603,936 active members*
2,659 visitors online*
Results 1 to 5 of 5
    Jan 2010
    3
    error code 201
    milltronics milling machine VK3 will run all drill cycles but will go to DOS trying to run any mill cycle.Deleted all program files and uploaded parameter file.Same problem could anybody help.THANKS
    Oct 2006
    179
    Error 201 is a Range Check Error. Something (parameter, program input, etc..) is out of range or too large. The DOS error contains an address number and software version. What is this?
    Jan 2010
    3
    Hi Jpawelk
    The DOS version is 6.22 and the address is 0019:15BD
    Oct 2006
    179
    The software version of the Milltronics software, not the DOS version.
    Jan 2010
    3
    Hi Jpawelk
    3 AXIS SLS CNC 6.3159p FLASH
    Thank you
  1. error code 017
    By musnar in forum HURCO
    Last Post: 10-13-2009, 02:20 PM
  2. Unknown g code G23 error?
    By keaton64 in forum Mach Plasma / Laser
    Last Post: 09-22-2009, 03:33 AM
  3. ps 101 error code help!
    By AC_Engineering in forum Bridgeport / Hardinge Mills
    Last Post: 11-13-2007, 01:01 PM
  4. art code error
    By Mike Boarman in forum Mach Software (ArtSoft software)
    Last Post: 12-31-2006, 05:46 AM
  5. M01 error code
    By MRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-12-2006, 01:59 PM
