Can any one tell me how to get rid of the radius' as the end mill changes direction. I just want it to cut straight thru move over and cut back. I attached a screen shot of the extra radius moves.
RAD. Yes those are my initials. Idea, design, build, use. It never ends.
PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
You can sometimes stop these by choosing the "start in center of workpiece" on the strategy tab which may be currently set for "start outside workpiece." If doing this causes the entire toolpath to not be created when you re-run the operation then you can create a rectanular "fixture" block just outside the workpiece opening (outside by a bit less than the cutter radius). This will keep the cutter from going outside and around the corner. - Terry
better for this application is 2D Conturing
In new SprutCAM 7 you can easily trim unwanted waste movements using open Job zones, constructed either from the part edges or vertical walls or both.
Yes, I'm running 7 now and using 2d contouring to face my part ends, it does exactly what I needed. I guess a lot of this is learning what all the features do. Thanks for the input.
R.DesJardin -
I must have missed your original post in December. I have had that same issue in SC2007, and the only way I could stop it was to create artificial "fixtures" to keep it out of certain areas. It was never a great fix, but it usually worked. That kind of extra motion is the most frustrating thing about SprutCAM that I have noticed. Not only is it wasted time, but it also affects the part's finish.
Does SC7 handle these types of areas much better? I have not upgraded yet because my understanding is that once I upgrade, my dongle will no longer work with the 2007 version. I don't want to make an irreversible decision if I'm not going to like it later....
Regards,
- Just Gary
Good news, in SC7 I've been using 2D contouring. This seems to be the solution and allows customizable lead in and out moves to be able to clear the workpiece. I have had no issues with SC7 and I'm running it on an old(2+yrs) laptop with XP on it.
My biggest problem is probably not knowing which operation to pick to machine with.
