I am fitting an EZ Trak 2 axis system to a Bridgeort in the hope that I can convert it into a 3 Axis sytem.
It is fitted with a 3 axis BMDC so I think I am on the right trak.
The software is version 3.19, will this operate a 3 axis machine ?, and if so how do I change it over ?.
If not what version do I need and more importantly where would I get, I would like if possible to program
it in G code which I understand can only be done using later software and I suspect 3.19 is too early.
This is fitted with a solid drive.
Next question is relates to the limit switches, I have the circuit diagram that was on the back of the box
housing the computer and it cleary shows the home switches but not the limit switches, are these not fitted ?.
and if not what stops the drives at the endo of the travel, are there soft limits instead.
I have not been able to find any kind of documentation or manuals beyond a programming manual so I am
struggling a little and any help from you wise people would be much appreciated. Dave
