 of 7
    Jan 2009
    245
    Ok, So I have been running Mastercam X for about 4 years now, and my customers send me .sldprt files from solidworks, that I open in mastercam, and save as a .mcx file. Now when I try and open .sldprt files, that I could open before flawlessly, it now says, "cannot find parasolid data in solidworks file".
    I have tried it on 3 different computers with the same result. Makes no sence to me.
    I mean just simple .sldprt files, Mastercam x will not open anymore from me. Is there a setting or something that could have changed?
    Apr 2007
    47
    I had this happen as well. Believe that it is because the version of solidworks is newer than what Mastercam X can open. Try going to mastercam website and make sure you have installed all the latest updates for version X. If that doesn't work you might have to update to update to X4 or X5. Good luck!
    Aug 2010
    102
    Quote Originally Posted by flatfnder View Post
    I think you're right. Although, I remember getting the error occasionally when using X4 to open SW2010 files, and I still get the problem when using X5 to try to open SW2011 files.
    I had read a fix for this somewhere, but can't remember where or what the fix was
    Dec 2008
    3216
    Generally, when Mastercam imports a parasolid file, it is expecting a solid entity in the file to convert......check with the customer that a solid exists in his file ??
    Aug 2010
    102
    Quote Originally Posted by Superman View Post
    coming from solidworks, isn't virtually any model a solid? As long as it's not made with a bunch of surfaces attached together, shouldn't it be a solid?
    May 2010
    There is a free download called Mastercam Direct for solidworks on the Mastercam website. Not sure if you have to be on a current maintenance program. Most likely knowing cnc software. Worth a try. I know you will get this error if your mastercam is too old for the solidworks file.
    John
    May 2006
    807
    How about asking the customer to SaveAS in another transferable format?
    Parasolid binary for example.
    IGES works fine.
    Been doing this too long
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  3. New machine part database - solidworks, igs, parasolid, etc
    By vacpress in forum Community Club House
    Last Post: 11-01-2007, 06:38 PM
  4. Faro arm data to solidworks
    By calthaus in forum Uncategorised CAM Discussion
    Last Post: 08-17-2007, 04:23 PM
  5. Convert 3d studio file to iges/parasolid?
    By Rekd in forum Uncategorised CAM Discussion
    Last Post: 04-09-2004, 03:10 AM
