588,410 active members*
5,361 visitors online*
Page 40 of 131 3038394041425090
Results 781 to 800 of 2602
  1. #781
    Jun 2006
    35
    Quote Originally Posted by Jimmy007 View Post
    Lee,
    Did you clean the machine well before first run?
    I would hope that HIWIN ball screws would not shed chunks of themselves during any wear in period- they are supposedly precision ground to verh high tolerances and would hope supplied clean to EXITEC so if lubed there should be no visible wear compomnents.
    You will likely find the crud on your screws came from elsewhere in the factory (in the process of building your machine or another near it), I pulled the covers off my gantry and found all sorts of alloy swarf and other crap in there.
    I thought i did a pretty thorough clean out, i didnt disassemble anything?,
    sprayed threads and best i could into bearings with crc, you got me thinking
    you're right about the precision of the ball screws, hope i havent screwed
    anything!
    Anyone else have metal filings in ball screw oil?
    EDIT: 03/01/08
    I found the problem with the metal particles!
    The metal particle's shown in my photo were actually already in
    the cheap oiling can i was using!!! Caution!! rinse out your new
    oiling can before use!!!
  2. #782
    Dec 2006
    878
    Swarf?
    Lee, It may pay you to send Taney an Email asking him to get a technician to look at your photo on the forum and give you an opinion.
    They are small particles so it may just be swarf.
    Does the machine sound as though it is operating smoothly? And are the filings becoming less every time you use it?
    Rocket.
  3. #783
    Jun 2006
    35
    Hey rocket,
    Ill email taney, as my rep doesn't seem to be all that responsive at moment! The original rep that sold me the machine has left the company!
    Can only hear a little bit of a gritty sound very occasionally, and only
    when manually operating it.
    There seems to be less particles since the first routing job, but will need
    do a few more jobs before i can be sure the particles have reduced.
    Other than that, an expected whining sound of the ball screws? The
    machine is running pretty smooth.
    A bit tiddly now, new years n all,
    Happy new years guys!!
    Cheers~!
  4. #784
    Dec 2006
    878
    Could this be the problem?
    Quote Originally Posted by bclark6716 View Post
    I have the sh-cnc 6090 (600mm x 900mm). For the size and price, you can not beat it.
    The only problem I have had was to replace x and y ball screws. The factory forgot to put grease fittings in the ball nuts. Needless to say after a few hours of operation, the ball bearings wore out. There was absolutely no problems with getting replacements. So, when your machine arrives, check the ball nuts for fittings and give it an extra shot of grease to be safe.
    Overall I am very satisfied with the machine.
    Brian
    Lee, You wrote that you could not find any grease nipples on your machine. Could you have the same problem as bclark?
    You need to grease your nuts!
    Also you mentioned using crc to clean things up - did you force some grease into the bearings on the ends of the machine?
    Who are the New Zealand agents that deal in these machines?
    Have a great New Years Eve. Don`t get drunk too early or you will miss all the fun!
    Rocket.
  5. #785
    Aug 2007
    81
    I don't have metal filings on my rails leef, so sounds like a good idea to get in touch with Taney about it.
    The issue of grease nipples seems to be up in the air, Scott doesn't grease his at all and just uses slide way oil, whereas I think Jimmy greases his linear rails.
    As for noise, we've made some audio files of what my machine sounds like when moving in each axes at high speed, the microphone was about 2 metres from the machine and kept in the same spot for each recording. You'll probably need to turn up the volume a fair bit for it. Let me know if yours sounds any different.
    Attached Files Attached Files
  6. #786
    Jul 2007
    239
    Quote Originally Posted by howzat View Post
    I give my nipples a good generous pump whenever I notice less grease present where the guides run.
    I'm still using the machine oil donated by a friend in the lubrication distribution business. He told me it is designed for machine guns and being light and designed to stick on components seems to do the trick well (I really like the way that stray dust doesn't seem to build up it).
    Your machine sounds healthy Tom. I'm getting used to the sound of mine now that I have increased the process speed. When delivered it was set at 9m/min cut and 3m/min traversing between stations. I am now cutting at 12m /minute and traversing at 30M/min as I get used to things and really liking how it runs (my kids reckon he sounds like a robot).
  7. #787
    Aug 2007
    81
    Hi Jimmy, is that the grease nipple you are greasing in that red painted area of the image I've attached? And if so does a standard grease gun fit it? It's interesting how different people have different ideas about lubrication.. Scott has said he's not a fan of grease on this small machine because it's a magnet for dust and it's too thick for the rails.
    You've also confused me when talking about increased process and traversing speeds, aren't the maximums 4 m and 6 m per minute respectively for the SHG0609?? Or are you talking about your larger machine? 30 m per minute?!
  8. #788
    Sep 2007
    218
    That do for sure look like a grease nipple to me I do agree on the issue on a GO or a NO GO on the grease issue. I have been doing RC car racing in my younger day's and for sure putting grease on anything moving was building up piles of dirt which worn the parts out much faster than normal.
    I would guess that the nipple it self is to lubricate the internal ball bearings inside linear movement part. I guess if you grease it to much it would come on to you're rails which I would expect be no good idea. Is the manual saying anything about this ?
    K
  9. #789
    Sep 2007
    218
    Quote Originally Posted by leef View Post
    Hehe, yeah rocket, did that badge to show off to my brother.
    He loves his toyotas
    I think the only fords i liked was the mk1 contina and escort.
    (for body shape obviously, not grunt)
    As for the metal filings decreasing, ill keep an eye out.
    Im hoping they are there because the machine is new
    and the ballscrews are just finding their place.
