603,978 active members*
2,225 visitors online*
Thread: error msg!
Results 1 to 5 of 5
    May 2009
    8
    error msg!
    I just moved my machine to a new place and I get this on the screen:
    923-11 ALARM P SVP SA Communication error MAaxis 2
    SBP 5-A v3. 02-A (ENG)
    MEMORY TEST: 0000
    LOAD: SYS
    EC PROCESSOR ON LOADING
    SERVO PROCESSOR ON LOADING
    SBP MONITOR
    with this, all the lights on the buttons are on (like every single one of them)
    also lights above the screen are on as well
    I checked the back and on the VACIII-Drive unit, it shows Alarm #15
    Dec 2008
    3216
    Communications error with MA-axis
    Mill/Lathe ??? with MA-axis
    something is not connected, swarf conveyor, bar feed etc.
    make sure all parts are connected and re-check
    Jun 2008
    372
    Alarm P is terminal. Need to call ya service guy
    Mar 2009
    1992
    must be mill. check connection in control cabinet first. It could be cable to magazine axis motor encoder also.
    Spindle (VAC3) is just stopped because of magazine fault.
    May 2024
    Re: error msg!
    Quote Originally Posted by Taehk View Post
    MEMORY TEST: 0000
    LOAD: SYS
    SBP MONITOR
    Did you ever figure out the problem? im having the same one. Was it a drive?
  1. Matsuura Mc500v seq error/magazine error
    By mc500v in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2020, 04:57 PM
  2. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  3. OM-A ROM PARITY ERROR "NOT RAM ERROR"
    By offroadxx in forum Fanuc
    Last Post: 05-08-2008, 02:15 AM
  4. BG error on 10T
    By guhl in forum Fanuc
    Last Post: 12-01-2007, 10:24 AM
