Originally Posted by
elmerfud
Wow, 35k rpm, 20.7 stroke valves say 21mm or so.
Maybe a desmo setup could hold the revs, a steel spring I feel would not.
Maybe a single cylinder test motor to prove valvetrain before you build all ten.
If you are building pnuematic valves the discoveries you make for sealing them reliably I would keep top secret, a patent or a business idea.
Pnuematic valves are still distant from mainstream and i consider them exotic. (if that counts for anything)
35k, you'll get a job at ilmor or cosworth, exciting stuff!