    Sometimes i hear a bit of a gritty noise when manually
    moving the gantry. Usually quiet tho.
    Im constantly putting oil on those threads!
    Kent, dunno if this helps, but this is how im using my machine.
    Im just copying the g-code toolpath files onto the supplied
    1gb usb stick and then plugging the usb stick into the
    routers handset. Selecting the file, then run.
    Router is in the garage, computer in the house.
    I didnt purchase the mach3 thing, and havent needed to install
    the DSP software yet.
    Lee; This was really valuable info. Having my PC out of the dusty environment do sound for me like a good idea. In this way you can sit in you're favorite spot having a cup of tea while listening to music without being exposed to the dusty and possibly noisy garage environment.
    You mentioned that you had not installed the DSP SW on you're PC. Is this to have a G code file transfered directly to the DSP without the need of a USB memory stick?
    Would it be possible to have some more pictures of you're machine? Ball bearings in all axis is of interest and close ups of the stepper motors. Is the steppermotors Nanotech an in case which ? I can send you my email adr on a PM if this is easier ?
    K
  10. #790
    Aug 2007
    81
    Quote Originally Posted by Kent_Norway View Post
    K
    Yup. Using the USB stick is so easy that I don't know when I'll get around to installing the DSP software either. I guess you could use any size stick as well so large files shouldn't be a problem..
    It might do but I can't read Chinese!
  11. #791
    Sep 2007
    218
    Howzat; Ho ho ho, is there no instructions in English???! That´s for sure not a good thing...
    Having a 1Gb memorystick is for sure bigger than the internal 128Mb of memory inside the DSP so in case I'm guessing that the 128Mb internal memory is just working as a buffer for the DSP then ?
    Would it be possible to have some more pictures of you´re machine Howzat? I can PM my email address? I do however guess that you have passed midnight in you're country and in the celebration activities now :cheers:
    K
  12. #792
    Sep 2007
    218
    LUBRICATION - Important
    To all having a machine with the linear guides on each side holding the Gantry, they should be lubricated. I have been reading on some of the manufacturers producing Linear guides and here is a link to a page which gives you a PDF of a linear system (I was not able to upload the PDF for some strange reason, even if I zip'ed it) Pay special attention to page page 30 and 31 (B46,B47,B48)! http://www.solectro.se/Archive/Docum...atalog/LFS.pdf
    The conclusion is for sure that we should lubricate, but if this attracts dirt on the reails, does this wear it out quicker (the reails)
  13. #793
    Mar 2003
    35538
    They should have seals with scrapers that will keep the dirt out of the bearings, and shouldn't be a problem.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  14. #794
    Sep 2007
    218
    Quote Originally Posted by cabnet636 View Post
    think i got it, actual size when carved 84" tall 12" wide
    That pice looked fantastic. If I may ask, what was the smallest endmill you used during cutting of the most intricate part? 0,2-0,3mm ?
    K
  15. #795
    Nov 2007
    2466
    kent
    i am so impressed that people think thats the finished product!!
    however thats the file saved on a disk, i will carve it today
    i must say everything i have carved (when i watch bit depth an z zero location) has come out just right
    will post finished product today
    i can see why people love vcarve pro after i settled down and started following instructions it all comes clear
    cabnet
  16. #796
    Nov 2007
    2466
    scrape
    and hold
    i am sure there are sealing caps readily available for this
    try this
    http://www.hiwin.com/bs/index.html
    and here
    http://www.ahpseals.com/
    cabnet
  17. #797
    Jul 2007
    239
    Yep, thats a grease nipple (although it may well be that the manufacturer would like you to pump oil in there rather than grease)-my manual is in english and it says something about using a mixture of 'Butter & Oil'.
    Was talking about the big machine, 20 & 32M/min max speeds.
  18. #798
    Jul 2007
    239
    K
    English instructions for the DSP should be in the DSP folder of the supplied CD with DSP handwritten in the face. There is an english subfolder on the disk (at least that's what I was told).
    Let me know how you go Tom, happy to e-mail my version (I obtained by other means) to you if it's not there.
    Cheers,
    Jimmy
  19. #799
    Jul 2007
    239
    Thanks Gerry,
    I have seen the build up of dirt you refer to.
    That is another reason why I routinely pump some grease in hoping that anything that does make it inside will be displaced by the fresh grease.
    The machine manual appears to suggest 'cleaning and oiling' be performed every 4 days when working with high density board (guess that could mean MDF, HDF, and P/Board) and 7 days with other timber types.
    My machines are only performing light duty (prototyping and small a scale production) so I tend to rely on the look and feel of the guides, rails, screws and gears as a means of determining when to clean/oil/grease things.
  20. #800
    Dec 2006
    878
    jubee, Your machine was due to arrive about now. Do you have it yet?
    Which one did you buy?
    Rocket.
  1. RemainCNC NZ Excitech 1530 router.
    By Big S in forum Excitech routers
    Last Post: 03-15-2018, 06:25 PM
  2. post processor for Excitech router
    By blade625 in forum BobCad-Cam
    Last Post: 09-12-2013, 06:19 PM
  3. Excitech 1212 router down, need help.
    By JacquesLeDick in forum Excitech routers
    Last Post: 08-25-2012, 07:23 AM
  4. Excitech router with NC Studio and Visualmill
    By DaRipper in forum Excitech routers
    Last Post: 04-30-2012, 12:53 AM
  5. Excitech new changes for CNC router
    By dianafeng in forum Excitech routers
    Last Post: 12-02-2008, 02:14 AM
