Sorry Splint for not sending you the deatils of that transformer guy. I just cant find them.
The Rutex cards also have a current limiting contol on them. So for instance if the servo is asking for 60 amps (unlikely) the current limiting control will only give it 10 amps or whatever setting it is at.
If I undersatnd correctly having 50 or 60 amps available to the driver card is not an issue, it only becomes a problem if the software is trying to make more than the upper limit of amps pass through the bridge.
Heres how it works. The software drives the Rutex cards that chops the voltage only.
The current pull is only determined by the windings on the servo.
If a servo has a 10 amp rating then that is only ever what is going to pull ( unless its faulty). Even if your power supply can give 1000 amps the servo will only pull 10 amps.
However, if your servo has a 60 volt rateing and you give it more volts then that is where you have to worry.
When designing your power supply make it as high amped as you can, but stick to the specified voltage of the servo ratings.
Being outside the square !!!
