587,842 active members*
3,384 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Example of Live Tool Engraving w/ Surfcam
Results 1 to 8 of 8
    Oct 2007
    30
    Smile Example of Live Tool Engraving w/ Surfcam
    :cheers:
    Does anyone have something they could post where they did a rotary axis engraving part on the C-Axis with Surfcam? I also need a Live Tool Post too.
    I looking to learn a few things:
    How to draw and set-up a C-View for a cylinder. Extract Text to the Cylinder. Then correctly tool-path the Text and post to Fanuc.
    May 2007
    71
    If You just have the cylinder and Text and text poistion
    1. Please keyin the Text string at that start position and explode the Text string (True Type Font and explode to geometries)
    2. Use 2 Axis controur or pocket to engrave the Text.
    3. NC Operation --> Transform Operation --> Wrap On Cylinder
    Wrap the 2 Axis Tool Path on a cylinder you need.
    Alll you need is a Living Tool mill/Turn SPost.
    Besides, if your text string at some Flat plane on the Cylinder, then just create that Flat Plane CView and program a Item#1 and Item#2
    Feb 2010
    Need help with Mori Seiki SL25 Engraving
    Doing the facing engraving is so easy, but when trying to do a the O.D engraving accross the dia. I have a problem with the program. If anyone could help me with a step by step instruction it would be very helpful.. I'm still running MasterCam 9.
    Thanks... Beau
    Feb 2010
    if your doing face engraving draw everything in sideview and plan.. contour letter's and ur done. that is if ur using MasterCam.?
    May 2007
    71
    Quote Originally Posted by BigBeau View Post
    Thanks... Beau
    Please read my explain on above for O.D. engraving.
    Sep 2006
    74
    Engraving on a Conic Section
    Anyone ever engrave on a conic section ? I have the conic section around the X axis, and the lettering is done in Solidworks, but I have yet to figure out how to get this to work......
    Apr 2003
    637
    4 axis or 3 axis?
    Sep 2006
    74
    4 axis...sort of
    figured it out, 4 axis contour works well. You have to select the guide surfaces separately each time you select a contour... painfully meticulous, but works.
    This is with Surfcam ..
  1. X3 - threadmill on live tool
    By cnc-king in forum Mastercam
    Last Post: 10-13-2008, 03:55 PM
  2. Puma2500Y live tool
    By phx in forum Daewoo/Doosan
    Last Post: 07-09-2008, 05:42 PM
  3. lathe live tool in MC
    Last Post: 04-28-2008, 07:56 PM
  4. Miyano Live-Tool
    By JerryH in forum G-Code Programing
    Last Post: 10-26-2005, 01:50 PM
