Hi all,
For those who interested pls visit http://www.excelcut.netmyne.com .
Cheers,
arman
Hi all,
Cheers,
arman
Looks great !!
Tal
Looks nice.
¿Where can I find plans for a foam cutter?
Hugo Carradini
hi tbarnea,
i like to have dxf input but not so soon. busy with other thing...
thanks for your suggestion.
arman
Very interesting indeed.
Very well illustrated and described.
Thank you for the information.
Hi all,
excelcut new feature:
1. accept dxf file
2. support independence x, y step/mm
Cheers,
arman
hi cwilliam,
i did some changes to the file. should be ok now !
new improvement:
1. implement with "add & subtract" algorithm - more accurate & fast
2. Backlash compensation added
rgds,
arman
First reference to ExcelMill does not link - oh the trials of website building - eh? Downloads ok from secondNOTE: first ref is minus "www" dubdubdub... second works
Sorry I missed a chance to meet you when I was in JB. Maybe next time.
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
ARMAN - just a quick question or 2...
1. Any plans to port it over to Open Office 2.0+ ? I messed around a bit with OO and it does not function a clearly or easily as I had hoped - maybe I go get some excel...
2. Could you share some more pics and plans/details of your nice looking foam cutter? There are always guys looking for ideas like yours. Its your thread or start another I guess.
:cheers: Jim
hi highseas,
thanks for your info about the "excelmill" broken link.
are u flying in jb ?
about openoffice, i've not yet play around with it. the reason i use excel 2003 to create my software is because my wife is a teacher. as a teacher she get school computer and has excel 2003 installed. so when she's not using during the night i'll take incharge.
regarding my foam cutter machine, it's rather ugly actually. i'll consider to post some picture on my website.
rgds,
arman
hi arman
I'm having some problems with the software -- like it works some time and it doesn't other times I'm running it on excel-2007 and i think I'm having an I/O problem -- like the software is not taking the port address or something like that !
what should i do please advice
thanks for your time
sahil
hi sahil,
i don't have excel 2007 to test. may be your pc speed is too fast. try increase speed delay from 10000 to 20000. pls let me know if this help.
arman - Greetings.
Porting the ExcelCut to Open Office would be real nice! Aa great combo - 2 freebie programs!
Is there a way to test/check a file without having the controllers attached to the pc? I'd like to do that to make sure all is well before taking the file out to the "shop." Maybe some trick to fool the software into not looking for the controller?
:cheers: Jim
hello arman
i think i have not made my question clear! what i meant was--- i was having a start up problem i.e once i open the program ( for the 1st time ) i input the parallel port address and un-check the home limit option the save the file and then give power to the machine wala it works -----as far as delay speed is concerned i have gone as low as 2000 without any glitching problems .
now for the problem , at the time of closing the program i get an saving option ( if i save the current setting are not ) once the program is closed and opened back it won't work ! but all of sudden after lots of opening and closing is works !
I'm new to all this stuff ! and i have been running this program on IBM laptop P4 , OS-XP service pack 2 and office 2007 !
thanks again for the help and i think its an wounder full program,i just have to work out my bugs
sahil
hi sahil,
try save as 2003 version. i'll test it with 2007 next week. (Holiday season in Malaysia)
hi high seas,
you can do that by
1. on 'limit switch' section UNCHECKED the Enable Home & limit Switch
2. on 'Shape Cut' section put 'Pause on Cut' = 1
rgds,
arman
okay i will do that n have a happy holiday seasonhi sahil,
bye
sahil
I lost my copy of Excelcut 4.2 due to pc failure. I don't have a backup, web site is MIA, and I can't get a hold of Arman. Can some one seed me a copy to b.bixel@juno.com. I have a password to unlock the source so I good there.
Regards,
Bart
