603,891 active members*
3,282 visitors online*
Results 1 to 4 of 4
    Dec 2006
    115
    Hello
    My machine is Gildemeister CT40. When I reverse the main switch, the machine doesn’t start. An error occurs: 9990 system error -> error operation gateway!
    Does anyone what it means and how I can solve the problem?
    I’ll appreciate any help.
    Regards
    Hello
    Check up the cabel connection between command station and switch cabinet.
    Regards mtronik
    <a href='http://www.ersatzteilcenter.net' target='_blank'>Online ersatzteilcenter für Werkzeugmaschinen</a>
    Jul 2004
    62
    Hello Nummer8,
    check if the switcher for the swarf conveying is turned on.
    Nov 2005
    263
    Hello,
    as I understand, the error occurs during initialisation.
    I think board is damaged.
    We’ve had a similar problem. After board change the problem was away.
    Andy
    <span style='color:green'>ERWARTEN SIE IMMER DAS UNERWARTETE&#33;&#33;</span>
