Having some issues with errors while using I & J codes.
Several times I've had errors on the machine while trying to cut a profile with cutter compensation. It seems that the I & J numbers generated just don't match with the centre point of the rad.
I've got around it by either using 'arc approximation' so that all the moves are linear moves. Or I've changed my GPP file to output 'R' moves instead of I & J.
Anyone had this problem?
Any ideas for a solution?
It's just a bit of a pain when it goes 9/10ths of the way through a 3D finishing cut and then errors out :-(
Cheers, and a Happy New Year to all.
