Connection on fanuc and computer is ok all light's is green, shouldn't need crossover cable theese days
![Wink](images/smilies/wink.png)
They fixed that some years ago.
< I hook my laptop up directly to Fanuc controls using a CAT-5 crossover cable.
I\O channel 9 didnt work, 5 was out of range. Still no luck, it's prolly something stupid i haven't done yet.
< 9 is the correct setting for Embedded Ethernet.
Any suggestions?
< Either buy a crossover cable or a hub.
Does it need reboot after I\O channel change? or something like that?
< Not after I/O channel change, but I believe it does after Embedded Ethernet parameter change.
Prolly stupid question since i could try restart
But machin is producing.
I powered on the other machine todo some tests, seemse like when connected to machine and WLAN it will work, something blocking it on the laptop i guess, will do a reinstall of laptop then a new test..
