588,225 active members*
3,995 visitors online*
    Jun 2022
    Error opening Xilog Maestro file
    Message comes up "exception has been thrown by the target of an invocation" when I try to open the file is there any way I can recover this file or has it been lost?
    Help is much appreciated.
    Dec 2022
    8
    Re: Error opening Xilog Maestro file
    Hello, you might already have this sorted as this post is 2 months old. It is more than likely a fault in the drawing itself. Be quite thorough when you check through your work. It can be caused by one of the geometries that is used as a tool path. Check your parameters as well, hover over it with your mouse and see if it returns a value, I have had problems in the past where the parameters returned "NaN". Hope this helps!
  1. xilog maestro
    By aymanodah in forum CNC Machining Centers
    Last Post: 12-09-2022, 11:52 AM
  2. How to get Xilog Maestro 3D?
    By Zane553 in forum CNC Machining Centers
    Last Post: 03-05-2021, 01:30 PM
  3. How To Fix “Error Opening File For Writing” Error In Windows 10?
    By Philiphamlet1 in forum Computers / Desktops / Networking
    Last Post: 02-04-2021, 07:47 AM
  4. Postprocessor xilog maestro please
    By JOSERRASZR in forum Alphacam
    Last Post: 03-27-2020, 09:32 PM
  5. Replies: 1
    Last Post: 09-28-2016, 04:18 AM
