587,175 active members*
3,232 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Exact stop vs cv mode in Mach 3 from sheetcam
    Aug 2007
    39
    I have a problem with the jerky motion of my router.
    I can only find Mach 3post processors in Sheetcam that outputs arcs in I and J commands.
    I have previously, using other CAM software, always done arcs with coordinate points instead of I and J,and had no problems.
    I have tried to force CV mode on using a G64 line in the beginning of the Gcode file, and the CV mode is showing green on the Mach 3 screen?
    Can anyone help?
    Regards and thanks
    Mar 2003
    35538
    If you mean the CV LED is green, then that means it's on?
    I don't really know what else you're asking?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2007
    39
    Hi
    The CV LED is green. Even so the motion seems jerky through the endpoints ofhe arcs.
    What I am really after is a post processor which does not write out I and J commands to cut arc segments, but rather breaks an arc up into lots of small straight lines and then cuts it.
  1. Help! Mach 3 Won't Move my Stepper Motor - Emergency Stop Mode
    By AntonCNC in forum Machines running Mach Software
    Last Post: 03-08-2017, 02:38 AM
  2. Not so exact stop on Fanuc 21i-MA
    By tcom-frazzled in forum Fanuc
    Last Post: 04-09-2012, 09:24 PM
  3. need help with exact stop in a tm1
    By mam in forum Haas Mills
    Last Post: 12-14-2011, 02:43 AM
  4. exact stop mods
    By howecnc in forum Tormach Personal CNC Mill
    Last Post: 04-25-2009, 07:20 PM
  5. (abnormality) cv vs exact stop
    By Claude Boudreau in forum Mach Mill
    Last Post: 01-18-2009, 01:33 AM
