Hello,
i have wired the input with an simple switch of the Exinout 24V card as shown on the diagram from the offical manual.
I am using an simple switch to turn an solenoid valve on. With M64H1P1Q1 the value open and with M64H1P1Q0 it stops correctly.
But wenn i try to use the mechanic switch nothing happens. Maybe someone have an idea ?
Another "problem", one pictures start input 1 on the left and relay 1 left , the other pictures showes Input 1 starts left, but relay 1 starts right.
Which version is correct, the numbers printed on the pcb or the version of the circuit diagram ?
Best regards
Chris
