603,896 active members*
3,946 visitors online*
Results 1 to 5 of 5
    Feb 2008
    231
    External Feed Rate control?
    Often I am cutting something new with my machine and it would be nice to be able to adjust my feed rate without having to use the windows keyboard (The only input device that I currently use with my machine). Is there a CHEAP (<$50) way to use an external device like a potentiometer or something else to control the
    feed rate? A potentiometer would be nice but how would that interface with MACH3. Again let me stress CHEAP.
    Scott
    Mar 2003
    35494
    To use a pot, you need a breakout board or modbus device that accepts analog input.
    On the Machsupport forum, there's a tutorial to use an Arduino that I think will allow this, and it's probably right around $50 to get it running.
    Simple tutorial on analog inputs with Arduino
    The required Arduino file is here.
    Arduino sketch for analog inputs to Mach3
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2008
    231
    Interesting. I am very experienced with programming PIC microcontrollers and they can accept multiple channels of 10 bit res analog signals. The question that remains is what to do with the digital value and how to insert it into MACH3. It sounds like I need to serial input the data to the PC and configure MACH to find it. I will investigate the Arduino link and see if that answers any questions.
    Thanks Gerry
    Oct 2005
    35
    What about something like this?
    I wonder if something like this would work with Mach?
    Amazon.com: Griffin Technology NA16029 PowerMate USB Multimedia Controller: Electronics
    Attachment 212370
    Fairly inexpensive and it is a USB input device.
    Mar 2003
    35494
    Quote Originally Posted by ivans View Post
    To use a USB device with Mach3, you'd need to write a plugin. There is a Mach3 plugin for that device to use as an MPG, but if I recall, it never worked very well, and I don't think it works with current versions of Mach3.
    Gerry
  1. Okuma Manual feed rate control
    By Jbyron in forum Okuma
    Last Post: 12-02-2011, 02:42 PM
  2. Control de avance (Feed Rate ) analogico
    By dotn in forum Spanish
    Last Post: 04-28-2010, 09:01 PM
  3. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
