586,071 active members*
3,820 visitors online*
    error EMCO 325
    Hello,
    i have a porbleme with a cnc turn EMCO 325 there is an error "no spmgr32 drivers are specified in spmgr32.ini manager is not active "
    the manufacturer wants to resell me an update and change the pc
    Someone help me
    attach the photo of the error
    cordially
    Re: error EMCO 325
    WinNC is not Siemens so probably won't find help here. You must have an older Emco AC95 control and a 325-II? Essentially AC95 is not supported any more and they want you to upgrade to the Concept control. If you have installation discs for WinNC, you could probably reinstall, but it's odd that you have anything missing in the first place. Did you clone or make any changes to the HDD?
  1. Emco Compact 6 Error Code
    By shaftalignment in forum EMCO Lathe
    Last Post: 07-03-2014, 02:51 AM
  2. EMCO PC Turn 120 lathe main drive VFD Error
    By F45CNC in forum EMCO Lathe
    Last Post: 06-30-2014, 10:25 PM
  3. Emco F1P-CNC error alarm please help
    By OLDTOAD in forum EMCO Mills
    Last Post: 02-14-2013, 02:32 PM
  4. Emco Maier 342 error
    By larrydpm in forum EMCO Lathe
    Last Post: 12-12-2011, 07:30 PM
  5. EMCO WinNC error 8 (PC MILL 55)
    By AWysiecki in forum EMCO CNC Machines
    Last Post: 09-08-2011, 05:58 PM
