603,891 active members*
6,357 visitors online*
Results 1 to 4 of 4
    Jan 2008
    17
    EZ track drive error
    Started by getting Y axis error. Found the motor bad got another motor
    and fixed Y axis, but then got a X axis DAC Underflow error. Found a
    red light on the Advanced Motion X drive, so I put it in Y and got the
    same error, moved it to Z thinking we could run the machine in 2 axis
    This time a green light was on all three drives. It let us home the machine,
    but as soon as we homed it the Z drive light went to red and stops right
    there. Do we have a bad drive or is something else going on? X and Y are
    running OK and we can run 2 axis.
    Nov 2004
    3028
    The fault is following the drive to where ever it is placed. Sounds like a bad drive to me.
    Did the Z home for you? Maybe you could reload the machine with 2 axis software.
    George
    Jan 2008
    17
    Z will home out then the red light faults out on the Advanced Motion drive.
    X and Y come up with the red light and won't home. Why will it let Z home out
    then fault?
    Nov 2004
    3028
    Is it possible that the Z appears to be homing? It comes up but stops not because of the switch but because it is faulting. Are you getting a DAC overflow? Drives OFF? After the Z homes? Try moving the z down and starting the home process and press the switch and hold it with a screw driver or pencil (not your finger). I want to know if it stops and thinks it is home and allows the other 2 axis to home. If you know how to attach a full size keyboard, go to DOS, and to PFM,exe. You can home it there, watch the following error, and read the alarm codes.
    George
  1. VF2 SS Drive Error
    By Delw in forum Haas Mills
    Last Post: 06-29-2010, 05:11 PM
  2. TM-1 Spindle Drive Fault Error ?
    By AMCTony in forum Haas Mills
    Last Post: 01-26-2010, 04:17 PM
  3. TM-1 Error 162 Y Axis Drive Fault
    By KevinWilkins in forum Haas Mills
    Last Post: 09-25-2009, 02:57 PM
  4. Arrow 500 Drive Fault Error
    By macmub in forum Cincinnati CNC
    Last Post: 06-02-2009, 06:46 AM
  5. boss 8 drive error 4000
    By IeatSteel in forum Bridgeport / Hardinge Mills
    Last Post: 02-07-2007, 09:20 AM
