Hello everybody
Does anybody know what this error message mean?
from Locfile:
17978 14:42:07 DPS100 OVERRIDE FEED CHANGED FROM 0 % TO 122 %
17979 14:42:15 DPS100 OVERRIDE FEED CHANGED FROM 122 % TO 164 %
17980 14:58:26 EEX400 TIME FOR FUNCTION AUCPRGCHK RUN OUT: AUCOL-ANTSWER NECCESSARY (MD*PRG=0) <--------------------------HERE
17981 14:58:26 WEX144 N18736 X-167.995 Y-193.849 A-6.741 C-0.213
17982 15:00:16 IWS183 DO YOU WANT TO DISRUPT THE EXCECTION IG THE CURRENT ISO FILE?
17983 15:00:17 IEX452 EXCECUTION TIME DATEI 00:18:14
17984 15:00:17 IUI053 COMMADN ACCEPTED: ABORT ACCEPTED
17985 15:00:18 IPS021 PRESSED THE SPINDLE STOP KEY
17986 15:00:18 IPS043 DESELECTED THE M03 MODE
17987 15:00:18 IAU038 PLC FEED HOLD
17988 15:00:19 IAU039 PLC FEED RELEASE
Thank you very much in advance!
Matthi
