603,942 active members*
3,812 visitors online*
Results 1 to 6 of 6
Hybrid View
sen-maquettes excitech 1325 with mach3 07-30-2008, 12:36 PM
Big S There are some of us on here... 07-30-2008, 01:46 PM
Field Worker Shannon, I have the 1325... 01-14-2009, 05:18 PM
Big S Mine has the same pinions on... 01-14-2009, 07:57 PM
Field Worker No, I'm trying to get one... 01-15-2009, 12:01 AM
Field Worker I have the 1325 and Mach3 but... 01-14-2009, 05:16 PM
    Jun 2007
    can somebody tell me how i can run mach 3 on a excitech machine ,and what do i need to to make it work
    Willem van Dijk (Netherlands)
    Jan 2006
    509
    There are some of us on here that are looking into doing the same thing (myself included) I can't see too many problems with using a breakout board and separate computer.
    Shannon.
    Jan 2009
    12
    Shannon,
    I have the 1325 model. Does your machine have the same pinion gear for the Y axis?
    Mine have bent twice and I am not sure what is causing it.
    Jan 2006
    509
    Quote Originally Posted by Field Worker View Post
    Shannon,
    Mine has the same pinions on the X and Y axis, I think they would be very similar to yours. I am not sure why they are bending though? The mesh needs to be just tight enough that the gears mesh with no backlash but not excessive pressure.
    Did you get new ones sent over from China?
    I think Kent Norway is still working on his Mach 3 conversion and mine may be a while off yet. There is someone on here that has an Excitech running on Mach3 though, forget who.
    Shannon.
    Jan 2009
    12
    No, I'm trying to get one here in the USA first. I hope to have something coming this week.
    Jan 2009
    12
    I have the 1325 and Mach3 but let it be know that I am new with it for 7 months, do you have the system up and running now as your post has been awhile?
  1. Excitech Cnc Router Purchase
    By rocket67 in forum Excitech routers
    Last Post: 04-21-2025, 06:06 PM
  2. Excitech SHM 1530A
    By GraHutch in forum Commercial CNC Wood Routers
    Last Post: 03-18-2012, 03:39 PM
  3. The sh-cnc Excitech 1530 B
    Last Post: 08-13-2008, 06:53 PM
  4. Excitech controller quest
    By Matty Zee in forum Commercial CNC Wood Routers
    Last Post: 08-07-2008, 10:26 AM
  5. USB FLASH FOR CNC 1325-A
    By Triono in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-02-2008, 03:43 PM
