587,744 active members*
3,252 visitors online*
    Nov 2014
    Extreme beam divergence -- tube failing?
    Hi all.
    I have a 600x900 CNC CO2 laser that I am realigning after not having used it for over a year. The tube is an 80w Reci. There are less than 100 hours on the tube, but it is >6 years old. The beam is significantly diverging -- seemingly upon exit from the tube -- growing to a diameter of >20mm at the far edge of the bed. See attached photos for a visual. All mirrors are brand new (swapped them out to rule out any optical issues with the old mirrors, but this happens with both). I have also visually checked the exit window on the laser, since I was wondering whether this could be caused somehow by scattering/reflection from the aluminum walls. It doesn't appear dirty, but I have never cleaned it.
    Before I expend capital on a new tube, I wanted to check to make sure this symptom of significantly-growing spot size is in fact a sign of irreversible tube failure. Thanks for any help.
    Nov 2010
    787
    Re: Extreme beam divergence -- tube failing?
    Quote Originally Posted by intelinc View Post
    Hi all.
    Too old to rock&roll :-(
    CNC lasers, constructions, service
  1. No Beam out of Tube.....HELP!
    By robwiacek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-07-2017, 09:17 PM
  2. CO2 laser tube beam characteristics?
    By AlexTsekenis in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-23-2017, 10:45 AM
  3. CO2 beam divergence over large bed?
    By MechanoMan in forum Laser Hardware
    Last Post: 03-13-2016, 07:22 AM
  4. Reci tube Beam Adjustment
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2013, 04:10 AM
  5. Beam divergence for the chinese tubes?
    By Konstantin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-16-2009, 01:56 AM
