603,850 active members*
5,050 visitors online*
Results 1 to 9 of 9
    Aug 2014
    3
    Etch Deep into Acrylic, but not Cut Through?
    I have access to a 60W Epilog and a 100W Trotec. I want to create something like a die or a photopolymer plate for debossing into card stock.
    To do so I need to cut away large chunks of the die material. But, to keep all of the elements in place, I would like to etch deep into the material, leaving connections between them which won't hit the paper.
    My first thought would be to use acrylic, mounting the "die" on something big and flat (like a thicker piece of acrylic).
    The question is, can I cut away chunks of acrylic without cutting all the way through? If not is there a material you guys would recommend? Maybe a bunch of passes on some piece of hard wood might work?
    Thanks,
    Gary
    Jun 2014
    611
    Re: Etch Deep into Acrylic, but not Cut Through?
    Hello Gary, this is Nolan from thunderlaser, I'm not quite understand your question, so I don't know whether the laser cutter can meet your requirement, can you explain it?
    I think cut acrylic is ok, but what do you mean cut away chunks of acrylic without cutting all the way through? or you can visit our website, you can see many samples and videos, maybe it's useful to you.
    Aug 2014
    3
    Hi Nolan:
    Thank you for asking for clarification.
    If I'm making a rubber stamp on a laser, I can etch the negative space away, leaving only the shape of the thing I want on the stamp. In this case, I'm looking to do something like that. I need to create a stamp that will leave an impression in paper that metal type would on a letter press.
    I can cut away most of the negative space. But, I still need small chunks connecting the letters so they stay in place relative to each other. The height of those chunks needs to be reduced so only the type makes the impression on the paper.
    Thanks again,
    Gary
    Jun 2004
    6618
    If you are not cutting through, then the letters would stay in place. No need for a bridge support then. That is how I understand your explanation so far.
    If you can show a drawing of intent, that may help.
    Lee
    Aug 2014
    3
    Hi Lee. The real question is can I cut deep into the the acrylic (or hardwood or something I can use like a die for debossing). I'm trying to produce something like below. The color is just to show the different shapes. The type would create the impression. The rectangle would hold it together:
    I have never dug deep into acrylic and I have the impression it would be very slow going. But, I need something hard with hard edges to make the into the paper (or really mat board).
    Jan 2008
    940
    Why not engrave like your rubber stamp but adjust your power and speed settings
    Nov 2012
    492
    Fixtureman is correct just engrave what ever material you choose just like you were making a rubber stamp, wood, acrylic what ever, derlin works well for this also.
    Dec 2012
    19
    you mean like this?
    Main products Email [email protected]
    Laser Cutting, Marking Machine, Solar Cell, Modular Test Equipment
  1. Deep Hole drilling, really deep...
    By GM81 in forum Fadal
    Last Post: 11-25-2013, 10:57 PM
  2. Acrylic cutting issues with non perspex acrylic...
    By amy_stars in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-11-2013, 07:09 PM
  3. Deep Deep Pocketing issues
    By Dsmed in forum Tormach Personal CNC Mill
    Last Post: 01-22-2013, 06:00 AM
  4. Clearing out ½" deep 1" wide in Acrylic
    By carguy327 in forum Glass, Plastic and Stone
    Last Post: 10-04-2007, 07:32 PM
