586,043 active members*
3,574 visitors online*
Results 1 to 4 of 4
    Feb 2018
    8
    Error Z70 tx8h Traub
    Hello. How to remove the Z70 error in controlling the traub tx8h lathe. I have blocked 2 Z Axes.
    Sep 2017
    139
    Re: Error Z70 tx8h Traub
    Seems like the home position is lost?
    If its an absolute system, check the battery voltage on drive unit.
    If incremental, please do the initial referencing of all axis
    Feb 2018
    8
    Already the error has been removed. I have a problem with spindle S1.G1 for mm / U does not work, and the C axis does not turn on. I need parameters for S1. I think there is a bug there. Simodrive 611 drive. Can anyone help?
    May 2019
    7
    error de drive axis
  1. traub csk 400
    By tzvetan in forum Mitsubishi controls
    Last Post: 05-13-2017, 10:14 PM
  2. TRAUB CSK 400 P
    By tzvetan in forum Machinery Manuals / Brochures
    Last Post: 10-26-2016, 05:58 PM
  3. Traub TX 8F DNC
    By cnc.apps in forum USB, RS232, PARALLEL etc
    Last Post: 08-24-2016, 04:49 PM
  4. NEED HELP - Traub TX 8H
    By jetge in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2016, 02:59 PM
  5. DNC Traub
    By ddorin in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2011, 01:42 PM
